theoretically, someone could hack your mail and disable broadcast in LUX (to cause flame here for example). To eliminate this factor, get tested for the virus fresh antivirus (for example http://www.freedrweb.com/cureit does not require installation), then create a new mailbox (on a different mail service with a long complex password) and ask the office to move LK broadcasts there.someone brought down and blocked my account mail where is my account
Владмосква
- Has thanked: 1 time
- Been thanked: 7 times
Re: Discussion broadcast. Reviews.
Well Vlad, something to disable, you need more to process the application for the trip, and I didn't. Just the personal account is enough. And who will break. It's already nonsenseВладмосква wrote:theoretically, someone could hack your mail and disable broadcast in LUX (to cause flame here for example). To eliminate this factor, get tested for the virus fresh antivirus (for example http://www.freedrweb.com/cureit does not require installation), then create a new mailbox (on a different mail service with a long complex password) and ask the office to move LK broadcasts there.someone brought down and blocked my account mail where is my account
The response of the subject, the question MM about the change in sensations from broadcast.
Broadcast itself is connected and nothing has changed, power has not changed.
Everything is technically secured and correctly.
This means that perceptions have changed broadcast on your part.
There are several options:
1) addictive (unlike, time it for 8 months did not come, and then it probably more about of energy, addictive in the sense when not noticeable bright broadcast although its a good thing she's doing.
2) the influence of external factors on the occurrence of fatigue or other effects that masked the stream and was like what its not enough power
3) super adaptation You to broadcast due to any changes (well, almost the same as PP1)
4) super energy to new tasks/ or a very very strong energy drain. And then the unlikely and not entirely normal, especially since the stream carries, though not perfect, but a protective function.
5) drastic changes in your cocoon, which made reference to the broadcast is not effective (turned it off with your hand part)
My diagnosis and diagnosis of the other person suggests that the most likely пп5. In my opinion this is due to the fact that You yourself have admitted to some external signal, which quite dramatically changed your cocoon and bind no longer fit You.
It is not very easy to "fix" because you need to repair will not bind and how would You, then, what is binding this man is out of touch with the current identity/embodiment, this part will not change in time and can't change, so we are talking about third-party inclusion in your cocoon (like entering/ third-party energy and information embedded in the whole density).
To say exactly what the source of this signal I currently can't.
It can be discussed separately, as well as ways to clean up this moment.
Just overwrite the binding will cause Your PC will translirovatsya not only you, but also shares (essence/tail someone something, etc.).
So you need to act differently.
Additionally I want to apologize that it's usually hard to answer You due to the fact that we would want to reach out to your understanding that there is no need to spend money when they deficit on expensive products such as PCs+ and AMP in the presence of masses available and also not a low-power homemade. And I want to reach out to You on the subject of which often in addition to BJ and PC need and human actions in order to achieve something, and if it is not reached, we may need to be more active myself.
Although our technical or other fault in the signal weakening PC+ You do not have, given your difficult financial situation and regular purchases ( and also stiffness in my replies to You), I want to make You a gift of another year broadcast PC+ and some physical products (I'll decide later what may in consultation with you).
The rest of the discussion of this situation would need to be in personal emails or on my forum. Otherwise we don't fit the format and to the same piece of information can be personal.<
Re: Stream. The basic features and rates.
Michael, just to clarify about "all non-standard situations "?Михаил_ wrote:2) stream "Regeneration-5" - increases adaptogenic capabilities of cocoon in any unusual situations and under high stress.
I understand, chronic diseases do not apply to "any non-standard situations"?
Chronic can be interpreted in different ways, to try. Don't know how it'll go, no harm. Not the standard is unexpectedly obtained by physical and / or structural energy and structural damage.
Hello.Can I connect the CM to a child, 7 years old from a close relative? Much sucking!
you can of course ....Гарин wrote:Hello.Can I connect the CM to a child, 7 years old from a close relative? Much sucking!
Hello! Judging by the notice in e-mail my stream hooked up early in the morning on may 24. I rent a slot in the Multiplexer, without products. I still wanted to understand what it really is. How I'll feel.
A few days before the actual connection was a feeling as if a stream is already underway
At one point the condition was of the type "I boa" - so quiet and smooth that even no comparison. At the same time, not hinder absolutely. But, no stress, no stress, no fuss.
As for 24, I woke up surprisingly easily, although eve went very late. Sometimes, in the output Wake up with a headache, as I say, from the displacement. Because Saturday is sleeping longer than usual. But does the General cheerfulness cheerful....
Today I can confidently say that get up in the morning has become much easier. I knew that if went to night at 7:30 to get up will be difficult. Now this is almost there. During the day the condition is completely relaxed. You can do a lot of stuff, to travel, to meet people, to talk, to discuss various topics. Thus, the emotional component is the same.
Also, changed attitude to the solution of problems in all Affairs. If I don't get the result today, I still know that I will get it. Out of doubt at all. Good or bad? Today was in the Bank changes the terms of the loan. Will lengthening the term to reduce the monthly load. The Manager strongly doubted that the decision will be positive, as I asked for maximum elongation. Payment is reduced by almost 2 times. The result will be Tuesday night. For my part no doubt. So let's see
In my opinion it is good.Артем Б. wrote: out of doubt at all. Good or bad?
I also got a burst of energy after the PC+ mode 2, 3 and 4.
The situation was such that for several days, 10-12 hours a day walking and at the end of the day I felt very fresh, apart from minor heel pain. And it was so natural that I realized/noticed it only on the third day.
And in combination with commercial Pandora Wake up much earlier.
Good morning! Tell me, what use the broadcasts to support the immune system?
In the same way that better connected to improve the condition of slovinky?
In short, you want something for your health.
СтАвР wrote:
understand to give some more specific answers , you need to have information about the situation in General
read the topic
http://openmagic.org/ph/showthread.php?t=69
http://openmagic.org/ph/showthread.php?t=74
viewtopic.php?f=5&t=4867
they have a lot of different answered and written, I am sure you will find something that interests You
Hello Artem B.
Well stream 2.2 impact positively on health.
Meet the post and links above.
For a holistic recovery, you can use stream PC+, if finances allow.
Well, there are a lot of free products from BJ, which can be used as the beginning with the aim of restoring health.
If the following conditions on joining the PA club there one of the broadcasts a special on the immunity is..Артем Б. wrote:what connect of translations for immune support?
Yeah, PC+, the genome/cells/kunka/ (the last 2 positions of the club and генома2)/ 2.2 basic club 2.4, 2.7, if desired.
Well, the PC+ that is to say all of the standard kit (YDF t/e/ too).
Hello!
Whether the conditions for the club - I don't know
I use BJ for the 5th year. Just not an active forum member. For example, now I am in 2.5 (for more than a year, before 2.1 too long). Helps a lot and like physical product. Therefore, not removed.
PC+ too expensive for me. Therefore, I want to get some items.
Also, I want to change the mode slots. In connection with this question. If I pay for the extension of the lease of slots with the change mode and add new products when a trigger occurs? After the end of the existing lease or the connection will happen before that?
Asking because now I have a mode Multiplexer, and want to take mode Detailed. Michael did not recommend to combine these two modes.
Another such moment. My son is a month for 3 years. He is now a age when he wants to participate in all processes of adults. Of course, not everything that adults do is permissible for the child. Sometimes sticking it where it don't.
At the same time with his stream, I connected to his Child's comfort, as the recent increase in tantrums. Hysteria "I want, Gimme", "Let it go mom, not dad," well, normal to be naked don't want to dress do not want, do not want to eat. It was not until the broadcast, but after the connection, little has changed. Sometimes, I think it became even worse.
Another big caveat is that when both parents are present, he's trying to manipulate. When we are with him one on one, interest in the resistance falls. Baby is normal. Well, it has always been.
By the way, in the garden, or in a different society to behave decently
These are the observations
Hello Artem B.,
To enter the club one must have stream PC ( not to be confused with PK+ ) for at least 3 months. And Michael must approve your candidacy.
The new product will be connected a few days after receiving the payment and depending on the possibilities of Michael.
I think as far as the child's behavior, the situation is very clear. He tries actively to control events around themselves, based on their understanding and all means are allowed.
If mom and dad have the same position on important issues, the child quickly realizes that his manipulations do not result. You need to count and his opinion and give him the right to Vybor.
And it have a lot of talk and a lot to explain - at least this is my humble experience.
Hysteria "I want, Gimme", "Let it go mom, not dad" - that's my daughter!
Treat him as an adult man.
"I want, give me" Let him do it. So he gets to learn and feel that he can. I know this is hard for you, but it is correct.
Hello! tried to add a new child profile,the system is not accepted ,do not like email. Enough photos and son's name.
Beso Thanks for the comment! That is exactly what we do. Allow to show to do what he asks. Just in children is completely his vision of the situation. The fact that mom is tired at his age, probably, it is difficult to understand... Well, purely domestic issues, of course
It's all absolutely fine! Stream still good for you...
please write in lichku mail forum (me) or personal email at my forum user saband (the interface) which email is used (trying to use) when trying to add a child profile.Гарин wrote:Hello! tried to add a new child profile,the system is not accepted ,do not like email. Enough photos and son's name.
The email must be real. Please see that You are not typos in it.
At this moment, email is the only MANDATORY parameter for the profile. When desired, do not specify anything else. Although if you have a name/picture, some other data, it may slightly improve binding.
The email can be opened specifically for translational purposes. The main thing that it (the email) was associated with a man, but he must be a real and not fictional.
If the registration with email doesn't pass, then you have three choices:
1) a typo in Emile
2) it does not exist (because the program checks it)
3) for some reason check the existence of a gets a negative result, despite the fact that everything is in order. This is a less likely option, but completely to exclude it it is impossible, just so far not faced.
Therefore, in order to determine which of the options exactly need to see the email, but of course not in the subject and in private correspondence. Thank you.
Artem B. I fully agree with what wrote Beso.
Michael_ Good day!
Son the day before yesterday fell heavily on the street, smashed face. Only damage skin, but powerful. And yesterday developed a fever, snot. At night, the temperature was already high. This morning, snot, coughing, and connected diarrhea. Stress that if such a reaction? I don't know.
Is it possible extra to connect him either to support the body? I, as usual, not good what is better....
It is already leased slots.
I promptly paid! Thank you!
PM post mile profile son and his current photo please.
According to the description it seems that at first it was not the right energy-information interaction, and the rest of his investigation. Starting from falling and ending with the physics of the body. But I will check.
Michael_ All sent!
OK, I quickly see, unfortunately I have another time zone.
