Contraindications
Siren The session should be carried out in the presence of the doctor as possible the following reactions: epileptic fit, spasm, or, conversely, fall tonics, blood vessels of the brain, delirium.
About Healing - the reaction is normal (at everyone). It is possible not more often two times a day with a break of at least 3 hours.
Re: Contraindications
If any of the symptoms (listed by you) will arise-the use of MM in any case no longer use?! Sorry of course if I buy this device, and he told me to be contraindicated. If only it was possible for an early first place to try , and if everything is in order, then we buy. Unfortunately, I don't know where we have here in Germany, you can try a session. Can you do something about it can tell, at least roughly. What do you think about the device, Alphamania", can I use it and get positive results despite my symptoms? Thanks again for your attention. Waiting for your reply.
Good day to all! Been wanting to ask. People with intracranial pressure can listen to the program Patrushev and APK-program?
Thanks in advance for the answer!
Iomic
Without light you can.
Hello!
The observed M, the diagnosis of acute polymorphic psychotic disorder while taking a psychotropic drug, 2.5 months undergoing treatment (haloperidol, trihexyphenidyl, carbamazepine ). Now complaints about sleepy state prevailing debility, although it at least made the reception tisercinum.
NOTE THE QUESTION!
If this is the case the application Navigator, what session do you recommend?
Thank you for your attention
NOTE THE QUESTION!
Absolutely contraindicated.Дзын wrote:note the QUESTION!If this is the case the application Navigator, what session do you recommend?
Thank you, maybe after this course ?
dzyn
Not earlier than three months.
[quote][/quote]
Then to meetings, thank you very much
Can I apply if vnutricerepnae hypertension and the application of sedative
I-hard labor
Better not to risk it. If you really want, you can only discs.
Andrew, good evening!I am very interested in your car,but Your note to protivopokazaniya written,if there was a head injury then it is necessary to consult a doctor,the question - how? the one who put the diagnostician or you have a special, which could determine is necessary to try or not.there is a desire, there is a machine, but there is a note to protivopokazaniya.how to be in this case?
Alexan
With Your doctor.
With Your doctor.
Валерий Пермь
Hello! I have a meningioma right frontal lobe if I could use a MM?
Valery Perm
Hello.
I don't know exactly, but hardly... Perhaps even one sound impossible.
Hello.
Валерий Пермь
Hi Andrew! Thanks for the reply. I last year a friend gave hypnotic audio programs for Health, thus I'm trying to get rid of this sore. Sens in the entry have an alpha, beta, Delta frequency (in his words I don't understand). Listen to them periodically, like normal. Wanted here and purchase MM, for bigger health effect. What do you think can help or is it still there?!
Valery Perm
Still with the light in Your case it is better not to experiment.
Валерий Пермь
OK! Thanks for the reply!
Валерий Пермь
Another question, if you buy MM, then listen to I can, but in MM the main light or audio?!
Valery Perm
Light.
Light.
Good day, Andrew!
Want to buy Navigator.
In his youth, had two concussions, are now engaged in a dogfight (without fanaticism), in the head no discomfort is felt, except when you need to bend over while standing upside down or doing push-UPS by putting your feet well supported.
A couple of months ago, did MRI, all normal.
Is it possible in my case to use a MM?
Gareth
Hello.
Yes, you can.
Hello.
Yes, you can.
Thank you.
Acquired Innerpulse, a week ago had surgery to correct the nasal septum under General anaesthesia, 4 times used, the last two times these headaches. Is it possible to use the machine?
