Bracelets Life
The module Explorer to the experience and the name of the module BJ. Description is on the website in the description section of modules.
In principle, the modules is a set of possibilities that leave flexible ways for creativity.
Explorer to the experience is the search of information verbal or non-verbal may direct (find an expert), may information (e.g. to dream something), etc.
Signal cartridges can be considered as the experience on which to focus.
In General, the cartridges assembled records are mostly not coincident with the modules BJ
Writing clear algorithms BJ and SK to do so:
1. a shared understanding. Cellular structures have an authorization system in computer. The user receiving the object (cartridge, SK, BJ) in job, retrieves the user access level. In bracelets and IC user access level has a very large opportunity, because there is written "enhancing the modules and objectives-the task uses", i.e. at the expense of BJ or SK or modulator (which charged itself with system 2.0) you can register any algorithm, it will work significantly more efficient than simply a thought-form. The density and durability is completely different.
The same cell structure, the cartridge - they are very simple and their task is simply to keep the information longer than with the simple infopresse, they are useless zero (they will not be programmed by the user because it is not set).
The algorithm for generating the channel can read with the transfer pair the module Explorer to the experience or just copy it from there (the cell structure have the f-tion of the copy block information in the file). To copy with the consciousness, not SK, SK does not copy the cell formation of no (this is literally not interinos, but something more complex).
that's all wisdom.
that's all wisdom.
- ГОРОДСКОЙ СУМАСШЕДШИЙ
- Has thanked: 115 times
- Been thanked: 1 time
Michael_, thank you!
Clarity full!
And it is possible in this or another thread of this forum post for a list and description of modules of different BZ (sold here) and specify additions and changes?
Interesting too is the list of the cartridges that are in development.
Thank you! You studied enough this issue!
Clarity full!
a list of all modules of the BZ is the same described in the thread my forum, replenishment is published there. And that branch contains virtually no chatter and discussion, a basic description of the modules.
As soon as I make all the mesh description, I will publish it separately.
All the updates at the same time pogruzhayutsya all bracelets.
( http://openmagic.org/ph/showthread.php?t=4)
however, long experience with the bracelets, says that quite often is to let go all on autopilot(this is usually very ideal).
then the subconscious works and selects the optimal combination of influences. BJ, especially above 2.0, very active awakens the subconscious.
A list of the cartridges under development it is hard to understand even for me. Here it is - you never know where that will is most clearly and successfully. Ie when it comes to the experience of using a discarded and unnecessary....
So I think, with the list of cartridges better keep on the topic of this forum.
In the near future I plan to release a special pair for modulator-SC that is different from unilateral transfers.
may also be cartridges on that topic (the vision) and several others.
In General, they can and hundreds to do, the question is whether?
it makes sense to only do something effective and original, different from everything already existing and real need.
A little sign, maybe useful to someone. The previous weekend, put the cartridges "General health" and "youth" in the UK, I BJ 2.6(Lev.hand) on the right.2.0. The sensation that the uterus is back in place (the women will understand, especially the one who gave birth) Men, pardon me for sex.
Today I received the BZ 2.5. BJ 2.6 has migrated to the right. hand(Yin), BJ 2.5 on the left. hand(Yang). For me BJ 2.6 on lion.the hand felt like something heavy was on the right side I would not have it.
So these 2 BJ very actively doing something in the body to the solar plexus
and from the body came out of the "surplus" energy the cold.
the left side on itself, right outside. I.e. the left Yin (mostly) taking over. Right - giver.(parties).
But it is still relatively arbitrary.
Ie and the person can be reconstructed on the specific impact and the bracelet is more "library", so you can read while holding in any hand, but some difference is still observed.
Clearly, the issue is no more. Thank you!Михаил_ wrote:long experience with the bracelets and said that quite often is to let go all on autopilot (it's usually very ideal).
And I think just...Михаил_ wrote:List of cartridges under development it is hard to understand even for me.
You see, the first stage of the manufacture of cartridges:
1. Select "setting";
2. Constructed mental;
3. Tolerated structure...
Received a full answer to your question.Михаил_ wrote:when it comes to the experience of using a discarded and unnecessary....
...Soon planning to release a special pair for modulator-SC that is different from unilateral transfers.
...it makes sense to only do something effective and original, different from everything already existing and real need.
Recent-funny: so I'm late to work ( well, at any time, except to the owner. Continue the experiment module "power-up probability" of my coming to a stop while the bus there with the validator ( scarce, but for me very comfortable ). And what is: fit - in stock: tram, bus, privately owned with a companion at the ready ( to pay in 2 times less ), but I chose the bus with the validator. Noticed not just a feature: options, each in principle favourable, but still have to choose. Yes...noticed demAs nervousness, conflict environment was at first and I remembered surprised. So a law, not individual bugs. To combat rolls with unbelief at times change the location of the bracelets ( Yes, even on his forehead to put ) - spec. feelings ( Michael does ) after some time I always find.
P. S. the Bearer of two 2.6 + two 2.0
Purchased for gifts 8 pieces BJ, wore one (I have SK 1M, thought enough) - no sensation (although sensitivity, "hear"), put 4 pieces, and here it is... something similar to SC 1M, only in "another place" and "stereo". Notice a tingling sensation under the bracelet (under the bracelets, but really at the same time unit, only one), while "tracking" things, you know the cause of the "disturbances"... Such is the experience of the first use... While leaving only one (after you have intention to BUY ANOTHER!), the rest - gifts for FRIENDS, PARTNERS, LOVED ones!
After all,
OCENET* HOROSHILOVA DELATITE!
After all,
Observation:
Going through the airport check-in, during the inspection, on the monitor is "lit up" (really like is surrounded by radiant light) 4 object of them on the chest of the SS and SB (both cards), as can be seen through were the pictures, at first glance something similar to a bar code (without numbers), and other small drawings. 2 other object - El. protection device and "source of energy from Michael".
BJ "does not light".
Such are the observations.
about "prosvetku" the most likely explanation is the impact of just material components (in the parlor apparently the foil?) and not operation of the device, although I could be mistaken.
In any case, such as the impact of those same BJ must be evenly distributed across the cocoon (irregularity still have the bracelet, but the operation of modules occurs with respect to all of the cocoon as a whole). I doubt that the influence and work of any of the devices will be reflected on the scanner, is the phenomenon of a slightly different type.
may or may not be...Михаил_ wrote:the impact of just material components
In pockets in addition to these items were still things they were shown on the scanner, but not light... the examiner stared for a long time... card and a "fingerprint" on the "source.", You do know that there foil can not be... the Type of scanner I don't know what to Domodedovo.
A question to all who may have friends is the examiners? Experiment, it is interesting to find confirmation (photo).
CRAZY town
Me at Domodedovo airport, Abu Dhabi and Colombo asked to make the room super with the neck, it seemed to them somehow suspicious, unfortunately the image scans I have ever seen. Then I went to put it in the Luggage to avoid crap.
well, in General I believe that the structuring of the flow of energy can change visible on the scanner.... Have to deal with this, it becomes funny. The principle is the same we see in the Kirlian, but there is contact shooting and high voltage.
about appliance protection issue in General is too complex because there is an active emitter (he was included?) and the source is fundamentally different from BJ the fact that he is not off. Ie if BJ is q-tion adjust the supply of energy (and its quality), + starting with 2.0, and even distributes the flow cell via the cloud (compare the surface of the cocoon and one point on the body....), the source - stupid forever outdoor faucet. By the way бж2.7 is about 10-11 of these sources at once, only each has the formula BJ and more powerful than that due to a number of modifications. Ie where the links have similar coverage, but structured charging system. Fair warning - 2.7 must be very, very gently used. I have a couple on different hands, breath was gasped physical for a couple of seconds.
in General, the issue with the scanner probably does require some additional study of the reasons for fixing the anomaly in the picture, maybe some benefit will come of it.
Thank you.
Thank you.
Maybe because it is hollow and in it something is? You never know, that is where people put drugs which can.Dimas wrote:CRAZY town
Well, finally I was going to write a few words in my long experience with all versions of bracelets, ranging from 1.0 to the most recent 2.7.
1. Bracelets really work, from 1.0 for 2.6 on the rise. The bracelets are 2.5-2.7 the features which later. But they need to learn to use it, if used wisely is a very powerful tool for managing reality, but without the ability there are a large number of benefits ranging from strengthening energy, endurance, improve health, to the fulfillment of the true desires, especially in older versions
2. In my experience with the bracelets, you can work as using separate modules, and simply putting a specific task, and the subconscious to let itself understands which modules to use. Really well still a bit to practice on different modules, or at least to read that the subconscious had a better idea of what they are.
3. As I have said to Mike many times, from my point of view, the distribution of the bracelets above version 2.5 it is necessary to severely restrict - either through much higher (by orders of magnitude) the price, or simply removed from sale. In my experience 2.6 too powerful an artifact to be in the open market, possibilities of its application in the management of a reality is very wide, even scare me sometimes its possible with proper goal setting. If the bracelets to 2.5 inclusive work best to harmonize situations, spaces, relationships, and best of all they just set a goal "to optimize the situation for me", the bangles 2.6, you can put specific tasks in the majority of cases they are carried out, and literally. This happens a lot of jokes - the type put to him the problem that when I go to the gym, so there was no one there - come and is there in nature no one, because it is closed
. If the task set correctly, then just amazed how everything is done. And then the most important task is to understand what you really need! What you really want! I would not want to interfere in the business with people, which also has 2.6. By the way, the 2.7 looks like the order increases the interest from the opposite sex...
4. Perhaps one element of why the bracelets are so well - creating the right inner peace and not an engaged state, in which all the teachings and the fulfillment of goals and desires + filling power bracelet
4. Examples of the impact of the bracelets were very much on different forums wrote, especially I will not repeat. From the latter:
and. I gave my parents 2.5. In mind to various reasons was not then they have a few a month. Arrived and didn't find the plot to them somewhere dripped a certain amount, they are beautiful paved paths around the plot, they just radiates positive and pleasant the energy of creativity. Beauty!
b. My dad has long been broken. He called the master, the amount for the repair of decent, dad was upset and didn't want to pay that TV, and for one and a DVD drive repaired itself
. Being an old Soviet engineer, he long couldn't believe it
V. Gave bracelet 2.0 one very confusing girl, where you all ride and who apparently lives by the principle that happiness should be "suffer". The next day she called me ecstatic that now feels the joy of life, self-confidence - just still radiated energy and happiness. Very happy for the girl.
G. Bracelets are good to use in certain techniques of certain schools associated with the removal of the consciousness of the body and impact on health and the situation with their help. When my wife gave birth, the property had to use it to the fullest and I am very happy with the result, I don't know, that was if at that moment I was not hung with bracelets as a tree (although at that time, only 1.0)
Anyway, today is enough, ready to answer questions<
Me version 1.0 never ceases to amaze. I swear I'm scared to put 2.6 and above. Today, loaded the headband, hour diarrhea in a few hours was too much for the bed to get up. Such processes launched that the body needed to disconnect for an hour, that would at least ease up a little. Michael warned that the head only prepared, I thought I was prepared
recorded 1.5 hours of video, most is just about the bracelets, different versions and so on. The questions posed in the subject said not all because I tried to make explanations thematically connected, continuous story. Now send for the installation of Vladimir, soon, I think, it will all be on the forum.
A warning to the owners of 2.7 (and the same applies to 2.8, while the truth is its sold out).
Bracelets these versions, you should try to exploit relatively carefully. In particular, do not soak + do not expose to strong mechanical loads.
The coating on the inside water resistant, but to protect him not further lowering the effectiveness of the bracelet difficult. At the moment we do not know the perfect and reasonable solution to this issue. Preference is given to the effectiveness of the work in the first place (power of the piano-powering energy in this case). Today I received a report from a user about this version of the delamination of the coating. That is quite strange, because I have the same on hand work more than a month in harsh conditions and no signs of wear. But I suppose that the reason may be in the water....
Of course the victim the bracelet will be replaced with a similar, but in General it should be noted, that I know of two ways to protect the coating at the same time will weaken the "function" of the bracelet.
In General, we can do anything, not just specifically in the water not to stick into the shower with him not to go.
Realize that this advance warning was not published - it is entirely my fault.
Water suitable for other versions.....
Although someone reported the cracking wood from getting wet, but this is a rare phenomenon (defect level + erased lacquer coating). Usually wooden 2.0 water transferred to the Ura, including "long-term". In the sea swam in the tub "soak".
2.7 and 2.8 is a very specific version.....
now, about the variation from Baikal larch in today's video showed what it looks like. It is very massive. Well, a very solid bracelet. Of these blanks (as long as they to me are not received, the photo is my personal copy) we will do all of high range 2.5-2.8.
To start with I do not recommend them! In order to avoid overloading the body. It is absolutely high-power design. Finally not yet determined their value. It will be different as now, for 2.5-2.6 and 2.7-2.8(mean the same complexity of the production process), in General, the area of laser application, there is about 4 times higher than normal, and the power will not be proportionally higher...<
If I understand correctly that Michael wrote that the scaffold is not implemented. So why limit? Or who have big money and the taxis? Not fair however.Василий wrote:3. As I have said to Mike many times, from my point of view, the distribution of the bracelets above version 2.5 it is necessary to severely restrict - either through much higher (by orders of magnitude) the price, or simply removed from sale. In my experience 2.6 too powerful an artifact to be in the open market, possibilities of its application in the management of a reality is very wide, even scare me sometimes its possible with proper goal setting.
