Advice from Andrei Patrushev
Гость2
Andrew, accidentally fell on your forum.
Interesting. Tell me, can I use these disks for my son 20 years old with a diagnosis of birth trauma (perinatal pathology of the Central nervous system) mental retardation - 2 gr of disability. The EEG almost no alpha rhythm as I was told, "functionalistic", although the guy is very good, musically gifted, understands a lot, but a complete "0" in mathematics.Difficulties with concentration, anxiety. Spoke as a child - hyperactive, now do not say anything do not cure anything...
But don't want to hurt. We are on the "razor's edge".
What are the doctors saying about it, are there any results on the EEG, what are the long term effects?
It's like some kind of science - psychiatry, for example, N. Bechtereva, etc.?
Sincerely, helen
Sincerely, helen
Andrei vi pisali
"I wonder what weirdo could put a diagnosis of "dyslexia" 4-year-old kid...?"
delali test proveray slux's podklu4eniem elektrodov .na Proxojdene Warner ... I sama na4ala bit' kolokola v - tak kak do4ka ne mozet raspoznat' zifri k primeru 1.2.3 - I u4ila's nei neskol'ko mesyzev (togo 4tobi ne dly viu4it' a dly togo 4tobi podtverdit' ili oprovergnut' moi somneniy) bez rezultatno. Ne mozet rebenok na kotoriy free talk 3 jzikax skazki rasskazivaet, obshaetsy bez problem s nositelymi jzikov , reshaet nezadumivays' logi4eskie zada4i dly mladshih sckol'nikov, o4en' vnimatel'nay ... ne v sostoynii viu4it' za neskol'ko mesyzev zifri 1, 2,3,pri etom arifmeti4eskie deistviy v predelax desytka proizvodit v ume. Tak 4to po povodu Disleksii vse verno. Vra4 skazal 4to such narusheniy vedut k disleksii.
No vopos ostaetsy. Mozno li ispol'zovat' vashi diski dly detey malen'kix? Esli da, to kakie? I vishla na vash sait kak raz po slovu klu4evonu TOMATIS tak kak nam vra4 nazna4il imenno etu terapiy.
Ариман
Andrew,
In my last question You did not answer, but Oh well. But on this answer? If sublimal is in English, my subconscious will accept? I know English perfectly, but it's not my native language. Like, there are words that I can not know the idea is that the subconscious mind must know all the languages, otherwise how to explain the phenomenon when a person after a trauma suddenly begins to speak in some ancient language. Or is the output already in the collective unconscious?
Ариман
I ask You why, Andrew... Because You're a very serious person with more experience. It is clear that You are not going to sing the praises of someone else's products, but I have less trust in the producers, because from them the truth about THEIR product just will not wait
Similarly, about Your products, I asked others. It is usually said that the audio tracks Patrushev honestly and conscientiously give what promised. Compared to the Thompson. There's also all honestly. Both WORKS. But a lot of stuff from other manufacturers is pure trickery, or very weakly active.
See: http://www.xtrememind.com/Deep%20Mind%20Ultra%202.mp3
These guys are using subliminal and NLP, and I do not hide. Promises they have extraordinary. Type, you can make ANYTHING (using eality Matrix). And this Deep Mind Ultra II. Free. Theta with subliminals, NLP and God knows what else.
You probably know by BWG presets Deep Mind 1-6. There has not been subliminal and NLP, but this thing was praised everything. What is Your opinion?
And another question. I don't understand the Theta-state, that it is the only one in which it is possible to do a Demonstration (the Epitome of Goal)? Or is it optimal for this? Can't be the only Mage usually carries a change of reality in a state of frenzied promotion of the psyche, up to the paranoid. This Is Gamma, HyperGamma. Used even orgasms (Tantra). So why is now such a fashion for this Theta?
Ариман
Нетрезвый Сурдопереводчик
- Been thanked: 1 time
about Tantra please do not give out all the secrets.here many are on duty at a computer with granary books and write down every wordАриман wrote: Used even orgasms (Tantra). So why is now such a fashion for this Theta?
so what? I was...after the surgery...couple of days I said in a semi-conscious state in some ancient languagewhen a person after a trauma suddenly begins to speak in some ancient language
Ариман
I reiterate that from what I know about sound and psychophysiology, I strongly contend that no audioerotica not and can not be. In the movies it all happens for only one reason - the Director said so. Since the last time, there was some kind of unhealthy excitement around the impact of a sound (even a movie now is it), then most likely something is going, but the sound of this "something" is just a cheap cover or "anchor".Ариман wrote:Andrew,
To the subconscious mind perceived subliminal, it should be for him true on the level of security or procreation purely for a particular individual. In this way, virtually any subliminal (without deep medicinal coding) works very poorly or not at all working... as for the promises, even Goebbels liked to repeat: "To believe in a lie, it must be monstrous".
All the effects that occur when listening to "audioerotica" and "subliminally disks" are provided with easy ISS characteristic of such discs and internal installation.
Yes, disk space wanderer (2nd track) done for children (school age) the technology similar to that of Tomatis.олга123 wrote:Andrei vi pisali
But, in my opinion, You treat your child like an adult, which is totally unjustified. All the time...
My CDs are not intended to cure anything.Гость2 wrote:Andrew, accidentally fell on your forum.
Sincerely, helen
Вне Времени
the theta-state=a state of meditation.once you've read a lot about Tantra,you have to imagine what it is.before consciously(or not)to enter into such a state,a person is first dominated by alpha rhythm of the brain,then follows a short burst of beta-rhythm and voila,you enter the theta state.using the entrance of the breath(and hence time) slows down,and...well, you know then.Ариман wrote:Is not the answer. I've read and studied, and nothing is confusing. Requires a clear response to the explicit question, but not a flood.
by the way,Tantra,Kama Sutra and orgasms packs are not one and the same.a well-known ritual of Panchamakara in modern tantric schools(about shovels "of the tantric followers" not a word, they can say nice words,but it is 100% false in the pursuit of money--people have nothing to do with Tradition and practice for samizdatovsky the Talmud)is not carried out.modern Hindu it is difficult to shift the awareness of drinking wine or selflessly Bang.Yes,there is a pair of rituals,but they are no more than rituals.
Ариман
Thank You, Andrew. Yeah not interested in me digital drugs
The word had, and all. Prefer natural. I'm interested in Manifestation.
To quote myself:
To quote myself:
Can you explain that, as a Developer?And another question. I don't understand the Theta-state, that it is the only one in which it is possible to do a Demonstration (the Epitome of Goal)? Or is it optimal for this? Can't be the only Mage usually carries a change of reality in a state of frenzied promotion of the psyche, up to the paranoid. This Is Gamma, HyperGamma. Used even orgasms (Tantra). So why is now such a fashion for this Theta?
Ариман
The elder,
Thanks for the reply. But I still don't understand why for Demonstrations mainly Theta? Or I misunderstand what this condition is best suited to control reality? When I do magical operations, as it is not meyrueis your wave system. If amplify Magic by Psychotronics, you should know which state is better to in. I did read that Gamma 40 Hz with its effect of "neural binding". It is believed that the frequency of the Schumann resonance. However, the program, all under the Theta made.
Brain without training is able to synchronize the frequency between 8-25Hz and below after training. At any point in time in the brain are present in all frequency range, so to speak only about power and spatial synchronization. Theta opens up access to those structures who are capable of "demonstrations"...Ариман wrote:Thanks, Andrew. Yeah not interested in me digital drugsThe word had, and all. Prefer natural. I'm interested in Manifestation.
To quote myself:Can you explain that, as a Developer?And another question. I don't understand the Theta-state, that it is the only one in which it is possible to do a Demonstration (the Epitome of Goal)? Or is it optimal for this? Can't be the only Mage usually carries a change of reality in a state of frenzied promotion of the psyche, up to the paranoid. This Is Gamma, HyperGamma. Used even orgasms (Tantra). So why is now such a fashion for this Theta?
Yes, God knows, - what will compare...Вне Времени wrote:hi Andrea!
Your products are very praised. I worked with discs Monroe, they made a long time ago and maybe Your achievements are more advanced. Do You have a product similar or close exposure Focus 15 Monroe? Or is it a classic of the genre, is not unique?
magical operationsАриман wrote:However, the program, all under the Theta made.
Last edited by Нетрезвый Сурдопереводчик on Fri Dec 18, 2009 11:22, edited 1 time in total.
Hello!Anonymous wrote:HELLO, ANDREW. I have a question for You. Recently purchased Your CDs. Use the Explorer before bedtime. Husband during the sessions was next. After a few sessions it became me just to drive to another room. Usually he doesn't dream (read - can't remember), and then traced that when I'm doing drives him to nightmares. And he's not lying, because I noticed that when he goes to sleep, spins, turns, twitches mumbles. Used to sleep is always calm. What is the reason?
It's hard to say... Maybe he fears that the marital relationship You are going to replace listening?
Ариман
Thank You, Andrew.
You want to say that Gamma 40Hz (they translated the recommendations of the Jeffrey Thompson) eliminates the possibility of synchronization of hemispheres? And those with the effect of "linking" all the information processed by the brain, enhancing neural connections, even the formation of new neural connections?the Brain without training is able to synchronize the frequency between 8-25Hz and below after training.
ONLY Theta?Theta opens up access to those structures who are capable of "demonstrations"...
Ариман
The elder,
"Magic is the art of causing changes in reality, to bring it into conformity with the Will of the Magician." A. Crowley.
Thus, any deliberate purposeful action is magical. Even to drink a glass of water.
I don't happen umarani, because I know that the word "death" is not hiding any meaning, is an illusion. Man by nature is Immortal, and, Realizing this, will never undergo the form of induction of false collective reality, which hauntingly demonstrates this lousy trick a sick magician.
God went out of fashion, do not tell me.
Magic may or may not be related to the TRANS state. No, on the contrary I do everything in a state of hyperconcentration attention and at the peak of the buildup of psychic power and the power of Intention. A state close to hysteria, but without crossing that line. Emotion is removed before the release of energy.
Vulgar medieval obscurantism. "Hammer of Witches" by accident is not Your Handbook? No creatures in all the Cosmos, stronger person. People Samoosas. Man is God, only firmly forgot about it. "Buddies" is not necessarily "inorganic". More often - other (than Your Identity) of manifestation of Your Higher self. it All depends on affirmations. Even if neogenic, then what? The Soldiers they are slaves, not masters. And, by the way, without this energy is impossible Wasps."but"--when you happen to die,your immortal soul will go in semi-perpetual lease "Friend".
Maybe God did it?only possible in the theta trance,all the magic and other meditation ...you will agree,not we ourselves invented,designed and assembled
I just want to say that these frequencies into the brain to "upload" through the periphery (hearing, sight, vibration) is impossible, and let Thompson is responsible for itself...Ариман wrote:You want to say that Gamma 40Hz (they translated the recommendations of the Jeffrey Thompson) eliminates the possibility of synchronization of hemispheres? And those with the effect of "linking" all the information processed by the brain, enhancing neural connections, even the formation of new neural connections?
The Delta, but it is also through the periphery is not loaded.Ариман wrote:ONLY Theta?
Вне Времени
Andrew,
Detail description of one of the disks:
I'll never know, what is the predominate frequency of entering such a state, but rather Theta, or even Delta? And whether it is achievable in principle by means of psychoacoustics?
Focus 15 is not so long ago in new equipment, "the doors of Perception", there's even instructions written by the voice of the son of Robert Monroe. It is "a condition beyond time", the state of just existence. In Focus -15 there is a feeling of lack of time, while the feeling of separation of consciousness from the body deepened further and reminds the state of deep sleep stages, with the only difference that the mind remains awake.Андрей Патрушев wrote:by the Way, I have long since disks Monroe doing - please remind - focus 15 this is where?:)
Focus energy 15 is recommended for the Establishment and implementation of what is intended, the intensification of our internal abilities with the clear Intent to manifest what is needed to Your higher Purpose in this physical existence.Exploring 5—Mission 15 Creation and Manifestation
Focus 15 is a state of stillness, a state of simply being. In Exercise 5, you will explore Focus 15 as a powerful state of creation and manifestation. From within the energy of Focus 15 you will be able to access the "ALL THAT IS" and know that your creative abilities are put into action through your intention.
