Question a newcomer on the bracelets(confused)
Дмитрий Никитин
Has thanked: 10 times
Been thanked: 10 times
Re: Question of the beginner on bracelets(confused)
Post by Дмитрий Никитин » Sat Dec 19, 2015 14:29
Good day! Please tell me I understood correctly, the maps transfer can be recharged an unlimited number of different objects?
Post by Михаил_ » Sat Dec 19, 2015 15:20
you can bind to the map transfer ONE item at a time. When you place another, the first will disconnect from the card and it will БЖ1.0 (thing in principle is also useful).
Астероид
Has thanked: 22 times
Been thanked: 9 times
Post by Астероид » Sat Dec 19, 2015 16:44
But how many BJ 1.0 is approximately equal to one BJ S 3.0++? I understand that the comparison is not very applicable - but how much? Hundreds?
Post by Михаил_ » Sat Dec 19, 2015 17:36
You actually studied what БЖ1.0 and what is 3.0 ? it's like trying to compare a hammer and a drill ... they are designed for different, although and and - tools. Nothing compares.
You can compare 1.0 with 2.0, 2.1, 2.2 and 2.4, can be a panacea, and that all of them loosely, because they are close (very), but since 2.0 is working with CO., and starting with panacea - even the possibility is enough free programming TO by the operator.
A 3.0 is generally ABOUT something ELSE ENTIRELY. It's not powerful, it's DIFFERENT!!!
the three-pointer is a different state of consciousness/operator in principle. As for example AzerSat nature and carving from the rock the monument is two different States ? absolutely.... so here we are not talking about comparing the power and multiplicity at all. Even within the subset of three-pointers, is very difficult to compare 3.0 (any version ranging from homemade matrix) and 4.0 (the operator site) and OZ (which is in principle a POWERFUL extension of three-pointers) and arbiter (which is also essentially a three-pointer but another way to put operator there).
In fact, it is like 4 different tool for the same.... here, for example if the jeweler makes the product - it can be molded and can be assembled in a manual mode from the stripes/wires/elements, prokatov/stretching-cook, and so on - the result can be similar in appearance, but the technique of production and the work with matter is very different....
Владмосква
Been thanked: 7 times
Post by Владмосква » Sun Dec 20, 2015 10:25
Дмитрий Никитин wrote:maps transfer can be recharged an unlimited number of different objects?
If you charge 2 items at the same time on one card, it will charge both, but with half power each. The more items simultaneously (in parallel) are charged - the less power each will be. Pro serial (alternate) charging items answered above Michael.
Владимир Ш.
Has thanked: 19 times
Been thanked: 34 times
Post by Владимир Ш. » Sun Dec 20, 2015 11:11
About the simultaneous charging of multiple parts, you can add one more thing.
BJ any version works with the conscious and the subconscious of the user(operator). If you put on the card transfer multiple workpieces simultaneously, the maps will all of them be taken as ONE piece, divided into several bracelets and if You give them to different people (for example, two, thinking that half the power of the BJ 2.7 is too much), it is not entirely clear who will be the operator and whose minds need to focus; there may be unwanted effects. In General, Michael wrote that to do so is NOT worth it. Pruflink to provide, unfortunately, can not, because I don't remember where exactly it was.
Post by Михаил_ » Sun Dec 20, 2015 13:59
Yes, really - products are also processed on the same card should not simultaneously carry different people - not good.... on line - you can.
Владмосква
Post by Владмосква » Sun Dec 20, 2015 18:11
Conclusion: put on 1 map (example 2.7) 2 clean the bracelet and their is 1 person on the left and right hands. This economy version turns out :)
Gelios
Has thanked: 3 times
Post by Gelios » Sun Dec 20, 2015 18:55
Владмосква wrote:Conclusion: put on 1 map (example 2.7) 2 clean the bracelet and their is 1 person on the left and right hands. This economy version turns out :)
Rather, optimization of interaction with the product :lol:
It turns out the large contact area, the use of direct physical connection with the two important areas of the body, which are usually the "entrance" and "exit" with the two hemispheres, because each with his arm linked and a large number of meridional.
Although cellular cloud also distributes the resource.
ps the Picture with the scheme of the meridians of a book on qigong, so to speak illustration http://www.litmir.co/BookBinary/106960/ ... /i_070.png
Post by Михаил_ » Wed Dec 23, 2015 14:10
In fact due to cellular cloud since 2.0 went myself using a ton of BJ one version one or two.
When using the card transfer, but you can experiment with how physical media distributed through the body, such as bracelet(s) and the belt can give interesting effects, especially on the 2.7
Байес
Has thanked: 17 times
Been thanked: 2 times
Post by Байес » Sun Jan 10, 2016 21:20
Like many others, reading the forum, gradually drowned in a sea of information on the bracelets and other products :)
I would like to clarify first:
With regards to lines 2.and 3.x. As I understand from the various topics and descriptions are two sides of the personal development media, mutually reinforcing each other: 2.x instructs the carrier to use different modes of interaction with the world, while "counting for him" (through the subconscious) the ecology of the goals and, if the goal is sustainable is the true goal, gives impetus to the world and accelerates its implementation.
3.x develops creative and camera quality relative to the world. That is, learn to understand what the media need from the world, what is its purpose and how it is achieved, and the interaction with the bracelet, or the stream is reflected in the fact that the operator come to the right decisions, insights that are then embodied in the physical world. How close to the truth my understanding?
Post by Михаил_ » Mon Jan 11, 2016 0:15
Not very close... or not close.
2.x allows you to work out operatorskie the quality of the different kind of mode of moderators, t/e not mode of the Creator.
No one calculates the environment, but usually podsoznanie wise enough ( compared to identity ) to something crooked not support. Often and personality after the start of wearing the BZ becomes wiser. Bumps with no change.
BJ cleans/podlivaet injury of the cocoon, including the historical/karmic, helps you tune to a planetary energy bypassing dentures izotermicheskoi different schools, and instructed in the way of energy your filters and modulators.
different versions work here with different aspects.
All reducing agents (I am opposed to saying that there is some development/self-development, since we are dealing with artificially
created by the degradation of the natural abilities that it was not necessary, did start to earn, they were just....)
3.0 is the position operator (as actor as well as expansion 3.0), when the operator is not involved in the game and looking at the world from a position of "I'm inside the matrix and I am in the world" (which are different), but from the standpoint - "I am out of this process and can change it unlimited, because it's my creative Playground." This is a deeper entering into the operator's quality, but most can't derada in this state how long (or even maybe only partially). This condition is also absolute protection (the Creator of the world cannot be damaged created by itself or something from the space of creation because he is outside of it, he is an observer).
Mode 3.0/executor operator has an inexhaustible supply of energy different from the energies of this world, it is his personal creative energy, which by definition has no end, so songs of different schools of "accumulation"/"hold" or other problems "where the energies get it" look pretty funny.... which brought to mankind....
Байес
Post by Байес » Mon Jan 11, 2016 0:52
Михаил_ wrote:Not very close... or not close.
Yeah :)
Thank you, Michael, for your detailed answers.
After getting on the forum want to buy/nabludat everything and more, but the voice of reason screams "figure it out first, what are you gonna do with that" :) Have to stop myself from unnecessary perfectionism, though of course purchase the "masters" with discount now it would be tempting. But to start with it...I think you have to twist a finger at a temple and you're right :)
Post by Михаил_ » Mon Jan 11, 2016 1:24
Yes you can actually.... I do not see anything wrong in this, important not to overdo it if it is critical for Finance ( on some homemade a nice place to live.... )
I do not think that there is some "obligatory path" which is to use jewelry and handmade them . Depends on a bunch of things first of all from the man... the most active users use it all in daily life for themselves and for there business/family etc... someone for healing/psychological practice, and so on.
And all very different including the starting state. there are those who started with three-pointers (arbiter had not yet).
Well, instead of 2.you have to be traslacion basic (2.2) or a homemade cure-all - because this level is also useful to have a...
though the Arbiter can itself fry overload,but dosing it is also possible, it has not been canceled (to wear first, not permanently).
ЛанаЛана
Has thanked: 82 times
Been thanked: 12 times
Post by ЛанаЛана » Sat Feb 27, 2016 22:19
MichaelI have a question to You as the developer... is it Possible in urgent cases to put on the map transfer any bracelet photo of a man who needs help...(maybe just as a short-term energy guiding help...?
Is there such an experience?
Виталий Куклин
Has thanked: 9 times
Post by Виталий Куклин » Sun Mar 13, 2016 18:30
Hello.
I have a question, sorry if not the topic...
Ordered a map of the transfer 2.2. study the forum and can't quite figure out whether to transfer such items as silicone bracelet, the kind that are sold in Euroset.
And if to transfer a watch with metal strap.
It is not yet clear whether one product is weaker if you charge one and then the other.
Фиолет
Has thanked: 32 times
Post by Фиолет » Sun Mar 13, 2016 21:06
Виталий Куклин wrote:Hello.
In principle, any object suitable for map transfer,even though the t-shirt with jeans :) These items are especially suitable.
Only 2 courses simultaneously will not be able to use.The transfer of only one object,as soon as relocating to another object,the previous one loses its properties,but in addition to the little 1.0. And please can zadeistvovat any wearable items :)
кирагуиту
Post by кирагуиту » Mon Mar 14, 2016 1:31
Л@на wrote:Manufacturer 1.0 free Open Magic. And why is 1.0, when it is so much more effective and easy to manufacture light versions. Matrix, Panacea to put on a piece of cardboard, for example.
I-1.0 this is another topic. I think it is unlikely that any other substitute.
Виталий Куклин
Post by Виталий Куклин » Mon Mar 14, 2016 1:35
Yeah, thanks, understood. Michael just wrote what I did for a student, the charged plastic bracelet to the watch and it turned out much weaker here and wanted to clarify.
I'm happy to wear a silicone bracelet. The only thing that probably it is narrow compared to the original BJ
Фиолет
Post by Фиолет » Mon Mar 14, 2016 8:37
Very true,parameters such as mass of the object,its width and the area of contact
with the hand or foot is also playing an important role.Therefore the wristbands commercial version is the most optimal for everyday wear.
Виталий Куклин
Post by Виталий Куклин » Sat Mar 19, 2016 16:52
Today is the second day in silicon bracelet is charged through the card transfer 2.2. Yesterday effects are not particularly felt, well... relatively.
Today slept in it.
Dreams are interesting, but trying so hard not to focus on the bracelet...
In the morning... But something happened...
I work at an electronics store. And the situation was such... That came first, one man to buy light bulbs, and leaving started to talk about the fact that he had met in the morning the 3 young boys with a beer, who took the janitor a shovel and began to throw snow to the second floor... they Say not so young people.
However, I would not attach any importance if they in a few minutes didn't come to our shop and began to shout, and ask to sell them the lamp for growing cannabis...
In short, what freaks I have not seen during the work, but this is a first...
Even in the afternoon began to feel my heel... I Have a heel spur, which has for some time not bothered because I work in sneakers and heel cushions...
So the effects of shake and activate old injuries make themselves known...
I think to write a supposedly small diary reviews...
In General the mood is good, although the evening still tired, but the mood is much better than usual...
Виталий Куклин
Post by Виталий Куклин » Sun Mar 20, 2016 17:40
Continue the theme...
Dreams dreamt today is quite strange. 2 days erotic dream... And today, still dreamed that the car I stole... Dreams had in common with evening thoughts, so keep checking.
Виталий Куклин
Post by Виталий Куклин » Tue Mar 22, 2016 17:15
Continues some "bounce" which was in the description, and there is a restimulation of old injuries. While everything in the descriptions cited. Celebrate some moments of luck. For example, went from Parking at the house, there was no place, came back, there were places, but still close to my entrance. And so something else.
Джейсон
Been thanked: 27 times
Post by Джейсон » Sat Mar 26, 2016 18:12
Tell me where the bands are the same to buy as the bracelets BH?
Фиолет
Post by Фиолет » Sat Mar 26, 2016 20:54
I buy in stores that sell fabrics,garment manufacture,mainly in these stores are spandex-the name of this thread.
