Small offtopic.
Re: Small off-topic.
Post by Михаил_ » Sat Aug 23, 2014 15:23
Well, Valera is not Rinat :) Valera often we each other perfectly understand and in the subject just on the other sees the world and ways of action in it.... Rinat is likely to almost materialistic position slightly biased toward alternatives.
Нина Жемчуг
Post by Нина Жемчуг » Sun Aug 24, 2014 14:44
Prompt, please, reception of ASD, my mother's drinking in small doses(0.25 X 3 times) and she much began to swell up, how can it be? To endure, it's nothing, maybe it's OK, will, or is better then not drinking, which would certainly not have wanted to(((((. Says she thinks that it has a negative impact on the kidneys. Maybe someone faced something similar situation?
Post by Михаил_ » Sun Aug 24, 2014 15:20
To reduce the dose temporarily. Affects the kidneys are not ASD, and slag...
Нина Жемчуг
Post by Нина Жемчуг » Sun Aug 24, 2014 15:26
Michael, thank you very much)
Post by Михаил_ » Sun Aug 24, 2014 16:25
And not to forget breaks to do you can Mineralnye breaks to do more (4 drink two to three a break for example), to reduce the load on the kidneys. You can increase the dosage literally dropwise. And how much time she drinks?
Нина Жемчуг
Post by Нина Жемчуг » Sun Aug 24, 2014 16:55
Drink 3 weeks, 5 days, drink 1-2 break makes. At a dose of 0, 25. The dosage was increased again, beginning with 0.10.
Владмосква
Been thanked: 7 times
Post by Владмосква » Sun Aug 24, 2014 17:00
Nina Pearl,
1) Armavir and Moscow (AVZ)? If Armavir, temporarily in Moscow, you can go, it poslabzhe.
2) Feed her a little?
3) Breaks try Friday-Sunday, to avoid confusion. Day 1 - very little break! 2 - at least.
Нина Жемчуг
Post by Нина Жемчуг » Sun Aug 24, 2014 17:03
Vladmoskva thank you. Armavir drink, food: vegetables, fish, cheese, fermented baked milk. Raw tried to move, does not work yet from her.
С. Альбатрос
Post by С. Альбатрос » Sun Aug 24, 2014 17:49
When the load on the kidneys fish and cottage cheese is better to remove at all, especially cheese. Kislomolochny is not so critical.
Владмосква
Post by Владмосква » Sun Aug 24, 2014 20:02
fish and cheese to clean up, Yes. And ASD peels, and fish and cottage cheese stain. It's like a window wash duster with "Mr Muscle", and the other hand to spoil the same window with a rag with engine oil.
Been thanked: 182 times
Post by Андрей Кабанков » Sun Aug 24, 2014 20:35
Nina PearlI would advise you to suspend the admission of ASD, to take a blood test on creatinin, urea and potassium.
If the parameters are normal, you can continue, if not, turn to the nephrologist.
Swelling of the feet can be caused not only by renal but also cardiac insufficiency of the right ventricle. In renal edema should be even swelling of the face in the morning. The heart, primarily of the foot and lower leg.
ЕВгений СПб
Post by ЕВгений СПб » Mon Aug 25, 2014 4:21
Михаил_ wrote:to Reduce the dose temporarily. Affects the kidneys are not ASD, and slag...
Michael, what do You think, in this case honey weaning can help to eliminate toxins, and if so, what part of the body to better handle.
Post by Михаил_ » Mon Aug 25, 2014 10:26
Can. Body parts - the letter f (all but one).
Элиан
Post by Элиан » Mon Aug 25, 2014 14:40
Hello. Sorry if not the topic. Who knows on how to effectively treat intervertebral foraminal hernia of the lumbar to the girl. Went to the doctor who did the MRI, stretched back on the machine and manually edit the spine. But after a month the pain persists. Until he had seizures but in General easier. I understand that if it moved the problem areas they claim to be sick. But maybe someone faced the same problem and he has a positive experience solve it?
Thank you.
Post by Михаил_ » Mon Aug 25, 2014 15:57
Local compresses todikamp for example.
Local ASD compresses can help, too - only in the breeding for oil 1к5
easy execution of arbekovskiy workout (to restore mobility)
warming up on the IR massager like Miguna (qualitative)
a good chiropractor 10 times
Cleaning hunger for 2-3 days (if not previously starving - that is not right) -recently a friend STRONGLY pripeklo 3местам at the back could not sleep, quickly regained himself so much a better state, now have the potential more slowly to get healthy.
ORP negative water or ASD course (sticking of the blood cells that for example show advertisers water from the coral club as glued cell clusters rassipautsya, and then starts the normal supply of remote areas including the vertebrae-bones-cartilage-joints, etc.).
Very good help in such cases by the way the device prolysis here magnetic therapy (sclerosis on my head - I do not remember, for it is not mine, comments from relatives were positive), but rather relieve the symptoms for pain, and comprehensively starting with PP1 selectively and what is available.
Кона
Been thanked: 8 times
Post by Кона » Mon Aug 25, 2014 16:37
View CAY (Yoga critical alignment of the spine), can Peter have classes.
The effect already after the first session visible. All the equipment you can do yourself.
Искатель
Has thanked: 3 times
Post by Искатель » Mon Aug 25, 2014 22:05
My dad also intervertebral hernia lumbar,couldn't walk,was in pain.Worn in the centre kineziterapii,after three months of training, the spasms weakened,the pain nearly gone,able to work independently,at home.Makes mini course Healing Pulse,with the addition of the Scorpion tail+ stretching,the load is gradually increasing.It gives good protection against recurrence.
Post by Михаил_ » Mon Aug 25, 2014 22:11
Искатель wrote:my dad also intervertebral hernia lumbar,couldn't walk,was in pain.Worn in the centre kineziterapii,after three months of training, the spasms weakened,the pain nearly gone,able to work independently,at home.Makes mini course Healing Pulse,with the addition of the Scorpion tail+ stretching,the load is gradually increasing.It gives good protection against recurrence.
Yeah, and this road - working. Simply with zero AI is too cool for many. And workout - it is important to do it gently without pain. Would be an improvement if you add the anti-inflammatory factors.
Элиан
Post by Элиан » Tue Aug 26, 2014 3:13
Thank you all for the answers. Will try...
Алхимик
Post by Алхимик » Tue Aug 26, 2014 5:05
You can still organize sleep on an incline, say works very effectively:
Has thanked: 13 times
Been thanked: 49 times
Post by ФилиНН » Tue Aug 26, 2014 12:32
The picture above reminded one useful device to solve such problems the dispensary Evminova
If special-the couch is no place, this is for the Cabinet. :)
According to the network there is a set of useful exercises for her(boards and spine).
Been thanked: 2 times
Post by ЗОМБИ » Sun Aug 31, 2014 0:50
Michael, can sanctify the impact of the active ingredients of cannabis, psilocybin mushrooms and лсд25 ? and about awasu also interesting
you can PM, wiping out a public post, give the information pls. :)
Post by Михаил_ » Sun Aug 31, 2014 1:56
Have not studied the issue in addition to Ayahuasca (studied in detail).
Heard and considered loyal to the hypothesis that LSD in the USA was implemented for research purposes services, and what they're frightened of massive consequences and shut up shop (which I think is correct).
I am not a fan of chemicals, even natural, acting on consciousness. Exceptions can be verified in therapeutic purposes.
From the list for consideration as an example of ethno-rasprostranennoe shamanic tools may be Alaska. Which unlike the rest of the list is not all easy. To everything else, my attitude is strictly negative for a number of reasons, although as they say, those same shamans - Western people can spoil everything :) (in other words depends on the method of application, context and purpose, a Western man often wants just a fun trip and not the target of the magical work).
On the one hand in most countries in the Euro-Americanized sense at least one of the two main components is strictly prohibited as a drug in the first list - namely the one that is called DMT. On the other hand, DMT is in man in smaller doses as well as a lot of what in the plant world. There is the hypothesis that DMT released into the brain at the moment of clinical death (the people who survived it then you have clearly sharpened the psi-abilities for life as a rule).
In addition, DMT for example is common everywhere in the grass "twitcher" who in childhood a chewed (intuitively?) there is certainly a micro dose....
One way or another in the civilized part of the world of DMT is considered a drug.
In some countries, LA (in Peru for sure) he shaman's drink, of which there are very many compositions are sometimes completely different from each other is considered a national treasure. There, by the way, my friend, for the new ideas and discoveries goes half of "silicon valley" to the shamans of the Peruvian and plus heal and clean up....
The second component of Ayahuasca - never banned and is freely available for example in the MSC - the vine. Though in some recipes it is replaced by something. It is a powerful MAOI (and here is our subject), plus powerful anti-parasitic;
As in the case of ibaloi byvaet (in other words not always, but the cases are not very rare) that after the ceremonies iwaskai fully chronicle. One Russian translator in Peru told me that he had come to Board the patient with asthma, allergies, and still figs knows than it is now perfectly healthy. Although there certainly plays an important role actually the shamanic part.
Therefore, from a chemical point of view is a powerful MAOI (already recovery) + brightness images (DMT) - that is, books and films for scientific acquaintance with the subject in General. Well, to learn that no one bothers it's not propaganda - once the connection is found everywhere in nature, it is necessary to have representation....
From a shamanic point of view, there are very very many (if not almost all) depends on who conducts the ceremony or the ability of the host to establish a mental contact with Ayahuasca (with the intelligence of the plant - vine).
This is a really important component and it is perhaps above all chemistry for 10 000% in importance. You in the absence of physical contact with the broth can get all the effects if you're in the General ceremony - well, it's quite magical collective action led by the shaman or group.
Usually locals (who no almost all except shamans among them) and Europeans first and foremost conduct through the easy fix physics and mental - t/e/ perceive distortion as information and work with their neutralization.
Oh, by the way for those who zeroedit and generally eats normally and keeps the body in normal - stuff about the horror stories in images and vomiting -tales. This is a direct need (cleaning) for those who keep body and mind in the dirt.
Further, every shaman of the clan and the sort of works a little bit differently and has its own goals and objectives and skills.
In this respect, some priuchenie europetheband shamans I have more respected for the flexibility of consciousness (I'm not talking about local and trained them for many years Europeans such as sir Malcomn :) )
As I said, many of the techno-elite of the United States love to travel to LA on avesco for health and new ideas - and it turns out tekhnoprogress :) well, more precisely including.
The mode of operation of consciousness and the brightness of the internal display because it very much higher than normal and brighter than normal vision.
By the way Alaska ALSO treats addiction, although not as bright and fast as tabernanthe iboga (perhaps this is due to physiological processes in patients receiving MAOIS but I do not think - rather, it is primarily the restructuring of the cocoon and consciousness under the influence of the experience).
Next.... many say and write a lot extra about the visions, well, there is some "higher worlds" and so on - really depends on the setting and translation of perception. not the fact that interpretation and there after, adequate! because man is judged in the context of their local concepts. More laziness to consider.
Objectively it may also be noted that the modern tradition in the same LA was not one that was 100 years ago. When working with older paper sources it is clear that the number of subjects was not informed kamuflirovannaya and Vice versa openly talked about some effects, like the manifestation of super-powers (direct) which is now quiet silent. Also categorically under a strict ban themselves shamans got sexual themes (during the session) although informed by descriptions and illustrations, it was different... ( and on the tested experience - their opinion was not true).
But the most interesting in this story is the Vine. Its role in the process that nobody considers. And she, and the impact on the spread of tradition in all directions with little-developed areas of LA - this is not simply due to the effects of the psychedelic. In fact, the Vine is really reasonable. And very :) but it has a different interface with the world. And appreciates human experiences, which are received during a session as a bonus, they become like and her feelings. From this point of view she's not interested in their indigenous tribes - there is now an ass - that to look at them? but the developed country is quite interesting.
And from its solution and interest will depend on how the process during the session. One of my friend when getting into the "forbidden zone" of his past for the third time Alaska refused to work at all - as he drank the water :)
So here we are not talking about chemistry and especially about the interaction with another consciousness. including those which became so widespread due to the fact that the territory of LA operatorsky no taxis (and out poglavarstvo already across the continent!) and on the other hand personally, I consider it adequate and dogovorosposobnost. Just need... for the good.
By the way my tough interaction with the local egregore shamanic birth LA was the reason for creating OS 2.2+.... I was there for a bit with a large area, when I tried to say that I climb into someone else's garden, I had to explain that the opposite is true - my garden, but they are on the other scale had gone too far and have put a mess.
Thus, I believe that in those areas where law razresheno with proper working use with adequate leading - it is a working tool.
But again - from the shaman or your ability to replace it yourself depends very much.
Of the existing traditional places in Peru can only recommend blumaroo (they have Russian site and work there by the way of the interpreter during the whole course). To break the law where it is impossible - not recommended.
And Yes - it is a working magical tool and not a means of entertainment. At the same time, however, and a serious cleaning.
Mangled wood can be...
Plus there are more stringent requirements to the diet because of the MAOI properties - there have been instances of strange effects like otshivaniya memory in humans, it is highly likely associated with mini-strokes due to delays in violation of the diet AFTER (a week taboo forbidden foods if cessie was more 1st).
Well, that's probably enough;
Yes. Part of the sprawling world of psychedelics, I consider it dangerous both biologically and psychologically (for artisanal use, without skills of control own consciousness), something that has historical roots connected with the application of disciplined mages, and due to the inability to do something differently, in short from the distortions of body and mind and the world.
To poison ourselves and risk the mind - do not think that you need to.
Danger even purely mental is everywhere and when using Ayahuasca without the control of a competent host, including. The seer needs to be in session.
And I really think (and not for public text) justified a ban on some substances in many places of the world. Because their application is not turned in then, and it was potentially harmful.
I think, this text may well be here, as a review a personal opinion.<
Post by ЗОМБИ » Sun Aug 31, 2014 2:12
thank you!!
Post by Михаил_ » Sun Aug 31, 2014 2:54
In reality, this subject(theoretical part) also addresses the reason for the creation of shamanic cultures and small Nations in this world some time ago, and for materials of the 3rd seminar. In the open I all this information to give fear and then shortcuts will put in.... it is poorly laid in the brain....
It is highly correlated in fact with the latest balerinami materials. Because directly related to aspects of the intervention other cultures and more specifically other creatures (not local at all) in the life of this world.
So by and large for a person of ordinary ogranichenno suitable and reasonable approach. Here really should say that an ordinary man for thousands of years and biologically it seems.... here's the problem....
