Bioresonance modulators
Your own guide in the energy-space
Россомаха
Been thanked: 11 times
Re: Bioresonance modulators.
Post by Россомаха » Wed Mar 05, 2014 15:15
нева wrote:But from the position of the gathering of ingredients and their transformation, is considered optimal, the use of practices Bagua, especially those complexes are related to the branch of her gun, aimed at the cultivation of the alchemical meridians(not to be confused with "magic).
Practice Bagua from Choma? Generally it is believed that magical (wonderful) channels and are used in alchemy, as ordinary people, they are closed, practices are designed to open these channels. Not tried his intentions through BRM to forward to the opening of a wonderful alchemy of channels and filling them with Yang energy?
нева
Has thanked: 21 times
Been thanked: 90 times
Post by нева » Wed Mar 05, 2014 15:28
Россомаха wrote: Generally it is believed that magical (wonderful) channels and are used in alchemy,
Used of course, without them anywhere, it is base. Alchemical meridians, it is more like a snake on the head of Pharaoh, or there is all sorts of out-of-body centers that once again and managed short Of alchemical meridians..meridians the longest...about 25 centimeters. Actually not mastered chudesnye meridiany, just do not get to master alchemy..and without them will not develop what is necessary.
нева
Post by нева » Wed Mar 05, 2014 15:38
Россомаха wrote: And not try their intentions through BRM to forward to the opening of a wonderful alchemy of channels and filling them with Yang energy?
) no ..not yet tried..)
Россомаха
Post by Россомаха » Wed Mar 05, 2014 15:55
нева wrote:Alchemical meridians, it is more like a snake on the head of Pharaoh, or there is all sorts of out-of-body centers that once again and managed short Of alchemical meridians..meridians the longest...about 25 centimeters.
You have already mastered, in the sense opened, these alchemical channels?
Россомаха
Post by Россомаха » Wed Mar 05, 2014 15:57
Try it, it was interesting to read your report about it.
лексветер
Post by лексветер » Wed Mar 05, 2014 17:04
http://ivan-ognev.com/pol-kristall-2.html Aura is close to the essence of BRM?
on what basis are selected crystallites, because each type is different influences on different chakras of people, in different :)
Aura
Has thanked: 22 times
Been thanked: 1124 times
Post by Aura » Wed Mar 05, 2014 17:42
Akela
Crystal is not just a kind of molecular sieve, which is a prerequisite for the generation, accumulation and transformation of energy, but also a kind of space, the potential of the frequency characteristics of which can interact with the energy-informational space. That is, we have a unique shape available for use on earth, but correlated with energy of a higher order. This is the uniqueness and "magicnet" crystals. Mobile network - it is only necessary material component for the transfer and dissemination of information. Information itself is intangible. Code crystal - is it a matrix or a data entity, the crystal lattice of a crystal can be called the material carrier matrix. The essence of information transfer is the stream. The term comes from the classical Soviet crystallography, although perhaps used in other fields and other values, so you asked a very good question. To make it easier to explain the essence of the translation matrix (media - crystal lattice) and the virtual information space (the material component of GEIP) can be represented in the form of a digital code, or geometric shapes. This review provides a comprehensive approach. By the way, sensitive people tuned to the crystal can directly read out these figures to see these geometric shapes. In this vein, there is no fundamental raznytsy between man, crystal or GAIP - there is only different information that determines the various forms and characteristics. The growth of the crystal is possible only at the expense of broadcast. Stream - the essence of symmetry, or organizing space. It is important to understand that energy can exist in a formless space, in the space of imperfect forms (unstructured) and space advanced forms of the (symmetric). Take for example the simplest type of broadcast is linear.
com/uploads/images/2014/03/30baf2e3bb742786b98cc91bd17c0aaa.jpg">http://s3.hostingkartinok.com/uploads/i ... 7c0aaa.jpg
The right part of the picture - grid broadcast. When applying lattice translation at point A we have the "infinite crystal", or "infinite lattice", each node of which is filled with properties A or g(A) = B, where g = the function broadcast. Broadcast BRM usually have the form of a network of non-linear broadcasts, to portray them in the picture very difficult. If you present it in numerical form, the crystal will be a certain sequence of numbers, and the broadcast - algorithm.
Stream is a fundamental concept, for example, food consumption absorbs not only calories but also information through broadcasts. Moreover, there is structured and unstructured food, the consumption of the first person can build internal structure, with the consumption of second - no. By the way, this idea was fundamental in the emergence of BRM (asked about the history of the modulators). Initially, the modulator is designed to complement and enhance the action of the crystal essences to be taken inside. Crystal essences are carriers of the vibrations of a crystal. But when testing the modulators showed results more interesting than the actual essence, though now BRM and crystal essences complement each other. By the way, when you receive crystal essences significantly reduced such effects, are described Akela and Valerich when getting started with BRM: pressure, insomnia, floors, equipment...it is absolutely normal and even very good! Don't worry, this is only the beginning) the fact that the above model of transmission is theoretical, but in practice, certain vibration characteristics, often exceeding the usual human, superimposed on a very specific person and very specific situation. Non perfect geometry, can feel "overweight" from better energy. Owners of internal symmetry from birth, or those who have built it consciously practice, this effect may not be present at all. We can say that someone needs to undergo a preparatory period to build, and someone already has the conditions to work with crystals. Symptoms such as and "response" are a reflection of the algorithm the direct-feedback. A period of structuring something like healing a sick person: first comes the fever, then recovery. "Escalates" is usually the weakest point in a person or situation (in terms of imperfect symmetry). The crystal formula is quite soft structure (axis build, build the geometry of the brain, etc.) the imperfect structure of man, preparing him to work with BRM. In the crystal bridge, one can control the stream due to the presence of the exchange fields between the crystals in BRM with one crystal - no (in any case, having the skills of conscious control of their structure).<
лексветер
Post by лексветер » Wed Mar 05, 2014 19:44
AURA, sorry super curious :) I'm just trying to understand what and how to get valid ie BRM is not as expected, plus it was not any embellishment of the placebo effect, you need to understand though how what and why I think is not the right way to just rely on reviews etc.
Quote: Structural elements: Garnet (Garnet) February (Amethyst)
Type of interaction: parallel
Superengine: cubic
Class superengine: exactaudiocopy
Frequency: 235-245 Hz.
Matrix exchange fields:| 0 -1 0 |
| 1 0 0 |
| 0 0 1 |
Dominant perceiver channel: verbal
Element: fire, air
Body system: body volume, a truncated body, a resonant body.
Maximum activity: on the moon rising"
can simple language accessible to the layman :)
2. long assumed that no accident semiconductors microcircuits, transistors, silicon etc ie the technocracy we are ambient everywhere, people too, mostly of flint organic components is I think no coincidence :? the influence and impact of household appliances per person
3 amethyst it is not a coincidence? one of the minerals that are resonating with the upper chakras
Акела
Has thanked: 28 times
Been thanked: 64 times
Post by Акела » Wed Mar 05, 2014 20:13
Аура wrote: to say that someone needs to undergo a preparatory period to build
Well maybe You're right, practice will show :) and thank you for your participation "in search of truth"...
Try without mounting the devices on a chamber plant.
Although the word stream transmission,the message transfer means in one direction, without feedback, well, like a radio or a TV set without interactivity.
Of course the TV can be turned off, can you turn off the modulator?
And thank you again!
Валерич
Post by Валерич » Wed Mar 05, 2014 22:26
Аура wrote:Crystal essences rather soft structure
Sorry for the ignorance, the crystal formula is what? Infused with shungite quartz or the water is not the same?
Аура wrote:pressure, insomnia, floors, equipment...this is absolutely normal and even very good! Don't worry, this is only the beginning
Came the analogy to strike the arm swings in the opposite direction. And I had 2 weeks of complete silence on real estate.
AuraYou once warned about the need for "fine tuning" at work. Could not a little disclose Your idea? For example, one of the tasks that I'm trying to decide whether to stop the appearance and flow of uncontrolled thoughts. Not totally problem I have with this, but "less is better".
Акела
Post by Акела » Thu Mar 06, 2014 9:55
Валерич wrote:to stop the appearance and flow of uncontrolled thoughts
By the way with experience modulator manifested in consciousness so to speak grey noise, with pressure at the heart center. Of course it can, the rebuild, but I still nebylo a masher, not a parlor, not Maritime BJ.
Just like in one of the series of Aralia, with the participation Khazanov, -...he's still alive, but...
нева
Post by нева » Thu Mar 06, 2014 11:58
Акела wrote:was manifested in the mind so to speak grey noise
Sorry. Could not, would describe in more detail. I have before falling asleep something like that, but is associated with a "broth" That is something absolutely chaotic, but dense and rich, which at the slightest force formed images and thoughts. That is, perceived some kind of substance that even before the emergence of thoughts. Directly with Pmami is not-connected, although it appeared recently.Here You said "grey noise".. in the waking state, if you listen, you may like it.
Акела
Post by Акела » Thu Mar 06, 2014 13:10
In proselochnoy condition, mesleki Yes obrazki all sorts of not good, "radish" pram which is generally not svojstvenny as you would think. But in bodesti radiate as radio along the lines of the main wave, the feeling of discomfort, not deadly but "...who knows what he is Margaret..." Possible adaptation due to the enlargement of the range of perception, but the "firewall" worried like a virus of some sort not to pick up.
Of course the device punctiliously as psi-the product extends the capabilities but don't want to finish Icarus :roll:
Interested in creating these devices was involved, the Creator of BJ, i.e., Michael? :(
нева
Post by нева » Thu Mar 06, 2014 19:07
Akela
I had chest sensations when tested Draghi from the BK (beryl) code. When opening a stone, five minutes later in his chest was growing a feeling akin to delight, only weaker, and was kept all the time until there is contact. After rupture of the contact, there is not much weight on for 10 minutes. But it is quite logical if we assume the vessels to dilate or constrict during experiencing any emotions, then you need a little time to get, everything back to normal come.
I have so only beryl was.
Aura
Post by Aura » Thu Mar 06, 2014 21:46
лексветер wrote:http://ivan-ognev.com/pol-kristall-2.html Aura is close to the essence of BRM?
The essence of lithotherapy is to use the influence of stones on human rights. The essence of BRM in the use of crystals as conductors between man and GAAP. The article lists different methods of polarization of crystals, some of them are used in polarization of crystals for BRM.
лексветер wrote:on what basis are selected crystallites, because each type is different influences on different chakras of people, in different :)
In BRM are certain requirements for crystals, but not jewelry. The main requirement is a place of crystal growth, because the growth process the crystals absorb the energy space, particularly in crystals of three-dimensional form. In BRM uses the crystals grown near outlet of the vertices of Energometall of the Earth. The energy field of the Earth has the shape of a crystal pentadecamer imposed on icosaedro. Energometall Earth has six tetrahedral vertices and eight triangular. Also the crystals are selected according to: macroscopic homogeneity, lack leneyna defects, blocks, and patches, molekulyarnoi square lattice and the diameter of the working plane, etc. of Course, each crystal is endowed with individual parameters, and that is why he is able to interact with the person. Each stone is a kind of cipher in our space. In fact, all our body we can lay out the stones from the acupoints to the organs and systems of the body. Eyes — sapphires, teeth — pearls, emerald — muscle, rhinestone — light, etc. But for us even this is not important, and that each crystal has its own frequency.
лексветер wrote: AURA, sorry super curious :) I'm just trying to understand what and how to get valid ie BRM is not as expected, plus it was not any embellishment of the placebo effect, you need to understand though how what and why I think is not the right way to just rely on reviews etc.
Superengine: cubic
| 1 0 0 |
| 0 0 1 |
Element: fire, air
Everything else is an explanation in simple language as basic characteristics of a crystal are working with the person. BRM properties reflect the relationship between groups of molecules and atoms arising from the interaction of field and field of BRM. In the instructions to BRM given transcripts of each property, but it is impossible to say that "if above this setting", the "more manifest this property", as having a spatial structure, we are always dealing with complex characteristics.
лексветер wrote:long assumed that no accident semiconductors microcircuits, transistors, silicon etc etce technocracy us ambient everywhere, people too, mostly of flint organic components is I think no coincidence :? the influence and impact of household appliances per person
No accident. As you rightly said, man is also composed of crystals. On this basis, increased many theories, speculative, or seemingly close to the truth...that man was grown from the crystal to those that are aliens using humans for obtaining crystals. It is important that crystals can resonate with the human energy and energoinformational field of the earth.
лексветер wrote:amethyst it is not a coincidence? one of the minerals that are resonating with the upper chakras
The crystals are selected randomly. Each crystal has its own properties. For a start, was presented to the Quartz Code, as the easiest and most versatile in terms aktivatsii and human use. Amethyst really resonates with the 7th chakra, no wonder all his priests using. Stream amethyst has a funnel shape with the apex at the top of the head.<
Aura
Post by Aura » Thu Mar 06, 2014 22:10
Акела wrote:Although the word stream transmission,the message transfer means in one direction, without feedback, well, like a radio or a TV set without interactivity.
Stream does occur in one direction. Everything else happens according to the algorithm of the direct-feedback, observe that we can as "response".
Акела wrote:of Course the TV can be turned off, can you turn off the modulator?
Yes, it is possible, by combining any metal object to mount the crystals do not several. minutes...but you can depositional crystal, and it may be that you have it will stop working. And there is a need?
Aura
Post by Aura » Thu Mar 06, 2014 22:35
Валерич wrote:Sorry for the ignorance, the crystal formula is what? Infused with shungite quartz or the water is not the same?
Infusions shungite is a water infusion of the crystal. This is the easiest way to eat the essence of the crystal. However, in this case the ability to use the power of the crystal is limited to 10-15% of its capacity. Therefore, it is desirable to use auxiliary forms of infused fluids primarily structured water. She is capable of, at least, take the information of the crystal. In the manufacture of crystal drawing crystals subjected to preliminary heating in a furnace, this is the first stage, then the crystal is ground to size of particles consumed, is distilled and special tincture.
Валерич wrote:Aura, You were warned about the need for "fine tuning" at work. Could not a little disclose Your idea? For example, one of the tasks that I'm trying to decide whether to stop the appearance and flow of uncontrolled thoughts. Not totally problem I have with this, but "less is better".
Yes, fine tuning is very important. We are talking about setting up on Your intention. Any desire is in the first layer of consciousness, you can then get to the origins of desire in the subconscious and superconsciousness. For example, you want money. In fact, it may be a desire for power. Or do you want the house. In fact it may be the desire of protection. It is important to get to the original desire, then work with the BRM will be fast and efficient. The criterion that you have formulated the right intention, can serve as emotional response. Physically, the emotional response is felt as the seal, the elation, the active heat, the updraft in the emotional center. Each crystal has a dominant perceiving channel. To form the intention should be the key of this channel. When you have found the original intention, when working with BRM you can already use this initial emotional response. This in itself is an important psychological work, in which you discover that many of the desires are not yours, and navasky other people, advertising, society. Stop uncontrolled internal dialogue is quite simple, it is better to use BRM Amethyst.<
лексветер
Post by лексветер » Thu Mar 06, 2014 22:46
Aura, thank you very much for Your complete answer :) :ay
quote Matrix exchange fields:| 0 -1 0 |
| 1 0 0 |
| 0 0 1 |
ie crystals among themselves can share and connect according to a specific algorithm pre-stored as the matrix exchange field
лексветер
Post by лексветер » Thu Mar 06, 2014 23:00
Aura! this topic is very promising, please pay attention to the branches in orgonite, SP the servicepack and Radionics, it seems the polarization of the crystals in these devices is also present to some extent and was umoljani those who stood at the origins of these devices, not by chance, for example the same organic starts and works best in areas of strong electromagnetic fields, slowly the jigsaw puzzle of understanding is going into one, thanks for the topic and lots of fun,,,
Aura
Post by Aura » Thu Mar 06, 2014 23:31
Акела wrote:Way to experience the modulator manifested in consciousness so to speak grey noise, with pressure at the heart center. Of course it can, the rebuild, but I still nebylo a masher, not a parlor, not Maritime BJ.
The difference is in the parlor, BJ and modulators is that the first is a charged product, and the modulator is a tool. He does not possess the desired properties, you are asking him to do the right properties. Here and there there are pluses and minuses. And you to direct obtaining information from GEIP tuned. Push only it can. Then grasp the desired image from the noise, grasp it and kontsentruytesya.
нева
Post by нева » Thu Mar 06, 2014 23:42
Аура wrote: Then snatched the desired image from all that noise
Slightly disagree..) the Noise is inherently self-sufficient. Like me for example, sometimes, to listen to the noise of the forest as a whole, not picking out..of..the noise kontektste oak or ash..)
лексветер
Post by лексветер » Thu Mar 06, 2014 23:49
AURA! THERE is a PURPOSE AND DESIRE to REMOVE the INFO FROM the field info from Tesla and other friends whose works have not fallen into the mass, it is possible with this devison,? being a techie thinks and practiced in this area, because a lot of these labors, but not everyone is given to this info, only people with a certain level of consciousness, or this device is connected only with the fact that he lives now really like the Internet that knows Peter live in Australia can use this device to find out what Ivanov lives in Europe.sorry for the lack of structure
Aura
Post by Aura » Fri Mar 07, 2014 0:00
лексветер wrote:quote Matrix exchange field: | 0 -1 0 || 1 0 0 || 0 0 1 | ie crystals among themselves can share and connect according to a specific algorithm pre-stored as the matrix exchange field
You can, provided Gematria interaction between them, which is implemented in KM.
лексветер wrote:AURA! THERE is a PURPOSE AND DESIRE to REMOVE the INFO FROM the field info from Tesla and other friends whose works have not fallen into the mass, it is possible with this devison,? being a techie thinks and practiced in this area, because a lot of these labors, but not everyone is given to this info, only people with a certain level of consciousness, or this device is connected only with the fact that he lives now really like the Internet that knows Peter live in Australia can use this device to find out what Ivanov lives in Europe.sorry for the lack of structure
Time works another device, it will be presented here
лексветер
Post by лексветер » Fri Mar 07, 2014 0:00
I often see a deliberate connection between technology and people, (no, not sick, and help is - a joke :) ) is thought for example before you start searching in Google to find an idea and understanding will find you , and no shit, and Vice versa begin to look for think find the understanding the topic is complicated hardly find it, and then BAM found, but not matching that expect and receive can be attributed to other causes, but the link definitely has the most interesting primary and secondary this idea directly opposite
лексветер
Post by лексветер » Fri Mar 07, 2014 0:06
Аура wrote: Time works another device,
what do you mean time, thank you in advance for your reply
