Small offtopic.
Been thanked: 2 times
Re: Small off-topic.
Post by ЗОМБИ » Tue Jul 01, 2014 13:51
Bubeev said that the installation for xenon, you can collect from b/y components for devices for anesthesia, but it should at least know what and where to buy... I don't think "xenon installation with your own hands" splitsaw the right way... although you can look
if you suddenly come across a manual "do it yourself" for the xenon, please throw the info, very useful
breathing exercises can then be described, if there is interest
I understand that it is easier to combine running with xenon therapy in the initial phase, not to produce mitochondria or not?
Post by Михаил_ » Tue Jul 01, 2014 14:21
Who Bubeev?
Why b/y components ? buy a new one in medinstrumenti - they're pennies worth....
why manual? go to the same pipchenko and carefully consider all :) however, it is possible to look video on YouTube with the same publicity STUCKEY.
Any techie will quickly understand everything....
Money really is a device for control of oxygen.
You can take St. Petersburg, avsoft (if not a full sensor and only oxygen will be 24 thousand)
and you can take Zelenograd cheaper (will be about 11tys)
reducer-oxygen (medical aka technical) fit the same as everywhere else (they are medical and technical) and everywhere suitable oxygen - the difference in the color of the body.
Need hoses, rubber breathing bag (you can buy in medinstrumenti, but you can on eBay, in addition to their medical else bdsm schiki use and therefore the proposal is not only in the medical branch)
valve and jar for soda lime (as soda lime absorber of CO2 in the mixture when breathing in a closed circuit)
The same atom-med center sells a simple circuit recycling of gas (without CO2 removal) for rapid anesthesia for 150 thousand (there's only the cylinders of the gear and tube - breathing circuit is 1000-1500P new), the cost can estimate.
Their machines АКТ1-2 and MAGI - just to consider the costs of gas and have a convenient handle for adjustment. It for 500 thousand
Equipment such STACKS is well shown in the video on the tube - it is clear that what is.... and I'm not sure what the detector is included in the price (it is 97 in the full set, the one with the channel on the xenon, not obyazatelno but useful, you can just oxygen control).
All these medpribory very good for medical centers, for legal purposes therapy... but for homebrew need brains.... how to tell acommidate some coaches of the national teams (where he used xenotilapia) managed to die because of the double safety violations, for herself, turning a gas mask on, the mask was secured with a rubber band caused a complete anesthesia without oxygen supply (idiots not put the number even after that).
Really, thank you Pipchenko, it is convenient to use the mask (don't even need to use a mask!) a mouthpiece, or just the phone as is (removed mask) or a special honey mouthpiece (worth 50p) - the mask gives the leak when you loose contact and the inside of the mask the volume of emission.
Says Pipchenko - shave should be very good if you want a mask.
Easier mouthpiece (that's not diving and the pipe round as it is) and a clothespin on his nose. If one is not pinched and the fingers in the nose, and to open the valve when there is no breathing and only the control of the mixture on the sensor. Then security should be fine - if anything will just fall out of his mouth and all. Although the norm is actually supposed to chaperone! (for control of the General condition).
Effects in the helium-argon - krypton too, because anesthesia anesthesia strong in the xenon...
Before beginning the procedure required to breathe for 3-5 minutes pure oxygen, it is called denitrogenization - from the tissues of excreted nitrogen.
I can assure you that the composition of the air on the planet artificially altered. And the planet it changes to normal (natural process about how transmute Bolotov) and continue to support changed . Reason - the consciousness of the masses and just a need for certain gases. I understand that sounds mad... but decided to share this - I am sure in Siem reap for 10 000процентов.<
Post by Михаил_ » Tue Jul 01, 2014 14:38
http://www.insovt.ru/gasanalysers/gkm.php is the correct detector (for example) however there are other but they are acceptable I will confirm later (when received). They are significantly cheaper.
It is necessary however to understand that without absorbing CO2 mixture will deteriorate, and after half an hour of therapy in about 10% of nitrogen is washed from the tissues. So... for General information :)
Post by ЗОМБИ » Tue Jul 01, 2014 14:42
duck here http://www.youtube.com/results?search_q ... 0%B5%D0%B2+
I his stories and learned about xenon he xenon to long floating screwed
Oh, I remember, he talked about the gait of power, such as it is very simple and not at all tired (and most importantly izmeneny comes), it is necessary at each step to inhale, the next exhale... I think so...
thanks for the info, I think will help... but in General I want as Bubeev ever make -- a long dry floating with periodic xenon inhalation, the main problem-a competent looking
Post by Михаил_ » Tue Jul 01, 2014 14:56
I note once again that the effects at the cellular level and minds have all noble gases and a change in the composition of the atmosphere (he loves to talk a friend of my son - " what could it be ???? :) ")
closest to the xenon - krypton, but from the light of helium - izmeneny there (well, not so bright, it is just different)
The xenon its "anaesthetic" effect at the same time removes a part of the blocks, but the physiological effects (cellular level) think highly of similar...
and yet - the effect of leaching of NITROGEN is important. It happens with just pure oxygen.
While all the details later.
By the way, the inert gases have different impacts on the delivery of oxygen to cells (its probably for a pen drive? to the cells and back)
In particular glubokovodnye on helium doing the mixture with the lowest percent of oxygen....
about argon - see the article I gave the link above.
well, there are a lot of jokes in this area.
Post by Михаил_ » Tue Jul 01, 2014 15:13
this is for a General understanding of how to operate breathing circuits http://www.anestesi.ru/Kontury_2.html
Yes, the price of krypton is about 10 times lower than the price of xenon. And the price of argon and helium well, actually....
Post by Михаил_ » Tue Jul 01, 2014 15:17
analyzers still there(example cheap) http://www.scubacenter.ru/catalog/detail/TestoGas_O2 but this is a bad way, then I will explain why ( General theme rebreather diving Helio-oxygen mixture almost coincides with the theme of xenon and inert gases and divers experience there postdictive helium long term)
Post by Михаил_ » Tue Jul 01, 2014 15:59
Yes, I have not mentioned nothing about the idiots, excuse me, coaches that went to the new incarnation, due to gross violations of safety... I separately studied the topic of deaths due to helium or even inert gases, because there was telescopica on this account and because fans sometimes are dying of hypoxia.
It turned out that most of the cases, death is due to complete violation of all reasonable norms. As a rule it is the inhalation of pure gas (without oxygen) or dirty gas (technical, not medical) and poisoning by impurities (one known case)
as well as a rupture of an internal high pressure gas (the leaders of the United States - the only case... "breathe" the gas directly under pressure without the gearbox), in short a whole list on the "Darwin award"...
интересующийсябж
Post by интересующийсябж » Tue Jul 01, 2014 17:10
That is, azon can be used for this purpose?
ИгорьС
Has thanked: 5 times
Post by ИгорьС » Tue Jul 01, 2014 17:41
As I understand it, the xenon or other inert gases lower the partial pressure of nitrogen and oxygen. So what? Ie, Semchuk right wrote that earlier the share of CO2 in the atmosphere was much higher than the present itself ATM. the pressure is also?
interesuushihsa
what is "azon"? don't know of such a gas. Or ozone or nitrogen. But I think that neither one nor the other will not go.
Post by Михаил_ » Tue Jul 01, 2014 18:07
интересующийсябж wrote:That is the azone can also be used for this purpose?
no
Post by Михаил_ » Tue Jul 01, 2014 18:11
ИгорьС wrote:As I understand it, the xenon or other inert gases lower the partial pressure of nitrogen and oxygen. So what? Ie, Semchuk right wrote that earlier the share of CO2 in the atmosphere was much higher than the present itself ATM. the pressure is also?
interesuushihsa
I have no idea what there Semchuk wrote, IMHO it can not be read at all....
the pressure above and the above inert gases, nitrogen is less CO2 - I don't know the details, I am not ready to write the exact formula of the old air right now. There is still hydrogen was. And oxygen was lower at times, but it doesn't work just like that (h/e/ the common man if the oxygen is lower it will die). This is a free burning was not supported ( and hydrogen line did not explode, because the percentage of oxygen low).
By the way there are scientific papers talking about experiments in France borophagine (well simulated in the chamber) to a depth of 750 meters (75 ATM) in a helium-oxygen-hydrogen mixture, except that such experiments can only be in the science lab to put with the right equipment, and not blow everything.
Аиша
Has thanked: 56 times
Been thanked: 14 times
Post by Аиша » Tue Jul 01, 2014 19:39
But not all these compounds are simply replaced by the reception of the peroxide?
Post by ЗОМБИ » Tue Jul 01, 2014 20:02
peroxide like for additional oxygenation, and noble gases the goal as I understand hypoxia-managed, and do not require skills to create, besides the fact that the xenon (maybe others) and even "dofaminove ways" works... for me dopamine is not less hypoxia are interested in 8)
MichaelI do not remember what your opinion on the acceptance of peroxide
should take it? with noble peroxide is better not to drink/to drip in parallel?
and if noble still add CO2, i.e., not to filter it below a certain value? After all, CO2 expands capillaries-the noble away, probably transported on extended vessels...
Аиша
Post by Аиша » Tue Jul 01, 2014 20:26
The method of Solodovnikovi - receiving peroxide with licorice root. The solution has pronounced detoxification effect, simulating the function of monooxygenase liver. By oxidation are removed from the body nitrogenous waste products (urea, creatinine, ammonia) and other metabolic toxic substances, which are formed during ischemia, intoxication, destructive-septic processes, burn disease, liver-kidney failure. A solution is independent bactericidal effect against virtually all kinds of pathogenic microorganisms - protozoa, viruses, fungi, bacteria. Under the influence of "solution" a certain part of the T and b lymphocytes die, but after 24 hours the number of cells of the immune system increases by 20-35% due to increased formation of new cells, resulting in an active immune modulation.
http://solodka.ru/text-1.html
Interested in the opinion of the forum!
Post by ЗОМБИ » Tue Jul 01, 2014 20:36
my opinion-the rates apply, of course it is better to drip, although Vienna is a pity, and so it's kind of a banal way of anaerobes and oxidized chemical residues, licorice like the transport of oxygen improves
and here's a question -- did the options.diagnosis before entry to the school run, in short I have the IPC (maximum oxygen consumption) as an athlete (former/scoring trenki/in the offseason), but I am lazy :)
I have ... high of 64.3 MPK MPK is good or bad?
(weight about 60 :cry: mass index about 20)
Post by Михаил_ » Tue Jul 01, 2014 21:43
Аиша wrote:But not all these compounds are simply replaced by the reception of the peroxide?
no it's actually quite another!
Post by Михаил_ » Tue Jul 01, 2014 21:46
Аиша wrote:Method solodovnikovi the reception of the peroxide with the licorice root. The solution has pronounced detoxification effect, simulating the function of monooxygenase liver. By oxidation are removed from the body nitrogenous waste products (urea, creatinine, ammonia) and other metabolic toxic substances, which are formed during ischemia, intoxication, destructive-septic processes, burn disease, liver-kidney failure. A solution is independent bactericidal effect against virtually all kinds of pathogenic microorganisms - protozoa, viruses, fungi, bacteria. Under the influence of "solution" a certain part of the T and b lymphocytes die, but after 24 hours the number of cells of the immune system increases by 20-35% due to increased formation of new cells, resulting in an active immune modulation.
opinion - it is better to zeroedit and periodically make the same inhalation. The peroxide ? I don't know... t/e/ about the use teoreticheski heard, almost I use most likely won't for a number of reasons.
I have plenty of other good resources. I believe that this method for normal people on a normal diet and the normal state energy
Post by Михаил_ » Tue Jul 01, 2014 21:48
ЗОМБИ wrote:my opinion-the rates apply, of course it is better to drip, although Vienna is a pity, and so it's kind of a banal way of anaerobes and oxidized chemical residues, licorice like the transport of oxygen improves
high consumption ? I think bad....
generally there are such good gauges of oxygen in the blood.... they need the house to have including for the study of the processes for inhalation or breathing exercises (a process that has not been studied deeply) I'm talking about pulseoximetry, it is either separate sensors (for physicians, athletes) or in function of medical bedside monitors included.
Post by ЗОМБИ » Tue Jul 01, 2014 22:15
I have a oximeter, I during the stomach.Trinec use, is impossible to drop the saturation of the blood before... I do not remember up to what percent :oops: in normal mode, the saturation is hanging out at 97-98%
and the guys in the diagnostic center, admired the kind of cool that the IASC high. there's biological age was measured from a master of sports in athletics 16 years, and me 15 8) I'm better...
and the master of sports this sat and breathed the hypoxic mixture, all with the same oximeter on your finger, I realized the periods of 5 minutes... he's not really low heart rate at rest was something like 47 that is, I do not remember... I am the way during the stomach.Trinec trying to drop the heart rate and elevate diastolic blood pressure, it turns out, the only effect very short... well, either you have to sit to breathe for three hours in a row... easier plyusanut here gas mixture
(the whole age thing as I understand it the speed of metabolism too fast is bad, I know)
it is better that the saturation of blood on what value was kept in everyday life??
(I read the forum andagencies, they're all inflamed that they have not 99%, especially after a meal drops :) say)
probably high IPC is not so bad, probably still the ordinary saturation is more important
(I think the high oxygen consumption is terrible in the background, because the body burns, and during load, I guess it's good, well, then perhaps "the swing," run, like the body alone is generally not enough "hawala")
peroxide can do once in your life to kursanti and enough... the same herpes travanut
Post by ЗОМБИ » Fri Jul 04, 2014 9:14
In the book “smart raw food” referred to ash Vibhuti and some ORME-metals, especially the ORME-rhodium.
(referring to the book on the previous page)
Vibhuti doing; it burns cow kakahi, the author says that it is possible to obtain an analogue; it burns, for example, plant Borisevich
Like Vibhuti is very powerful. ORME-metals invented some DAVID HUDSON
David Hudson, known as the Creator of the term ORME (Orbitally Rearranged Monoatomic Elements Monoatomic elements with rebuilt orbitals)
It's something like monoatomic gold...
Any opinion on these substances? You can? Need?
still remember Gray suggested to burn through the bone on a hot metal... the type of mega-calcium... maybe it ORME-calcium?
Post by Михаил_ » Fri Jul 04, 2014 12:30
my opinion - this is all crap....
Марат Г.
Post by Марат Г. » Sat Jul 05, 2014 1:16
Good evening to all forum members.
Picked up on the street a baby pigeon, it was thoroughly devoured by crows, wing, head.
Very silly-that was the dove, did not even eat..
The chick is already big, but still at the back were not baby feathers..
Given Vetom 1.1 is involved in the milk through a syringe, and obviously will give ASD..
from the chick strong conjunctivitis, obviously you will need to rinse with a weak solution of ASD.
Sincerely yours, Marat
Post by Михаил_ » Tue Jul 08, 2014 19:52
I have a Board in the nearest time Thai tabernanthe iboga centers (which are actually 4re found) not to use it. Well, unless it's already paid for.... comment on why I won't. Just a tip.
