ATTENTION Summer discounts.
Been thanked: 10 times
Re: ATTENTION Summer discounts.
Post by Мастер 108 » Sun Jan 04, 2015 14:19
No match, Ivan, "programki for e-deck," we do not need random shuffle, and, m-m-m, intuitive. If you need is programs - use for the alignment Photoshop or some free analog supports working with layers.
Post by bofara » Sun Jan 04, 2015 14:28
I can understand it - the question is in General concerned mainly not to carry the deck, and about intuitive /not specified programmatically/ run on the smartphone screen tablet.
димыч
Has thanked: 7 times
Been thanked: 16 times
Post by димыч » Sun Jan 04, 2015 17:34
print to do on one side I understand...
even if you print on glossy photo paper and then laminated one side, then you can laminate carefully scrape them off the paper and the result will be a translucent printing on film...of course the quality will be worse than during direct printing,...
maybe the discussion is better to postpone the topic for alpha-Vitu...for General and convenience...
Has thanked: 13 times
Been thanked: 49 times
Post by ФилиНН » Sun Jan 04, 2015 17:44
These paper firms like his original paper to have a visible way the name on the back, as I remember, and we need it? About to tear do not know, I even in hands did not hold under the current paperless technologies. But now I read that some of the points of service print and on film.
Necessary nuances to clarify... That is, the adhesive film(simplification of Solomennoye? but transparent?). There are with a light-diffusing layer. Better?
Post by Михаил_ » Sun Jan 04, 2015 19:45
bofara wrote:I can understand it - the question is in General concerned mainly not to carry the deck, and about intuitive /not specified programmatically/ run on the smartphone screen tablet.
nope... need 9 physical objects. At least for this version of the deck, separate from each other.
Андрей Ермаков
Has thanked: 3 times
Been thanked: 15 times
Post by Андрей Ермаков » Sun Jan 04, 2015 19:55
I understand this film for making presentation slides, it should be hard.
Post by ФилиНН » Sun Jan 04, 2015 20:22
All kinds of different thickness. And for advertisements on the Windows and round tables, involving bending. And hard for us even better.
димыч
Post by димыч » Sun Jan 04, 2015 20:32
white or transparent - is there no difference?
Post by ФилиНН » Sun Jan 04, 2015 21:00
I don't know. :) I can only assume that the transparent - correct. The milk layer is how it looks when you zoom? Maybe some "regular" noise, like a picture of a "standard", only repeats itself, maybe just the chaos. Layer one side? There is no need to share a sort of strange individual cards from each other.
Here is the spec.lamination... order even a simple lamination does not matter? If in service give.
Post by Михаил_ » Sun Jan 04, 2015 22:53
Евген412
Has thanked: 18 times
Been thanked: 14 times
Post by Евген412 » Mon Jan 05, 2015 0:50
But if to print a set of cards (0-8) on the same sheet, collected in phtoshop one card, will this affect the result?
димыч
Post by димыч » Mon Jan 05, 2015 1:43
Michael said that this is his work files, and there are already other outputs,
I think that if someone custom Linux piece are all grateful ))
I have also when printing by means of Windows - remove a Daw with "image frame size"
still 2 extreme some a little bit not imaged, half of the numbers on the frame for example is visible.. hence already in the marriage goes. Well missing only 3 of the Central 2/3 of the frame...the print is obtained in a marriage or need to split hairs with the scale of the print.
Has thanked: 112 times
Been thanked: 71 times
Post by АндрейКо » Mon Jan 05, 2015 2:11
dimych xnview put a scale of 4 (and x and y ) when printing - everything is fine.(the printer Xerox 6000) have a little less than Bank card
PS - I'm afraid such things are Windows to trust - and to better scale the integer to take.(you can take 5)
Post by Михаил_ » Mon Jan 05, 2015 2:13
it is better not to print the different cards (different numbers) on one sheet of paper, is not fatal, but better not.
Евгений-М
Post by Евгений-М » Mon Jan 05, 2015 3:49
Have peremabiri a bit (put in a standard sheet of A4), set the resolution for printing is 200 dpi, the physical size of the card is equal to "factory" original. The TIFF format without compression.
View if there is no objection on file example, map-2, then the likeness will make and lay out the rest of the files..
Work for 15 minutes.
https://yadi.sk/d/BdNTk2y8dnaeN
Happy New Year to all! Michael thank you!
Андрей С.
Been thanked: 4 times
Post by Андрей С. » Mon Jan 05, 2015 4:25
I guess, in connection with the features of the gif format, the file format should not be changed. Michael will correct me if I'm wrong.
Евгений-М
Post by Евгений-М » Mon Jan 05, 2015 4:41
Андрей С. wrote: in connection with the features of the gif format, the file format should not be changed.
Think so too, but GIF it with compression, so I used a more generic TIFF.
By the way before Michael was PNG.
In any case formats need clarity, then it is better not to guess.
Post by Михаил_ » Mon Jan 05, 2015 5:02
well I recommend that kind of thing to use as it is... simply print of the desired size and forward.
the process of generating the picture - trailing in the creation of maps, I this in detail in one of the seminars explained and I will repeat once again. T/e/ work is carried out when converting the same data (primary) in the picture.
АКВО
Post by АКВО » Mon Jan 05, 2015 14:01
I have a 0 and 1 card more than the others on the 7mm, as it should be?
Евгений-М
Post by Евгений-М » Mon Jan 05, 2015 14:48
Factory card all the same.
Галатея
Post by Галатея » Mon Jan 05, 2015 16:34
Eugene - M if you will not be difficult to publish and the rest of the files as you first map posted.
Евгений-М
Post by Евгений-М » Mon Jan 05, 2015 17:16
Galatea you will do well all night, taking into account the comments.
Атом
Has thanked: 8 times
Post by Атом » Mon Jan 05, 2015 18:40
Happy New Year!
Michael thank you for your congratulations and a gift!
All happiness!
Расторгуев
Has thanked: 6 times
Post by Расторгуев » Tue Jan 06, 2015 1:11
Michael if you print as is,then they will be a little less like playing cards,and the original commercial (the ones that sent me to the office) they are smaller by about a centimeter. How to be or make great as-is or customized in size commercial?
Post by Михаил_ » Tue Jan 06, 2015 1:16
No difference.
