First impressions
Александр_
Post by Александр_ » Mon Jul 16, 2007 20:14
Андрей Патрушев wrote:
Dimas wrote:
Александр_ wrote:please Advise how to disable digital mode.
Well, if you did not include on purpose,the machine works in sinusoidale mode...
Depends on the car... :P
All these gadgets are only Innerpulse. In any other case it is not necessary to be upset, because we are talking only about what is best. With Rectangular signals it is also quite affordable. I have dozens of people at the Institute is experienced on Nova Pro.
Hurray !!
I'm a happy owner of innerpulse.
be so kind - how is it done ?
Pavel
Post by Pavel » Tue Jul 17, 2007 0:10
Александр_ wrote:would you be so kind - how is it done ?
The guys From Section Distribution Innerpulse in Russia (PIRIR) is another client ready to go. :mrgreen:
Post by Андрей Патрушев » Tue Jul 17, 2007 0:23
Dimas wrote: Well, if you did not include on purpose,the machine works in sinusoidale mode...
Hurray !!
See here: http://www.mindmachine.ru/viewtopic.php?t=926
Евгений Кош
Has thanked: 2 times
Been thanked: 2 times
Post by Евгений Кош » Tue Jul 17, 2007 12:49
Андрей Патрушев wrote: When reaching a sufficiently stable alpha state in everyday life, a complete normalization of sleep, you can start meditation sessions with the advantage of theta frequencies. This will help in further work in the transformation of the personal complexes and getting rid of diverse fears. But I warn you once, unlike alpha theta - this is not a pleasant pastime (either immediately or later). All the negativity will be activated through a conscious integration process...
Green is not necessarily associated with the alpha frequencies.
Yes, by yourself notice that a month ago, I was more receptive to the negative(fatigue) from moving and a change of scenery than it is now.. 2 weeks was on vacation, moved around a lot (even managed to Demos call in to work, socialize and buy Colortrak:) ).
On vacation tried 1 times theta concentration ( I have a situation at work that want to solve).. In General, the clatter in my ears - nothing nebylo... focused on the situation.. but - nothing.. not before not after.. and not clear.. I have the feeling that just sat and listened..
Post by Dimas » Tue Jul 17, 2007 13:10
Евгений Кош wrote:[In General, the clatter in my ears - nothing nebylo... focused on the situation.. but - nothing.. not before not after.. and not clear.. I have the feeling that just sat and listened..
Eugene,perhaps You are too much concentrated?!And try the same disk,just on the contrary,did not think,or slightly to think about the situation,not getting involved emotionally...!Write feelings..Yes,make the sound louder,only to komfortnogo level.
Post by Андрей Патрушев » Tue Jul 17, 2007 14:22
Theta concentration is not the concentration that You need at work (a disk Ultramesh. Theta concentration is intended for meditation on the point on the mandala, the mantra, on the breath, on the steps...
Евгений Кош
Post by Евгений Кош » Tue Jul 17, 2007 15:36
Андрей Патрушев wrote: Theta concentration is not the concentration that You need at work (a disk Ultramesh. Theta concentration is intended for meditation on the point on the mandala, the mantra, on the breath, on the steps...
I wasn't focusing on workplace and not on work..
just the situation is working on that you have not found the answer.
This house, settled in a sitting position, focused ( so to speak) on the problem and has cut a theta concentration, waiting for any signals and hints from the subconscious about the solution to this question..
PS, Your "tip" on the forum, bought the book "the Sedona Method", it seems that "working" the issues can be solved by a similar method.
Развивающийся
Post by Развивающийся » Wed Jul 18, 2007 22:10
Андрей Патрушев wrote:When reaching a sufficiently stable alpha state in everyday life, a complete normalization of sleep, you can start meditation sessions with the advantage of theta frequencies. This will help in further work in the transformation of the personal complexes and getting rid of diverse fears. But I warn you once, unlike alpha theta - this is not a pleasant pastime (either immediately or later). All the negativity will be activated through a conscious integration process...
That is, normalization of sleep, is a signal for switching to the different frequency or the same again, all the feelings?
Andrey, tell me, a break in the work with the machine are needed, including after a course of alpha frequencies?
If Yes, how many?
Развивающийся
Post by Развивающийся » Wed Jul 18, 2007 22:28
Still can not understand what is associated with what and is?
A couple of days ago began to appear boils on the skin, similar to colds... first on the head (nape), then spin (small plot) now and legs began to appear, but not very much (never a problem with it was not). What would it be?
Only deal with I02 (evening) and Conductor (morning). Drink more water 2.5-3 liters per day.
Whether there was at whom something similar?
Влад
Post by Влад » Wed Jul 18, 2007 23:09
Pavel wrote about this in the topic solar Wind.
http://www.mindmachine.ru/viewtopic.php ... 0%FB%E2%FB
Pavel
Post by Pavel » Wed Jul 18, 2007 23:41
Developing
it's so out toxins. Just in my childhood and now, perhaps, you are stuffed/stuffed with all sorts of medicines, chemicals. Just drink water and go to warm up: warm baths, warm sauna, warm bath. Try without overheating. Then the capillaries on the skin dilate and all the toxins and all the chemicals, accumulated over the years begins to go faster through the skin and the organism is rapidly cleared. You can use and Golden mustache, as already mentioned. But only him is also to be careful, if too often to use it, the boils will begin to harden beneath him and the body will begin to "scream" that hurt him in that place, and that it should be removed.
By the way, I still have abscesses appear, but only on the back - and only much less than before. The body cleaned and it should help in this wonderful cause.
Post by Андрей Патрушев » Thu Jul 19, 2007 2:47
Yes, Sedona method works great.
But for creative problem solving you must do just the contrary, with de-concentration. :P
You can also theta-hypnosis, after giving the job to podsoznanie: "While I rest, listening to the program, please to solve this (what) the problem the best way for me".
Евгений Кош
Post by Евгений Кош » Thu Jul 19, 2007 10:31
Pavel wrote:Growing
Quite adhere to the same opinion.
I really love this beginning to happen even before meeting mindmachine.. as soon as he began to temper the body and the right to drink water in the first months of wypasanie abscesses - just surprised me.. was beginning to think maybe somewhere constantly in contact with the infection.. but I went through Malakhov and realized that it's the toxins knocked this way out of the body:) Oh, and incidentally - the body received a charge of vivacity from hardening - has raised the bar of immunity.. all hidden in the body "cloaca" dormant savings stafilokkov began to be ejected and inflamed.. I have had very deep and painful inflammation.. including on my face (ugh.. when I remember).. It all gradually goes away in 2-5 months ( probably depends on the stage of neglect in the accumulation of toxins)..
Now almost nothing.. if that will jump (the standard everyone sometimes jumps something) then just apply a compress of timescale (1 to 3 water) for 40 minutes per day ( deep sores), and usually in 3-4 days, nothing remains..(it is better certainly to help the body in this way, not to increase inflammation and increase metabolism in the area of the boil).. and of course - if in doubt, it is certainly better to see the doctor.. let's see.. maybe some will have to open.. on my priest at the beginning was such a popped deep and sick.. - right leg dragged so sick.. and the temperature is small.. but the doctors thought that opening will not be long.. I left him.. with a couple of weeks. In General all the accumulated toxins (I personally) painlessly don't want to go, be patient :)
Евгений Кош
Post by Евгений Кош » Thu Jul 19, 2007 10:35
Андрей Патрушев wrote: But for creative problem solving you must do just the contrary, with de-concentration. :P
Thanks, I understand now.
Now I know one more goal :) - to learn how to formulate the task as concisely, logically, and concisely as You (to start) :))
Развивающийся
Post by Развивающийся » Fri Jul 20, 2007 23:00
Pavel wrote:Growing
Now I understand what's going on....
I remember reading on the forum about a similar situation...but to compare did not think there it was on the CD "solar wind", and everything is interconnected and wheels and water one brain clears, and a different body...
Феникс
Post by Феникс » Sun Jul 29, 2007 21:24
In some branch Pavel and Dimas have already described a similar experience...
Now it's my time: Eleven days of listening to "Explorer", all the signs of incipient tonsillitis, and for no apparent reason, like out of the blue... :roll: :wink: However...
Сперанца
Post by Сперанца » Sun Jul 29, 2007 23:05
Phoenix
Can holodnenkoy like to drink? :wink:
I start Explorer tomorrow before going to bed:)
Today poprobyval first session of meditation. Thought I would die. The session time was reduced to 17 minutes.
If alpha was the ease small tingling. Then just like needles pricked the limbs and WHISKEY!
And as if the chest was a large plate, breathing was particularly difficult. A couple of times even stopped breathing :shock:
Is this normal?
Post by Dimas » Mon Jul 30, 2007 13:11
Speranza
Speranza,please be careful,we need You alive!!! :P :wink: Water drinking??try to ignore the kinesthetic sensations of Your limbs!Focus your attention on the breath, not forced, it's easy..Just try to enjoy the process-inhale and exhale...Feel how the air passes through the nose,through the larynx...What is air?Whether dry,moist,what he is like if he goes through way?As it fills Your lungs,maybe he's like a whirlwind swirls inside Your easy,and can smoothly goes down and lies like fog?...etc.
Try. :roll:
Путешественник
Post by Путешественник » Tue Jul 31, 2007 23:40
Today I arrived InerPulse c ColorTrack glasses. Immediately evident how the device was Packed by the sender. The packaging was very reliable, and so customized to what is within that accidentally destroying the device during transport would have to manage. Taking and expanding the contents, I immediately decided to proceed with the test. The first test device was a great success. To start with, I put r03 meditation. Noted that the sound is quite decent quality. Headphones among headphones of the middle class, also sound good. On them it is possible to even listen to music on consumer equipment (and especially for our purposes will go differently, if the bottom isn't getting). Literally through ten-fifteen seconds pavelis such a simple visual c aggravating. It should be noted that the ColorTrack glasses are indeed very good, the colors are just great, the intensity is decent (don't understand those who say that they are not bright), I even turned it on themselves glasses :). Tracking mode, however, I'm immediately turned off (it is sometimes wrong and does not phase transitions), but if anyone wants to use it as entertainment, that I think it's even like it. By the end of the session there was an interesting a state of mind. After the whole day peacefully slept (good that holiday:)), striving to achieve WTO was not, so sleep was quite normal. In the evening we checked how the car behaves with AudioStrobe signal. Sensitivity he was good, much better than with a homemade decoder:). For a long time did not check, there and so all is clear. But found the manual mode. This is the mode I am just very pleased with the fact that it is very easy to control and all functions are available. To study the effects of feedback on frequency and storing the altered States of consciousness, with the purpose of easy entry into any of them (and modulation quadrupeds) without the aid of apparatus, this mode is simply irreplaceable. It remains only to program (this feature I haven't checked) machine to the new session, which will be effective for me, and can be used to explore the deep state.
Well, here's all the results of the first test. Have not noticed any deficiencies that would not have been discussed on the forum in the decision-making process about the acquisition. So I got exactly what expected :). In General I liked the device, I hope will last a long time.
Pavel
Post by Pavel » Tue Jul 31, 2007 23:58
Путешественник wrote:it Should be noted that the ColorTrack glasses are indeed very good, the colors are just great, the intensity is decent (don't understand those who say that they are not bright), I even turned it on themselves with glasses Smile
for someone like. It seems to me that they have become much darker since the acquisition. :roll:
Путешественник
Post by Путешественник » Wed Aug 01, 2007 0:10
The LEDs did not seem to have a tendency to fade as the phosphor :roll: . Maybe a button the intensity is poke, if by chance the setting hit? And I can really only think?
In any case, time will tell...
Алексей А
Post by Алексей А » Wed Aug 01, 2007 0:26
Pavel wrote:for someone like. It seems to me that they have become much darker since the acquisition
And how much time has passed since the acquisition?
Pavel
Post by Pavel » Wed Aug 01, 2007 0:34
Alex And
the Traveler
You guys should read the topics about why the brightness of points in the users mind-machines falls over time.
It's simple, if you think that the brightness of colorica at the maximum for you too nasty and too high, it is an objective indicator of whether you have huge layers of stress.
Евгений Кош
Post by Евгений Кош » Wed Aug 01, 2007 9:00
Pavel wrote:Alex And
the Traveler
Most likely is an objective indicator of individual sensitivity and nothing more.. and the objectivity of the diagnosis "huge layers of stress" only in reaction to the brightness of colortree - not only of doubt but of confidence in the complete lack of objectivity.. because there is a 50/50 shot.. or there is stress or not :)))
Путешественник
Post by Путешественник » Thu Aug 02, 2007 0:23
Stress there is no doubt from lack of sleep :)but what about the fact that its the brightness of LEDs can be defined not so sure. Although there is Luscher test (a mental state is determined by the preferred color), maybe one can make such a conclusion...
