Disk Explorer
- АлексУжг...
Евгений Кош
- Has thanked: 2 times
- Been thanked: 2 times
Andrew.. thanks for the tipАндрей Патрушев wrote:Explain little Toffee that You were her in the future
while talking and not for me, but I'm just to the point
I sometimes go back to childhood and there is a small talk, but! right now dawned on me that I never told myself that You suggested. feel this is it!
Евгений Кош
I actually bought this things are GOOD mugs. (good ears closed and was soft)САМОЛЕТ wrote:Another question...if I connect the player to the MM,then the headphones need to use from MM or from the player?
and chose to frequency characteristics 10 Hz-22 kHz.
and listened to through the player. ( according to my research the audio out from the computer is mixed a bunch of noise.. that you begin to hear in times of heightened hearing.. that does not happen often in the first months of operation with disks.. especially the Massage of the Brain)
Евгений Кош
IMHO at once - makes no sense. It is necessary for the Conductor to give time for inner work.АлексУжг... wrote:1.Is it possible immediately after the conductor listen to the healing.
2. Now we have a cold, shouldn't the break be done?
For example - if the conductor to listen to in the 18th and 19th.. so if you really want Healing, then if you go to sleep at 23-24.. it is.. for example, I so rarely do when you really really want.. start Healing without audiostrobe and Slipshihsja pillows.. - get the full thrill
I even enjoy healing ( for a good sleep) at any time when wanted very much.. ( in the sense - 1 time per month or 1 per week courses without any healing.. and just as a nice background for falling asleep)
I. I. Poloneichik the "Effective psychotechnique"http://www.bcardbook.com/shop_languages.htm there is such a technique.Ириска wrote:Thanks for the reply! :)
Are there any special techniques for talking with their children "I" or is it all happening spontaneously, as I had?
That is, you need a special state to enter that child's "I" to talk more? While listening to "Conductor"?
Please tell me Andrew.....
I decided to start listening to Your CDs as recommended with "Explorer".When I listen to it for 21 days,then you need to take a break for three months.After three months of "the Guide" will need to listen only once or again have to listen to 21 days?
And another question....
In those three months when I "rest" from the "Explorer" is it possible to listen to Your other drives and do with a mind machine?
Can I immediately the next day(22день)after 21 days of listening to "Explorer" to start listening to some other Your ROM?Or need a few days to wait?If Yes then how much?
Евгений Кош
PLANE
I recently a question about purpose, asking, that's what said Andrei Patrushev, maybe for You it will clarify the situation.
My question verbatim and the answer is:
And still not quite understand about the goals: to put every time, before listening or for 15 (21) days work with just one?
Андрей Патрушев wrote:the Purpose of doing this, which is topical for You at the moment. In the process (as a result) listening, it may become obvious that the old goal was not adequate.
Thanks Toffee!Ириска wrote:PLANE
And still not quite understand about the goals: to put every time, before listening or for 15 (21) days work with just one?Андрей Патрушев wrote:the Purpose of doing this, which is topical for You at the moment. In the process (as a result) listening, it may become obvious that the old goal was not adequate.
