PSYLERON
Check the connection between human consciousness and physical world
Has thanked: 125 times
Been thanked: 263 times
Re: PSYLERON
Post by Шалтай Балтай » Sun Nov 27, 2016 1:25
same for simultaneous:
Code: Select all
$ ./psy-test.exe out-10Sec-sync.dat
iNewSources: 1
There had been found 1 Psylerons connected
0) Name:"RGZD378" Type:"REG1"
Selecting Psyleron with #0 as a source
Writing to file: 'out-10Sec-sync.dat'
Cnt: 27; k = 100.00%
$ ./psy-test.exe out-30Sec-sync.dat
iNewSources: 1
Writing to file: 'out-30Sec-sync.dat'
Cnt: 81; k = 100.00%
Code: Select all
 0 Nov 27 00:21 .
 0 Nov 21 14:10 ..
 46 Nov 21 14:10 Makefile
 2700 Nov 27 00:21 out-10Sec-sync.dat
 2676 Nov 26 01:54 out-10Sec.dat
 8100 Nov 27 00:22 out-30Sec-sync.dat
 7952 Nov 26 02:00 out-30Sec.dat
 8117 Nov 26 02:03 out-30Sec.zip
 2213 Nov 27 00:21 psy-test.c
 17763 Nov 27 00:21 psy-test.exe
 4081 Nov 27 00:21 psy-test.o
that forehead that forehead :?
but to our shore sho will beat all cod
Re: PSYLERON
Post by Шалтай Балтай » Fri Dec 02, 2016 11:35
Sdalat sample per 1Мгб, stood an hour :(
UNT
Code: Select all
$ ./ent ent-116111.dat
Entropy = 7.999813 bits per byte.
Optimum compression would reduce the size
of this 1007616 byte file by 0 percent.
Chi square distribution for samples 260.91 is 1007616, and randomly
would exceed this value 38.63 percent of the times.
Arithmetic mean value of data bytes is 127.4715 (127.5 = random).
Monte Carlo value for Pi is 3.140910823 (error of 0.02 percent).
Serial correlation coefficient is -0.001369 (totally uncorrelated = 0.0).
well, like the rules.
what is really strange is the fact that the distribution does not look normal, triangular some:
:shock:
may I th screwed up.....
Re: PSYLERON
Post by Шалтай Балтай » Fri Dec 02, 2016 12:30
and not, like the rules:
just the boundary conditions hard patched :oops:
Re: PSYLERON
Post by Шалтай Балтай » Tue Apr 11, 2017 10:33
well, actually, came to me TrueRNG really even about. play. great toy. under Linux is put on hurrah. installation - just copy the files from the archive. No passwords, keys, and other on-mozh sick of crazy crap from the 90s. Size - exactly half crazy. performance - exactly 1,000 times more (in a thousand. 2Кбот against 2МБот), antropine tests - gut. gnucci the demon is not set, so the rules.
conclusion: the psycho is just some izdevatelstvo over common blotted, I'm sorry.
if it is who NAT - take it from here, Stoll: https://en.wikipedia.org/wiki/Compariso ... generators
rush is just not, many do not understand what it is and what to do with it. so shake off here sucks, like crazy, sorry.
good luck
PS
is there a toy, RNG on optics, uuuh. vesch! Well, the price he... 3килоТугрикофф.... hautecouture! :oops:
Миртова
Post by Миртова » Fri Dec 15, 2017 21:25
Good day to all!
Buy psyleron used, profitable. bc
If interested -
email: mirler@mail.ru,
phone: 89166071680,
Valeria
Has thanked: 2 times
Been thanked: 21 times
Re: PSYLERON
Post by Логик » Sat Dec 16, 2017 15:23
Myrtle
Wrote you a PM.
ВасилийИванов
Re: PSYLERON
Post by ВасилийИванов » Sun May 13, 2018 7:11
Welcome!
Buy psyleron used or new.
Write suggestions on mail:
do_boogaloo@mail.ru
Психиатр
PSYLERON
Post by Психиатр » Sun May 26, 2019 1:17
Hello. Really need psyleron!
Work with large groups of people (150 or more people), want to explore the possibility of coherent interaction of people in altered States of consciousness, and the influence of large groups on a random number generator. Buy Your psyleron or rent for a while. Really need help mates!!!
89266137794
easydrums@yandex.ru
