Quick guide buyer's mind PHOTOSONIX machines
Re: Quick guide buyer's mind PHOTOSONIX machines
Post by Андрей Патрушев » Sun Apr 29, 2012 10:12
Vitaleks
After the "i" (select a leaf), a little like that.
ВитАлекс
Post by ВитАлекс » Sun Apr 29, 2012 10:21
Andrei Patrushev
After i go to the r session
Post by Андрей Патрушев » Sun Apr 29, 2012 10:55
Vitaleks
So not loaded, it is necessary to repeat. :?
ВитАлекс
Post by ВитАлекс » Sun Apr 29, 2012 12:34
Andrei Patrushev
You cannot start a new session. Do everything according to instructions. When you close the program LSlib climbs window:
What does it mean and what's there you need to press?
Post by Андрей Патрушев » Sun Apr 29, 2012 13:22
Vitaleks
"The library was changed. Save?"
Post by Андрей Патрушев » Sun Apr 29, 2012 13:23
ВитАлекс wrote:are doing Everything according to instructions.
Probably not. :)
ВитАлекс
Post by ВитАлекс » Sun Apr 29, 2012 15:25
Andrei Patrushev
LSlib-File-New-Device-innerpulse-Download-Select com port-COM1-Chek System Connection is OK
Add Session-Download-mind healing.LSS-Download-Session(Append)-Librari has been modified. Save it?-Yes-save as:
How and where to save?
Post by Андрей Патрушев » Sun Apr 29, 2012 19:22
Vitaleks
ВитАлекс wrote:How and where to save?
So, where you want, there save the ordinary way, enter a name and hit "enter". This saving does not have to download relationship. Try initially to survive and then to press LSS-Download-Session(Append).
After clicking LSS-Download-Session(Append) on Innerpulse needs to run the lights, if everything is done correctly, and in between sessions of "i" and "r" should appear in the session of the "u".
ВитАлекс
Post by ВитАлекс » Mon Apr 30, 2012 17:59
Андрей Патрушев wrote:Try initially stored, and then press the LSS-Download-Session(Append).
Default saved to offer in the same folder as the downloaded session (patrushev). Continue to offer after clicking on the Yes button in the window that appears after clicking on the x in the upper right corner of the program. How can I change this procedure? Where can I download crack for the program?
Андрей Патрушев wrote:After pressing LSS-Download-Session(Append) on Innerpulse needs to run the lights
No lights was not.
Post by Андрей Патрушев » Mon Apr 30, 2012 19:40
Vitaleks
What socket You are connecting the cable connection with the computer?
ВитАлекс
Post by ВитАлекс » Mon Apr 30, 2012 20:04
The computer is a com port, in mm is the Jack points.
Post by Андрей Патрушев » Mon Apr 30, 2012 21:26
Vitaleks
Try to place the directory with library and sessions in the root directory of your C: drive.
ВитАлекс
Post by ВитАлекс » Tue May 01, 2012 10:35
Andrei Patrushev
The folder with the downloaded sessions is on drive C. If you mean the mm library, it is not entirely clear how this can be done because the computer doesn't recognize mm as a disk drive. MM is detected only in the LSlib when you click on the Chek System Connection, you receive the following window:
Post by Андрей Патрушев » Tue May 01, 2012 12:58
Vitaleks
I don't know then. :? - Everything should be fine...
The only thing left is either put completely new batteries or to be powered with a power supply.
And before You have been able to establish new session?
ВитАлекс
Post by ВитАлекс » Tue May 01, 2012 16:22
Andrei Patrushev
Had not tried to establish a session.
