manufacturer BJ 3.0 N
Распартаченый Торчок
Re: making 3.0 BJ N
Post by Распартаченый Торчок » Sun Mar 24, 2013 17:11
a change in the structure of the carrier material due to the shift.
Interesting...But what else acts this way,well, change the structure of the material,due to the shift?Or We have is just that...
Has thanked: 24 times
Been thanked: 142 times
Re: making 3.0 BJ N
Post by Маг.нет » Sun Mar 24, 2013 17:30
I do not think that correctly understood a question, if you need an example of a phase shift to understanding in the physics of the transition of a substance from one aggregate state to another, the same "Python" to solder, the metal melted (changed aggregate state from solid to liquid), and then it froze (again change state from liquid to solid) the structure of metals before melting and after can vary, especially if the conditions during solidification "special", well it is not exactly a generalization specific to 3.0 charging technology 3.0 N is solved in software. There is another puzzle of the same mosaic (again does not apply directly to 3.0, and describes one of the properties TO his ability to phase shift in "another world") message Mihaila. Maybe the question You meant another?
Sincerely, MAG.no 〠
Re: making 3.0 BJ N
Post by Распартаченый Торчок » Sun Mar 24, 2013 17:54
MAG.no I meant, what else can produce this "phase shift"(decided by software) structure of the subject and in what "region" :) ?Or until there's only "area of 3.0" and the corresponding phase shift...
Re: making 3.0 BJ N
Post by Маг.нет » Sun Mar 24, 2013 18:00
Yes there is "scope 3.0" - external (otherwise) as in relation to our World, and 3.0 is enough.......
Sincerely, MAG.no 〠
Re: making 3.0 BJ N
Post by Распартаченый Торчок » Sun Mar 24, 2013 18:06
MAG.no Gegere Bugulma=Thank You Very Much :o
Андрей.В
Re: making 3.0 BJ N
Post by Андрей.В » Tue May 07, 2013 7:56
Маг.нет wrote:Michael_ wrote(a):
charging version done
in file three of the mandala.
4 hours or more (up to 2 days) first is a base, the base state, instead of cleaning.
same - the second is actually 3.0
then again the same third - there is a matrix describing 3.0
then all 3 but in this order - inside second, then a third, outside - the first.
all 4 stages to wrap up the mandala which wrapped bracelet with foil.
additional reinforcement - the use of audio or audio through the Amplifier.
It is not clear how to do it all. Is there a good example of how this is done ?
Re: making 3.0 BJ N
Post by Маг.нет » Tue May 07, 2013 11:00
What is meant by "a good example"? How wrap the item (bracelet) to a paper (Mandala) and foil, and then expand and wrap to another? And then the third? And finally how wrap bracelet in a sequence turns in the second, third, first Mandala and folds in the foil? But if you wish to add efficiency, how to place within the convolution next to the bracelet and headphones to enable playback of the audio track? And maybe how time of realization of the stages of the process? Don't understand.......
Any "how"the answer is - as You prefer!
Sincerely, MAG.no 〠
Андрей.В
Re: making 3.0 BJ N
Post by Андрей.В » Mon Jun 17, 2013 14:28
Printed in the salon three pattern. As they wanted to understand what it means :lol:
I noticed that on the A4 sheet where Latin.. there is no in each line the first letter. To reprint or go?
Re: making 3.0 BJ N
Post by Маг.нет » Mon Jun 17, 2013 15:20
optimal when it matches the original, but "cut copy" like that will work
Sincerely, MAG.no 〠
Андрей.В
Re: making 3.0 BJ N
Post by Андрей.В » Tue Jun 18, 2013 16:20
Audio ran through all the steps and here is it's done at the last stage. I'm so screwed up? :shock:
Re: making 3.0 BJ N
Post by Маг.нет » Tue Jun 18, 2013 17:20
it is optimal to replicate the technology - guaranteed results, to spoil do not spoil, but it is better to repeat the described scheme order
Sincerely, MAG.no 〠
Хастред
Re: making 3.0 BJ N
Post by Хастред » Thu Jul 11, 2013 1:35
Tell these invisible simboli on the 2nd and 3rd sheet in PDF file 3.0 for charging is needed, or they are there just so zatusovalis? Simboli perfectly clear if importeres document in Corel.
Re: making 3.0 BJ N
Post by bofara » Thu Jul 11, 2013 10:00
Don't even remember how many times "imported" in Corel that file when engaged etimi pieces. Never were such "characters".
Хастред
Re: making 3.0 BJ N
Post by Хастред » Thu Jul 11, 2013 10:06
You just have to go to view/wireframe (this is a contour mode), simboli lie above the picture completely discolored
Re: making 3.0 BJ N
Post by bofara » Thu Jul 11, 2013 10:18
Хастред wrote:simboli lie above the picture completely discolored
Yes, they are. :shock: It's the scanning that document, or some other reason ... Similar to these characters from the PC.
Re: making 3.0 BJ N
Post by Маг.нет » Thu Jul 11, 2013 10:45
Any correction of the "1 copy" (provided Mihailom) reduces the density when print with the original (primary Mandala).
So everything is all in place....... and it doesn't matter on purpose or accidentally, it is so, it is workable.
Sincerely, MAG.no 〠
Re: making 3.0 BJ N
Post by bofara » Thu Jul 11, 2013 12:00
Some, like Druid, wrote, by the way, what did work artifacts 3.0 using the laser burning out, it is through the preliminary computer processing of the mandala /homemade/.
фФрост
Re: making 3.0 BJ N
Post by фФрост » Fri Jul 12, 2013 2:49
Guys, tell me please.
1. You can do 3.0 N 2.0 (which is made of the System of "1копия" 2.0)?
2. I have the 3.0 N is ready, but it was made into a regular bracelet (not BJ). You can for example paste it on the System "1копия" 2.0, and then again to charge at 3.0 N? - all this in order to be screwed.
Re: making 3.0 BJ N
Post by Маг.нет » Fri Jul 12, 2013 6:50
TO (2.0) to 3.0 N is useful for optimizing the charging process, into the final product it malorealno (a jammed structure 3.0).
1. you can;
2. product 3.0 2.0 system may not recharge correctly.
Sincerely, MAG.no 〠
фФрост
Re: making 3.0 BJ N
Post by фФрост » Fri Jul 12, 2013 11:32
Thank You, MAG.no!
лексветер
Re: making 3.0 BJ N
Post by лексветер » Tue Mar 25, 2014 15:38
good health! prompt who knows why these pictures, these tracks are what M suggested that they contain, from whom and under what circumstances. why not invest in a painted image, picture personal intention, personal energy, etc and also in the audio track :? as I understand M. someone or rather something what a certain essence through the method of channelling dictates how and that is through emotions, feelings, thoughts, and what is most important and what hidden goals and intentions are dictated by unclear :? don't like nedogovorok like believe take try, why so little info is given to the process of recording the application info on the subject, in General, business clear that business dark :)
Валерич
Re: making 3.0 BJ N
Post by Валерич » Tue Mar 25, 2014 23:40
Маг.нет wrote: and it doesn't matter on purpose or accidentally, it is so, it is workable.
Tell me, please, is it possible thus to charge the pendant, or does it have to be a bracelet? And if a bracelet - what material is preferable?
Thank you.
Андреас
Re: making 3.0 BJ N
Post by Андреас » Wed Oct 08, 2014 3:45
Explain to me to have somebody. What I read can not understand. When charging 3.0 N you can use a simple disc or as in the case of 3.0 L for the full functionality you need to make 2.0?? In other words, whether TO while charging simple blanks system 3.0 N??
Владмосква
Been thanked: 7 times
Re: making 3.0 BJ N
Post by Владмосква » Wed Oct 08, 2014 8:32
Michael wrote:
charging system 3.0 N - full, it generates 3.0 TO, but it's DIFFERENT FOR 2.0, so actually it is still something to take into a preset.
ie the usual blanks TO be.
Андреас
Re: making 3.0 BJ N
Post by Андреас » Wed Oct 08, 2014 11:37
Thank you! What I wanted to know.
