Disk Исцеление2: Rainy Afternoon
Дивергент
Has thanked: 16 times
Been thanked: 2 times
Re: Disk Исцеление2: Rainy Afternoon
Post by Дивергент » Tue Nov 10, 2015 2:28
Андрей Патрушев wrote:Irene
What is СК1М?
:shock:
Post by Андрей Патрушев » Tue Nov 10, 2015 8:47
Irene
"One cannot embrace the unembraceable". :?
Through the iPhone - only in. wav format.
Has thanked: 478 times
Been thanked: 264 times
Post by ЛИЛИЯ-Р » Tue Nov 10, 2015 12:06
Ирен wrote:Dear Andrew, (sorry don't know middle name), is it possible to use your electronic file via СК1М for example? well, that is, whether the desired effect?
This is Michael's need to ask.I tried Endorphins through SK-1m-working . Just do not forget the Endorphins ,this is the CD that can be on the go to listen to while you work. And Healing is still designed as a relaxation and any relaxation lying down or reclining. Because when you start Healing 2 or any disk on the relaxation and meditation you should be at rest, and especially if you send another ( via photos), you need to warn him.
Дивергент
Post by Дивергент » Tue Nov 10, 2015 16:50
:ay
Дивергент
Post by Дивергент » Tue Nov 10, 2015 16:52
thank you Lily-P for what do not mind to share their experience.
Дивергент
Post by Дивергент » Tue Nov 10, 2015 16:58
drives Andrei Patrushev actually effective
results from using is very good!
Ашот Васильевич
Has thanked: 2 times
Post by Ашот Васильевич » Tue Nov 17, 2015 13:58
The disc is interesting... feels something between a Massage of the Brain and Healing 1 (two of my favorite on the CD).
After a few rounds, I wanted to get a cat. I have to cats are not indifferent, but during the audition the way a cat is perceived as the home of the Keeper.
Generally while listening creates the impression that cats ' purring has healing power. That is not the sense, namely, feeling. I have back problems (like many) and it is often that lying on your back felt the clamps, unit, voltage cause discomfort. Especially if not previously warmed up. Mostly in the neck and the neck-thoracic. While listening to mentally direct purring in this Department and it helps relax the problem area.
But have a question... I, for some reason (this is true not only Healing 2) after listening to 5-7 times begins and grows with each time terrible discomfort in the body, especially along the back, from lying on his back... Me, each time getting harder to lie on her back the entire session and every time this feeling occurs all the sooner, closer to the beginning of the audition. To avoid increasing discomfort, (which in turn pumps the irritation), I flipped on its side. Listening to the discs on the side I usually fall asleep.
At the same time, listening to Healing 2 on her side and drifted off to sleep, I often have Lucid dreams. While in the Dream I hear in the background the sounds of the disk and in the dream there is a realization that the sounds of the disc in the background are the "engine" of this lucid dream, support OS. As updrafts of air support soaring.
True awareness of being there, but manage sleep difficult, especially processes that violate the usual laws of physics. For example, fly hard, though perhaps after some tweaking, a little easier to pass through walls or closed Windows. But it is not the question.
Andrei V., tell me.
1. How critical, if you listen to the 2 Healing on the side?
2. Whether the therapeutic effect if you sleep while listening?
3. And most importantly, what can be the reason of increasing discomfort in the body with each new listening? And how can I fight it?
Because of this growing discomfort, I still have never attended the full course a single disc (although I have almost all Your CDs), for almost 10 years with Your work.
Every time the same, after some number of auditions, starting to turn her on her side and fall asleep. And then, after beginning to turn on its side at the beginning of the audition, and did stop to listen because I think listening on the side and in her sleep is not very efficient. Make a long break, start a new course and everything is repeated.
In the end, I have almost all Your CDs for quite some time, but not one of them listened to continuously for 21 days.<
Ашот Васильевич
Post by Ашот Васильевич » Tue Nov 17, 2015 14:01
What to do?
Ашот Васильевич
Post by Ашот Васильевич » Tue Nov 17, 2015 14:15
Россомаха wrote:Cat purring real or computer simulated?
The cat is real. :ay Unfortunately, died last year from a tick bite. :cry:
You should not write this.. (( :cry:
Ашот Васильевич
Post by Ашот Васильевич » Tue Nov 17, 2015 14:50
ФилиНН wrote:To the end of the course at the end of the disk is sometimes manifested this effect - as if wearing light points and very little "fun"
I have the same feelings you had. Light flash and flicker. I listen to the mask of Palantir II, in complete darkness.
Post by Андрей Патрушев » Tue Nov 17, 2015 19:44
Ashot V.
Ашот Васильевич wrote:1. How critical, if you listen to the 2 Healing on the side?
Not critical - even standing on your head, if You prefer. :)
Ашот Васильевич wrote:2. Whether the therapeutic effect if you sleep while listening?
Saved.
Ашот Васильевич wrote:3. And most importantly, what can be the reason of increasing discomfort in the body with each new listening? And how can I fight it?
Whence I know why. :? Yeah, and what's the difference??? Just change position. After all, nowhere does it says in the same posture lying the whole session still. It is recommended only to start the session in the same pose, although it's not necessary.
http://www.mindmachine.ru/forum/viewtop ... f=8&t=2181
Кэст
Post by Кэст » Wed Nov 18, 2015 0:54
Андрей Патрушев wrote:Vlad Jaruszewski
Unfortunately, Yes. :?
Andrew why is loss , because both formats and WAV and FLAC formats without quality loss.
Post by Андрей Патрушев » Wed Nov 18, 2015 11:00
CEST
Carry out an experiment several times (for clarity) translate wav to flac and back, and then compare the spectra.
Ашот Васильевич
Post by Ашот Васильевич » Wed Nov 18, 2015 23:03
Thank you.
ТатьянаА
Post by ТатьянаА » Thu Nov 26, 2015 18:21
I have the ROM downloaded,but neotkryvshiesya,that's what gives
The file is already in use. Close other programs that might be using the file, or stop playing the file, and then try again. What is it?
In the second file will require a passport bc
ТатьянаА
Post by ТатьянаА » Fri Nov 27, 2015 16:49
Random unable to open and listen to.Last night and this morning listened to.Anxiety decreased,thank you so much!!!! :) But in the 1st folder,bothered ,being,where Porl need and where to get it??? :oops:
Post by Андрей Патрушев » Fri Nov 27, 2015 17:15
ТатьянаА wrote:But in the 1st folder,bothered ,being,where Porl need and where to get it???
Honestly, I can't even imagine - what You... :?
ТатьянаА
Post by ТатьянаА » Fri Nov 27, 2015 17:26
AAH!All understand is another healing :wink: Sorry :o
Даррья
Has thanked: 3 times
Been thanked: 3 times
Post by Даррья » Tue Dec 01, 2015 1:47
Uhhh!!! This CD is SOMETHING! That was incredible!! Can sheets to write what feelings and sensations during the first listen :) :) although it is enough that when it ended, I just jumped with laughter and outstretched into space from me was torn: "I am the Earth! I have my escort - Pets! Drifted! As far as the Sun! HOME!!!"©))))))
:D :wiz :D bi :D
Эксперт
Been thanked: 4 times
Post by Эксперт » Tue Dec 01, 2015 23:03
In short this story is. I listened to the disc on the phone for 20 days and the last day I noticed that I had the equalizer on (enabled lower and upper frequencies). So, could it be the effect of the disk? Or do I need to re-listen?
Post by Андрей Патрушев » Wed Dec 02, 2015 0:10
Expert
Nothing to worry about. :)
Эксперт
Post by Эксперт » Thu May 26, 2016 19:01
Good day!
Healing 2 is better to listen to before bed or during the day?
I would like to sleep. :)
Post by Андрей Патрушев » Thu May 26, 2016 19:22
Expert
Better day, but it is not a dogma. If the sleep after this good, and listen to your health.
Эксперт
Post by Эксперт » Thu May 26, 2016 19:24
Andrei Patrushev
Well!
Ростислав
Has thanked: 35 times
Been thanked: 28 times
Post by Ростислав » Thu May 26, 2016 23:53
I always listen to at bedtime ))) and figs then I will raise up in the morning)))
