BJ 2.1 / 2.2 / 2.4
Дядя Вадя
Re: БЖ2.1 reinforced "hard" version 2.0
Post by Дядя Вадя » Mon Oct 17, 2011 20:28
Michael_Boris
it was this observation that the module runs slowly and not instantly. like a kettle on the stove - boiling water immediately. start in advance is necessary. but the manifestation(brightness and clarity of the result) probably really depends on the owner.
oak should still double dose BJ. (IMHO)
Has thanked: 24 times
Been thanked: 142 times
Post by Маг.нет » Mon Oct 17, 2011 21:05
Modules BJ it is only a mechanism (algorithm), and working with this mechanism does the Operator itself (even on "autopilot"), bracelets, in addition to its other properties, can be a good help as well as a channel to the energy source, but the size of the potential (capacity, bandwidth) available for use, the property is not BJ, namely the Operator, although periodic replenishment+work (active use of the potential) can increase this capacity (capacity, free capacity). You can be able to get at least 30-fold dose (judging by experience), but "above head can not jump" (to borrow only to the extent of its capacity or a little more, gradually stretching "energy bubble", increasing capacity). Older versions of the BZ - channel wider (thicker wire), filling (charging) is faster, but the limit is the same as important and as "wires" and "battery" - the body of the Operator. Initially most of the potential of the BJ is paid exactly on the regenerative processes of the body, i.e. if you have something to restore, the Modules can stay a little (except for special cases maintain the security of the body).
Sincerely, MAG.no
Seonic
Post by Seonic » Wed Oct 26, 2011 4:41
Prompt pozh-that,whether there are functional differences "Bracelet of life 2.1 (tree)"from the "Bracelet of life 2.1 (ebony)" or is the difference only in "design"?
Борис_
Post by Борис_ » Wed Oct 26, 2011 9:11
Seonic wrote:Tell me please,is there any functional difference between "Bracelet of life 2.1 (tree)"from the "Bracelet of life 2.1 (ebony)" or is the difference only in "design"?
Functional differences can not be, except on black tree is a bit more powerful
Sunshine
Been thanked: 2 times
Post by Sunshine » Sat Oct 29, 2011 23:17
Today is exactly a month since I wear on my feet one BJ - 2.1 black wood and 2.0 turquoise. If someone still doubt about the "health" bracelet, it is only your personal suspiciousness. I wear them without removing (and generally afraid to take off due to the worsening of the situation in the world), first: I have had a stronger moral core, I became more calm, in-2: I was invited to work in Gazprom, in-3: color and happy, see a situation "from above" not emotionally involved in the fuss and negativity, b-4 IT sees and feels everything! Especially friends and relatives. Do not torture yourself, support your life! :ay
ММ
Has thanked: 185 times
Been thanked: 40 times
Post by ММ » Sun Oct 30, 2011 23:29
No, it's just a joke! Another maiden bloom and was super happy ( after the girl of Basil). Also on the work already in Gazprom settled. :wink: And it to wear only 2 of the BZ in a month :lol: :lol: And I burdock MM carry 4 pairs BJ 2.1 already since April 2011 and absolutely no results. None of the modules not working and still didn't work. None! Work daily with BJ , at, ISS-1 + a sticker on the computer. And where are the results? No suspiciousness do not suffer, do not torture yourself and support your life :ap
In General citizens are "lucky", "blooming" and "smelling" I don't believe you. And Michael could not believe it. I trust myself and my eyes.
АКВО
Post by АКВО » Sun Oct 30, 2011 23:50
Personally for me, everything works fine.
You are not forced to use these things, if you don't like something, turn and do not wrinkle anyone brains.
Борис_
Post by Борис_ » Mon Oct 31, 2011 10:00
MMWrite more about how and what goals were set - the view from the outside sometimes helps
stom
Post by stom » Mon Oct 31, 2011 10:43
One month ago happened the sudden failure of all types of alcohol. БЖ2.0 3 month. HF,SC,IIM-1,El 8mes.
Post by Михаил_ » Mon Oct 31, 2011 13:27
ММ wrote:No, it's just a joke! Another maiden bloom and was super happy ( after the girl of Basil). Also on the work already in Gazprom settled. :wink: And it to wear only 2 of the BZ in a month :lol: :lol: And I burdock MM carry 4 pairs BJ 2.1 already since April 2011 and absolutely no results. None of the modules not working and still didn't work. None! Work daily with BJ , at, ISS-1 + a sticker on the computer. And where are the results? No suspiciousness do not suffer, do not torture yourself and support your life :ap
1. No joke I see. At the same time you still do not believe for example a photo of Masterda, which captures completely the physical phenomena of water (the effect on the rate of evaporation and structuring of the added paint on geometry, as in others our own experiences noticeable effect on the water, which is still placebo no, exactly as in domestic plants and animals in the other cases). You are not forced to believe. As and buy. But other users are more than you :) So respect their right to result of expression. Otherwise, it mildly does not look nice.
2. It is obvious that the efficiency of the method depends on the person, its initial data and psychological portrait. However, it is rarely completely invisible. For example, when only two cases known to me of the "surrender" of the product ago, in one of them, people doubted the effectiveness of the products, but his sausage in the wrong direction. We long discussed with him in private why. I hinted at the fact that his chosen way of life is clearly somehow out of sync with the subconscious desires, he decided to take the product and leave everything as it was before. By the way he wrote once on the forum that on the second day after wearing 2.6 quit Smoking marijuana, although smoked for many years and throw not going.
So it is obvious that if the effect is weak, there are some reasons EXCEPT those which You yourself invented. This is not some magic wand from the films or the fantasy that one size fits all processes equally. Potential for early use and living conditions, personal power and psychology are all a little different. It would take too long to talk about it and give recommendations what can I change, but don't see the point if it can't see You. You are not forced to use. Please take the product back, get your money back and take it easy. But we respect the other.<
Post by Михаил_ » Mon Oct 31, 2011 13:35
I recently "internal" channels ordered S++. The person who ordered it, successful people, self-made without charge from zero to very good in our society positions in the media, and having other personal developments without BJ. That such a person has previously purchased the same 2.6 works as expected - like a tank. All the rest works TOO. But if the person expects efficiency as a neighbor, so, too, was a tank, and while he wants to sit on the ground, Oh.
All that I can now (and BJ I for myself use almost all of the line in different combinations), it is woven from many things. In one day recovered. However cases of abrupt changes I know a lot of fertile soil. Really don't know of any case that didn't work at all. The most ardent do not feel and believe, we tested for the 1 hour test when I sold "Lira-100" I a week took. Certified by the Ministry of health and diagnostic complex. Shows sharp differences after 1 hour, BJ.
One of these home and related pessimists who do not believe took 2.6 on a hike and then wrote a review about this wonderful rescue. The next extreme alloy 3.0 I gave him, the result was abuse, matuhi and almost curses upon return. Because alcohol is somehow bad compatible, the bracelet started to patch and all the power went to it - he fell asleep at the oars and team it almost nailed. Took off the bracelet and passed. Other manifestations were not.
Not all the people to dub with the same brush. This is not true.
Has thanked: 478 times
Been thanked: 264 times
Post by ЛИЛИЯ-Р » Mon Oct 31, 2011 14:22
Without advertising, you say. My daughter took my winter bracelet 3.0 Lite.,without the ++ .But the result of this. She is an accountant ,her salary was 20000. To raise and not going to. A lot of work ,little money. Wanted to leave work. 've learned from me about the bracelet and wore. Asked how to use but at first long didn't believe and laughed. Then he took off and scored.The past 3 months.A vacation coming up ,need the money.She again started to moan ,nachto to go ,salary delays. I asked her does she wear a bracelet ,when she again began to moan that not enough money. I asked her to try again, just to vilify him. A week passed ,she without waiting for the arrival home I wrote to the agent that her 5 thousand salary increased. A month passed ,she was again unhappy-leave is very close. Like the woman in the tale about the goldfish...Again began to work with the bracelet and then unsubscribe again I added another 5 thousand Left on vacation. Came a change of leadership.Her Chapter Boo gone and many from the firm. Because they do not have to add salary. New GL Boo .demanded for his slave -(daughter )of pribvate salary as a merger of the two firms. And she's only like 2 weeks ago added. The chief even laughed. But for the good. After 2 months my daughter up to this time -is not enough! And now Nov have 40.thousand. FIE,FIE not to jinx it. This is not fiction. In our office everybody knows about it. Because I regularly talked about the addition of daughter z of the Board.
Now, think for yourself....
I almost forgot,wouldn't it be right to say that when it always Svetlitsa Super.
Been thanked: 10 times
Post by Мастер 108 » Wed Nov 02, 2011 0:03
ЛИЛИЯ-Р wrote: I asked her does she wear a bracelet ,when she again began to moan that not enough money. I asked her to try again, just to vilify him. A week passed ,she without waiting for the arrival home I wrote to the agent that her 5 thousand salary increased.
She just was wearing or even what did, well, there is whispered what? And I wear the third month (2.0, 2.1, 3.0 N and Panacea), but with a salary all the way around - naked salary for the third month in a row :cry:
But everything else, in the sense of modules, it works more like - lower back hurts much less, almost gagged sucking one energy channel, well and so on trifles :ay
Someone tell me how to correct the situation with the finances bi ?
Post by bofara » Wed Nov 02, 2011 0:08
BJ 2.6, I think the fit is good for finances. If You do not, then P can be reprogrammed with the target - yeah, for a good purpose is a good affirmations here on the website and the forum.
And, Yes, You have, I think a good product type SP turned out... There is inserted affirmations?
Try P and 2.6 to wear separately, not together.
Михаил_ wrote:Yes, all true... 2.6 clearly implemented one as powerful.
It's on the panacea can be taken almost as powerful, but to include it without knowing it by experience - is more complicated.
Маг.нет wrote:the User will respond with an example.
In the "P" is not only 2.6 but 2.1, 2.5, 2.7, 2.8 and even a small addition that fills the gaps between the products. If we take the potential "P" for 100%, no further strengthening of "one of..." (mentally, but it is necessary as that to understand the "boundaries and rules" or "cybernetically", but this control device is still in the work), in this case, these 100% stretch" (split into sectors) between all ranges, somewhere more, somewhere less. Bracelet 2.x can "to release" 100% of their qualities (focus).
Example (stretching range - focus):
Charge 1.0 ("wet") take 100 % of the available range, then 1.0 L (matrix) reducing range (by allocating more aimed at health), increases the potential (corresponding to the needs that many feels like "stiffness", the power of which is higher, but only in this region) due to focusing in one area which gets more than 1.0 (wet).
Something like this...
Sincerely, MAG.no
Post by Михаил_ » Wed Nov 02, 2011 4:45
Master 108. You need to look reason well or larger. Just for some increase in the level of Finance it is an inner quest that you have to pass something changing in myself. Ie a conflict with himself in his subconscious. And for someone really in this place, no plugging, (which does not exclude those in the other) and just helping BJ on new potential easier to push its importance.
Here is the same Basil, writing a review for ISB-3. But he and IIM-2 and HELL, and Stabilizer and a large 3.0 S++.
All this is noticeable in his work. But. IIM-3 was significantly increased his potential ( and not only him). ie business flooded the hill and quickly the whole office.
And so many users - BJ (any, sometimes 1.0) triggers as a means for moving the bar (a pole, the ability to overcome the potential barrier).
Others have this plugging is of different nature. And they need to understand more deeply. As an option - good psychoanalyst or therapist may dig inside something that touches.... sometimes these bizarre and strange things are dug out, and in places where everything seems calm and "nothing could be" and there is some idiotic fear with the identities of sitting deep and conscious level not manifest itself. And it is subconscious. And when it hinders itself.. well, plenty of other options exist.
Post by Мастер 108 » Thu Nov 03, 2011 1:05
Михаил_ wrote: As option - a good psychoanalyst or therapist may dig inside something that touches.... sometimes these bizarre and strange things are dug out, and in places where everything seems calm and "nothing could be" and there is some idiotic fear from childhood, a deep-seated and conscious level not manifest itself. And it is subconscious. And when it hinders itself.. well, plenty of other options exist.
Oh, well, no, in our "village" a good psychoanalysts and psychotherapists :? Though without clear about that touches, when even the closest people is not something that is not praise, but on the contrary will not fail to belittle any success, any achievement :evil: And after their "kind" words not what lose heart, sometimes the formation lie the whole day (what will that bondage - all the same...). Though like plenty of plans, but just no strength for that...
As it is correct - I don't know. Yet, as the saying goes, manage to keep a zero balance. Something like that :(
Post by Михаил_ » Thu Nov 03, 2011 2:05
some psycho.... work via Skype, although this is not the best option (direct contact during the session undoubtedly more effective), I once brought a recommendation to this effect on their forum. If there is just a thought (mine) is, I know how professional quickly and more accurately allocate what you need to understand a specific person to "came" and it became clear where to change it. Often understanding and starts the process of change.
Generally, the situation is often such that the person is not synchronized in any way the task of self-realization and financial success. Ie it turns out that the success of this kind of duty (a close word - a burden), and self-actualization generally retracted where a=the 10th plan. Or something like that.
But it would be nice to match at least partially.
Борис_
Post by Борис_ » Thu Nov 03, 2011 10:14
Михаил_ wrote:Actually, the situation is often such that the person is not synchronized in any way the task of self-realization and financial success. Ie it turns out that the success of this kind of duty (a close word - a burden), and self-actualization generally retracted where a=the 10th plan.
That's exactly what it is, and it is not clear what to do with it...
Post by Михаил_ » Thu Nov 03, 2011 12:50
Psychology to revise their.
Post by bofara » Wed Nov 09, 2011 19:50
... Someone tell me how to correct the situation with the finances bi ?
SW. Master 108,
There is a positive development in Your problem?
Post by Мастер 108 » Fri Nov 11, 2011 22:07
bofara wrote: SW. Master 108,
A week ago there was a training for sales. Using the month view :? .
PS Bofara, thank you for your participation.
Post by bofara » Fri Nov 11, 2011 22:12
:ay
амарра
Post by амарра » Sat Nov 19, 2011 11:45
Wear 4 bracelet 2.1 (4 months). There are SK, IIM, Radionics.
after connecting to the system Radionics on washing SK resources, occurred a tangible gain of all devices.
At work we have to face a lot of dark aggressive people. The early part of negativity pierced the field. Now the pitch has become like rubber. It dampens the energy of negativity and mirroring back to the source of the feelings.
The last example. Negative phone conversation with a female partner. After 2 hours on the way home just fall asleep behind the wheel. There is a feeling of something foreign next to. Stop on the track, on the way to Moscow. Had to sleep in the car. After 30 minutes of sleep, Wake up and clean. Through the day this woman calls and says her car hit a ridiculous way at the gas station. From my side there was no comment, but she began to communicate with me, careful now, senses something.
But another question. Now bracelets I can only wear. On the hands and feet appeared red spots, imprint bracelets (right rectangles). I have the feeling that they are some accumulated negativity in yourself and can't self cleaned. There are options what to do? Whether cleaning with water, light, fire? Or just give them a break?
Post by Михаил_ » Sat Nov 19, 2011 12:14
амарра wrote: But another question. Now bracelets I can only wear. On the hands and feet appeared red spots, imprint bracelets (right rectangles). I have the feeling that they are some accumulated negativity in yourself and can't self cleaned. There are options what to do? Whether cleaning with water, light, fire? Or just give them a break?
questionyou all that in what they construct.
No, the bracelets do not can accumulate on itself the negative.
1) if the bracelets on the Crimean blanks (plain wood), then they would just start to dissolve the varnish (or the impregnation on the surface). This may be the reason.
2) if it is ebony, the reaction components of wood resin
and in that and in other case it is rather the fact of strengthening of work BJ (got used to and You have the potential increased possible). If 1) the inner part of the sand these can literally. if 2) the more useful will be the opposite - to cover what kind of wax.
In addition, the zone of high energy and tight fit can in itself give redness.
So the General advice is to change the place where dressed + possible wear on the sleeve top (if used on the feet to toe for example and not by him)
Post by Маг.нет » Sat Nov 19, 2011 12:15
In principle, the BZ can take negative as expansion joints, but that it accumulated in itself - was not observed. Such a reaction (redness, prints), in my opinion (Michael_ corrected), the result of removal of structural slag (remnants of the destroyed destructive elements after cleaning of the organism in this locality). I use bracelets of different versions is similar, if reversed, as the redness and the imprint are on the limbs where they were, but no new ones, and if this is the place to put the other bracelet of the same version, then see the continuation of this process (redness and prints), even if the material of the bracelet of another. BJ in this action (again this is in my opinion) more does not perform the function of collector-storage device (like a vacuum cleaner), and pumping station, which pulling on the destruction, spray it (sends it to the processing environment).
It is also possible, and the individual causes such a reaction.
Sincerely, MAG.no
