Bracelets Life
Трейдер
Re: The Bracelets Of Life
Post by Трейдер » Thu Feb 02, 2012 10:10
Michael thank you! You helped me a lot ... I solved the problem with Your help.
Трейдер
Post by Трейдер » Fri Feb 03, 2012 12:49
Today lost your Bank card.. I searched all you can ... was easy to panic ... remembered the bracelet ... found in 5 minutes... fantastic I swear ))))
Алекс С
Has thanked: 2 times
Been thanked: 7 times
Post by Алекс С » Tue Feb 07, 2012 0:22
A question on charging/up to clean the bracelet version 2.0 using 2.5 (foil mental command, two days)
If BJ 2.5 never wear and never planned to wear is not configured on the operator, it is possible to take it apart and create some semblance 2.0 one link with the objective in the case of a relief TO have a branch created one link, not suffered TO 2.0 in other threads created by other links?
And in General, TO reset, reset TO, and so often do we see reset TO to "worry" about this?
Post by Михаил_ » Tue Feb 07, 2012 0:33
1. the bracelet is configured to the operator the moment when You finally decided to buy. It repeatedly checked. Ie, before he even Packed in your package (for example).
2. can be disassembled, but no good but harm.
3. reset TO is rare but not so rare to be neglected.
4. reset TO affect not 2.5 and all the bracelets of the operator at all.
5. 2.0 thus obtained is considerably inferior to 2.0 received a factory charger, card transfer or sticker 1копия. Makes no sense to take 2.5 for this case. Ie NO. Easier to charge a panacea matrix and switch matrix 2.9 (for example). 2.5 this is a serious product that should be used for other purposes. By the way what You wear does not change the fact that it works with You, changing the intensity thereof.
6. of course you can do the 2.0 as specified in 2.5, if it is convenient, in the process, and so on. But keep in mind all these reservations. I would recommend doing it to those who are able to lose TO Bush in their distributed 2.0 and feel the need for such action. For some it might be IMPORTANT. I.e. reset TO it's not my or someone's whim, but a vital necessity, a condition of safe use. The Panacea is bypassed from the other side (if there is a panacea that is simply not there), so it is so to distribute safer. 2.0 in some cases preferable can be its softness.
Алекс С
Post by Алекс С » Tue Feb 07, 2012 0:48
Michael, thanks for the clear explanation. All clear.
About my question - I was just looking for theoretical relatively inexpensive way to transfer a large number of relatives and friends from 2-3 bracelets 1.0 after one and a half months of wear, on a higher level.
Of course, planned a "Panacea Lite --->2.9", but I was thinking, and would it not be right before doing this to give a month or two or something intermediate.
Here and planned to "2.0 Lite under 2.5".
Post by Михаил_ » Tue Feb 07, 2012 1:38
there is still a version 1.0 Lite
ягуар
Post by ягуар » Wed Feb 08, 2012 19:29
all versions of the bracelets(a proprietary charging) possible to separate 50: 50 and to connect with clean bracelets??.. :oops: ..and yet... I was thinking, and integrated in the panacea...switch function that would look FOR the bracelet version any remained, or has been reset..I think it was useful function.. :ay what do you think??...
Post by Михаил_ » Wed Feb 08, 2012 21:08
Yes of course you can, (to disassemble) but they will be weaker. I.e., the spreading of charge from such perebora not adequately factory.
about TO - well, in the versions of nothing has changed basically.
sometimes modules are added (and this affects all at once) and sometimes added functional modes panacea and it affects all panacea.
Otherwise, each type BJ - this thing is not subject to modification.
Трейдер
Post by Трейдер » Fri Feb 10, 2012 11:12
The set of modules are the sound tracks , for example in module a Prophet to Tell me it's modules to charge who wants to make bracelets or for wiretapping in the quality of the training ?
Post by bofara » Fri Feb 10, 2012 11:34
Module a Prophet to be spoken/I think that is visualized, it seems - whatever you like/ to work with BJ 1.0-2.x-P.
Track the Prophet you can use to listen to headphones directly in my ears, also the background playback in the field cocoon /headphones and/or speakers for the structuring of the liquid, also you can play /turn/ through СК1М, Radionic...
There is a possibility to "charge" BJ track Prophet, when between track 4 and track 5 /to supply/ to put the track of the Prophet. Then the Prophet will use much bandwidth BJ for yourself. Because it is written in openmagic.org. But what are the implications of the impact that actually turns out - the one who did it if someone did that :? / have not written to let people know. :) IMHO the impact will be specific. :D
Трейдер wrote:this module to charge who wants to make bracelets or for wiretapping as training ?
Most likely the latter. :ay
Трейдер
Post by Трейдер » Fri Feb 10, 2012 11:56
If they are to listen for , how often it is better to do and should there be some sort of pause between the wire tracks or you can listen to everything at once ?
Post by bofara » Fri Feb 10, 2012 12:14
No it is recommended to listen to the tracks for "charging" the BZ - 1 to 5.
Rest /Tablet, standard, Probiotics, Ozone, cleaning of blood, the Prophet, Stabilizer - herecan listen to and/or used as described above. With regard to scheme listening - no strict rules - all individually, but, at least at the initial stage, it is not necessary to reboot. The information is there here
Трейдер wrote:should there be some sort of pause between the wire tracks or you can listen to everything at once ?
Better the piece. Everything from, um... Not good.
Виктория
Post by Виктория » Sat Feb 11, 2012 15:20
Greetings to all members of the forum! Bought in office BJ. On the advice of Lily a week used 2 PCs. of 2.0. Then put 2.1 2.0 5 days reviled them together...not seen break through:) Put 2.6 so I immediately felt while listening..:) I Tried to enable the modules.. Funnel flow and air flow...Frankly I do not understand engage them. See next:)
Has thanked: 478 times
Been thanked: 264 times
Post by ЛИЛИЯ-Р » Sat Feb 11, 2012 20:54
Виктория wrote:I Welcome all the forum users! Bought in office BJ. On the advice of Lily a week used 2 PCs. of 2.0. Then put 2.1 2.0 5 days reviled them together...not seen break through:) Put 2.6 so I immediately felt while listening..:) I Tried to enable the modules.. Funnel flow and air flow...Frankly I do not understand engage them. See next:)
Funnel flow is visible immediately when there is a negative situation ,she resolves. This is evident in the situations,the positive thoughts coming. Restore energy and bring it into a balanced state. The modules can be matched to the situation with which we must work and observe changes ,reviews in the body and outside.
Тяфа
Post by Тяфа » Sun Feb 12, 2012 0:45
I still did not do well to study the information on the modules, as if that holds :? instead, come up with your module "Parking", when the house approaching, I am asking the bracelet works very well, and started to feel what my place. Typically, the place began to appear near the entrance (we Have a VERY large tight places because the house is near the subway, and who from the suburbs commute to work Park and ride on the subway :evil: ), yesterday toured the house on the other hand, an inner voice immediately said, here are three places - choose the one you decided to check and went to the entrance, so not that to Park drive was almost unreal. This, too, an interesting situation has turned out, parked the car, but sitting I doubt it, as it turned out the side and can hurt. Suddenly on the other side of the courtyard was quickly coming aunt and gestures. I think some sort of strange. Look here the signaling to nearby to the standing car on the opening worked well, I think I out to her car, pressed close what little space left to sit comfortably. Came to ask what we needed, and she goes, "Oh wait. I did go, my place will be, as you prefer". Even heat did not, immediately to the side crawled. In both! :?
Андрей С.
Been thanked: 4 times
Post by Андрей С. » Sun Feb 12, 2012 2:22
Well, this is not your module :) You just give the command to subconscious to solve the problem and it solves it. I also often use the language without specifying any modules, or with the command "activate optimal modules for..." However, to know the modules too (at least just to represent their ability), but all the time, if the holding means is not needed, I guess.
Белый Камень
Post by Белый Камень » Sun Feb 12, 2012 3:16
"your module" probably just the same bad choice here, and it is "your module" not "module BJ" ))
Generally, any variant of assumption is necessary to the mind, him without them and hard for us without him, so far Image
Мариомар
Post by Мариомар » Mon Feb 13, 2012 16:32
Good day! Want to share an interesting feeling of wearing 2.6. I wear exactly a month. Every Sunday I get down. So... set. In the period from 22.30 and somewhere to 24.00. At this time the bracelet as if compressed in the hand, feels slightly rotated in different directions, the hand begins to ache from fingertips to elbow, and aching with terrible force, and on the inside, as if a pair of spokes. The energy at the time evaporates, and I just lie flat. If the bracelet change on the left hand, the pain increases, if you remove the same effect. the first time was not very strong, but last week it was very hard, I was so sick with both hands, and I almost physically felt how his / her palms out two powerful heat beam (as from a heat gun, which the heater :) ). Then I got sick... From Monday to Thursday, kept a stable temperature of 38, weakness, drowsiness, anything has not wanted to, slept all the time. Besides temperature, no other symptoms of cold or flu was not. Doctors do not cause drinking structured water gallons and slept. 2 times listen to the night Healing A. Patrushev. Tried to enable the modules to improvement (the standard, Old planet), feels like can't start the car in the cold, i.e. "the starter turns but doesn't grasp" :( as if not enough energy to activate. On Friday morning included the track "cleansing the blood" background, and after 10 minutes the feelings involved the eponymous module. Immediately felt better.... More there was no fever, feel fine. This Sunday "according to tradition" the bracelet came to life again, grew heavy and almost tore my arm off :lol: ... What could it be? Just want to say that no global goals are not set and the modules do not particularly include, the knife in passive mode.
Post by Михаил_ » Mon Feb 13, 2012 20:54
it can be cleaning. Well, why on the weekends - apparently somehow linked to personal and planetary biological cycle. Overall quite normal and very good.
In General, within the said Constantine in a nearby branch of a large-scale change of the world BJ a few stronger........
Мариомар
Post by Мариомар » Mon Feb 13, 2012 21:42
Михаил_ wrote:it can be cleaning.
Cleaning is always good :ay
Михаил_ wrote:why on the weekends - apparently somehow linked to personal and planetary biological cycle.
Apparently the end of the week brings something cleans, and adjusts to the new :wink:
Михаил_ wrote:in General, in the framework of the mentioned Constantine in the nearby branch of a large-scale change of the world BJ a few stronger
Honestly not much understood about what speech
Л@на
Post by Л@на » Mon Feb 13, 2012 21:51
I was from Panacea, 2.6 also wear. Aching hands, fingers. One of the fingers were swollen and 1.5 times thicker than the others. It was painful to tears, there was nothing I could do at home, even just to drink tea was a problem, the Cup seemed to not lifting. Here on the forum wrote that someone back ached, etc., naively thought that I surely are not threatened and there is.
Breaking gone, but interestingly, the skin tone was changed, nice color, servatory left.
Л@на
Post by Л@на » Mon Feb 13, 2012 22:20
The bracelet I continued to wear, to remove, to clean away, such thoughts did not arise. Think better not interrupt this process.
Мариомар
Post by Мариомар » Mon Feb 13, 2012 22:24
Л@на wrote:Bracelet I continued to wear, to remove, to clean away, such thoughts did not arise. Think better not interrupt this process.
I had to take a shot, for the purity of feelings :oops:
Л@на
Post by Л@на » Mon Feb 13, 2012 22:39
Just someone from the forum here and started to panic and dumped their sins on the bracelet. Marimar, it's not about You. :)
СтАвР
Post by СтАвР » Mon Feb 13, 2012 23:31
Michael
BJ ebony are of two types, black and brown-black
and here noticed after a recent purchase 2.0 wide, brown black, as P is also brown-black.
so in both cases there was irritation after a few hours the socks, is different than just black BJ by brown-black?
on the feet there is no such, and Yes
