Universal structurer space.
Integrated control technology a reality
Россомаха
Been thanked: 11 times
Re: Already in sale! Versatile outliner space
Post by Россомаха » Thu Nov 24, 2016 10:43
US House optimizes space individually for each occupant of an apartment or under a certain average person?
Aura
Has thanked: 22 times
Been thanked: 1124 times
Post by Aura » Thu Nov 24, 2016 18:08
Влада Ми wrote:is it possible to use the device in a newly built house? So far, only the planned redevelopment. But we plan to change much there. Or it is better to use all the same upon completion of the work?
On any stage, at the stage of construction or the commencement of redevelopment it would be well.
Aura
Post by Aura » Thu Nov 24, 2016 18:09
Россомаха wrote:US House optimizes space individually for each occupant of an apartment or under a certain average person?
Depends on how You define the differences between “particular inmate” and “average inhabitant”.
Россомаха
Post by Россомаха » Fri Nov 25, 2016 11:09
The particular inhabitant with the number of GUA, maps Bazi. Ie, given the useful and not useful elements, sectors and trends.
Aura
Post by Aura » Mon Nov 28, 2016 15:06
Россомаха wrote:US House optimizes space individually for each occupant of an apartment or under a certain average person? The particular inhabitant with the number of GUA, maps Bazi. Ie, given the useful and not useful elements, sectors and trends.
The EOS parameters are determined by multidimensional timeless settings, line settings, which You listed, on the one hand, remain unchanged, on the other hand, are rebuilt based on new established connections. Our world and people as his part is much harder than linear parameters and their linear interaction, defined as “useful” or “unuseful”. It all linearly, superficially and temporarily. Figuratively to describe this: imagine a circle and a sphere. If on the circle we can find a certain point and define its parameters, then on the sphere the given function will be...also circle, that is, the set of points, and the question of the interaction of two linear parameters at once disappears, since the scope of the question extends to the interaction of two volume figures (and in this way correct, that is the real projection of the point is actually two points where the second is located on the opposite side of the circle that we already dismantled in answer to Your other question, and that brings us to the proper use of linear parameters), than in fact is the interaction of the operator and space – the interaction between the two forms of nature, that is, the interaction forces. In the linear plane of thinking and perception there is no concept of circulation, since there is no specified amount. Another thing that happens with the human linear perception in real interactions with the space time resonance (there is linear movement, but no circulation, in contrast to the resonance with the space). That is in fact is one of the ways of development that are determined by the integration in the space that too in this thread understood. That is why the integration into space – for the modern man – this is the main program for entering the interaction space. At the software level is determined and the spectrum of frequencies, and the mobility of consciousness, and software immune system, so we finally we come to the concept of the internal structure, and this is a discussion for branches neocolonial.<
ЛанаМайнд
Has thanked: 7 times
Been thanked: 22 times
Post by ЛанаМайнд » Tue Nov 29, 2016 14:32
Good Time to all. The issue has matured to the Aura. The house has a sick person, after a massive stroke. Lying for almost five years. Is such a person in the same space - not favorably. In General, people who are sick, terminally already, not good in the same room is. Here is the strongest weaning energy. Healthy people who take care of such people undermine their health. The structurer can help? Healthy yet people?
The situation is severe, effort and patience is greatly on the wane.
ЛанаМайнд
Post by ЛанаМайнд » Tue Nov 29, 2016 14:39
Generally seen, at insultion, even if there is not a vast degree of bleeding in the brain, greatly changed character for the worse. Climb the bad traits and personality. Well, with heavy - all the trouble. How many times have you seen a terrible picture. Not a trained person, who had no business with such patients, they are really scary. I have the feeling that the body goes in rent to the entity, and the soul flies out completely!
ЛанаМайнд
Post by ЛанаМайнд » Tue Nov 29, 2016 14:56
Then, there is a contingent of elderly with dementia, severe energy vampires, even if not in conflict, pulling energy from the household. Blood relatives, too many gifts. Not necessary to enter into conflict with them, and why? But the departure of a significant they are. Consciousness is static, rushing aggression, intolerance, etc. they form in the space of those holes (portals) - where and rushing things.....
Aura
Post by Aura » Tue Nov 29, 2016 21:19
Lanningthe situation is serious, but not negative. Rather thin than heavy. To describe the situation here for some reason will not answer in a PM.
кросби
Has thanked: 56 times
Been thanked: 33 times
Post by кросби » Mon Dec 05, 2016 21:52
Aura
Hello.Acquired US and in this connection there are questions.
1.All standard programs are on hiatus.They all fit together?For example, you can simultaneously include the "meadow" and "space mountains"would not venegret?Or do you have recommendations on the combination?
2.Describe amps."auto"mode.
3.If not difficult describe additional programs:"ecology of space", "lead chains","climate","stop time".
4.How important is the location of the WHISKER:in the room where you sleep for example or at the other end of the apartment - in the room?
Thank you.
Россомаха
Post by Россомаха » Tue Dec 06, 2016 10:57
кросби wrote:.How important is the location of the WHISKER:in the room where you sleep for example or at the other end of the apartment - in the room?
And yet, it is better to put on the floor or on the rack or on the windowsill?
Россомаха
Post by Россомаха » Tue Dec 06, 2016 12:27
кросби wrote:.Acquired US
Share your impressions and feelings about the work US.
кросби
Post by кросби » Tue Dec 06, 2016 13:28
Wolverine
a couple of days-I will unsubscribe
Aura
Post by Aura » Wed Dec 07, 2016 22:04
кросби wrote:Aura
Alchemy, not the vinaigrette. This non-linear settings, so the salad will not work. Contradicting (mixed linear preferences ) and the impact of the programme was divided into Home and Office. All programs from one package can be activated at the same time, the default match, it's like going into a multidimensional space, i.e. at one point the user will have an access to the space. It will all depend on the multidimensionality of consciousness, can be located in multiple spaces simultaneously. Meadow and Space mountains? There are high Alpine meadows... conditionally. Meadow creates a horizontal structure, the Space of the mountains is vertical, and there are high Alpine meadows, the horizontal structure vertical levels...I think it is clear. The question of compatibility of conditional programs in General, I like Home and Office are at home all the time, just because pereklichka honed, and work from home a lot. Conflicting programs can also be linked, would be geometry, usually users do not need it, it's a matter of necessity. Imagine a tug of war to serve this process in a harmonious characteristics required of the median power, not less power than the most powerful vector. I don't think a normal person is such "training" can be useful, so the packages have been split into Home and Office in one package all combined.
кросби wrote:2.Describe amps."auto"mode.
Auto mode maintains the current frequency characteristics of the space. The comfort zone can be simplified to correlate with the auto mode in neocolony.
кросби wrote:3.If not difficult describe additional programs:"ecology of space", "lead chains","climate","stop time".
Ecology of space supports the harmony of the interaction between the spaces of different levels. In other words, between micro - and macro-systems are also located structural (primarily informational) communication, which support the geometry of the total space of earth in the balance. This balance – balance in motion and continuous interaction. Ecology of space allows you to maintain an open and harmonious system. In practice, this means that the required energy will come from and no at the right time. Not a neighbor to come for the hammer, when it is most needed. The TV can be turned off at the moment when it is transmitting, which can provoke a response. And when you need for example salt, will suddenly come to the neighbor who'll lend...simplistically to understand. We are talking about all levels of interaction, including the level of the interaction space of an apartment with the state, etc. Ecology of space is a harmony of interaction spaces.
Lead the shackles like already explained the program work – fixing the low-frequency structures, which are often attracted negative emotions of the inhabitants or sometimes even random people. More specifically, present in the space almost constantly (who flew in the astral around the room, realizes a thoroughfare, not an apartment, any space has a lot of jump points), and negative emotions provoke them to certain actions, that is, given a definite food preferences. Someone knows how to interact with them and even use, some not... cats, for example, by nature know how to transform, that's how they treat people. Most of these structures are defined as “brownies,” or more vaguely “essence”. Lead shackles not removing them from the space, and exclude their possible impact on inhabitants through the cutoff of recharge. Record. Freeze. In the astral you still can meet and in normal circumstances they cease to act, because the clean channels of influence. Negative emotions can and should work, but there is space almost every where ST is the transition point, and low frequency structures begin to provoke, to demand the necessary food. This happens for various reasons, usually certain geomagnetic zone. And here either to move or to lead the chains. Although with the usual “house” you can try (if you live on the 1-3 floor, above the hobgoblins there). For educational purposes :)
Microclimate creates a harmonious space for interaction between operators that act on space, simply put the permanent inhabitants.
Stop time stretches of time, creating a concave structure that slows soliton-golograficheskie field processes of the brain. A wonderful program for recreation, rest and detuning from external fast rhythms. Allows you to increase the amount of free time for vacation.
кросби wrote:4.How important is the location of the WHISKER:in the room where you sleep for example or at the other end of the apartment - in the room?
And where, practically no difference. There are subtleties, for example, around Windows, in the corner, in front of a mirror or in front of the passage. But it is in "running" cases as an additional factor of influence, if to start to enumerate, it is a big separate theme. For the most part - does not matter. In fact, everything is simple, there are basic principles and they all boil down to the perception of the geometry of space, and here (from the perspective of individual development) to develop better perception than follow someone else's recommendations. For example, there are anomalous zones where as that is not place, all is one. A visit to these areas was one of the main stages of work on US. There is a similar theme of clothing, as the energy-shell, the principles are the same, yet much interest the subject aroused. All the time. And your space :) Perhaps a separate topic about Energoremstroy space will appear. There is a subtlety in the arrangement of the WHISKER in a vertical position (on a stand) or horizontal (just put a functional element, for example, on the table). This is another expansion of functionality. Orientation structure works differently from the base ascending and descending energy flows. Anything is preferable depending on the data characteristics of the space, for example, in high-rise buildings there is a General recommendation to use the horizontal option, but it depends on the geometry of the building, each particular case are best considered separately, so it's best to try both and use based on my experience.<
кросби
Post by кросби » Sun Dec 11, 2016 2:14
What would write a review ,it is necessary to have developed the sensing apparatus,I do not,consciousness registers the effects by circumstantial evidence,from the point of view of shamanism.The play of energies, it does not register.I only use it a few days,not every frequency I try.Unable to register a strong rise of physical condition in the morning,when going to the gym-physics jumped to thirty percent.
ЛанаМайнд
Post by ЛанаМайнд » Sun Dec 11, 2016 17:57
Good time of day. Aura can be the description of software packages, "Child", "Ethereal space" and "Protection of the fortress."?
Aura
Post by Aura » Thu Dec 15, 2016 17:58
Essential space and Protection of the fortress can be called basic programs, they are recommended for permanent inclusion and combination with other programs.
"Ethereal space"
Prime quality air space – ease. The program is well suited for smoothing hard and the hard energies (when the space “presses”). The program allows maximum display setting frequency, that is evident in the comparison changes.
"Protect the fortress” creates a layered shell according to the principle of the filter to external energies and the free flow of internal. The space has a pyramidal structure, but with different add – ons you can build up a picture of their turrets. First and foremost, the space fortress stabilizes the system protects against chaotic energies. Hence the name – the fortress - the space of stability. Second, the space fortress has grounding properties as the quality of support on the land quality interaction with the Earth's energies. Thirdly, add-ons create the internal structure, comfortable for every occupant, that is, create subspaces of personal comfort, which is particularly useful when several people live in one common space, for example, in one room.
The program “Child” builds up the space under the laid down period, which is determined by the specified life cycle of the parents (the lunar cycle at the time of conception). Depends on whether the child to be in fine or coarse environment, and how will progress in the future, that is, whether the pledged goods or springboard. Girls one period equals 7 years, boys – 8 (because of this difference, they say girls Mature faster, although the difference is really not that big). You can describe the program as using the space to overcome the necessary and inevitable social pressure, which is the process of growing up and education, and embedding in the company the experience of past lives. Software can be divided into several parts: the Experience of past lives, Interaction with parents, Correct breathing, the Digestibility of energy, Movement (physical layer), Toys, and Horizontal level, they, in turn, are divided into levels: natural, social and domestic. It is clear that the program is designed for children of different ages and wondering how it was to watch the program at the adult... man he learned to walk again, that is the use of legs as backup, but as a tool for interaction with the Horizontal level.<
ЛанаМайнд
Post by ЛанаМайнд » Thu Dec 15, 2016 21:35
Aura, thank you. Slowly dozakazyvayut program extended package.
супермэн
Post by супермэн » Mon Dec 19, 2016 23:51
How does it feel? from the outliner?
кросби
Post by кросби » Wed Dec 21, 2016 10:59
Aura
Well, one more request,describe:fireplace and pet names are clear,but I want to read the description,then almost all the programs will be described.
How does the frequency of the generator to work programs,such as the fireplace,the growth of plants?Are there any observations or recommendations?
Влада Ми
Post by Влада Ми » Sun Dec 25, 2016 15:45
ЛанаМайнд wrote:Generally seen, insultion, even if there is not a vast degree of bleeding in the brain, greatly changed character for the worse. Climb the bad traits and personality. Well, with heavy - all the trouble. How many times have you seen a terrible picture. Not a trained person, who had no business with such patients, they are really scary. I have the feeling that the body goes in rent to the entity, and the soul flies out completely!
Strange... but I'm such as people are increasingly observed in healthy people...especially when their jealousy begins to hladat. The feeling that there is something not quite awakened out of this world...very often such people nope was surrounded by my husband in his business. Call them "predators". But you have to take off to engage him and to me. They are often guests in the house, because under the status so. And I have every time the feeling that the house made the animals, and after them remains as a trace, as if marking their territory and consider it their own. a very strange feeling.
Lanning are there any observations on the work of the US? Thank you) And then want to buy, but did not dare)
ЛанаМайнд
Post by ЛанаМайнд » Thu Dec 29, 2016 18:19
Good all the time! Unsubscribe until that is clearly already evident, as in coincidence and randomness do not believe. First, with the acquisition of the outliner, had a very necessary and useful for me experience in my field of work, and indeed, I am entirely satisfied with these new acquaintances. That's what I needed, lacked. As if began to gather puzzles for further, more productive and prosperous life. This is the main point. Second, sleep has improved. Once better was to sleep and relax. Gone is the anxiety that at times rolled over. Now, if the house and people are very negative ( and sometimes) and energy trace of it remains. Thirdly, increased efficiency, she began to see what had not noticed before. Concentration, once under another host, everything is seen.What previously was hidden,or simply filters the internal missed. In General, Yes, there is change. But somehow it all folds up to keep track of exactly how and when is hard. In fact as already recognized
Vlad Mi, no doubt. If there are problems and the intention to solve them - structurer to help. To solve them you, he's just a help))))))
Aura
Post by Aura » Thu Jan 05, 2017 10:29
кросби wrote:Aura
a Fireplace the structure creates a Central, but the moving point-the area of maximum manifestation processes. This point of attraction and gathering attention for the cyclic detection of the external process and its completion. We can say that the Fireplace is one of the ways awareness of external processes, the program is suitable for individual processes, to dive in yourself, awareness of energy gathering and collective processes, discussions, gathering of group energy, pumping family egregor. The location of the Central point can be controlled.
Pet generates natural and some primitive social structure for more comfortable stay of animals in space. The program can reduce the level of anxiety and aggression of the animal, supports the implementation of pet in their natural energy functions.
Frequency does not change the operation of programs, rather, let it be different from the position of human interaction with space. Any structure can vibrate with different frequencies, it is probably more the challenge is not to set the frequency the program, and to grasp your own range. The functionality of the tuning frequency is not so much the extension of software functionality, how much the integration with space. Setting the frequencies – it's the quality of energy that will be attracted. By analogy, as the human brain, antenna, attracts certain qualities of energy. Energy structure remains the same adjusted resonance with certain energies. You can make an analogy with the movement of the body. For example, a person makes a move that is set to a specific external form. When a child learns to walk, it makes no sense to make him go fast or slow steps, learning to be. For example, learning, normal and comfortable for the person getting to do step 1.5-2 seconds. He is not conscious of this rhythm, not speeding up and not slowing down, if only the internal rhythms being controlled outside, you will not make him hurry. But if you offer a person to take one step after 40 seconds. this will create a certain tension (each frequency is characterized by a certain kind of stress), which in turn causes new quality of the same external form (in this case the step). To step for 40 sec. determines the higher concentration, tracking, and awareness of the process (in this analogy – the process of walking), and as a result, the other qualities of energy and movement energy body than normal, the usual-walking unconscious. Or, for example, ask to change the frequency in the other direction, for a quarter of a second. In an attempt to make a move quickly, the frequency determines the concentration and the density of the energy body, as well as the centrality, the other in qualities of concentration. I think the clear analogy, the same shape, different frequency, other quality. Quality defined by basic harmonic frequencies of the space is in the description of the frequencies. And in this analogy you can understand an important point, the frequency appears in the changes and relative to their own internal rhythms. And recommendations about the combination of the program-the frequency can not be, because the inner rhythms, if they are all different, but if not, then the experiments with the frequency space can help own rhythms to understand and build.<
Россомаха
Post by Россомаха » Mon Jan 09, 2017 13:10
And can be simultaneously with the US to buy a House one program in advanced package and how much it will cost?
Been thanked: 182 times
Post by Андрей Кабанков » Mon Jan 09, 2017 13:22
Programs can be purchased in your personal account. Below are the regular/club prices.
Child 4200/3550
Microclimate 3400/2900
Plant growth 2500/2000
Stop the conflict 3700/3150
Lead shackles 4700/4100
Converter unfavorable character-graphic information 4600/3900
Fireplace 3200/2800
Ecology of space 3800/3200
Purification from negative sound vibrations 3200/2800
Essential space 2900/2400
Pet 2500/2000
Stop time 3400/2900
Protection Of The Fortress 4200/3600
Structuring and harmonization of the substantive level 3600/3000
