Oh, thanks a bunch! with such a detailed step-by-step clue for sure all interesting files discovered and even without risk for the Navigator now put it on chargeЛИЛИЯ-Р wrote:LILIYA-R
tell me, what kind of mp3 files stored in the Player - Normal?
Светочек wrote:tell me, what kind of mp3 files stored in the Player - Normal?
Navigator never ceases to amaze me with its functionality and convenience (prior to its acquisition earlier I had Innerpulse)ЛИЛИЯ-Р wrote:LILIYA-R
Most likely, You are trying to run audiostrobe not the player.Бауржан Танкеев wrote:Andrew, good day! mm Navigator does not launch the files in the folder "STROBE" ERROR: "invalid file type" tell me what to do.
Depends on the task glasses universal. In the General case the eyes are closed.ААААА wrote:1 wearing glasses and turning on the Navigator .....eyes closed or open should be?
Yes, it can happen with acute stress or post-traumatic stress disorder. Or eye disease. Try to set for the session in the most comfortable color.ААААА wrote:2 if the brightness level on low and uncomfortable ..the person from blinking what to do in this case or is it some sort of health problem and what to do?
To talk about the effectiveness of after not less than 15 sessions (days - any number of sessions in one day count one). In severe cases speech can go about three months....ААААА wrote:3 If performance is not particularly visible even after 5 sessions ...what's the problem is that not done?
To remove the brightness to zero and gradually add up to the appearance of clearly visible flicker (on the test signal (see manual), separately for each color).ААААА wrote:4 how to select a comfortable brightness points...
It's not me, and to Dmitry Shumova.ААААА wrote:Yesterday decided the first time to listen to the session OsozSno1 folder gate on the memory card. So after listening for some time been present in the mind of certain rhythms offhand 20-30Hz and still like modulirovannye amplitude 2-5 Hz ..) it's all feeling) ....and as if the indentation of the brain ...ie the first real time the effect of Machine...what rhythms and what aims do not tell ?
Excessive stimulation leads to inhibition. You have a high level of stress, seem to have passed already in distress. Most likely You need the second half of the day, perhaps even before going to sleep to do with the alpha relaxation. In the morning the second track of the Star Wanderer.ААААА wrote:forgot to ask then , but after making a Cup of coffee or tea just knocks as he wants to sleep and the eyes close-the-fly !) COFFEE and sleep like as it is not compatible,what is it ?.
No.ААААА wrote:AND may have been inattentive, but there is for sat-NAV session type Zrenie?
