CD "brain Massage"
соболь
Post by соболь » Sun Mar 23, 2008 22:21
Hello, Andrey!
Tell me, what will happen if you listen to the disc Massage the Brain and to consume Ginkgo Biloba? What is the effect, not harmful? Or what drives you?
Thank you
Post by Андрей Патрушев » Mon Mar 24, 2008 13:26
Вахидус wrote:hi Andrea!
Thank you for Your work and Your discs!
Listened to the Conductor, and are now trying to listen to the Massage of the Brain. After the Conductor has become noticeably more confident yourself to feel (although this was nothing, but now it became much better became, so to speak, assertive, which is very pleasing). It became clearer to understand how to behave among people so that provalis not by you, but used to health you.
However, Massage is not so optimistic. Trying to start a second time, but all the same. Let me explain.
Listen to the morning from 6.05 to 6.50. (just listened to two or three days in a row). During the day much lost intelligence. Hard to bring attention to the fact that the interlocutor speaks. Elbaevich reaction. Stop listening to the symptoms disappear, everything comes back to normal. Different drives are not susau. Drink water, all as expected. Player sony portable, disc, cdr format. - audio. earphones earplugs sennheiser 300 c. Mind machine yet.
Key question: tell me, normally what happens to me, or not?
Sorry, just had not noticed...:?
Whether You listen to from beginning to end? Do You have a Star traveler in order to compare the response with the 2nd track?
Post by Андрей Патрушев » Mon Mar 24, 2008 13:28
соболь wrote:hi Andrea!
Thank you
Ginkgo Biloba gives a synergistic effect with AVS and binaural rhythms. As far as I know and he tried - not bad. But everyone is different and everyone has their own, so be careful. :)
Post by Guest » Thu Mar 27, 2008 19:29
Andrei Patrushev
Hello!
What does a synergistic effect?
Post by Андрей Патрушев » Fri Mar 28, 2008 10:59
Anonymous wrote:Andrei Patrushev
Hello!
A synergistic effect is when, roughly speaking, 2+2=5
Post by Guest » Fri Mar 28, 2008 15:10
Andrei Patrushev
Do I understand correctly that:
1. sharing Bilobil (I have this drug) and Massage of the Brain reinforce each other's actions?
2. the decision (to share or not(for the person after stroke)) must come from personal experiences?
Post by Guest » Fri Mar 28, 2008 18:53
Speaking at a joint use (Bilobilo and MM), I was referring to sharing during the day (i.e. at intervals), but not in a moment.
Post by Андрей Патрушев » Fri Mar 28, 2008 22:39
About Bilobil - it is better to come from the attending physician...
The joint in this case is not necessarily simultaneous use.
Post by Guest » Sat Mar 29, 2008 14:37
Andrei Patrushev
Thanks for Your advice, but just attending and appointed Bilobil.
My question was about something else:
1. Did I understand correctly that the "Synergistic effect" (in this context) means that sharing Bilobil and Massage of the Brain reinforce each other's actions??? (I'm talking about using not simultaneously but at intervals of 2-3 hours).
Post by Андрей Патрушев » Sat Mar 29, 2008 16:57
Yes, that's right.
Post by Guest » Sun Mar 30, 2008 20:28
Andrei Patrushev
Thanks, understood :)
Алексей35
Post by Алексей35 » Mon Mar 31, 2008 12:29
Good day to all.
I want to start listening to the CD "brain Massage". To disturb only the presence of side effects – can an alcoholic or a drug addict to become a (((. If all those instructions, which are attached to the disk, is it possible to guarantee that there is nothing wrong with my psyche not happen, now she's fine. Are there any initial symptoms, which would say that it is better to finish classes, and then ....?
Honestly speaking, for me, this music strikes fear and to relax you need to stop afraid.
Post by Dimas » Mon Mar 31, 2008 14:20
Алексей35
An alcoholic and a drug addict You will not be on the disk that's for sure :) with the mind also nothing bad to happen, in PRINCIPLE, can not!a simtom-wanted to do-engage,I feel that is enough-stop and all :aa
Post by Андрей Патрушев » Mon Mar 31, 2008 15:48
Алексей35 wrote:Good day everyone.
I have a ochuchenie that You will in no case be engaged in any psychoactive technologies. :(
Иррина
Post by Иррина » Sun Apr 06, 2008 18:36
Good day to all! :)
Recently listened to disc "MM" at the music center (usually the player) and perhaps for the first time in my life I met with a sense of tenderness. This I did, just for information about your positive changes
Probably the player still not quite the bass removed :roll:
Иррина
Post by Иррина » Sun Apr 06, 2008 18:43
Алексей35 wrote:Honestly speaking, for me, this music strikes fear and to relax you need to stop afraid.
Maybe You just plenty of information to gather, to become clearer, and then the fear will be replaced by the feeling of joyful anticipation and confidence :wink:
Миша
Post by Миша » Mon Apr 07, 2008 14:32
Hello, Andrey!
I have a question. After the carbon monoxide poisoning I was diagnosed with "MS" with all the ensuing consequences. This disc, as I understand it, treats the effects of a stroke, and I will be able to help? Or anything you can advise?
Post by Андрей Патрушев » Tue Apr 08, 2008 9:58
Миша wrote:Hello, Andrey!
Don't know - no one has ever tried.
My uncle Oleg Patrushev (occupational therapist) successfully treated with sclerosis and other diseases with his methods - large doses of vitamin B3 - nicotinamide (nicotinic acid).
Миша
Post by Миша » Tue Apr 08, 2008 12:50
Thank you very much. And more specific information on methodology, do not tell where you can read? As you know, this disease is not treated by traditional methods, and about non-traditional I something information find. bc
Post by Андрей Патрушев » Tue Apr 08, 2008 13:01
Миша wrote:My uncle Oleg Patrushev (occupational therapist) successfully treated with sclerosis and other diseases with his methods - large doses of vitamin B3 - nicotinamide (nicotinic acid).
Thank you very much. And more specific information on methodology, do not tell where you can read? As you know, this disease is not treated by traditional methods, and about non-traditional I something information find. bc[/quote]
Write - send (free).
Евгений Кош
Has thanked: 2 times
Been thanked: 2 times
Post by Евгений Кош » Tue Apr 08, 2008 14:55
Андрей Патрушев wrote: Write - send (free).
I found this method on the Internet.
Check for yourself.
Had the first course of 21 days.
Well I can tell you that the thrill of selection of the dose nicotine - vpechatlyayuschie :)
Very frightened when we got up to 8 tablets per day (take them in one go).. - phew..
face red, ears red, neck red.. the belly.. the red back is red and body warm like the sun, get tan.. thought - kick came :)
but .. on 9 tablets reaction did not ( well, except that very light barely perceptible tingling).- found dose.
In General survived :)
now waiting for the end of the break after the course .. and will continue.
for this method of reception is constant and always the rest of your life :) ( with breaks of course)
P. S. my goal of admission/research - cure osteohondroz..
P. S. S. after the first year the improvement is happened.. the feeling that even as finished the course even worse. I think that will be any conclusion only after the 3rd course.
Евгений Кош
Post by Евгений Кош » Tue Apr 08, 2008 15:04
Andrew, maybe You know, but Your uncle in the new method may be changed selection of the vitamin complexes for any new? and then I found his method where he writes about the whole family, undevit etc.. and these "curiosities" of the old even difficult to find in pharmacies :)
Post by Андрей Патрушев » Tue Apr 08, 2008 15:15
Евгений Кош wrote:Andrew, maybe You know, but Your uncle in the new method may be changed selection of the vitamin complexes for any new? and then I found his method where he writes about the whole family, undevit etc.. and these "curiosities" of the old even difficult to find in pharmacies :)
Yes, now the method of "Complivit".
But all my life, I would not advise to use. 15 days, then the same break. And so in severe cases, three months. For the prevention (better to combine with steam room and Jogging) in spring and autumn at once.
Евгений Кош
Post by Евгений Кош » Tue Apr 08, 2008 16:21
In General ( sorry for offtopic) problem of vitamins - still unresolved. Some lights of science data show where the vitamin degrades human health ( study time from 10 to 30 years), while others show and prove that it is necessary to begin to remedy the lack of vitamins and not those doses ( which is recommended) and larger doses ( for example research and methodology Oleg Vasilyevich Patrushev) - amazing things happen in terms of restoration of human health ( this can be read in the method O. V. Patrushev).
Post by Андрей Патрушев » Tue Apr 08, 2008 16:28
Евгений Кош wrote:And all ( sorry for offtopic) problem of vitamins - still unresolved. Some lights of science data show where the vitamin degrades human health ( study time from 10 to 30 years), while others show and prove that it is necessary to begin to remedy the lack of vitamins and not those doses ( which is recommended) and larger doses ( for example research and methodology Oleg Vasilyevich Patrushev) - amazing things happen in terms of restoration of human health ( this can be read in the method O. V. Patrushev).
Well, not so simple. If the body lacks nicotine, which governs "movement" of all the other vitamins in the body and much more, it is possible though to seize, and no other benefit, but harm will not be. I myself have repeatedly faced with this phenomenon, when examined at the diagnostic complex LIRA-100 athletes who on the advice of trainers vitamins in large quantities.
