Deck Alpha-Vit
Евгений-М
Re: Deck Alpha-Vit
Post by Евгений-М » Mon Jan 12, 2015 2:00
Андрей С. wrote:does it make sense to use the deck in small short-term (or signing ) purposes?
Yes, it does. Very good for the resolution of conflicts, for example family or work communication.
And if when I first saw I did not go out operational tasks, the deck decides.
As an example, someone has the drop on you is not the case, take this "scrap" and put the task to harmonize... will see the effect. :)
A situation just fall apart on the fly.
Владмосква
Been thanked: 7 times
Re: Deck Alpha-Vit
Post by Владмосква » Mon Jan 12, 2015 15:01
Nine - with the first shuffle (from the deactivated state) inclusive?
From the first, inclusive. More Michael wrote that
you Can continue to work (but it is better to start with a new series of permutations
ie 10 or 11 shuffle is not going to be sick. The scheme of the "Stop work with a deck (work deck!) occurs at any point in time (changing the order of the cards on the passive) or after 9 permutations (changing the order of the cards on the passive)" - just a recommended option.
АлексейН
Has thanked: 20 times
Been thanked: 3 times
Re: Deck Alpha-Vit
Post by АлексейН » Mon Jan 12, 2015 16:16
I have yet to AV not out. Tol-whether skis do not go....
Well, or with the language on targets strained, or the goals themselves very heavy...
Although there is something very heavy. Wanted OS to work. And stub for this used, and AB - to no avail yet.
Владимир Ш.
Has thanked: 19 times
Been thanked: 34 times
Re: Deck Alpha-Vit
Post by Владимир Ш. » Mon Jan 12, 2015 16:55
For lucid dreaming: have a card 'colorful dreams', there is a stream with the same name (very effectively). In addition, there are CD Andrei Patrushev 'lucid dreams'.
Евгений-М
Re: Deck Alpha-Vit
Post by Евгений-М » Mon Jan 12, 2015 18:41
АлексейН wrote:Want running to work. And stub for this used, and AB - to no avail yet.
Dreams are more dependent on body physics. If not, then first put all the appliances and AV on the achievement of normal physical and energy body. As I understand it initially it is not important what to use, the same "Colored dreams" or AB..
Noticed on its own - launch all sorts of cleaning and adjustment and the OS can not see more, although I have included easy. The entire resources of the body left to restore..I Have here a pattern.
Re: Deck Alpha-Vit
Post by Михаил_ » Mon Jan 12, 2015 20:58
Yes something like this is as said ...
Re: Deck Alpha-Vit
Post by Михаил_ » Mon Jan 12, 2015 21:00
By the way essentially the deck is better suited to achieve the objective purposes in the world (shoving them) than for less objective transformation inside the cocoon (impact of a on itself), where it is hard to catch the moment when you need to shuffle.
So with dreams originally ...ERM... so it is possible but it's kind of kinky, it is better to start with the options (physics of the body and target products) and they stuck for quite a while... because it's not fast.
АлексейН
Re: Deck Alpha-Vit
Post by АлексейН » Tue Jan 13, 2015 2:09
Yeah. Accepted. Thank you.
Has thanked: 5 times
Been thanked: 8 times
Re: Deck Alpha-Vit
Post by Воффка » Wed Jan 14, 2015 12:06
Michael_
Michael, Hello!
Tell me, if when cutting a homemade alpha Vita the edges of some cards have been cut (about 0.1 mm) can be used?
After cutting the cards, the lamination is unstuck on some, you can fix the edges with tape?
Л@на
Re: Deck Alpha-Vit
Post by Л@на » Wed Jan 14, 2015 12:24
The whole sheet is laminated? I thought each card separately. All the same right?
НРР
Has thanked: 2 times
Re: Deck Alpha-Vit
Post by НРР » Wed Jan 14, 2015 13:46
Л@на wrote:the whole Sheet is laminated? I thought each card separately. All the same right?
Lana and so and so but it is better separately, so the card was not stratified.
Re: Deck Alpha-Vit
Post by Михаил_ » Wed Jan 14, 2015 20:52
First I cut from a sheet, now laminated each separately. just cut edge - perfectly normal.
ОлегЧ
Re: Deck Alpha-Vit
Post by ОлегЧ » Fri Jan 16, 2015 1:08
Please tell me who've done maps: laminate on both sides?
Re: Deck Alpha-Vit
Post by Михаил_ » Fri Jan 16, 2015 1:16
Typically, the lamination process generally bilateral...
ОлегЧ
Re: Deck Alpha-Vit
Post by ОлегЧ » Fri Jan 16, 2015 2:13
Okay, thank you! tomorrow I hope to be finished my card :)
ТатаЖ
Re: Deck Alpha-Vit
Post by ТатаЖ » Fri Jan 16, 2015 11:46
Good day! Tell me, and you can print a black and white printer, or you just using color ?
Бисо
Has thanked: 49 times
Been thanked: 38 times
Re: Deck Alpha-Vit
Post by Бисо » Fri Jan 16, 2015 12:51
Hello Tata,
It is better to use a color laser printer. If this is not possible, then a color inkjet. In a pinch you can use black and white printer, but this will significantly affect the strength of their work.
However, the strength of the work depends on the operator, but it is better to use a colour laser printer.
ТатаЖ
Re: Deck Alpha-Vit
Post by ТатаЖ » Fri Jan 16, 2015 16:58
Thank you, Beso... I thought so, just wanted to clarify....
Хаст
Has thanked: 13 times
Re: Deck Alpha-Vit
Post by Хаст » Fri Jan 16, 2015 17:47
And if, instead of lamination, for convenience, to stick cards to a hard cardboard - is this normal?
While experienced alpha-Vit 1 time, solved a small problem at work. Just tried to release himself and shuffled at random, not listening to intuition. Everything turned out optimally.
Бисо
Re: Deck Alpha-Vit
Post by Бисо » Fri Jan 16, 2015 17:57
Hello hast,
Michael wrote:
"I also recommend them on tape to print, as I do, but not on paper. There are certain reasons.
To make a full alpha Vita need the process the lamination (which I also recommend to do) to produce a completely special way, and then decks the stream is processed. These two stages You can't fool ourselves, but you can still use the film and to laminate the deck."
Хаст
Re: Deck Alpha-Vit
Post by Хаст » Fri Jan 16, 2015 18:31
BesoYes, I remember this advice Michael. I think the lamination process captures and enhances the structure depicted on the maps. But the laminator is not, and on cardboard to stick want purely out of convenience. And over to reinforce the layer of varnish for example. But of course it can, everything can not, so ask :)
Бисо
Re: Deck Alpha-Vit
Post by Бисо » Fri Jan 16, 2015 19:03
hastthe cards work and without lamination, but weaker.
On cardboard to stick I think you can, but "on top to enhance the layer of varnish such as" don't know.
Евгений-М
Re: Deck Alpha-Vit
Post by Евгений-М » Fri Jan 16, 2015 19:24
Хаст wrote:But no laminator,
Colleagues, laminators have almost every corner, where the "Photo Moment" and "the Photo on documents", Copy Centers of all kinds.
They can cut too.
It's not expensive. Only avoid locations near the Universities, there are for poor students the price tag is always 2 times higher than just ... :)
If you ask what is to say that Feng Shui :) (the Council old and working). Then all questions are removed at once.
Re: Deck Alpha-Vit
Post by Михаил_ » Fri Jan 16, 2015 20:25
Хаст wrote:BesoYes, I remember this advice Michael. I think the lamination process captures and enhances the structure depicted on the maps. But the laminator is not, and on cardboard to stick want purely out of convenience. And over to reinforce the layer of varnish for example. But of course it can, everything can not, so ask :)
The lamination process is not fixed and does not increase, there is a laminator intelligent as a mage. the machine is made and the processes it a lot harder... like on the input manuscript on the edition (I'm exaggerating much).
If not for the film/laminate ( film has its advantages due to the material structure and transparency!) do not care to glue on cardboard or not, but I didn't glue (the extra mass will interfere with cards in vzaimodeystvovat scenario, although very weak).
Dense photo paper is enough. And laminated in a lot of places for a small coin and not just at home.
Been thanked: 10 times
Re: Deck Alpha-Vit
Post by Мастер 108 » Sat Jan 17, 2015 12:49
My question is probably a little strange.
For me it was always a problem what to consider as a starting point. For example, say, in Singapore, the world's largest Ferris wheel spinning in the sun - but if on the other hand to look? But here it is just that clear - direction (to the South) specified cultural-historical and wheel spin on Feng Shui.
And in the case of a shuffle of the deck - where it begins the countdown? Here, the deck is on the table - which card considered first? The one that is closer to me (count me) or the map at the bottom of the deck (from the table)?
For fans to joke, they say turn the deck vertically and count from left to right is also does not change what card is considered first and where to count?
