Psychic workshop. Discussion.
нева
Has thanked: 21 times
Been thanked: 90 times
Re: Psychic-workshop
Post by нева » Fri Apr 17, 2015 17:46
Владер wrote:have a Good feel of these tensile and compressive energy efforts.
Master Qi Gong..usually try to hide knowledge about how these efforts are being made, for the reason that if a student can learn, he will have nothing more to learn..)
Владер
Post by Владер » Sat Apr 18, 2015 10:05
The entire body to keep in mind is no problem. Somatic and visual deconcentration I did a lot. But this is different. After 6-8 points usually attention at all evenly distributed through the body.
So the question is the ultimate goal of the exercise is to reach this state and still try to keep the attention of these 12 points is not spreading on the body?
Aura
Has thanked: 22 times
Been thanked: 1124 times
Post by Aura » Sat Apr 18, 2015 10:22
To keep under attention, without spreading through the body. The purpose of technology "the Volume" is volume, not just integrity. It is important to keep the attention of the greatest possible number of aspects at the same time. What is not immediately obtained 12 knots, which is normal, it is important that this number is significantly higher than the usual amount of attention. Attention training is almost like a muscle: for quality transition requires a mile, in this case, super attention.
The workshop is not a set of exercises, but rather a consistent line of development of the energy body. Next technique volume flows and is combined with technology and energy efforts. Then it is assumed retention of different energy efforts in each of the nodes at the same time, this technique of "Form". Just have the integrity to hold very difficult, but integrity is not yet form.
Владер
Post by Владер » Sun Apr 19, 2015 9:26
Got it, thanks
нева
Post by нева » Mon Apr 20, 2015 11:24
Владер wrote:Can we work on the spine as well. Attention allocated to a pair of adjacent vertebrae, compress, stretch.
That You almost found a way to work with inter-vertebral hernias.)
львёнок
Been thanked: 5 times
Post by львёнок » Mon Apr 20, 2015 21:49
I think that the way to cope with the problems of weakened muscles, for example, the belly (called the apron) :wink:
VladerYes all who are too lazy, ie "once", to engage in physical body, you will sing the laudatory songs-ditties :? because such practices may start right at work, on the bus, anywhere without equipment and specials. funds bi
There is such a practice: people quietly going about their business, and at this time his thinly-body double to fall coached his carcass :lol:
And your method for problems with vertebrates hernias - it's just :ay - you just umnichka
мимоходом
Has thanked: 66 times
Been thanked: 312 times
Post by мимоходом » Mon Apr 20, 2015 22:09
It is doubtful that you can train the physical body, imagining that it trained. Nothing happens, it is an illusion.
If you imagine that energy affects the physical body, can be roughly estimated by the formula E=mc^2 as it should.
If someone got rid of the hernia mental offices or pumped their press, please write
львёнок
Post by львёнок » Mon Apr 20, 2015 22:52
мимоходом wrote:it is doubtful that you can train the physical body, imagining that it trained. Nothing happens, it is an illusion.
in passing, is been said that is already trained? And if you doubt that this is possible, tis on your right :? but this does not mean that you are right, doubt all you want, doubting Thomas also wanted to put their fingers in the wound of Jesus
мимоходом
Post by мимоходом » Mon Apr 20, 2015 23:14
What does doubt, or doubting Thomas. Is the result real? Or fancy only? One case mental exercise and quite another matter physics
львёнок
Post by львёнок » Mon Apr 20, 2015 23:56
passing
Well, if you don't understand (even what's Foma), it is a long time :?
Let's not clog the thread useless discussion, just go past :evil:
мимоходом
Post by мимоходом » Tue Apr 21, 2015 0:09
Thank you for sent. But the question is very simple, it is not clear where the aggression
львёнок
Post by львёнок » Tue Apr 21, 2015 3:33
in passing, again you do not understand neither the message, nor, especially, aggression (your very nick full of meaning, so the pun she asked for it for this reason :) ), just a futile argument, just offered to finish it, and nothing more :?
Владер
Post by Владер » Tue Apr 21, 2015 8:30
Any problem in the body - a lack of energy in a particular place.
Even just applied attention - already improves (probably in the function of pain is to draw attention)
If you carefully scan the body with their attention, that there are places that consciously is very difficult to penetrate, it is popped out.
The proposed method allows to make a lot of active attention ( where attention there is energy) into the problem areas.
So the lock will help to dissolve (although the blocks have psychological roots and good to decide these things as a whole).
And what about strengthening the muscles - a moot point, although if, in addition to make a certain image and intention can and will succeed. :)
Милая
Has thanked: 257 times
Been thanked: 259 times
Post by Милая » Tue Apr 21, 2015 10:58
I now actively work with your body on a mental and on a physical level. Noticed that, if you regularly pay attention, for example, the abdomen, the abdominal muscles, once You will not be able to resist, get up and go to swing. The impulse is so strong that You will not be able to resist. Of course, you can posoprotivlyatsya and continue to contemplate your abs without taking any action contrary to bodily urge, but I think it would not be useful neither for the body nor for the mind.
Post by bofara » Tue Apr 21, 2015 11:00
Владер wrote:Any problem in the body - a lack of energy in a particular place.
It may be excess, not only the lack of..
Владер
Post by Владер » Tue Apr 21, 2015 12:29
The excess can also be a problem, but in my experience this is usually a result of blocking just above the channel (dam led to the flooding)
That is, again, lack of attention, only not in the excess place, and next
львёнок
Post by львёнок » Tue Apr 21, 2015 16:17
Милая wrote: .... if you regularly focus on, for example, the abdomen, the abdominal muscles,.....continue to contemplate your abs without taking any action
Of course, if you just focus on the abdominal muscles and contemplate them, they will be in a relaxed state, but now imagine that the muscles of the abdomen is spring, the start of its mentally possible to compress, hold it in the compressed state for some time, then the maximum stretch, hold for some time, and so a few times, you'll immediately feel the tone of the real muscle not only the press, but paired muscles, while all the time doing nothing.
So gymnasts before performing difficult exercises to mentally scroll which muscles in what order and how it should work, and then shut off the mind, then the body fulfills UPR on the machine :?
АМарта
Has thanked: 2 times
Been thanked: 2 times
Post by АМарта » Thu Apr 30, 2015 22:29
Somewhere in the vast forum was of old,that the musicians left and right brain are working synchronously during the execution,because the left and right hand perform different jobs(so to speak)).In connection with this question to the Aura-it might be worth at this point to send in GAIP intention? :)
Aura
Post by Aura » Sat May 02, 2015 21:46
Ангел wrote:somewhere in the vast forum was of old,that the musicians left and right brain are working synchronously during the execution,because the left and right hand perform different jobs(so to speak)).In connection with this question to the Aura-it might be worth at this point to send in GAIP intention? :)
Yes, it is possible to say that intention, formulated at a time when both hemispheres are actively interacting, is true.
АМарта
Post by АМарта » Sat May 02, 2015 22:03
Aura,thanks for the reply.
Иван Славов
Has thanked: 650 times
Been thanked: 150 times
Post by Иван Славов » Sun May 03, 2015 19:58
If once these exercises from the workshop decide to release in the "training manual" or book - badly wanted a specimen for yourself. With the personal signature of the author of these practices. :)
I did this practice /with chaos yesterday, as I read today/..
Today, returning from work looking here's what. A woman sitting on the sidewalk /right on the sidewalk! :shock: before the building of the fire brigade/ reading a book, Smoking, drinking coffee, etc., "Annealed" to complete.. Well, maybe not playing glucofage :), then it would be stupefied..
Well, chaotic manifestations.. :)
львёнок
Post by львёнок » Sun May 03, 2015 22:51
Ахим wrote:If once these exercises from the workshop decide to release in the "training manual" or book - badly wanted a specimen for yourself. With the personal signature of the author of these practices. :)
"And I and I and I have the same opinion!", that is also subscribe to :ay
agni
Post by agni » Mon May 04, 2015 22:04
subscribe)
АМарта
Post by АМарта » Mon May 04, 2015 22:24
I also subscribe)
нева
Post by нева » Tue May 05, 2015 0:53
also subscribe. and under what? )
