Logik, I may not be optimally laid out.
The question is not how to do it rather a problem of beginners.
Much more important to make something working. And with that there are a shitload of nuances:
Sacred geometry in crystallography, compatibility and interoperability of stones, with the filler and shape resonances of stones, proportions in size and composition, etc., etc.
However, for many here as on fishing: the process is important..)))
SP. Stones
Re: SP. Stones
How to work with crystals Marcel Vogel? Is where to read?
Re: SP. Stones
People, has anyone heard something about Anchi (Anchi) crystals? What is it all about. Maybe it is not only in America?
Re: SP. Stones
ANCHI crystals (from Ancient Chi (ancient Qi)) is mainly tourmalines age more than 1.6 billion years. They are believed to have primordial energy of the Earth, so can be used in the relevant energotaktika. While sold in the United States, each instance has a unique number and recommendations for use. Think there'll be Chinese counterparts ))
Re: SP. Stones
Properties and, accordingly, the method of application depend on the number of faces and the size of Vogel. Its main feature - orientation, which is achieved due to the precisely calculated angles at the base and at the top. Often found in radionica, some not without success, used in Zhen-Tszyu.Димонъ wrote:How to work with crystals Marcel Vogel? Is where to read?
Where to read? google "vogel crystals"
Re: SP. Stones
that will give a stronger effect - crystal of tourmaline sharpened at both ends or 3.5 cm rhinestone ball 4 cm
arc option - crystal 1.5 cm x 4.8-5 cm or 4cm ball - both from rock crystal
I want to program on technology BJ or maybe SP make
the ball is most likely on the table in the workplace will be used
or can advise how best to use
photos unable to upload
Re: SP. Stones
someone can feel or meant to say crystal rhinestone real or fake?
seems real, but I would like to know your opinion.
http://yadi.sk/d/Y4vQk2t4hWT8d
Re: SP. Stones
A good stone. Made in Brazil (pendulum gives the rotation in the southern hemisphere). Casting from waste products (that is, the fragments and scraps of real crystals rhinestone and seems a little amethyst) to a stamp from a real crystal. After partial cooling (when the outer layers are already against his palms, and the interior still looked like the consistency of the dough) was thrown into the water to get the internal structure, then obsluhoval grinder.Эдуард wrote:someone can feel or meant to say crystal rhinestone real or fake?
For active devices fit completely in the passive is absolutely useless. Cleaning required (to be buried for three days in the ground, then under running water at the same time and in the final three days in the wind and sunlight/moonlight). After that you can very successfully be used on its own.
Re: SP. Stones
thank youк-13 wrote:A good stone. Made in Brazil (pendulum gives the rotation in the southern hemisphere). Casting from waste products (that is, the fragments and scraps of real crystals rhinestone and seems a little amethyst) to a stamp from a real crystal. After partial cooling (when the outer layers are already against his palms, and the interior still looked like the consistency of the dough) was thrown into the water to get the internal structure, then obsluhoval grinder.Эдуард wrote:someone can feel or meant to say crystal rhinestone real or fake?
