алекс. wrote:OK, wrote a letter to the office. nick I your at registration indicated, but for some reason in the account information it is not, and there is no way to add it.
next question: I want to extend the stream and add a new item (IP). loose slots features, but opposite to the selected new product in the order is not able to select a group of slots. this product and its linking to existing slots will start automatically or need any additional manipulations?
Alex, nick added.
Disabled groups of slots can produce only one action - to extend :
that is, press the "extend" existing at the time the modes at the right time, or you can remove unnecessary modes, but do not add!!! and after you physically connect can "enable", that is, to log in is disabled, and opposite to them will be key to INCLUDE. Then You can add new modes to this group button to CONFIGURE, but do not delete!! to remove the modes is impossible in the current broadcast, to remove the modes is possible only in the case of an extension (see the beginning of the text)or in the case of physical disconnection.
....the second possible action, click on "enable", it is in the case described above in the case of "unfreezing" if You previously "frozen" slots or products)
You can personalise the profiles in only CONNECTED groups of slots.
If You want, as written below, run panacea in chaos mode, which is disabled, then You just click RENEW at the right time, and when ordering you need to select a group of slots with the desired mode of chaos!! but you need to have a group of slots with this regime, such as chaos was in the CONNECTED status. Or You can extend the desired group of slot machines with this regime, if it for example is also in the Disabled. Well, either buy new slots with the regime.
In the end, for any product need the group slot that contains the selected modes. So Your phrase is
to start the panacea in chaos mode implies the product is a panacea + group of slots with the regime of chaos.<
