In the help Navigator
Stavr
At me such happens, when the battery is "dead". Try to put the charging time 6-9 hours (night,the best time for these batteries) and fully withstand the charging time.
What is your firmware version?
Re: the help Navigator
latest 1.14
I have rechargeable batteries GP 2700
Stavr
May not fit the batteries?
"The opportunity to work from 4 NiMn battery size AA voltage 1.2 V"
well, I have 4 battery NiMn size AA voltage 1.2 VДимас wrote:Stavr
any deviations from the instructions
Stavr
Try to charge the batteries for a long time.
was in charge for 15 hoursДимас wrote:Stavr
see what happens then accomplish your goal
Don't forget to enable charging of the batteries in the Navigator.
Yeah, I just stuck the power cable - not a charger. In the instructions there is a table - how much to charge certain batteries (this time is set when switching on the charging mode).
so I turned the charging mode and exposed for 15 hoursАндрей Патрушев wrote:Yeah, I just stuck the power cable - not a charger. In the instructions there is a table - how much to charge certain batteries (this time is set when switching on the charging mode).
Hmm,strange. And so it was with the beginning of the purchase or was after something? That is, did I understand correctly that when listening to normal sessions, the device operates normally and when you start recording in the "audiostrobe" account suspended after a certain period? This happens only with "Explorer"? On the batteries that came in the kit was the same? If You press Play when you enable charging?СтАвР wrote:so I turned the charging mode and exposed for 15 hours
Алексей Крячко__
To ensure that you understand the batteries if the case, you just need to extract all of the device podkluchit network adapter and run the "problematic" mode in which the device stops working. If all is well, the case in batteries. It should be noted that the use of large-capacity batteries and long charging time still guarantees nothing. If the batteries of different voltage or rastellini they previously operated and recharged, you will play the role of so-called "memory effect". It will be that when you put them into the device and charge, up to the optimal voltage in all the batteries you pull out and some of them will be early discharged.
Therefore, the need to use the right set (4 pieces) which comes with the device or purchased separately. And all together in the device discharged and recharged.
what settings can I convert?Димас wrote:Stavr
You can not convert, and connect via line-in input. And I enjoy EAC
what is the format?
MPEG Layer-3 Codec (professional) 320 kbps 44.100 Hz stereo?
Vladimir Nikonov
Vladimir, tell me what the listening session in the evening and which in your opinion affect the number of ordinary lucid dreams?
about that trouble which was described above that the charge does not hold
in General, as it is intuitively found a solution
it turns out that the battery cover is not tight it is adjacent and they almost fall out and it is not full contact, placing it between the cover and Akka-mi paper the problem immediately sebau exhausted
simple OS does not happenПавлум wrote: easy lucid dreaming?
Stavr
Of course does not happen
A simple and lucid dreaming
Ochepyatka
Ochepyatka
Анна Сергеевна
Good day to all! The question in the first place to Andrei Patrushevalthough I'm sure someone else knows...
Didn't find the answer to this question in the forum, although perhaps it is hiding somewhere in the branches unread... "Open" points in the Navigator give you the opportunity to keep my eyes open during the session, it's understandable. There are a number of series specifically designed for viewing with open eyes. And this is understandable. The question is, does it make sense and is it acceptable at all to use the session with eyes open about which are not written, they are designed specifically for this? That is, how does this compare with all the sessions. And most importantly, does it make sense - does it give any advantages?
Thank you
Thank you
Unless you need to do something with your eyes open, it should close so you are more relaxed.
Анна Сергеевна
Andrey Kabanovthanks
Re: Program to create sessions.
I have firmware 1.15 - can't find in the Navigator, Explorer and so on. Tell me in detail where to find them and under which name they recorded? Thanks in advanceАндрей Кабанков wrote:On a flash drive already pre-installed drives A. Patrushev (explore, Healing, Endorphins, journey through the inner worlds) and two new programmes for relaxation.
Hello!
I have a version of Navigator 1.14
Very much I ask to help to understand a few nuances, because my two weeks of efforts to anything didn't lead
1. Explain-decode, please, that's specifically for files stored in the Library folder and its sub - abbreviation of the Latin I nothing to say, and details found only on basic sessions.
Under what names in the Library are marked: disc A. Patrushev, "Healing", "Explorer", "Endorphins", "Journey through inner worlds" mp3 program "Threshold relaxation" ,"Progressive relaxation". As well as the four audiostrobe program of Dmitry Shumova (Autostimulation lucid dreams, quit Smoking, Normalization of appetite, Normalization of blood pressure) and drive Angier Satori (Ethnic drums).
2. And, obviously, a very girly question
in Pathfinder are ordinary batteries or rechargeable batteries which can be charged in the same Navigator?
I would greatly appreciate the help of anyone who will help improve my "navigators" literacy
Batteries they can be charged in the same NavigatorСветочек wrote:2. And, obviously, a very girly question
All scramdisk and mp3 files are located in the second icon ,click on it,written PLAYER, flipping through gate-entry,button -triangle, choose the level ,color ,audio options, or simply click next,and choose any gate-drive scrolling.Folder-Noise as well and it opens all the files listed.Светочек wrote:Under what names in the Library are marked: disc A. Patrushev, "Healing", "Explorer", "Endorphins", "Journey through inner worlds" as well As the four audiostrobe program of Dmitry Shumova (Autostimulation lucid dreams, quit Smoking, Normalization of appetite, Normalization of blood pressure) and drive Angier Satori (Ethnic drums).
These files are located in the first icon-add. modes - next-Combe.with Essie-next, choose the session that are needed.Светочек wrote: program "Threshold relaxation" ,"Progressive relaxation".
In the second row ,the rightmost icon shows the battery charge. When charging be sure to insert the cord to connect the charger and enter the charge mode select the charging time and click OK(Treugolnik) charging went,lights up left green light and the right red as charged will burn both green. Completeness of charge watch on the bar in the same icon.Светочек wrote:2. And, obviously, a very girly question in the Navigator are ordinary batteries or rechargeable batteries which can be charged in the same Navigator?
Thanks for the tip!Воффка wrote:Batteries they can be charged in the same NavigatorСветочек wrote:2. And, obviously, a very girly question
in Pathfinder are ordinary batteries or rechargeable batteries which can be charged in the same Navigator?How to calculate the charging time is written in the instructions.
