About the players, soundcards and other Goodies...
Развивающийся
I, too, bought the discs, there was a question on what to listen to? The house is a laptop. But after reading on the forum opinion about listening to CDs on computers, I realized that it is not grateful. Here and bought a Sony D-NE730 for 2600 rubles, Malaysian production. Simple headphones. I do not compare with anything, so, I'm happy.
By the way, very much wanted to buy from the line Panasonic, but all were in vain. At online stores, where were they when ordering said that players no...with the exception of, for example, Vitek and other garbage, but you know....throw money on it........
So, I kept a count of the number of stores where I called about Panasonic 42 th, I gave up and bought in the online store latest Sony.
Mirich, due to the fact that almost all decent manufacturers remove CD players from its line, to advise a specific model does not make sense, as it is unlikely to be in the store. Very well said, someone on the forum that it is better to take disks and go to the store that is on the counter.
I took the Sony D-NE 730 (if you can find, take Sony D-NE 830, but they were already taken out of production, so as lucky).
The sound quality is very good. FM is missing, but I suspect you are taking it not for this.
Can write, what not to take - Panasonic made in China, because they will live long.
IRiver sound very good, but short ... all of it.
If you want to know a lot about iPods, then you here - http://www.player.ru/talk/.
- Оранжевое Сон-Це
What about the players that you can relatively easily get at the present time, the best is the Sony D-NE 830. In the CMC you can get here: http://www.mirinfo.ru/cat/goods.aspx?gd_id=79539 (Malaysian). The ratio quality/price better just do not to find.
Worth to mention about the Rockbox project:
http://ru.wikipedia.org/wiki/Rockbox
- alternative firmware for a large number of players.
Distinctive feature - support most lossless compression formats: WAV, FLAC, Wavpack, Monkey's audio, etc.
The acquisition compatible with the firmware of the player is a good alternative to buying the outdated CD player-MP3.
About listening copies of Audio CD on your computer.
It is clear that to keep a copy of should not in MP3 or OGG, and using any lossless codec - see above.
For reading CDs is better to use a properly configured EAC - when you first start the program you need to specify what accuracy is critical reading.
If you are using a sound card from Creative, it should be borne in mind that it is always an internal resampling (re-sampling) from 44100 to 48000 Hz, and with not the best algorithm.
The result of this retailinga significantly iscariots high frequency (for example, - AudioStrobe). Somewhere in the Internet was given two files with a high sound of the same frequency - only one file at 44100, the other in 48000 (you can make this file yourself). The difference when listening - are huge.
Also, on some models, the front of the DAC - worse than the rear. You can recommend:
1) to use an alternative driver http://kxproject.com/ - better algorithms, exchange the front and rear
2) player Foobar2000 http://www.foobar2000.org/
3) enable DSP for foobar - resampler - 48000, ultra mode
- high-quality resampling algorithm
4) the output of the sound through Kernel Streaming
- bypass post-processor sound Windows
Most built in sound cards behave the same way as cards from Creative, so apply the recommendations 2-4.
But, it is best to use a sound card, able to output 44100 without resampling...
About the compression in MP3 with the same frequency range and AudioStrobe - this can be done using the following command-line options Lame in EAC:
-b 320 --cbr-m s --noath --notemp --noreplaygain -k-q 0 % s %d
-b 320 --cbr use constant bitrate of 320 kbit/s
-m s - stereo mode (not Joint)
--noath - save the sounds for the absolute hearing threshold
--notemp - save the sounds regardless of the presence of a masking effect
--noreplaygain - ban analysis of the volume level
-k - to disable all filters (for high. the frequency, at low. frequency)
-q 0 is the highest quality algorithms
Comparison of the spectrum of the original in WAV and MP3 spectrum obtained shows significantly less distortion compared to the compressed files using the Lame settings by default.
High-frequency components is stored, AudioStrobe is working fine.<
Today I received the discs
The question arose on what to listen to.
CD-MP3 player I have, and not yet in sight
The computer has a Creative sound card, but the previous post made me doubt: is it worth the listen?
On the CD-ROM drive has a headphone Jack, the Play/Next and volume control. Maybe better to listen to it directly?
If Yes then can I use it at all apart from the computer, making Autonomous power supply
Rinat
CD-ROM is unlikely to give better sound than the sound card.
Yes, do not bother you so - the previous post was for the purists and audiophiles.
In practice, few will be able on hearing the oversampling 48000 notice.
If you want to join the purists - install kxproject and foobar,
if audiophiles buy Creative X-Fi (not the "X-Fi" Audio) - it is possible to listen without any resampling.
And headphones are necessary in this case to be no worse than the Sennheiser HD 280, HD 650 and better - without compromise - so they you any ultra-high frequency hear
Otherwise, why worry about such errors, which would still normally have nothing to play.
And if you are not hunting to be recorded anywhere - listen on the computer as usual - this is more than enough
It is a top hi-end model of the most famous companies specialized in headphones.
You can read here:
http://www.sennheiseraudio.com/ru/icm.n ... -end_09969
here:
http://www.ixbt.com/proaudio/sennheiser-hd-650.shtml
The price is about 12 Tr
Given their price, it can be assumed that they will reproduce even more than the.
For normal music. center these headphones overkill. Enough for the HD 280.
You can read here:
here:
Standard player does not contain such option.
Need to download the Kernel Streaming from here:
http://foobar2000.com/components/index.html
The plugin is extracted to the components folder, then in the player settings is necessary as the Output Device to choose what you want.
The player has a good Russian site http://www.foobar2000.ru/
Hmm. The review of these ears is already 3 and a half years, and the firm during this time has not released anything better.Джедай wrote: It is a top hi-end model of the most famous companies specialized in headphones.
Thanks, Jedi, I figured with Kernel Streaming. Do your links I found a lot of interesting plugins for all sorts of foobar. Tried the Bauer stereophonic-to-binaural DSP on conventional records - like. Much easier to listen to. Before some voiceless I felt when listening to headphones in the soup and get tired with time, and then the head. As you now believe the plug-ins like the Bauer stereophonic-to-binaural DSP (or 4Front Headphones, etc.) will distort the binaural records or these records is already the de facto ground under headphones?
Yes, similar plugins will introduce unnecessary distortion that predpolagaetsya to listen without extra processing.АВИ wrote:As you now believe the plug-ins like the Bauer stereophonic-to-binaural DSP (or 4Front Headphones, etc.) will distort the binaural records or these records is already the de facto ground under headphones?
Looking for CDплеер shopping, interesting picture, why is all that I examined does not see the drives that I set(Healing, Conductor) the only simple Phillips started to lose, but there is no effect of audiostrobe, glasses don't work, plays format MP-3 and WMA-CD,
A question for the experienced, in the above formats, the effect of listening of disks is saved or not. And then sent me the discs as I understand it with overwrite protection, even on a computer will not survive, how can flash players to pump? I ask because in the gland particularly not hack, as in programs...
All happy New year!!!
Николай Барбицкий
Николай Барбицкий
