Bracelets Life
For bracelets the negative consequences will be, their shifts are recorded.
For "prototype" charging can be used 2.x having a laser engraving.
Whether its 2.8 do not know, but should. To charge rather than 1 bracelet.
With a larger number could be slightly reduced only in the charging time.
Such a charge would, in any case to give "industrial" 2.0 quality.
Foil wrapping is not necessary but can speed it up a little while charging.
In addition to joint locations, just need the mental command: "Charge 2.0".
Sincerely, MAG.no
Sincerely, MAG.no
Re: The Bracelets Of Life
MAG.no, thank you)
I know) I need to experiment))Маг.нет wrote:Such a charge would, in any case to give "industrial" 2.0 quality.
Владмосква
- Has thanked: 1 time
- Been thanked: 7 times
1) the Status, when I'm not BJ, it felt brighter. Like naked
2) Outflows related channels is quite possible, and not one. Thanks for the tip.
Often people with a negative mood - energopostachalna, i.e. the potential of 'Energomera'... with a positive mood - energy surplus, i.e. donors
But this does not means that you can not 'feed' loved ones, everything should be in moderation. In General, normal human communication(and not only) is the exchange of unwanted energies.
Not quite, although often there's more important factors are present. For example:АКВО wrote:People with often negative mood - energopostachalna, i.e. the potential of 'Energomera'... with a positive mood - energy surplus, i.e. donorsBut this does not means that you can not 'feed' loved ones, everything should be in moderation. In General, normal human communication(and not only) is the exchange of unwanted energies.
1. Contact. If there is no energy contact (even if you are face-to-face), there will be no "loss" to absorb the impact of the opponent. As well as partial contact - the degree of involvement in the interaction, the more the opponent (absorbing) it turns out to provoke, motivate, or as that on another to engage in the interaction, i.e. the stronger the contact, the can be wider than the channel leakage.
2. Absorption. Emotion if contagious, even in a good mood opponent, can also configure a channel for absorption of the energy.
3. Objects, events causing the response.
4. Strong-willed "punching".
5. The power of compulsion. etc.
I.e. it is difficult to classify the mood of vampires and donors.
Communication Yes, but human nature during communication to exchange energy in different bands. In 2 words, it does not explain, but vampires "eat" the energy of certain bands and not necessarily at them there it is not enough, just like their power system is configured, they don't even recognize it, and rebuild it just do not know how or do not want.
Another important factor is the state of the "absorbed" - potential, density, contravest, vovlekaet, stereotypes, and other physical and psychological "problems".
With relatives (vampiresim, mostly adults, more often women, but sometimes in different ways), you can build a "safe system" of interactions, where "the wolves are fed and the sheep intact". If they "need" to take (povstrechalis), you can choose when and what to give or not to give (not getting involved in the interaction of emotional, mental, etc.). Michael_ as recently described (probably on his forum, can't remember exactly) communication with his mother, a very appropriate and useful example of effective energy exchange.
In General, things are not so simple in each case can be different....
And the normal balance is not preserved, reasonable exchange (collection and waste).
Even in the interaction of the vampire can not feed, if you take action.
Sincerely, MAG.no<
Michael as bracelets affect food choices? The food is all tired and pull on something that is not familiar. But it is unusual and yet not be absorbed wants.How to be?
Владимирович
It has a 2.6? Anything that it is hidden under the epoxy?Маг.нет wrote:For "prototype" charging can be used 2.x having a laser engraving.
Personally I use 2.5, BUT
Sincerely, MAG.no
Маг.нет wrote:is it Possible as (in their spare time) to use FOR CHARGING bracelets-items system 2.0 (KO) as a charging matrix? How much is reasonable and effective?
hereМихаил_ wrote:2. you can use, but exactly how any BJ older 2.x versionwhere on the link of engraved charging system are in fact (and it working). Only clock is more complicated - there is only one sticker, and bracelet lot of links, so effective bracelet bracelet charge. But until the full charge is 2.0 far.... although FOR sure there will be.
Sincerely, MAG.no
Владимирович
Thanks for the reply!
The charging time is what should be at least approximately?
Depends on the material, from massiveness. A couple of hours.
You can slightly speed up, wrapped in foil, but only slightly.
For copying the object to activate "Charge 2.0" mental command.
it is Not recommended way to make 2.0 for others, only for themselves.
Reset TO "copy", can reset TO the original, much ruined 2.x....
Sincerely, MAG.no
Sincerely, MAG.no
Владимирович
Thanks for the replies!
All 2.x have the SAME engraving.
uncoated 2.5
coated neutral 2.6
with the coating composition Neutro 2.7
with the coating composition of NATO 2.8
the command "charge 2.0" actually, no(and therefore impossible, for example charging with 2.0), but probably a mental promise to a greater extent activate the job FOR it to charge, especially if the band is not 2.5, in which the charging figure as a whole is open (on the surface). Foil useful.
The charging time is 2 days. Good - day. Normally at night, if you need to quickly, and the hour will be enough for small items, and for greatly exceeding the size of 2.x - you need to increase the time is significantly desirable and insulation foil becomes more binding.
in addition, such charge 2.0 unfortunately our "factory" 2.0, i.e. it uses a number of factors, including a special screen and special fields, and so on. And on the bracelet only about a third of that.
uncoated 2.5
coated neutral 2.6
ie 2.0 will be exactly the same, but is less manifest. The functionality does not affect the power of a few affect.
And 2.6-2.7-2.8 in this sense, it is worse than 2.5, as there is to the charging system - coating. Ie, best of all, this trick works with 2.5
to the topic of energy exchange. after a long pause met with a friend who openly said "eat" me, absorbed energy, and now he sensed that I learned how to dose this process that it became more like a mutual energy exchange.
and I must admit, a whole list of friends "vampire", much less called me up and vampirate.
it's all subject to Results).
All right. This process is multi-faceted and involves not only the energy aspect, but not only psychological. There is a certain mental component, the number and quality of your energy and so on, i.e. many parameters which determine can eat or not. Often the psychological component of the leader (first person to throw on the return - then he gives himself), if you break the contact (for example, throw up mobile
), it often helps very effectively, since it decides a part of the psychological aspect. Well, after a while, stalling and the rest.
Michael, thank you
will charge))
Strange.... I have a set of those and nothing to this day has not fallen off with them(one of them 2.
. Yes spit (figuratively) it has its properties recorded think. In General, any hardening composition.....Normally flies have personalities that the quality is not very much survives.
the belt can charge the 2.0 version ??
if not the topic izvenite. I do not know where to write?
contact the "help Desk" on openmagicягуар wrote:strap can charge the 2.0 version ??
And... Peter finally overcame the engine and its not store
according to the official version that is what hampered this progress. Me that somehow ... well, not that purple, but not essential for sure.
