The Card Is Masculine.
.Ксения.
Been thanked: 91 times
Re: Map Of Male.
Post by .Ксения. » Thu Jul 30, 2015 19:31
In any case, are you :) who, if not you? :) the card is just an auxiliary tool, though powerful. It is as if a man long did not go, and he atrophied the muscles of the legs, and then he gradually began to recover with the help of simulators or other auxiliary things. A person or a machine? :) I'd say the person using the simulator. After a while the muscles will regenerate, and the simulator will no longer need.
Астероид
Has thanked: 22 times
Been thanked: 9 times
Re: Map Of Male.
Post by Астероид » Thu Jul 30, 2015 19:35
So I want to make sure that I regain use of his legs with the simulator, not just walking down the street.
.Ксения.
Re: Map Of Male.
Post by .Ксения. » Thu Jul 30, 2015 19:43
In my opinion, what matters is that you are really positive changes and shifts were, and what exactly - is it important? :) even if it's just the placebo effect :)
Well, if only for my own understanding and how everything works.
Re: Map Of Male.
Post by ***** » Thu Jul 30, 2015 19:56
It turns out these "scratches" I'm the lucky :oops:
Has thanked: 112 times
Been thanked: 71 times
Re: Map Of Male.
Post by АндрейКо » Fri Jul 31, 2015 14:25
.Ксения. wrote:I'll post here a photo of the card, and Michael would later publish a detailed description (it is what it intersects with women's cards, especially where shared modules - a description of the same or similar).
Successfully received the card. Examined and found that asterisk in my map is not as pictured, but in a mirror image of the axis adusei from the operator.( or flip on long side and will be in my map.)
and the Pandora core silver - and the photo may not understand what.
Decided to ask just in case. (card working, I currently power more than enough from the defaults even uvinul 30-40%...)
Re: Map Of Male.
Post by Михаил_ » Fri Jul 31, 2015 14:30
It does not matter :) kernel Pandora can be different colors (basically go silver or gold, it does not affect the mentioned functions), the location of the polar rose on the nuclei is not important, although usually they are equally spaced :)
Re: Map Of Male.
Post by Михаил_ » Sat Aug 01, 2015 11:29
Reviews and discussion of test broadcasts moved here: viewtopic.php?f=31&t=5854 :)
Re: Map Of Male.
Post by АндрейКо » Sat Aug 01, 2015 15:23
Is it possible to adjust the speed of the card?
(don't have time to even watch what she's doing - because of low speed video interface)
The map is very "warm" cocoon - feeling somewhere on 2/5 from 360 degrees around (if kept under pillow at night).
If the led on the card with the index finger - felt polar rose.(the kernel also heat vary, in my case the core of the generation of individuals which is at the corner three polar rose triangle - but the individuals themselves do not see :) ).
.Ксения.
Re: Map Of Male.
Post by .Ксения. » Sat Aug 01, 2015 18:25
АндрейКо wrote:is it Possible to adjust the speed of the card?
Generally the map is made so that users with the most convenient it was to work with her. So - you can try, but if you want to slow down only in order to sync with the "video interface" and out of interest :) the effects work is probably slower to appear.
And yet you did not try to "view" the work is not in real time, and, say, at your own pace, as record, which can be slow/rewind etc?
Re: Map Of Male.
Post by АндрейКо » Sun Aug 02, 2015 0:47
.Ксения. wrote:And yet you did not try to "view" the work is not in real time, and, say, at your own pace, as record, which can be slow/rewind etc?
Cannot. Only in a certain state (not sleep and not wakefulness) and only real time.
Re: Map Of Male.
Post by АндрейКо » Mon Aug 03, 2015 1:14
A rather strange condition:
On the one hand I'm a little pribaldel from exposure, and on the other with occasional attacks of hysteria with aggression are observed (within norm, but nevertheless). All I need is a little understand what is happening and capacity is reduced.
Damage to equipment (PC, monitor, pair of digital TV box...) has been added and plumbing...
Re: Map Of Male.
Post by Михаил_ » Mon Aug 03, 2015 14:13
hihihihi :) Me then some of the characters yesterday complained :) for damage to the equipment and plans -I card remotely laid (on the Cabinet) prior to dispatch-delivery.
Корвин
Has thanked: 2 times
Been thanked: 55 times
Re: Map Of Male.
Post by Корвин » Thu Aug 06, 2015 14:13
АндрейКо wrote:has been added and plumbing...
Add a spoonful to the dressing shoes, cracked at once, bought the most powerful.
Дмитрий Т
Been thanked: 2 times
Re: Map Of Male.
Post by Дмитрий Т » Mon Aug 10, 2015 21:03
Michael, Xenia, and it is in this map, the analogue of 2.6 or 2.7 as a powerful pusher for doing things?
Or it is assumed that harmonic man, and so has the necessary skills
Ie, 2.6, 2.7 artificial pushers, and the male map helps to work out the man that he was a pusher
Re: Map Of Male.
Post by Михаил_ » Mon Aug 10, 2015 21:35
Дмитрий Т wrote:Michael, Xenia, and it is in this map, the analogue of 2.6 or 2.7 as a powerful pusher for doing things?
Well, let's start with the fact that 2.6 and 2.7 are independent products, which of course in the map are not included. They all have their own principles, which are documented and clear. And they are not artificial pushers, and trainers of the respective States and settings of natural aspects. Besides, they multiplie. And for men and for women are well suited.
In fact, the cards have been made as a versatile product, but not as a replacement for anything in the world :) and they don't make the relevance of classic BJ something below :) therefore, nothing is expected, they just have different objectives.
Naturally harmonious harmonious men and women and these including aspects of the potential more, but this is not to say that it is inappropriate to use 2.6 and/or 2.7 or for example the panacea in their quality (and perhaps in these modes), if necessary - homemade.
Дмитрий Т
Re: Map Of Male.
Post by Дмитрий Т » Tue Aug 11, 2015 6:26
Okay, thank you.
And how
- "drive" - the feeling of drive, inspiration and creative flow
This module tries to translate human is a condition and occurs whether the recharge energy? If a person is relatively speaking weak energy, and he will be a sense of drive, not whether there will be the depletion?
.Ксения.
Re: Map Of Male.
Post by .Ксения. » Tue Aug 11, 2015 14:00
Dmitry, a module (or stream) "drive" is set up in such a state, there is not mortgaged more makeup. Generally it is the state of limitless energy :) it's like the energy in your personal world, which is your creative capacity is infinite. Also, if the person here is in a good, creative, inspired state, it in itself is energy-rich. Module/stream could work as a "switch" in this state.
Other options - if a person has lack of energy, in the case of the first map can go (conscious or unconscious) elaboration of the reasons for this shortage, whether ancestral, karmic and/or psychological layer, or a combination. After your normal energy flow is restored, it will be easier to tune. If somebody with a lack of energy to deliver clean stream "drive", then there are individual options for... someone he can "not go" because you must first restore prosharenny energy in other ways, and someone on the contrary it can help just to get in this condition and to recover. The reasons for lack of energy may be different... someone, for example, it may be just from a lack of creativity and bright colors in life, in this case it may work out well.
.Ксения.
Re: Map Of Male.
Post by .Ксения. » Tue Aug 11, 2015 20:33
In addition to the previous post I remembered that I already asked a similar question about the broadcast module and the drive. Perhaps it will be useful to you:
I Have a map + drive+men's standard.
I don't know..When you connect up the mood and as the like swines. To me, when beginning to use a new product or stream.
Then it seems like nothing normal, but noted frequent small connection at home and at work..When there is full of matter and "immediately" found the right man in the hallway. Or get a call from a person who helps in full of the actual problem.
All this is against a small depressuha. Ie as strange - depression + drive. So maybe ?)
Answer:
Well, you have some things can surface and be worked on in the background... and also a note that POPs up some old emotions, blocks, but they just worked in the background, and not "fill" you in its entirety. Overall, from the standpoint of the control program and General functionality of maps was "prescribed" that such things were worked out gently and did not get out to the front, without them having to sink into them and live them again. To do this, including the algorithm made "three streams" - that man was a big support and your own wisdom in dealing with such things from his own past and ancestral experience. Therefore, it may be felt that the work goes on, but somewhere in the background and very gently.
Re: Map Of Male.
Post by Михаил_ » Fri Aug 14, 2015 1:04
By the way about "Drive" :) although I like this state of life is used and is present constantly, but with the advent of the card (I honestly afford to set one aside, although used and 10kω, and I think to back this up, more fun !) I began to note that I have it (drive) a lot more often showing brightly. And became himself its add :)
Even in the seemingly ordinary and sometimes boring kind of processes can be in a state of drive :) probably I used a few more rules stuck to their "ordinariness".
Re: Map Of Male.
Post by АндрейКо » Fri Aug 14, 2015 1:21
On the cards:
Masculinity: at work everything changed on 2/3... there is a big suspicion that the map caused a General cleansing of the body.(there is even a reaction to the skin)
Often began to remember his father (perhaps also a study in the background). May have been livelier in sex :)
my wife's card (Feminine): called study lines, daughter of(wife) mother. (quite severely). - she even said "independent experts" who do not subject BJ (engaged in removing the blocks for a different technology).
Collected today, the family Council decided to continue using the card.
The General opinion is a powerful thing , you can even say very.
Re: Map Of Male.
Post by Михаил_ » Fri Aug 14, 2015 5:12
Hahahahahahaha :) sounds simple five :)
Re: Map Of Male.
Post by АндрейКо » Sun Aug 16, 2015 1:24
There is still a strange and repeatable effect (when you sleep and the card under the pillow)
Wake up hours in 3 nights of thirst and drink 300-350 ml of water :)
(even got tested for diabetes just in case... everything is normal, your nose breathes freely...)
Perhaps in this way there is a recovery.
НРР
Re: Map Of Male.
Post by НРР » Tue Aug 18, 2015 21:29
Today I received an envelope with a card. From where the roses in a circle on the sides there is a stratification. Is this critical? If this layer is completely peeled will not affect whether it is a job card? He asked the office to give this moment the attention :evil: Or at all so? :)
.Ксения.
Re: Map Of Male.
Post by .Ксения. » Tue Aug 18, 2015 21:38
Work cards will not be affected, but if you want the map to change, of course. Sometimes mail letters "rolled", and if plain paper is not care, then the multi-layered plastic can affect so. So better card to send a parcel, not a letter. But when we did the second batch of cards, just change the technology that they were stronger in this regard, I don't know what you got. If you want to change - call/email to the office, you will change.
Жанночка
Re: Map Of Male.
Post by Жанночка » Tue Aug 18, 2015 21:46
I also have 2mm, I think that is when cutting was formed.
