Structured water
ВикторРусс
Re: Structured water
Post by ВикторРусс » Mon Aug 25, 2014 23:19
Was recently a kinesiologist and have tested the water BSL-med, turned out to be negatively affecting my stomach small and large intestine, probably because of the aluminum, which after filtering is still a lot of remains in the water. And the water cooked on their own, without electrolysis, only in the regime of saturation has a positive Outlook.
impact on 100 units. if you look at the 1000 point scale.
the owners of such filters, there is reason to think..
новый Искатель
Post by новый Искатель » Sat Nov 08, 2014 0:26
be activated (tonizirovanie, structured) water
it is interesting here that - decline in food consumption:
it is not I write, it's written by a man who uses Emerald
http://iskateli.info/showthread.php?t=3 ... #post56123
About food (desire), in smaller quantities also noted thought first thought me and the lady one that emerald si also said they say to eat fewer and now his wife said that really ))) eat what you do not want
according to some, if you drink the correct water up to 2 times can be reduced consumption. At the same weight, and so on. And decrease feelings of hunger.
I suspect that BSL-med although there are oddities with aluminum, similar effects were given.
Interestingly did anyone something is too.
новый Искатель
Post by новый Искатель » Wed Jan 07, 2015 16:54
anyone interested in negative ORP for drinking, from Icarus by the way there was a console-activator to reverse osmosis, mineralization,
we can discuss
manual
http://ikar.udm.ru/files/pdf/i_si_01m-50.pdf
reactor iridia, before doing the oxide of ruthenium
Владимирвввв
Post by Владимирвввв » Wed Jan 07, 2015 18:10
Андрей Патрушев wrote:a new Seeker
Well, what shifts the ORP of the track membrane? From +200 makes -30~50. There is also only little holes... :)
Interesting.And what exactly is track membranes such a shift (they are different firms and rosemary are googled). But if large size track etched membrane to take 2-3 or membrane to bridge the shift will be 400-600 on the idea?
новый Искатель
Post by новый Искатель » Wed Jan 07, 2015 23:22
I doubt very much if track membranes so easily moved ORP....
and I can give the link when I wrote this ? if 4 years ago it is clear...
Владимирвввв
Post by Владимирвввв » Wed Jan 07, 2015 23:36
You wrote, wrote Andrei Patrushev 10 messages ago in this thread. posting.php?mode=quote&f=44&p=121871
And then also write that lowers the ORP http://torsunov.ru/voda.html (I googled)
БелоГор
Post by БелоГор » Thu Jan 08, 2015 0:33
If you structure your drinking water the old-fashioned way has become difficult, what are not satisfied with the method of obtaining "proteios water" from the atmosphere?
The Peltier elements public, copper or brass sheet to buy no problem. Triple dew point, the law is not abolished.
Settled water is easy to filter out from the inevitable impurities.
So goes the chase is not for drinking-water quality, and fashion.
новый Искатель
Post by новый Искатель » Thu Jan 08, 2015 4:42
Владимирвввв wrote:You wrote, wrote Andrei Patrushev 10 messages ago in this thread. posting.php?mode=quote&f=44&p=121871
then it is clear. then I will say as a person who is 4 years actively boiled in the water - what can not track membrane to reduce as much as 250 units.
If this happens - give a photo of ORP meters. Show your proof )
the emeralds on BSL-med, everything else pictures of ORP meters vidil. on track membranes - 1st time I hear it. My opinion - this is not. A maximum of 50 units lower.
If you write that lowers - but will not argue that lower. Give pictures of ORP meters. Before and after.
Владимирвввв
Post by Владимирвввв » Tue Feb 03, 2015 22:00
A new method of obtaining "live" water.
The essence of the method is to add hydrogen to water, which reacts with an active form of oxygen ORP shifting in the negative direction.
In this embodiment, the electrodes do not interact with water (only gas) ACC water is not travserse metal electrode.
Владимирвввв
Post by Владимирвввв » Fri Feb 13, 2015 2:39
БакСер
Post by БакСер » Mon Mar 09, 2015 18:32
Greetings to all!
Father builds a country house. Dug a well. Gave the water for examination. the Excess of nitrates in 3.4 timesfrom the norm. The water supply system with Central water supply cannot be held to dig a well or to drill a well in another place is not an option. Need water from the nitrate to clean.
Question: What are the treatment options well water from "nasties", including nitrate? If (for nitrate) membrane filters and reverse osmosis systems?
In advance, thank you all!
Post by Андрей Патрушев » Mon Mar 09, 2015 22:00
Baker
Perhaps not how it cleans... the Molecule is too small - using all pass filters. Can be electrolysis only...
You can still well up to 70m to deepen - there is a second coat is usually very clean, but a little expensive...
БакСер
Post by БакСер » Wed Mar 11, 2015 11:08
Андрей Патрушев wrote:Baker
Well is not an option, at least at the moment, because such money is not available.
About filtration: systems reverse osmosis does not cope with the nitrates?
новый Искатель
Post by новый Искатель » Sat Mar 14, 2015 15:22
I bought emerald 04, doing experiments with contactless activation oils. curious.
it is also possible to activate the yogurt, juices. Study.
this is on Tesla quadrupole, a catholyte
http://iskateli.info/showthread.php?t=3 ... #post58750
новый Искатель
Post by новый Искатель » Mon Mar 16, 2015 15:24
contactless activated yogurt.
Владимирвввв
Post by Владимирвввв » Tue Apr 14, 2015 19:12
Post by Андрей Патрушев » Wed Apr 15, 2015 18:22
Obtaining water from air Interesting thing... Perhaps buy yourself... :)
Бывший Регент
Post by Бывший Регент » Mon Jun 01, 2015 21:09
Sorry, I can not be silent.
новый Искатель wrote:be activated (tonizirovanie, structured) water
Extremely interesting, mainly because poor appetite is a BAD symptom.
In General, in the electrolysis of the chloride formed a variety of stuff (the exact composition depends on many variables), completely remove which may not even have all of your filters along with reverse osmosis.
Turn the bench while no one was killed.
АМарта
Has thanked: 2 times
Been thanked: 2 times
Post by АМарта » Mon Jun 15, 2015 23:08
Dear experts,please answer those who are in the subject.Anyone used for water structuring proofreaders Koltsov? Manufacturers claim that the liquid is structured over 2-3 minutes(though it is unclear what the volume).
Post by Андрей Патрушев » Tue Jun 16, 2015 9:32
angel
More than a glass have not tried. Taste, indeed, changing...
АМарта
Post by АМарта » Tue Jun 16, 2015 14:00
Andrei Patrushev,thank you very much for the reply. Eyeing him,I want to buy for structuring water. Where to get objective information,I don't know.(
зилоп
Post by зилоп » Thu Aug 06, 2015 16:26
Андрей Патрушев wrote:And You just try (without any rings, etc.) perekipat (1-2кап/h) of glass in the glass..
What we found about the digging of water information in Google. What is it and where about it to read.?
Met a dropper Kelvin, so there is generally a vessel containing water to several thousand volts to charge. Interestingly, there is a ORP , or is it completely different parameters?
Алега
Been thanked: 3 times
Post by Алега » Fri Aug 07, 2015 1:59
Want to get a negative ORP - add the water ASD and you will be happy and many other positive effects.Confirmed personal measurements.
Алехан
Post by Алехан » Tue Nov 17, 2015 15:28
Hi, I'm new here. :)
Advise what better to buy the pot, to make the anode and cathode water?
And if possible tell me where you can read how this cell to do with their hands.
thank you :)
Post by Андрей Патрушев » Wed Nov 18, 2015 15:52
Valery ban'kov, Doctor of biological Sciences, Professor of the Ural state medical University, kindly provided us with the opportunity to read his monograph: "Water, electromagnetic fields and life".
