New session for the Navigator
Гарет
Has thanked: 49 times
Re: New session for the Navigator
Post by Гарет » Sat Aug 05, 2017 17:53
Андрей Патрушев wrote:Session "Mind Healing 2" (MndHlng2.ses) - for the recovery of alpha activity in the brain after a traumatic brain injury and illness with a high fever.
Andrew, turn on the link, and there is a file size of only 4KB
Post by Андрей Патрушев » Sat Aug 05, 2017 18:10
Gareth
How much should it be? :) It's a text plain mashinnoi session.
Гарет
Post by Гарет » Sat Aug 05, 2017 19:51
Well, if the text, so it probably should be) Only what to do with it I do not understand (like using the Navigator to start the session) :)
Or simply a Massage of the Brain 2 limited?
Post by Андрей Патрушев » Sat Aug 05, 2017 19:53
Gareth
How are You session using Navigator launch???
Download on a flash drive, and run....
Гарет
Post by Гарет » Sat Aug 05, 2017 20:27
Andrew
Download into the directory and launching from it, but all the files weigh at least several megabytes, and there is 4 KB and the Navigator gives - "not correct format"
Post by Андрей Патрушев » Sat Aug 05, 2017 22:16
Gareth
You are confusing something. The maximum weight is 8KB, mostly 1-2KB. I downloaded and checked this session - everything works fine.
You have what model Navigator?
Гарет
Post by Гарет » Sun Aug 06, 2017 13:24
Andrew
Honestly I do not know the model, gray with yellow and green buttons on the panel.
About the size, we seem to talk about different things, I just downloaded "remember what you have read", size of this session 89 MB
Over the three years of owning MM, first time I can session to run :?
Post by Андрей Патрушев » Sun Aug 06, 2017 13:45
Gareth
"remember what you have read" is a combined session, and we talked about simple. To find and run a combined session in the Navigator, select: Training\extra modes\Combe. session. As usual the session started from the menu Training/Baseline session (or Library).
Гарет
Post by Гарет » Sun Aug 06, 2017 13:56
Andrew, thank you.
I apologize blunted.
Гарет
Post by Гарет » Sun Aug 06, 2017 14:39
Listened MH2 - feeling unusual for the sessions I think this session greatly affects the vestibular apparatus.
Andrew, MH2 can be listened in parallel with "remember what you have read" and "learn quickly", according to the scheme: 1st day - "learn quickly," 2nd day - MH2 and "remember what was read" (echo with a break of 3 hrs)?
Post by Андрей Патрушев » Sun Aug 06, 2017 15:18
Gareth
You can, but ÌÍ2 in the first half of the day, and "remember that I have read" - in the second.
ГлебФ
Post by ГлебФ » Mon Aug 21, 2017 10:14
Hello,and conversion of more basic sessions, Nova Pro under Navigator is not planned,maybe I can not find them in the Navigator, for example on the relaxation of only 8 sessions,and in the Nova about 15?another would certainly like for more frequency characteristics of sessions in the description ,so for example even for a more clear notion of the differences between sessions for CMP in the section of relaxation and vitality .
Post by Андрей Патрушев » Mon Aug 21, 2017 10:47
Gleb
The average user typically applies a session or two of life. These eight sessions equivalent to 32-m, if you change the shape of the signal: S, As, R, B.
The difference between SMR sessions in the topics of relaxation and vitality lies in the Z-rhythms.
ГлебФ
Post by ГлебФ » Mon Aug 21, 2017 21:21
Very entertaining it seemed the session from the section of Relaxing, under the name of SMR .Here only I can not understand whether it is suitable for alpha training?what's the frequency? And yet,you wrote that the average is selected 1-2 in life ,whether good is a choice if you take this session from the point of view of practicality? :)
Post by Андрей Патрушев » Tue Aug 22, 2017 0:58
Gleb
SMR - sensory motor rhythm provides the state of "body asleep, mind awake" - perfect for studying. The best course to study first the alpha rhythm sessions "r".
митек
Has thanked: 23 times
Been thanked: 15 times
Post by митек » Sun Sep 10, 2017 14:59
Started listening to ÌÍ2. As a righty. Prior to that, paused a month.
I must say that I was plagued the last weeks a lot of negative thoughts. My personal relationships have long stalled and I not in forces to resolve them.
But now after listening to 8 times feelings of hatred, resentment, etc. the feelings intensified, the reception significantly.
They increased significantly with each day of listening.
In fact, this condition for a long time, just greatly intensified everything. Old resentments began to surface.
I don't know whether to attribute it to the category of depression or not. Waves of rage are much stronger than usual.
After the outbreak finds sadness sadness. To cope with them became a lot more complicated. Sedona makes little EFT yourself hard to get and find quickly a place.
Actually I wanted to ask you, Andrew, is in order? to continue, pause or change the same headphones?
Maybe it's a side to the phenomenon? Today is not listened to as it seems easier. Maybe in a day to listen to? The effect will be?
Or maybe better to just leave till the best times and first to solve their problems.
But that would allow them to have confidence. I thought to raise. A vicious circle poluchaetsya.
Post by Андрей Патрушев » Mon Sep 11, 2017 1:05
митек wrote:But now after listening to 8 times feelings of hatred, resentment, etc. the feelings intensified, the reception significantly.
This is an adequate reaction during beta-stimulation.
митек wrote:I don't know whether to attribute it to the category of depression or not. Waves of rage are much stronger than usual.
No, depression is not true - depression is indifference.
митек wrote:Actually I wanted to ask you, Andrew, is in order? to continue, pause or change the same headphones?
This audio program is intended only for the purpose for which intended (see instructions). With psychological problems it does not help, but rather may exacerbate them. To resolve psychological problems indirectly, more suitable alpha waves (the Explorer and the Healing 1).
митек
Post by митек » Mon Sep 11, 2017 2:34
Thanks Andrew for the clarification!
That explains so much.
I recently beta program listened.
Post by Андрей Патрушев » Sun Sep 24, 2017 13:19
митек wrote:EFT yourself hard to get and find quickly a place.
Work secondary benefits: "What will happen if You get rid of this problem?"
митек
Post by митек » Mon Sep 25, 2017 12:29
Андрей Патрушев wrote:MiTek
There is, perhaps...
There is such a device LIRA-100 - that's it. Can be approximated by the book the Dominant factor
In fact, it is quite rare. When I worked with Leroy at the Institute of the interior Ministry (8 years), the 300 surveyed had 1-2 people with really inverted hemispheres, and another 20 people, with a strong functional bias.
Andrew! I reread the instructions and found here http://www.mindmachine.ru/photosonix/guide/10.htm about 25% of people inverted hemisphere. Now again thought...
Can you tell me where is my mistake?
Thank you
митек
Post by митек » Mon Sep 25, 2017 12:30
Thank you!
Post by Андрей Патрушев » Mon Sep 25, 2017 14:06
митек wrote:can you tell me where is my mistake?
Well, 20% is according to the literature, but personal experience I have another. Of course, you can write off all the specifics of the legal Institute. - There is a rigorous selection of pile tests. I suspect, that the majority of children with inverted hemispheres, they simply are not (as our entire civilization is focused on a normally organized right-handers).
алекккс
Has thanked: 3 times
Post by алекккс » Wed Feb 21, 2018 9:51
Андрей Патрушев wrote:All sessions in the firmware.
Reflash to version 2.00*, but I was in the Navigator there is no sessions if you believe the instructions should be in the folder "special" http://joxi.ru/52anj30iGpk19A
Can you tell me what could be the problem or where to download the complete set of all sessions.
Post by Андрей Патрушев » Wed Feb 21, 2018 10:34
Post by Андрей Патрушев » Wed Feb 21, 2018 10:40
Session to be combined with "suggestive material" (similar L03) - create combined sessions.
A_Hypnos alpha hypnosis. Better suited to different training programs - to develop something new, as it provides a connection with consciousness.
T-Hypnos - theta hypnosis. Better suited for working with deep structures with grievances, anger, shyness, a psychological trauma, etc.
Download link: https://cloud.mail.ru/public/Fzca/tAHDUx8Wz
