The reason grazing is that we pull the energy from the event itself.
If there is a conscious rendering of an event especially, there is a number of determining factors we increase the probability of the event or Vice versa.
Talent in this case, a resonance with the collective experience + private structure of the cocoon (experience) probably accumulated over many lives.Александр86 wrote:But will this device in achieving such goals:
People want to learn to play the violin, but he has no talent.
He is willing to engage, to work hard, but hard work is not everything. Talent is something, what is lacking in this case, can I compensate?
neeee....Маг.нет wrote:Michael_ question INFOPRENEUR (when using SK 1M):
1. How much exposure time is required for transferring "special" properties of the source structure on "segerstrale" to the size of the 10-copeck coins "activated" quartz (for repair of water), for use by function - active source structure how effective such a transfer, the lifetime of activated quartz - 3 months.
2. Do I need quartz to activate until the moment of transfer, the Gulf water.
3. Is it possible to change the taste of the water is desired (to acidify, to sweeten), odor, and other designed properties.
4. "Svezheotzhaty" rock quartz, watered stationery glue, at the moment drying feature next to the source structure, for example, with the Cartridge to the Modulator on the object table... (before drying)
After a(?) time, peel the adhesive (the source structure) falls off, what time the logs will save the properties of the structure.
5. Is it always necessary to implement INFOPRESSE, to create a "screen" by putting SK 1M in a box and locking as previously described, the properties of the "screen" with a marker.
Thank you!
Sincerely, MAG.no
So razmyshlyal. Essentially everything is clear, thank you, truly bringing together multiple issues, decided to look for total.Михаил_ wrote:something of a hodgepodge kind of came out.
In goal was the purchase of a car ie I of course did not write in plain text let me 100T.R. the language was another perfect, BUT this is the amount I needed and it is about the amount I thought(i.e. I have in my head is spinning)What was standing in the goal?
well, not this way....it is a way the greatest evilGOT it! And now unhappy
Read Zeland....I don't know, Zeland any read or Burlakov
Michael, thanks for the reply, but I'm still not clear whether it is possible a little more.Михаил_ wrote: SK can work with different tasks at a time - for example to use the recording of several audio tracks on input.
Several intermediate steps to register you can also.
1. in turn, this means that while there is a track with a specific purpose, the maximum resources of the device and your (indirectly, You are part of this system World-You-Sa) is aimed at this (reproducible problem). But of course others without moving into a state of "stop" - the life processes are continuous, but in fact, a potential device is distributed on several targets... somehow...Рираха wrote:Michael, thanks for the reply, but I'm still not clear whether it is possible a little more.Михаил_ wrote: SK can work with different tasks at a time - for example to use the recording of several audio tracks on input.
1. "Working with different tasks in the queue" - what does that mean? If I understand correctly, for example, write in a circle three audio tracks (each is a separate goal-task). So here's how it works "on queue"? Take the first task and running with it to result? Or each task in turn - at the time of filing it on audiojack some kind of mental-energy support, and they essentially work all the time?
2. If I have spun a long term goal in the UK, then for a few hours I put something momentary-current, then set a long term goal as the UK with a long-term goal at a time as it is momentary?
3. Is there any fundamental difference from the viewpoint of the input tasks via audio or via a piece of paper, put on the table? Is there a difference between a task, printed or handwritten?
4. If the difference between the paper and no audio can I one piece of paper to write several different task-goals - and let it lay on the table in the UK and affects all tasks at the same time? Or this is only possible, say, for a progress of the subtasks, but not for tasks from completely different areas?
Since SC operates with the energy structure of small programmable components (cellular cloud), it can be any algorithm suitable for partially basic (copy for example), to clarify to the desired level and depicted in the form of an audio file, a piece of paper or something.верунчик wrote:And you can read more about a special on some example?
With respect
