Disk Explorer
Post by Андрей Патрушев » Thu Dec 25, 2008 22:23
Ириска wrote:Please answer my questions :?
Ириска wrote:1. Please tell me whether the body temperature after an hour-half an hour after listening to "Explorer" to rise to 37-37,2? Listening to the disc today for the fourth time, the last two temperature rises.
Weather is bad and the work is cool, but if it were cold, you would have had other symptoms...
And so the whole day everything is normal, temperature is 36.6, and after listening up.
2. What can be associated numbness in the back of the head at the end of listening to the CD?
3. And still not quite understand about the goals: to put every time, before listening or for 15 (21) days work with just one?
Thanks again!
Can't be only what can't be... :)
The rise of temperature in the evening, for example, is common. Numbness in the neck can be due to the fact that You have not changed the position.
The purpose of doing this, which is topical for You at the moment. In the process (as a result) listening, it may become obvious that the old goal was not adequate.
Post by Андрей Патрушев » Thu Dec 25, 2008 22:31
Зловредный wrote:To Patrushev:
Thanks for the reply.
Although it is not very clear.
If you cut off from the "conductor" of the prayer, it will not affect its effectiveness?
First, it is not a prayer
I understand that it is not a prayer. Perhaps this word would be correct to quote, well, really how it happened. So this passage called earlier, someone from the forum and I found this word is convenient to specify the desired fragment. You do not understand what I want to chop off:), right?
However, this is not important. More important than the next.
Андрей Патрушев wrote:<...>
second, in this case, You risk to face in the end with the "seasonally"...
I will take my chances, given that I try to put headphones on immediately after turning on the drive, and after a short delay, so skip this fragment, and after the end of "meditation" take them off immediately. Moreover, I do not really understand in this case what do you mean by "seasonally" and because it doesn't scare me:).
Maybe I'm overly cautious, but I still wouldn't want to have something that I really don't like and is evidently inconsistent with my worldview has permeated my subconscious. Sorry if still, delete initial and final fragments, beginning with the words "the Lord is one..."deprive the listening efficiency (which I doubt, but I think You know better) - I would not want to discontinue the course in the middle of the (today the twelfth day).
I understand that you can not please everyone. But with creative thought, finally. :) For example, the Creator may be Your DNA... Explorer for a long time existed without these words, but the number of cases and situations led me to these changes.<
Зловредный
Post by Зловредный » Thu Dec 25, 2008 23:16
For Patrushev:
I, of course, being conscious, can demonstrate creative thinking. But something tells me that my subconscious mind will perceive the current text literally, as his usual.
Hard enough I had to start doing with Your discs... But get over yourself I won't do it.
In General, as I wrote above, the issue has been resolved - will cut and what will be will be:).
But, in fact, a comprehensive answer to my question :ay . Cut "on the ears":).
Thank you!
Ириска
Post by Ириска » Fri Dec 26, 2008 0:42
Andrew, thank you very much for the answers!!! :o
A good thing do :ay
Has thanked: 478 times
Been thanked: 264 times
Post by ЛИЛИЯ-Р » Fri Dec 26, 2008 1:24
Andrew thanks for the CDs from my mom. I've had it a month and listened to the Conductor of Healing and Massage of the Brain. Usually when she came home there :wiz brother one hosted. And this time it came all at its best.
Before I told her to change their thoughts and attitude and everything will be different. She didn't believe and only scolded him. And I was told that everything is complete, the whole business.
Listening to the Conductor and the other drives she read from a sheet of affirmations (I wrote to her what she would like to change).And here is the result! All because she wanted to. Calls me and says thank Andrei Patrushev. She knew I wrote about it in the forum and swore that I write. And then she asked. Although I thought quite hopeless with it. So many years I tried to tell her that and talked but never came to it. And then test the first time listening of the Conductor and the moms began to ask questions on change of the consciousness. :wiz
Yeah I can't believe that the changes went. Because my mom like a saw "friendship" said that this is not a cut.
Thanks again from me.
Евгений Кош
Has thanked: 2 times
Been thanked: 2 times
Post by Евгений Кош » Fri Dec 26, 2008 10:35
Зловредный wrote:Although, I think that his answer will not change anything. I will cut this piece or continue listening as before - with the delay in the commencement and early termination at the end.
and remember.. this text is created by a man who believes in "the Creator".. all the text is just steeped in this knowledge. So I'll cut you even though 99% of everything from the conductor, but even one letter is pronounced like that already carries the information about its knowledge.
blowing or empty "into the subconscious" ( as naively said "penetrating the subconscious"), you represent only about your current lack of understanding of the processes surrounding.
Give only the direction -> is the subconscious decides to Put in mind that either or not to start. but if Your Consciousness (burdened with some kind of a thing) resists and decides that it is start - that is the road of development is long and complex which is sure to be a complete revolution of values.
in the top and bottom.. what the bottom and top. :)
АлексУжг...
Post by АлексУжг... » Fri Dec 26, 2008 11:22
Fourth time listened to the Conductor. Any color and other effects while listening. At night healing. Woke up from the fact that legs from knees to feet sweating. In General, I will continue.
торк
Post by торк » Fri Dec 26, 2008 13:34
the disc is accidentally scratched, in consequence of that lost ending at 1.5 or 2K(where the output at one, two.. meditation completed) :oops:
because when listening I often fall asleep found IT on 5-6 times of listening :shock:
to leave so or to sienite new?
Евгений Кош
Post by Евгений Кош » Fri Dec 26, 2008 13:37
торк wrote:to leave it or sienite new?
IMHO better than the new one.
Зловредный
Post by Зловредный » Fri Dec 26, 2008 13:41
For Kosh:
My dear, You have decided to change their roles from "bung for each barrel" to "annoying fly"? You nobody asked. And the conversation does not concern You.
I have previously made You aware of the fact that Your opinion is not interesting to me.
Given that I didn't ask You any advice, Your condescending and didactic tone in the communications sent to my address absolutely inappropriate, and I'm inclined to perceive it as disrespectful. Save it for those You interesting.
Евгений Кош wrote:<...>
The subject of Your pseudoanalytic ekzortsistov, the result of which is this, absolutely not related to reality ravings, are Your fantasies about the object, not the properties or actions of that object. However, that goes for the rest of Your fantasy "assessments" of me and my words. Because not for You to judge the level of my understanding of the surrounding processes. Before that pay attention to the development of their understanding.
I also know how to evaluate. For example:
1. Interfering with their "extremely valuable" advice and guidance "absolutely true" estimate, when You do not ask, and in those cases, when the conversation does not concern You in any way, and using a derogatory tone, You declare your exorbitant inferiority complex. Well, of course!? Suddenly without cost. Not being able to realize themselves in real life and feeling from that his inferiority, and you like You scour the Internet in search of prehomogeneous of forums like this, where You have the opportunity to snooping "without muzzles and leashes", "bark" and "bite" other participants with impunity.
2. His utter disregard for the rules of the letter You say about his emotional immaturity. After all, the rules created by adults to harass and humiliate the kids, right?:). Here's Your "nu-Nu" in the next topic proof. Language of the case didn't show me when I called him the "sverhkategorijnye" text? Do not be surprised, because it is so themselves and to behave like adults when dealing with strangers, Yes:)?
3. His disrespectful tone You provoke conflict and thus declare his complex of self-destruction. Not to mention Your extraordinary bad manners.
Did you catch it?
I ignored Your first attack, You are gone. It seems, even gave You the confidence that You stumbled on someone who will obediently for You to fulfill the role of the victim and You tried to "stick a needle in me" again. I had thought that after our last conversation, You realized your mistake, but troleptal pyrikov like You words, as usual, are bad.
This is my last polite warning - keep your disgusting yourself.
You keep on pestering me further, I will give You the direction.
I'm here on business, not to make up anyone to the company for empty talk.<
Евгений Кош
Post by Евгений Кош » Fri Dec 26, 2008 14:19
Зловредный wrote:my Dear, You have decided to change their roles from "bung for each barrel" to "annoying fly"?
Curiosity, and curiosity sometimes I look for the uninitiated :)
Зловредный wrote:You nobody asked.
No one? :) if your name is Nobody - the answer was - Anyone (that means not you).
Forum - a public place. Don't try to distort reality. To you in private mail, no one climbs. You said it yourself in a public place - and then agreed with the publicity. Receive a response in this case is a logical thing.
If someone is trying to "convert" forum for themselves as a means for PERSONAL communication - they are sadly mistaken..
Forum rules ( at the moment) do not prohibit post replies to messages from users.
If anyone wants to chat tete-a-tete and do not want to get a reaction from others - there are private messages.
Зловредный wrote:And the conversation does not concern You.
The conversation touched TOPICS :) Well the answer was in the SUBJECT.
Зловредный wrote:I have previously made You aware of the fact that Your opinion is not interesting to me.
Not interested do not read.
Зловредный wrote:you keep on pestering me further, I will give You the direction.
Playing not to flirt ..sometimes drown in your own snot :) Your attempt at intimidation - just touches :)
But as always, people with similar behavior as you, I leave You a chance to say their "extreme" word in the dialogue.. otherwise you can not sleep.. but not able and then.
everything passes and this will pass.
I'm even worse than you can imagine.<
Зловредный
Post by Зловредный » Fri Dec 26, 2008 15:41
You, as I know from the forum, used the disks Patrushev. Well, the way we write - from the inadequacy of the drives does not help.
Playing not to flirt ..and sometimes drown in their own snot :) Your attempt at intimidation - just touches :)
No intimidation, relax. It was just a warning that my patience is not infinite and my politeness towards You my patience will not survive.
If that can be pricked here is Your attempt to hide behind the publicity of the forum. This is the most publicity does not give You the right to be treated with disrespect to other forum members.
And this topic is for discussion of the "disk Explorer" and not to discuss other members. Besides Your imagination, as I've shown in my previous post, have no relationship to the disk.
Really it happens? The question is rhetorical.
"Sometimes I synonyms values
Awaken associations other:
Condoms - are the fixtures,
Well, the condom - surely the people"
Verse is not mine, but I agree with its contents completely.
All the best!<
Евгений Кош
Post by Евгений Кош » Fri Dec 26, 2008 15:58
Зловредный wrote:You, as far as I know from the forum, used the disks Patrushev. Well, the way we write - from the inadequacy of the drives does not help.
A logical observation.
From inadequacy within a certain stratum of society - not guarantee the "help" (IMHO). That's for sure.
Зловредный wrote:my politeness towards You
Зловредный wrote:Well, the condom - of course, people
Зловредный wrote:trilepton pyrikov like You
Зловредный wrote:Not to mention Your extraordinary bad manners.
:ay
Пианистка
Has thanked: 10 times
Post by Пианистка » Fri Dec 26, 2008 16:01
Dear Eugene Kosh and Malicious!
I subscribed to new posts from the forum. I think I am not alone here.
Please, if you need to figure out who's the baddest, or some other neponyatki - move it to private messages.
Very frustrating instead of useful information about the drives or their discussions, receive letters containing exercises in the manipulation of words - I would not read them, but until they open the link - don't know what letter.
However, I really don't care who of you in this virtuosity)))
I wish you all peace in the world)))))))))))))))))) :aa
Зловредный
Post by Зловредный » Fri Dec 26, 2008 16:11
Dear Tatiana! I'm sorry that discussion with me makes You uncomfortable. I would myself, with great pleasure the time spent in this idle talk, spend it on more useful activity.
Thanks for the wishes of the world! Same to You:)!
Post by Guest » Fri Dec 26, 2008 17:19
Татьяна_Я wrote:I Wish you all peace in the world))))))))))))))))))
:o :o :o
:o :o :o
Kosh
Пианистка
Post by Пианистка » Fri Dec 26, 2008 19:30
Eugene Kosh
Hello!
If you remember, in the early "orbits" of this thread, somewhere it was mentioned that sometimes the Conductor causes an increased sensitivity in relationships with others)))
Although, I myself have not experienced this - for all the time that I'm listening to the Conductor, I once had a nightmare. And the rest - all. as always.
The only thing I'm sorry for the other disks there is no voice of Andrew)))
PS Flowers always to nice and in winter especially))) :aa
Никакой
Post by Никакой » Fri Dec 26, 2008 23:20
Malicious
You are very attached to their knowledge.Completely ossified.Be open to what is inconsistent with your worldview.
Therefore, the reaction to Eugene you have such.
I recommend to you to be inadequate,rejecting the common responses to certain situations :)
Евгений Кош
Post by Евгений Кош » Sat Dec 27, 2008 17:19
Никакой wrote:You are very attached to their knowledge.Completely ossified.Be open to what is inconsistent with your worldview.
The person claims not from a misunderstanding of knowledge. The main claim is that he answered without his permission. and "threw up" and for weight is written to them - lost the essence. Which isn't just about me - it affects everyone forumyan. This behavior of people manipulating the rules of the forum "if they say I wrote that should answer that-it means all the rest of the grain and trying .. and someone will answer - that it will result in the type of my anger.. because NO one they say you never asked". and who wrote "nu-nu" he definitely showed the language in the monitor, what caused the abuse . And the fact that online answer freely, those who didn't ask - once classified as "submodularity forum".. but not perceived as freedom of communication.
That's the point.
Such behavior - I will fight always. Because here ( until the change the rules) - will answer questions not from the fact that INDICATED who should be responsible and who is to shut up.. and to answer those WHO WANT .. and the only way.
and all sorts of insinuatsii trumped only (tone of writing I supposedly insulted, saying that he thought so badly of me.. probably thought something worse than an asshole when he wrote, etc) to arrange to covered their true goals - not a ride. A lot of people here who see the point.
and if it will be moved to the flower bed, then so it will be better.
Евгений Кош
Post by Евгений Кош » Sat Dec 27, 2008 17:58
Татьяна_Я wrote:Eugene Kosh
Hello!
Yes , it is .. Although Andrew just says that the wind is blowing from the trees sway. :) Here and now, my opinion is that the Guide helps a person "hear better" and if the inside was informed once muted aggressiveness ( as happens, for myself I know.. mad at someone else, but I understand that to do nothing and push it inside.. and after a certain time, like as already and not evil.. but ! it may just "rough" feeling) then again start to feel it..
Personally, I have to first listen to the conductor (after the session) so it was aggressive to all others. when introspection is unexplainable .
So here is my opinion now (here and now) about the "increased sensitivity" :)
Sorry?.. no offense to Andrew :) His voice is a crutch which you need only for a time :) Don't get attached :) IMHO in the end the work with the conductor to be born\appear\Wake up\Wake up to Your inner Guide, who knows More what You need than anyone :)
Here's another :o :o :o
Post by Андрей Патрушев » Sat Dec 27, 2008 20:59
What an insult - I'm about the same write on the forum. :)
Никакой
Post by Никакой » Sat Dec 27, 2008 21:13
Eugene Kosh
Primarily this:
"Although, I think that his answer will not change anything. I will cut this piece or continue listening as before - with the delay in the commencement and early termination at the end."
The rest is the rejection of information that does not correspond to his knowledge.
Евгений Кош
Post by Евгений Кош » Sat Dec 27, 2008 21:18
Yes! that too.. but it's his choice as he wants well supplied, in this case, his "cut" does in forum relationships not affected.
p.s. I'm even! those people who "sharpen" the Explorer by itself. :) for example I had a few "mentally inserts" in Explorer, when I heard a certain period inserted\woven into Andrew's own additional words ( uttered to myself) type complementing :) what causes internal response approval .
Пианистка
Post by Пианистка » Sat Dec 27, 2008 21:20
And I have the impression that it was just a Troll... :aa
