Small offtopic.
well useful including OS 2.2+, but maybe someone will have other ideas?
(module suit so be useful as a temporary means, so if these things are so dopekat)
Re: Small off-topic.
What is there to guess - You /back in description/ pointed to three /BZ 3.0/ as:
I would add the use of bismuth to that..
PS by the way, stay in the LM must also prepyatstvovat of any foreign influence, but that, as previously written, does not allow to get new experience, so I think that may be a temporary measure.. of Course, you can probably do something in LM-->via PC--> in this world that will ekranirovanii on the principle sensor to sense when there is a need ekranirovanii-automatically turn on-intelligent to work in this key..
---For those who have been in EK work with the 3.0 may be similar to operator mode and full shielding.
finally completed my turntable, a thick aluminum rim
powered by BP laptop 19 volt, spins up to a maximum of 17,000 rpm.
small racocha - rubbed rims magnesium block, which the Chinese sell for ignition of fires.
previously disks when rotating, rubbed with sandpaper, and why they have become rough, you can just block, but then
the surface will be rough.. rim also rubbed a bar, I hope it increases the efficiency of the fan.
in practical use yet do experiments, when you sleep next to her, there was a strong relaxation,
link - a hair on the rim - also some influence on the head there, but it is difficult to specify.
water changes the taste, it becomes like colder and closer to spring...
I have 2.2 OS+ screen metro not 100%, but compared to what it was before, of course a large part of the negative casts. If earlier after the subway, I feel aggressive and drained, now a little melancholy, and somehow, for the power offensively
Assume that the PC may well work in this case
Why are you on the metro talking about.
(We was cleaning it, and it can be again)
I think the problem is the wrong picture of the world, hence any negativity around such a person. Manifested in different forms.
Also artifact watch should also help in the etim:Михаил_ wrote:maybe someone will have other ideas?
the shielding of the object(or the operator) for different purposes due to the artificial out-of-sync time-streams;
about broadcast to the people, which you are so afraid of the subway-
you can read a little here, right at the level of assumptions and guesses
http://ari.ru/news/feb558c22
myself I became irritable recently, and then there it is...
the suit land definitely need capital to wear...
I do not recommend this Ari.ru to read... some kind of tin
well, Ari.ru definitely pin the resource to either not read, or read carefully, realizing that he diametrically has a certain egregor.
On the other hand the article I looked - well, there is probably correct almost everything that is written. But not all.
To metro it is irrelevant. "Panelki" in the underground were and are still from the Soviet era. Their intention is benevolent - to prevent in the area where a large number of people the effect of the crowd, such as the failure of all "pometkovo" or something similar. Them for many years (vanilka) though I suppose they could upgrade to something newer.
In General, mentioned in article effects connected rather with the fix just Pro-Aryan themes in the consciousness of the population (including technological means) and it's kind of a novelty (what he did to the election, slightly or even a little podatocite and corrected), and the effects of this is not only negative. Although maybe I am not aware of the whole process (I don't want to climb it and see what is there for someone who translates).
So guys are not right - the most likely source of the "light of the inadequate" - "their" - because the local stream are not just Pro-Aryan-minded specialists, but there assistance was provided from external to the world the power which was behind the appearance of the Aryans here a long time ago.
T/e/ not just "egregore" but concrete living beings here and now (external t/e/ different civilization, though related, parts of us and in essence always military in its mood).
All this makes the situation quite confusing
I fully admit, however, that there is an external signal (not local) and that these signals are at war in the minds of citizens
So the reality is much harder and more completely than what is described in the article.
As for "metro", the different approach and not to apply for screening
And why do we need different ways of protection in the subway ?
I'm enjoying the metro ride for example. People with this background are perceived somewhere on the periphery. Certainly with them attunement is not present, because if you attune it is immediately noticeable and disgusting. If the conversation on everyday topics as an end in itself carry with them that must and attunement will take place, but if it's seriously to take the conversation. And if you listen to music completely somewhere in their realities fly and still do not care.
Not a very serious communication or interaction does not happen sonstroem from which sick and it stinks (literally by the way).
ps Well, or if the contact is to be fully involved and not perceiving party, if you know how to position to get involved quickly.
pps There is an exception - the attention of the representatives of protivopolojnoe the floor. Clearly very positive from the energy point of view is perceived in most cases.
But the acceptance of such aspect interactions are quite compatible with the absence of contact with the environment.
Well, still hope someone will guess..Михаил_ wrote:as "metro", the different approach and not to apply for screening
And that teleportation yet..
About how! probably have to give up cheese and coffee. Michael, thank you. I'll figure it out.Михаил_ wrote: after harmaline problem with tyramine-containing foods can be up to a week or two if harmalin used not a single
Coffee is usually not so hard a requirement, if the dose maaaaaaaaaaany, but of course it is better not to risk it. But the cheese - it is necessary to remove accurately.ИгорьС wrote:About how! probably have to give up cheese and coffee. Michael, thank you. I'll figure it out.Михаил_ wrote: after harmaline problem with tyramine-containing foods can be up to a week or two if harmalin used not a single
Overall this is a good reason to improve nutrition
well activity 2.2 operator-dependent, and combinations of factors.Мариомар wrote:I Have a 2.2 OS+ screen metro not 100%, but compared to what it was before, of course a large part of the negative casts. If earlier after the subway, I feel aggressive and drained, now a little melancholy, and somehow, for the power offensivelyAssume that the PC may well work in this case
In the subway because a man-made filling strong. there is also at good help (em-background from the engines of cars also adds passive effects)
Just check out from this worldМихаил_ wrote:as "metro", the different approach and not to apply for screening
интересующийсябж
- Been thanked: 1 time
Well, if not shielding means transfer effects, negative energy, of nonsense in people's heads in a different direction. That is, in the You the arrow and You catch and quiver - but that's vampirism!!!Михаил_ wrote:as "metro", the different approach and not to apply for screening
That is not to be closed, and open - that's what You mean?
Please help me if anyone knows:
Got a chopper. Charge the water with her (I put a glass near the fan) - water as water in appearance.
If the glass is put directly ON IT (in the center) that water has strange properties appears. Firstly the taste it gets a little oily (the finish is there, not nasty, and special). Secondly, when you look at the surface in the glass, the flashes seemed more grainy than regular water. I have the feeling that the water has changed physical properties slightly. At normal water ripples on the smooth surface, and this "grainy", i.e. smaller.
From here 2 questions:
1. Is it possible to drink? (Michael said that on top of the fan energy is bad and a person there to be no good)
2. The "energy" of water, fuel, etc. in this place anymore or not? Or if the effect is negative, then the charge will be reversed, i.e., worse than when the next to put the object(more interested in the effect on fuel would be better or worse)?
P. S. Understand that the offtopic, but more just a place to ask. It looks like knowing and seeing only here.
Some have strange ideas about lifeинтересующийсябж wrote:Well, if not shielding means transfer effects, negative energy, of nonsense in people's heads in a different direction. That is, in the You the arrow and You catch and quiver - but that's vampirism!!!Михаил_ wrote:as "metro", the different approach and not to apply for screening
On the side of the chopper just the saturation of space. And at the top and bottom vortices. They have their own properties.Алхимик wrote:please Help me if anyone knows:
To drink? well, probably still no.... t/e/ in certain cases and not all the time maybe. But if it is clearly feel how much and when.
Well, almost but not quite about the fact.Андрей С. wrote:Just check out from this worldМихаил_ wrote:as "metro", the different approach and not to apply for screeningWell, or three to enter, and phase shift... Or not about that?
I always say to do so.... this is a basic tip
Michael, what produces a quality spinner if the disks rotate in opposite directions?
if you twist them one way some people wrote that the increase in the number of disks spinning in one direction does not increase effects important rotation speed...
I just have this upgrade turntables (rim high)
is it possible to upload pictures of the turntables? and generator the riders rapidly spinning top will impose
In Soviet times, was hard to install sometimes and the words were traced, probably a glitch, or maybe just reading, but the brain does not whistle. I noticed on the facts and not only by me, neskolko times Penalosa "background" . Last time not only in the subway, in stores , on the street and in many institutions. By the way, the signal interference is also a sense, then, is not that the whistling and the beat (as binaurally) Now I understand why just such a strange state that few of the signals in one place and the output is caught other, even sometimes different and also felt. More positive , relatively than aggressive. Aggressive moods -signals from other in other places and systems , communication systems, tyrneta and other. There is no background, and trumpets of Jericho .Михаил_ wrote:well, Ari.ru definitely pin the resource to either not read, or read carefully, realizing that he diametrically has a certain egregor.
All this makes the situation quite confusing![]()
I fully admit, however, that there is an external signal (not local) and that these signals are at war in the minds of citizens![]()
By the way, in Ukraine the invisible part of these signals , while not precisely defined where , but it is adjusted (forgive me living there) what"signed" a thousand years ago. You can see the territory names and that there setschas happens.It will become clear..Now it is thus eradicated. But this one ..<
Knowing how much to withdraw and the need to include , in the subway main problem , contacts with people sometimes forced to close. Some barge in like a bulldozer in a private space , picking like a propeller. And just kicking the idea, regardless of toneloc metro. A train in the subway, she several times caught, and there are those who don't understand what it is doing when the sound of the underground fall into a state of polytrans and away.....I wrote somewhere about such cases...when ridiculous was he when I had to mentally communicate. A man sits very sullen and upset thoughts, ask badly, the eyes met and she smiled, got off to view, "asking" the wife....his head is waving and smiling-no. "ask" as a joke mother-in-law got smiles wider and nods Yes. Well, a little popereklyuchat, the output went up and said thank you, all right , how it's done and relieved that. But this is one example. There are many. When I'm literally in the spring , caught a civilian who was riding with me , poured another...and by two guys. Those went quick smart, then stopped abruptly and the girl after came out as a zombie with view...looking for someone in the car puzzled . Girl sitting with glass eyes, but the look was already on top of books...TRANS and fear in his eyes. Often people in the subway playing the wrong game...the atmosphere there allows faster constraits .Gelios wrote:And why do we need different ways of protection in the subway ?I'm enjoying the metro ride for example. People with this background are perceived somewhere on the periphery. Certainly with them attunement is not present, because if you attune it is immediately noticeable and disgusting. If the conversation on everyday topics as an end in itself carry with them that must and attunement will take place, but if it's seriously to take the conversation. And if you listen to music completely somewhere in their realities fly and still do not care.
pps There is an exception - the attention of the representatives of protivopolojnoe the floor. Clearly very positive from the energy point of view is perceived in most cases.But the acceptance of such aspect interactions are quite compatible with the absence of contact with the environment.
Oh, pardon me )))))softopia so ...
And publicity there as "read" a feast for the eyes -especially hidden text. Do you interesting).<
Yeah))))as soon As someone else's"nose" in my space, in the subway, so the phone ,which at, once something gives, like the Text came ,and there are no new or itself without touching the power button , it turns on, then shuts off, the atoms completely hangs. I have this signal----"Hovis who can" So it was before the accident in the subway, only to another branch. Good on our cars not the nipples, and the little old. Between Tushinskaya and Schukinskaya down deep and drove so that the people became afraid, and then braking sharply was that just before the fall never came. There's hair on end were all. Come to the office, and there is news that the accident because of the speed in the subway...there are so kicking, thought covered, and he is dead at 100% charge almost to zero.Михаил_ wrote:subway because a man-made filling strong. there is also at good help (em-background from the engines of cars also adds passive effects)
