System extensions 2.0 Ah 2.0 with a base at
Re: System extension 2.0 Ah 2.0 with a base at
Post by Михаил_ » Sun Apr 21, 2013 3:26
no difference
Владмосква
Been thanked: 7 times
Post by Владмосква » Mon Apr 22, 2013 13:03
atuona, the situation is important only for these cards:
1) pairs of cards, "the Shield, Stop, broken ties": a pile - sleeping posted - active.
2) cards with "P-youth": the day left, day right (pockets) or shot-put (the shoes).
However "the Shield, Stop, broken ties" and "N-youth" are not Ax cards.
This is more for beginners so as not to confuse one card with the other.
Has thanked: 24 times
Been thanked: 142 times
Post by Маг.нет » Mon Apr 22, 2013 13:45
Владмосква wrote:atuona, the situation is important only for these cards:
1. it is not necessary that if a pile, then sleep post can and inside on the sides.
2. later Michael_ commented, so not necessarily.......
Sincerely, MAG.no 〠
Post by Михаил_ » Mon Apr 22, 2013 15:25
as you can and do not spread, but simply to give the command.
Кимили
Has thanked: 6 times
Post by Кимили » Mon Apr 22, 2013 21:00
yeah, thank you.
and...thank you!
good and beginners :) explain that the cards that are in the metal, Oh: travel, roads, humanity.
the feelings, when acquired, they earned even before its AT1.
the forum put everything in its place:) appeared at and ...a new power Ah.
Владмосква
Post by Владмосква » Tue Apr 23, 2013 9:15
"Companions" and "the Road" purchased for travel. But they also wear because transport use, not a machine.
From "the Road" on the first day a funny effect was due to a failure of the movement listened to the Manager of the subway in the first car on the radio. I have not heard and wanted. Well, I love to listen to them :) Crashing personally, I have not touched - to the place in time.
Petr99
Has thanked: 3 times
Been thanked: 15 times
Post by Petr99 » Wed Apr 24, 2013 6:17
Михаил_ wrote:as you can and do not spread, but simply to give the command.
And be sure to keep in the field the cocoon? efficiency is influenced by? Thank you.
Post by Маг.нет » Wed Apr 24, 2013 7:00
.......in the field the cocoon in collaboration with the working structure involved more "points of engagement" rather than remotely.
ie work (interaction with Product) is performed simultaneously for a large number of parameters is multidimensional and saving a resource that is used to maintain the health of the principles of remote interactions, although will work remotely.
Sincerely, MAG.no 〠
Пианистка
Has thanked: 10 times
Post by Пианистка » Fri Apr 26, 2013 22:47
today I received the AT2 and the Keys and doors - the impression is very interesting :D
one as is the Keys and doors? I have the key "special" - a large, and very large bunch of keys and tried key to put together with the thumb in a bag - but he gets out I'm afraid he'll hurt the stick. You can keep the FOB in the pouch and the key on the bunch? or is it better that they are together in the bag were?
Post by Маг.нет » Fri Apr 26, 2013 22:55
It all depends on You....... the key is the consciousness of "materialistic perception" of use of mental qualities (meanings) associated with the relevant ideas, no matter where the key is, the structure in the key FOB. Good choice!
Sincerely, MAG.no 〠
Пианистка
Post by Пианистка » Fri Apr 26, 2013 23:12
MAG.nothanks , you explain everything very well :)
Владмосква
Post by Владмосква » Sat Apr 27, 2013 2:09
Report on "Roads and transport":
come down to the station with a transplant, the station is Packed, the train is empty - ready for circulation by the arrow due to an emergency ahead, the timer is reset - i.e. there is no movement for 20 minutes already. We approach the train runs past the driver and shouted to everyone "get on the train!". The turnover of his Manager canceled, traffic resumed.
In the end, I even minute lost, and escaped the fate to get home by bus.
AW blew for time of emergency and me sliding something somewhere.
Michael, thank you very much for useful everyday items!
Владмосква
I'm afraid that he'll hurt keychain
the keychain is easier to hurt the situation than the subject. If the voltage will create a situation, then it and the 7 quilts will not save.
Владмосква
Post by Владмосква » Sat Apr 27, 2013 18:29
Report on product "the travellers" svejesobranna:
subway friend met along the way talked, went in the same direction. The product works at 100, driving on the road with the right people.
Кимили
Post by Кимили » Sun Apr 28, 2013 1:45
interesting resonance to the described by me three cards:)
interesting( sorry for the repetition, b.m. to enhance the "interesting":)), but has anyone tried to give the COMMAND/S cards?
to meet with a specific person, on ...an easy way to a specific place( make clear the location-goal)?
the order for "fellow travelers" with the given compliance settings?
companions in the physical road(or "companions" in any.
and, perhaps, by "humanity" comments - suggestions - experience is respected BJ-colleagues? :)
or Michael time and inspiration to share?
thank you.
Post by Михаил_ » Sun Apr 28, 2013 5:09
all cards have a functional algorithm for the KO, and Ko is the basic properties, such as adaptability, programmability, and collaborative work with other products, etc. So everything is possible and each individual.
СтАвР
Post by СтАвР » Tue Apr 30, 2013 23:49
Michael, and what if anything water the crust will be based on humanity, travel, etc. and Svetlitsa
with Svetlitsa super, benefits, conflictana be?
like should not, but to clarify is
Владмосква
Post by Владмосква » Thu May 16, 2013 14:20
Stavr
1) conflicts with the parlor will not. But on each chamber to put the "Panacea without software or Flashca to be Embedded in the overall system".
2) cards, developed by Michael are not in conflict and can be worn in any configuration.
Владмосква
Post by Владмосква » Fri May 31, 2013 13:23
Keychain AD cracked so major, in three places. Never beat him. With the official structures did not swear.
Probably took something serious at work (big organization), or somewhere else.
Oh, it's time for stickers to go!
Has thanked: 478 times
Been thanked: 264 times
Post by ЛИЛИЯ-Р » Fri May 31, 2013 14:06
Chatter around the world passed)))))Have cracked many of the friends and members of the forum))))))it's Time to work on all the stabilization or harmonization. Not personal needs exclusively.
Post by bofara » Fri May 31, 2013 14:28
ЛИЛИЯ-Р wrote:it's Time to work on all the stabilization or harmonize
Overlay image still proved its effectiveness. But I think that it is necessary to take into account some inertia in this case. For example, if you want to "secure" a place with "tablet" and "probiotic" - type antigripp - it is advisable to make at least a few months ago. It's only for example.
This of course required a good hygiene of the thinking and the behavior of the operator at least during the "operation." :?
Владмосква
Post by Владмосква » Sun Jun 02, 2013 23:26
Keychain AD cracked is even the case, as it turned out. Right isabelino harmonization of production processes! No details - too personal. But very positive! :)
Has thanked: 112 times
Been thanked: 71 times
Post by АндрейКо » Wed Sep 25, 2013 17:16
Yes, the world is becoming more plastic...
Just a printout on a laser flower garden at the phone...
(on one side what looks like a man...)
A couple of people can't get through to my cell phone... (at work...)
They no message arrives (the caller appeared on the network should be... the service of blocking unwanted callers is disabled for both the operator and the phone...)
On a conscious level I was almost all the same, but the subconscious does not want such calls :wiz ...
He can call :)
The situation is so stable for a month already...
(maybe is 5 percent of calls to me no more...)
PS - Just today I complained about it 2 people at the same time...
(and I call these people with different phones - same result, all other through without any problems. Just iron these things difficult to implement...)
Галкина
Post by Галкина » Wed Sep 25, 2013 17:43
АндрейКо wrote: PS - Just today I complained about it 2 people at the same time...
A similar situation in the last 2 weeks. Me to very selectively cut off all the relatives, also regardless of the phone the call. They ringing, but to me, no calls comes.
All poobeshali that I not only did not answer, then another, and no call back :)
And all the other people that are not part of my family, well through without any hindrances.
Магистр
Post by Магистр » Wed Sep 25, 2013 18:18
АндрейКо wrote:Just a printout on a laser flower garden at the phone...
It is homemade?
