The word "Colonel" is somehow annoyingАура wrote:Engineer and physicist, Lieutenant Colonel air force Moroshkin, D. I., in collaboration with the Swiss company "Aurum AG"
Bioresonance modulators
Re: Bioresonance modulators.
Andrew! If I understand correctly, the CCM device can be any device broadcasting in the MHz range Or a range is of fundamental importance?
Can anyone of the users poyasnite please. I mainly used a very tight city line phone at work is ringing non-stop. Mobile almost never use. Even I use the tablet a lot, but he does not use the mobile connection and Wi-Fi. I'm not really versed in Hertz, tried to educate myself about the technology that is available just about gertsevich ranges, but it turns out that neither voroskoi phone or tablet, do not fall under the data frequency - as mobile. Could you list what is a device in the MHz range at the household level? Ie I'm trying to figure out where else to stick to BRM. Would be grateful for any info. Thank you.In principle, it can. And not only in the MHz range. In the KHz and GHz ranges, too, can. But it will be different formats of antenna field. Not every transmitter has a wide network of access to GAIP as a mobile network. Despite the fact that the mobile phone has a low capacity. Although the idea of connecting BRM to powerful transmitters (not tube) are correct.
Good day!
I plan to order BRM, mastered all 52 pages of threads of discussion. But still there are a couple of points regarding the operation of the device, which remained for me not absolutely clear. I will be grateful to you and all the other knowledgeable people for clarification.
Crystal laid in the intention, method of laying clear. But here's the question, if a person nakladyvat intention, for example, to pay off their debts. Then switch focus and use a smartphone in his usual casual mode, communicates with people, solves issues and problems, in which these debts are present, i.e., most of the information "traffic" through the phone for just problems, not their solution, that will not happen if the record in the crystal opposite information as the dominant in the information space of the operator? Debts I gave as an example, to put it more simply, can harm the operator himself using BRM, if you do not know how to adequately control your thoughts and emotions? Or another example. People want to improve their health. But at the moment here and now he is sick, i.e., his identity is aware that in the body the problem. BRM is taken further, there lays the intention to heal, to improve their health. But the identity of the operator is still aware that the body aches, because the miracle does not occur instantly. How will act the crystal in this case? Whether there will be overwriting the original intention to gain health on the intention to stay in a state of disease? After all, if the crystal is always in the wave field of the person, and written in it that the man dominates. Dominated by fear or uncertainty, you get fear and uncertainty many times reinforced?
Who use BRM on your tablet Wi-Fi, email, does it work? Share your experience pliz
Aura
- Has thanked: 22 times
- Been thanked: 1124 times
Mobile network as one of the most active and widely used technical components of GEIP, in the chain of work BRM is a “translator” intention of the operator is required. Tablet with wi-fi for BRM is not suitable. Used frequency - of 900-1500 MHz.Ким wrote:could you list what is a device in the MHz range at the household level? Ie I'm trying to figure out where else to stick to BRM. Would be grateful for any info. Thank you.
p.s. the question was answered many times already in the thread
p.s.s. developers may also can relax
Aura
Do not confuse inherent intention and everything that is transmitted directly through the CMC. When the intention is laid, the operator creates a positive setting, as described in the instructions and discussed in this and other branches the General rule is well-formed intentions - not only for BRM, as an affirmation or setting for the subconscious including All channels of information flowing through the gadget is the activity of the center, their color is not important, important is itself a activity.Ф. Ли wrote:But here's the question, if a person nakladyvat intention, for example, to pay off their debts. Then switch focus and use a smartphone in his usual casual mode, communicates with people, solves issues and problems, in which these debts are present, i.e., most of the information "traffic" through the phone for just problems, not their solution, that will not happen if the record in the crystal opposite information as the dominant in the information space of the operator?
Ф. Ли wrote:uses the smartphone in his usual casual mode, communicates with people, solves issues and problems
Contradiction...Ф. Ли wrote: most of the information "traffic" through the phone for just problems, not their solutions
The ordinary crystals are different from crystals in polarized BRM if the first is sometimes worth akkuratisty, the latter have a positive organization structure.<Ф. Ли wrote:I wonder if overwriting the original intention to gain health on the intention to stay in a state of disease? After all, if the crystal is always in the wave field of the person, and written in it that the man dominates. Dominated by fear or uncertainty, you get fear and uncertainty many times reinforced?
Please clarify how to understand this positive organization structure? In my understanding of BRM is a tool, a hammer kind. What it will provide is what you get. In a polarized crystal I can lay negative attitudes, and he does not realize, or what? And as the device will determine what is for me a positive and what is negative?Аура wrote:ordinary crystals differs from that of the polarized crystals in the BRM if the first is sometimes worth akkuratisty, the latter have a positive organization structure.
Aura
Crystal has the perfect shape, so positive or negative is determined quite objectively – the perfection of the structure (shape). Crystals read not all information. Crystals with a positive organization structures tend to read information, an approximation to the perfect form.Ф. Ли wrote:please Specify how this is to understand positive organizing structure? In my understanding of BRM is a tool, a hammer kind. What it will provide is what you get. In a polarized crystal I can lay negative attitudes, and he does not realize, or what? And as the device will determine what is for me a positive and what is negative?
Clear. Thanks for the repliesАура wrote:Crystal has the perfect shape, so positive or negative is determined quite objectively – the perfection of the structure (shape). Crystals read not all information. Crystals with a positive organization structures tend to read information, an approximation to the perfect form.Ф. Ли wrote:please Specify how this is to understand positive organizing structure? In my understanding of BRM is a tool, a hammer kind. What it will provide is what you get. In a polarized crystal I can lay negative attitudes, and he does not realize, or what? And as the device will determine what is for me a positive and what is negative?
Hello! He is a BRM? Glued to a smartphone battery in it. Only the crystal. As it can affect the operation of the phone? To turn it off or not charge? The problem is rather in the mobile-phone. Regarding the numbers it's just the attention, and imposed. I have no BRM, but if I look closely and pay attention to the numbers are the same, it is also possible to memorize them. Nonsense. It seems I am far from this topic. But still ordered. Check it out. How to activate, be sure to accomplish your goal.
Цикарадзе Тина
- Been thanked: 1 time
I was interested in BRM, only how to choose the modulator can not be determined.
I liked the Smoky quartz BRM and BRM GA BALANCE (Bridge Garnet - Amethyst).The big difference did not see,but can't decide which one to take.
Can someone enlighten me?
- Иван Славов
- Has thanked: 650 times
- Been thanked: 150 times
My BRM Smoky quartz gave. And on my phone when I use it on a phone of a man who now uses - works on implementing the desire. BRM GA BALANCE such progress in the realization of the desires is not shown to me during use. He has other characteristics - read everything in the description is.Цикарадзе Тина wrote:I was interested in BRM, only how to choose the modulator can not be determined.
Цикарадзе Тина
Thank You Achim.I was interested in BRM, only how to choose the modulator can not be determined.
For starters acquire a Smoky quartz,but then we'll see
Also I tend to smoky quartz, but it is difficult to make a decision, I want this and that, the result is still nothing. Recommend please dear users, what fits better to the Scorpions?
Good time of day! Bought, stuck, waiting. Conceived intention. Nothing usual as said by other users does not occur. Only that you feel more confident. And nothing. We will wait, maybe even not activated my verdelite. Though only took 4 days, as pasted
ПавелАлексеевич
- Has thanked: 66 times
All good health!
Not a lot of confused, help please!
The manual says to attach BRM on the phone...
Advanced comrades is recommended to stick to BRM on the phone battery...
Better still, revive this Miracle?
Thank you in advance for understanding!
Written, then that's where to attach)))) Can not be glued, under my silicone case just put in, but cut himself under the crystal hole. BRM is not lost, it is possible to withdraw at any time, contact of the crystal with his hand, and protection in the fall.ПавелАлексеевич wrote:the manual says, BRM to attach to the body of the phone...
I have SMOKEY and the bridge of Mr. A. the Work of both coincides with the descriptions. SMOKY is very strong in defense. The bridge significantly increases sexuality and just wildly energetic. The difference is huge. BRM-s magic...Цикарадзе Тина wrote:.The big difference is not found
Цикарадзе Тина
Yay! Got my BRM Smoky quartz.
A feeling as if a magic wand acquired.
During activation (5 days ago) expressed the intention to improve their performance, and today, she does not believe
made double the norm,so easily and quietly that and not noticed
Feel comfortable and confident.The truth is it can be self-hypnosis.I'll wait for the next results.
I have a question.How many intentions can be laid at the same time?
Aura
At the same time BRM works with one goal in mind. Before laying new intention recommended crystal drain - to several. hours (at night) to close any metal object such as a coin on the contacts of the crystal.Цикарадзе Тина wrote:I Have a question.How many intentions can be laid at the same time?
ПавелАлексеевич
Thank you for your question, thank you for your answer ! Aura, please tell me, if I'm close to two quartz and they four contacts closed between them, it somehow affected the health of BRM?
Thank you!
Thank you!
Aura
In health - no, the intention, Yes.
ПавелАлексеевич
Thank you!Аура wrote:For performance - not on the intention, Yes.
It turns out in this situation, we need to create a new intent?
