Advice from Andrei Patrushev
Post by Андрей Патрушев » Fri Oct 01, 2010 20:22
Ламер wrote:
Ламер wrote:thank you for your prompt response.
Read the annotation to the CD "Music for hypnosis and self-Hypnosis", it is stated that the sound track used from Explorer. Does this mean that you should do in payzu, barnyardgrass listening between the conductor and the drive. Or are these courses it is possible to listen immediately one after the other.
Andrew please answer this question.
Yes, you need to make a pause between them.
Ву-цзи
Post by Ву-цзи » Sun Oct 03, 2010 16:09
I have a question to all(who knows)and Andrei Patrushev in particular:
there is Silva,the book describes a method of affecting other people through the alpha level.
how can a person calculate the at(is there) to show(what aims,with what purpose), and erase the wrong setup,sent at this level???!!!!...
Thank you in advance :wiz :)
Post by Андрей Патрушев » Sun Oct 03, 2010 22:21
Алексей Надёжин wrote:
Андрей Патрушев wrote:This is absolutely the same. Just on different recorders with different offset value.
Very surprised by the answer.
About the offset I did not say anything. It doesn't matter. I was talking about the source material: it's different. Accordingly, the question arose: were various versions of this ROM? And where did the title "Mother Nature 1" on the second disc, if they are the same.
Just one disc with CD-text and the other without, with one and the same source with the same name.
Post by Андрей Патрушев » Sun Oct 03, 2010 22:22
Ву-цзи wrote:I Have a question to all(who knows)and Andrei Patrushev in particular:
Wedge wedge :) hypnotic suggestion to protection.
эди
Post by эди » Wed Oct 06, 2010 6:50
Hello Andrew
I 23g I Kurilsk marijuana with experience of 6 years also tried many psychotropic substances(2years neupotrebljiva) weed sometimes...for the second year suffer from deterioration of memory and rasinovo attention.The second really annoys me...for example trying to read interestnoy glinow article and me from the power enough for 20 min and then aplil...
I interesuet:1)increasing the concentration of 2)memory 3) mood elevation and obschitelna
Question do you have discs in the Arsenal that would have helped me?
bc
Post by Андрей Патрушев » Wed Oct 06, 2010 8:14
эди wrote:Hello Andrew
bc
Hello.
For this purpose the disk Ultramesh (sociability also increased slightly as a side effect :)). The last track in the morning instead of coffee, and the second - at low volumes the classes that require focus and concentration.
Be advised to work with the disk Explorer.
On each disk there are instructions http://www.mindmachine.ru/patrushev.htm
Before class it is useful to read carefully this thread: http://www.mindmachine.ru/viewtopic.php?t=2181
Ли
Post by Ли » Fri Oct 08, 2010 1:22
Hello!
Just want to apologize if a similar question already asked on the forum, - I, unfortunately, have not found the answer. The fact that the disks are very fragile: neither treat as carefully, still scratched. Besides, there are many inconveniences associated with the fact that on a netbook without a disc drive won't listen, for example, somewhere on the road. So, I'd really like to know how and what Converter is it better to transcode the disk to your computer? I read on the forums, say, in wav format can be translated without loss of quality, i.e. all frequencies should be preserved. Of course, I suppose I could argue "Buy a player", but it is also not an option (plus, the discs are all the same on the computer was created). In a network of many different programs, not all of which are actually as good as stated in the description. So I would like to know the opinion of the Creator. It is very necessary! I would appreciate an answer. :o
Post by Андрей Патрушев » Fri Oct 08, 2010 9:27
If
While the best quality can provide the program EAC(eng. ADB.).
Ву-цзи
Post by Ву-цзи » Sat Oct 09, 2010 0:58
Andrew Hello!approximately or exactly how to make the right protection in the form of GIP.suggestions? Thank you
Post by Андрей Патрушев » Sat Oct 09, 2010 1:02
Ву-цзи wrote:Andrey, Hello!approximately or exactly how to make the right protection in the form of GIP.suggestions? Thank you
Hello!
In my opinion, it is a good idea implemented in Explorer... :?
Ли
Post by Ли » Sat Oct 09, 2010 13:23
Thank you! We seek :)
Алексей Кузнецов
Post by Алексей Кузнецов » Sat Oct 09, 2010 21:21
Dear Andrey, yesterday morning I "was the place to be" SL. phenomenon. The right eye appeared a patch of light, similar to wide toothed zipper. Prevented watch. 15 minutes later everything went. Then about an hour later was repeated in the left eye. Then I tried to raise my head so. to look 45 degrees up and everyone was gone. Did that 4 times. And then it passed. But going back to the sun, felt its radiation very strongly the right side of the head. At 17: 00 on Thursday (yesterday was Friday) was listening to my favorite Conductor. Prior to that, regularly listened to the night Hypnotic trance. How do you think it could be?
PS Of the unexplained. Before the second phenomenon when I wanted to use my cell phone, I suddenly found that the phone "lock", although I did not enter the code. Then after a few taps of a button offered the phone lock removed.
Нетрезвый Сурдопереводчик
Post by Нетрезвый Сурдопереводчик » Sat Oct 09, 2010 23:21
Алексей Кузнецов wrote:Dear Andrey, yesterday morning from me !was the place to be" SL. phenomenon. The right eye appeared a patch of light, similar to wide toothed zipper. Prevented watch. 15 minutes later everything went. Then after about an hour was repeated in the left eye. Then I tried to raise my head so. what would smotre 45 degrees up and the sun
I have sometimes left eye is closed is the place to be,especially if I've never used MM.is it dangerous? az
Алексей Кузнецов
Post by Алексей Кузнецов » Wed Oct 13, 2010 1:00
Today was such an interesting effect after listening to the Conductor. Listened, as recommended by 17-00. Sometimes heard, sometimes not. At the end I heard both Andreev and right and left. Then, after finally fell asleep and see a dream is completely real. The topic is not recorded and will not talk about it. Then come in yourself and see the room and continued sleeping. To the left (i.e., left brain through the eyes) I see the room and to the right (i.e., right hemisphere) continue to see the dream. Here's how that I've become. And if this separation is driving when suddenly and street and what's on your mind?
Post by Андрей Патрушев » Wed Oct 13, 2010 14:27
Alexey Kuznetsov
So on each disk and says that it is not recommended for 2 hours after listening to drive, etc. :?
You're not a Lefty? :)
Алексей Кузнецов
Post by Алексей Кузнецов » Thu Oct 14, 2010 0:01
No, I'm right-handed, but having read about the need to develop both hemispheres, now trained to work with the left hand. So the mouse only work with the left hand. But because many people due to the nature of the work do many things with both hands. And for example drivers of cars with manual transmissions in the city they rule the left wheel and the right steer gear. This is especially pronounced among drivers of buses with a box and taxi drivers. Two years ago, began to try to draw various geometric shapes with the left hand, even the beginning of something, but changed jobs and now no time for it. Do wonders after listening to your CDs I have quite a lot, even though they are small. But there are large and unexplained. But I associate with some other things. I hope to achieve the same results, which is a write.
By the way, this year training to achieve the ability to brake with your left foot just as and right.
Post by Dimas » Thu Oct 14, 2010 12:37
Alexey Kuznetsov
You need to train both hemispheres of the brain, Ambidextrous. The fact that You are working the mouse and the box pulled almost devoid of meaning, need to train fine motor skills. At the same time with both hands draw a marker (so without pressure and effort,You don't train muscles) the two hands of different shapes (triangle, left, right a rectangle for example, at the same time,this is important), do it every day for 10 minutes, getting positive emotions, if not in a rush - better to defer to a good mood. It's great to do after alpha and Massage of the brain. We at uni told me wonders right about students on which to MSU ,I think, experience set, I can practice too :)
Алексей Кузнецов
Post by Алексей Кузнецов » Thu Oct 14, 2010 22:48
Yes I don't paint for several years. And about the box and the athletes will only say one thing, as previously little involved in Motorsport, to think almost any athletes much better than the same ordinary. But there is one thing, natural selection. Who failed, the incompetent. Just had at work dealing with one stunt from the thumbnail - thought very quickly. Well, training for different spazmatical this of course result. Only here while in our country the results from these guys from MSU alas not visible. In those States with such things, as we see from the materials of the site do millions, but no breakthrough, that leap, nowhere to be seen. So the General quiet and systematic development of the enormous cost. And just the movement without even a hint of any goal.
PS I saw went Statesis Brundza - it was flying and not riding. After this rally, and not the ring. It was something to the point of not human. He "sensed" way. Also in the literature are described and some test pilots, and military pilots too. And look at the current pilots sprotsmen in aerobatics. Complete the splice with the plane. But Bess[SPAM] proper training and under the guidance and supervision of experts give the greatest results. Have I, a mere Amateur, and that is something obtained through the site and the Internet.
Post by Dimas » Fri Oct 15, 2010 12:05
Alexey Kuznetsov
And I told You nothing about exercise, air, and rally. I told You just about the correct development of both hemispheres of the brain increase in ganglionarnah connections between cells in the right hemisphere, which gives improved physical and mental health, increasing the creative and intellectual abilities, etc.
Алексей Кузнецов
Post by Алексей Кузнецов » Fri Oct 15, 2010 15:13
So I'm not perceived as "mouse working and the box pulled almost meaningless". The development of the ganglion is Bess[SPAM] one of the most important elements in improving the intellectual abilities of a person. But to disregard the constant exercise of the hemispheres in everyday human practice it is not worth it. But then to ganglia I have another question, what power is needed for their growth? Still they are material, physical body parts and they need something to build. The answer to this question, I have not yet met. But I am a simple mechanical engineer in biology weak. If you can build how to build muscle, then training causing their development needs and related proteins, microelement and other and other. I now eat a Supplement as L-arginine. This amino acid is important in the construction of vessels. Good job blood vessels of the brain allows you to assesst delivery of the essential components of the milking of his life. There's still one important point is the microelement composition of the blood, because getting into the cells of a living organism you see how important to correct sootnoshenie such basic elements as calcium, potassium, sodium. And this is only the basic. Each cell power and, therefore, base composition for its proper operation must be optimal. So when all our cells, including muscle work in unison, all the "nerves-wire" transfer from "sensors" undistorted information, then the brain is working as it should. So the issue is very complex and to focus only on the training of the brain is probably not worth it. Although if you look at it from Iraq, you can doubt my many postulates of our science.
Ву-цзи
Post by Ву-цзи » Sat Oct 16, 2010 23:26
Andrew Hello.Question:can the listening sessions(once a day) Mind-mash. 7-8 days to start listening to your CD?
I.e. a course of sessions over 21 days,and the drive will have to continue to listen to the 21 day...(muses.center broken here to fix must)...will bust for the brain,i.e. the brain will perceive this workout???...or is it better to finish MM and then after the break, the disk drive? Thank you...sincerely :wink:
Ламер
Post by Ламер » Sun Oct 17, 2010 0:16
Andrew please tell me.
There is a problem, sometimes bad turns to switch from work problems. And therefore little time devoted to the family, as being in the family continue to consider have arisen in the work situation. Sometimes it is possible to reverse the situation. As I understand it, the handler has to help. How to formulate the objectives in this case?
Thank you
Post by Андрей Патрушев » Sun Oct 17, 2010 10:21
Ву-цзи wrote:Andrey, Hello.Question:can the listening sessions(once a day) Mind-mash. 7-8 days to start listening to your CD?
Hello.
It is possible, with a break of at least three hours.
Post by Андрей Патрушев » Sun Oct 17, 2010 10:28
Ламер wrote:Andrew, please tell me.
Thank you
Well, something like: "work is Work, and at home, I'm home"...
To change habitual behaviour a little something to listen to, it is necessary to change behavior: to track it and replace the others. This can have a good help technique and Sedona Hoponopono. A significant factor on the path to success is regularity, sufficient time and positive emotions from the process, so organize it as a game. And do not be like the hairdresser: "Oh, Nitsche not...":)
Дал
Post by Дал » Mon Oct 18, 2010 13:55
Hello, Andrew,
I found your methods when looking for information on how to help your child. Read a lot on your website, cha forum. But that was quite sure want your advice. My child is Sundram attention deficit disorder (add), problems with learning, attention, memory, concentration. He is 8.5 years old, goes to first grade (last year colleagues, worked individually with the teacher). I want to try your CDs to give to listen to him in this manner: in the morning before school disk space wanderer - 2 track (15 minutes), and the Mozart Effect during homework. In this mode, to do 15 days, then 15 days break, then another 15 days etc Will not listen through the headphones, just through speakers. Just very difficult to convince to lie sokoine those 15 minutes (it is involuntarily poluchaetsya - hyperactive in nature), but as nobody.
What do you think, can he do while vzrosleet to 14 years, then buy MM. Sorry for the error, change the language, I'm not English.
