The Program Of Andrey Patrushev Raduga
Post by Guest » Fri Mar 28, 2008 17:52
also interested in this question
Post by Андрей Патрушев » Fri Mar 28, 2008 22:30
олег75 wrote:SHOCK, a SHOCK TO OUR SYSTEM
• SUFFERING FOR OUR SYSTEM
• STRESS FOR OUR SYSTEM
• ANXIETY, CONCERN FOR OUR SYSTEM
IN DISORDER, THE HEAVINESS OF OUR SYSTEM
• INJURY TO OUR SYSTEM
• EXCITEMENT FOR OUR SYSTEM. is napisaa in BSFF-text.not dangerous at all when working with the subconscious,use such images?
In the relevant context - is not dangerous.
анирам
Post by анирам » Mon Mar 31, 2008 18:56
and I really enjoyed it all. advice to all who are annoyed by the intermittent movement - look no PRAMO on the screen, and slightly ahead of him or behind him, if that's what you thought. a similar behavior of the eyes is used when viewing 3D illustrati. try
Иррина
Post by Иррина » Sat Apr 05, 2008 23:03
Good evening, Andrew and all who reads :?
Downloaded the program, did the settings and started to watch. And female curiosity, you know what !? :roll: Thought I'll see what I 25-th good (I mean trasformare) and it turned out that I, Irina, lady female can be confident, calm, to be young and healthy :wiz About how !
Dear Andrew, what are You the program only for the male half made ???
Of course, I understand that "the product in the running", but it is a little bit sad for the beautiful half of humanity :cry:
[Максим]
...about...
Post by [Максим] » Sat Apr 05, 2008 23:08
Hello, friends!
After another session with the program "rainbow-arc" I had a couple questions. They are directed more to Andrew:
1. Why [BSFF-text] in the center and [phrases of affirmations + phrases-Sedona] uses a different (sort of) color? For example, failed to notice the phrase at the center of a light green color and light yellow color. And in the phrases on the edges of the screen is not found, the color purple, and light green and light yellow meet. Noticed the peculiarity of that phrase in the centre are, for the most part, darker and phrases around the edges - lighter. Does this (not completely random) distribution of colors of any value? Or I can adjust the colors the way I like without changing the effect of the program?
2. Also interesting the following feature. Phrase BSFF-the text appears on the background of a dense cluster of stars (dynamic white dots on a black background). It turns out (at least for me) that the background blue color has a relatively weak visibility, i.e. bad "contrasts" with the background. To see the contents of sentences with the same combination of colors (black, dynamic white, blue), it is necessary to look intently (unlike other colors present). I got everything excellent, the monitor and video card have good characteristics. Although nothing can be ruled out. Therefore, the question is: is such effect that, if consciously at the previously articulated reasons, the phrase "readable" is bad, and the subconscious mind "does not emit" this phrase? Because EV this case it turns out that the subconscious mind gets sketchy because of the "neprostaya" some text phrases may in General have a different meaning.
Very interested in your opinion. Thank you for your attention! :)
P. S. by the Way, about stutter and blinking images. It all depends on the performance of the video card (tested on different computers). And on the same laptop (not new) I had it so that the picture not only moves intermittently, but the phrase (located the left side of the screen) half are cut along the length and height :? Here's an interesting thing, which again is corrected by replacing the computer with a more powerful video card.<
Иррина
Post by Иррина » Sat Apr 05, 2008 23:40
(in addition to the previously sent)
:oops: Wish: please make a female version bi
The program :ay
Post by Guest » Sun Apr 06, 2008 2:04
Change the end, here you will be a female version :wink:
Иррина
Post by Иррина » Sun Apr 06, 2008 8:48
Мирали wrote:Change the end, here you will be a female version
Read the "First read" and understand the purpose of the writing, and then why someone once you can work, and someone - change ..the end.. 8) :o
Post by Guest » Sun Apr 06, 2008 13:59
Иррина wrote:Read the "First read" and understand the purpose of the writing, and then why someone once you can work, and someone - change ..the end..
cityyou from "first read"
I provided primary texts. It is a text file "аффирмации.txt" (a set of affirmations). Each sentence represented in various forms, which also facilitates its absorption. You need from this large collection to choose what You need (and save in a separate file) or, using the samples to create your own (be sure to use all forms).
here is an example of how I fixed
memory and attention
unable to concentrate and remember
dostoina to have a good memory and attention
everyone knows that I have a good memory and attention
I feel that I have a good memory and attention
I see that I have a good memory and attention
I understand that I have a good memory and attention
I know that I have a good memory and attention
sureandI have a good memory and attention
saying that I have a good memory and attention
I tell myself that I have a good memory and attention
appreciate that I have a good memory and attention
and so on in the same spirit.......
Иррина
Post by Иррина » Sun Apr 06, 2008 18:21
Мирали wrote:here is an example of how I fixed
Thank you :).
I'm probably in the excitement of a new hurried :? and not very carefully read everything. It happens to me sometimes. Thanks again and I'm glad you, too - of fixed, worthy, sure, but I have the impression that this forum of "weak" just me and Lilka bi RA-a-a-blowing it pleases :o
Post by Guest » Sun Apr 06, 2008 18:58
Irrina
I myself have a "weak" just do not belong!
I am a woman, from the category of "strong" :ay :wink: :)
Иррина
Post by Иррина » Sun Apr 06, 2008 19:43
Мирали wrote:I am a woman, from the category of "strong"
I wanted to say :ay , but why in ""? :wiz
Post by Guest » Sun Apr 06, 2008 20:18
in "" because strength is not physical :D
Post by Guest » Sun Apr 06, 2008 21:29
Мирали wrote:in "" because strength is not physical
:ay but still :wiz
Иррина
Post by Иррина » Tue Apr 08, 2008 0:15
Good evening :)
Andrew, tell me please
-is it possible to file affirmations to change the font?
-what will happen if the string to highlight words?
For example: I know that I have a good MEMORY and ATTENTION :?
R. S.(previous post is also mine)
Post by Андрей Патрушев » Tue Apr 08, 2008 9:27
Иррина wrote:Good evening :)
Hello.
- the font can only be changed in the program (in settings), change the font in the file will not lead to changes on the screen.
- words are highlighted :)
Иррина
Post by Иррина » Tue Apr 08, 2008 21:25
And I want to "rainbow" ended in some sort of an interesting screensaver that will reinforce the effect of watching the program (this is the point in a well-worded sentence). :o
- (??) how long does it take to do? to achieve the desired effect?
Thanks for the answers for the previous questions.
Like the program :ay
Post by Андрей Патрушев » Thu Apr 10, 2008 12:02
Иррина wrote:And I want to "rainbow" ended in some sort of an interesting screensaver that will reinforce the effect of watching the program (this is the point in a well-worded sentence). :o
Interesting idea with the screensaver! What this could be, in Your opinion?
You have to do it until neither achieve the desired effect. :)
Иррина
Post by Иррина » Fri Apr 11, 2008 21:03
Good evening :)
A few options:
after 15 minutes
1) the stars are going to the point of small diameter, the effect of forward motion and appears colorful image of the planet Earth (meaning that if the person is a microcosm of the macrocosm that is improving itself, it helps the planet); :)
2) stars - in point, move forward and transform the points in the shining 9-pointed star as You in "the Solar wind", and if lights to make a colorful (smooth transitions corresponding to the colors of the chakras) it seems to me, the effect is stunning (of course, if it's not too much); :)
3)stars to the point; moving forward, the image of the track (since we're all Going, I mean in the way of self-development), postenno the dark background brightens and the image appears beautiful house on a background of picturesque nature, or on the shore of the pond (I think that it is the dream of many people); :)
4) stars to the point, a dark background appears lighter and beautiful sea sunset (watching sunset on the sea gives a feeling of peace): :)
it offers beginner, but as You might understand, then You have the last word
Glad the idea with the screensaver like :oops:
Post by Андрей Патрушев » Sat Apr 12, 2008 11:12
A few options:
after 15 minutes
Great!
Try to load a programmer... :roll:
Re: ...about...
Post by Андрей Патрушев » Sat Apr 12, 2008 11:41
[Максим] wrote:Hello forum users!
A brain quickly gets used to the monotony and starts just ignore it, therefore, introduced a different color. Some cheredovanie colors made my circuit work with the chakras to harmonize them. You can make your set according to Your own expediency...
Unfortunately, in the center somehow reflected not all colors (this bug bude removed in the next version).
Look at the screen have multiple sight seeing at the same time 4 corners, to read the affirmations and the fact that the centre is not necessary - maybe a head ache...
About cropping - on "laptop" for some reason this happens... :?<
Re: Side effects rainbow
Post by Андрей Патрушев » Sat Apr 12, 2008 11:56
щкфсгд wrote:
Андрей Патрушев wrote: The reasons may be several:
- chronic dehydration;
- the time classes more than 15 minutes a day;
- wrong looking at the screen - trying to catch the look of each affirmation;
- installing a different frequency;
- the content of personal affirmations;
thanks for the reply. But dehydration is no interference in the program operation and the introduction of new affirmations was not - just curious what program is it - no more than 5 minutes.
It's probably just a coincidence, but to me it seems unlikely. The headache is pretty intense type of migraine. Today will see a neurosurgeon and hopefully, what a coincidence
Five minutes even mindmachine will be no effect...
Контиблу
Post by Контиблу » Sun Apr 13, 2008 17:00
Good time of day!
It seems to me that if using the porgram that you can load in the brain :( visual images associated with the desired information, it would be much effektivna.
Roughly speaking, if the program supported graphic formats, the user would have much more opportunities to use it. Accordingly, the demand would have increased significantly.
художник
Post by художник » Sat Apr 19, 2008 1:21
Hello!
Andrew, thanks for the program! 20 monitor I can move it fine. With text and sound mono quite comfortable.
Made this. As a sound I made a mix of L06 NOV(s)+Windows D Thompson(under the starry sky is very cool fits) the Effect was stunning! MM plus rainbow
Post by Гость » Thu May 01, 2008 19:34
damn...complete nonsense ! Sucks!
The effect of 25 fps (the invention) was originally used for military purposes , which costs money - and what you want to say? this thing is now possible here and so you download from the Internet ! it's all bullshit - to-one brainwashing! And most importantly - there are still people who believe this shit!)))
