http://www.mindmachine.ru/viewtopic.php?t=1076
Radionic devices Karl Welz.
Lepton generator Katrina is described in detail in Perelman Entertaining Physics and called "thermal sound generator".
I did like this in the country from asbestos-cement pipe - physical experience, such that not only the torsion field and the leptons believe, but in anything...
I think now that if I did this "crap" from a steel tube, then, most likely, would have nothing wrote ...
By the way, chicken from the woman ceased laying for a long time...
Петр Петрович
Andrey Vadimovich, so if this is Your answer that radionic devices- uniquely evil? While customs allowed the import to Russia? Ahead of the answer will say that I read Your earlier message about the awareness of the Russian special services about the possibilities for mind-machines, more precisely-about their ignoranceАндрей Патрушев wrote:posted: Mon Feb 22, 2010 5:58 pm
Torsion generator Katrina is described in detail in Perelman Entertaining Physics and called "thermal sound generator". I did like this in the country from asbestos-cement pipe - physical experience, such that not only the torsion field believe, but in anything... I think now that if I did this "crap" from a steel tube, then, most likely, would have nothing wrote ... by the Way, chicken from the woman ceased laying for a long time...
Not at all.Петр Петрович wrote:Andrey Vadimovich, so if this is Your answer that radionic devices- uniquely evil? While customs allowed the import to Russia? Ahead of the answer will say that I read Your earlier message about the awareness of the Russian special services about the possibilities for mind-machines, or rather about their ignoranceАндрей Патрушев wrote:posted: Mon Feb 22, 2010 5:58 pm
I'm just saying that many here argue as in the Russian proverb:
- Are you enjoying the goose feet?
- Oh, delicious!
- You eaten?
- No, not tasted, but my brother-in-law seen as their master tasted...
I used to pass through any experience yourself and analyze from all sides, because quite often the various "pieces" that have noticeable effect are issued at all of the other "stuff"...
Now I'm translating a user manual, and when you get experiences, then you will be able to form your own opinion and share it...
Петр Петрович
User guide in this case is more like a brochure than a guide to the instrument. The device is non-standard for other purposes, and the claimed device: if energy/field, then why pipe, and even stainless steel? It is not clear...Андрей Патрушев wrote:Now I'm translating a user manual, and when you get experiences, then you will be able to form your own opinion and share it...
And if not a secret the way You want to get personal experience: also through the transfer test at the manufacturer's website or directly from the device?
From the device...Петр Петрович wrote:User guide in this case is more like a brochure than a guide to the instrument. The device is non-standard for other purposes, and the claimed device: if energy/field, then why pipe, and even stainless steel? It is not clear...Андрей Патрушев wrote:Now I'm translating a user manual, and when you get experiences, then you will be able to form your own opinion and share it...
МатрицаРеволюция
What is not clear? She radiates. This waveguide.the device is non-standard for other purposes, and the claimed device: if energy/field, then why pipe, and even stainless steel? It is not clear...
And as usual the issues with customs?while customs allowed the import to Russia?
And, moreover, it's the ICE!
Будунист
Fulfillment of desires just!
There is a proven technology that works, and that is absolutely free! And the result is the same and even better.
On the website: http://ris.cc.ua on the tab "Radionics"
Вульдемар
devices Radionics
To fulfill the desire a lot easier and absolutely free by using proven technologies on the website:
http://ris.cc.ua on the tab "Radionics" is a description
Петр Петрович
Taken from the above website from the section on "Dowsing". Quote " ...And more. Pendulum will not give the question of the future. Only the past and present. Sometimes he likes to joke..." Next "...dowsing will help you to choose a life partner. Lay out the pictures of potential candidates, and the pendulum will indicate the most suitable person for you!..."
Are there any questions?
МатрицаРеволюция
According to the description given on the website, nothing can be done. Two words and a link to the store, which no longer exists.the wish is much easier and totally free with the help of proven technologies on the website:
To do radionic very simple. Only you will have a hard time to Express his thought in the form of abstraction. Otherwise, he strengthen it will not. You have to put a piece of paper with the icon that is drawn using the pendulum. One mistake - bummer. In short, if a psychic is not a magician, nothing will not give you this. There are already harvested trends - but when YOUR own is much better.
In addition, if the goal is difficult, you need a powerful and constant pumping. For this we use instruments like Carl, or other generators. But, not being sensitive, you will not be able to use even Radionically Welz, designed for a wide audience. There should be rate to set the potentiometers. Non-psychic to do.
МатрицаРеволюция
Новик
Ie if I want the most simple health,money and development of self-improvement( I want to learn higher auditory training)МатрицаРеволюция wrote:All this just seems simple. In fact, cybermage is an art, just like regular magic.
I have been using this device will not succeed, so what?
Because we must already have certain abilities
What a vicious circle turns out....
МатрицаРеволюция
- Шалтай Балтай
- Has thanked: 125 times
- Been thanked: 263 times
It looks like it.МатрицаРеволюция wrote:But not being sensitive, you will not be able to use even Radionically Welz, designed for a wide audience. There should be rate to set the potentiometers. Non-psychic to do.
However I think that it is a little tricky.
No sense just give more variation.
Ie - each will get more or less in its scope.
Well, originally it was clear that this is not Utah
Ванька-встанька
So for this and invented prog-Manifests - killing 2 birds with one stone: 1)she puts the frequency from 0 to 99 without having to RUB the plate of the device; 2)contains a set of Trends. So even more tempting for the money is impossible, because more than half the trash outright, separately, would not buyМатрицаРеволюция wrote:Also, if the goal is difficult, you need a powerful and constant pumping. For this we use instruments like Carl, or other generators. But, not being sensitive, you will not be able to use even Radionically Welz, designed for a wide audience. There should be rate to set the potentiometers. Non-psychic to do.
Ванька-встанька
- Шалтай Балтай
+1Ванька-встанька wrote:So for this and invented prog-Manifests - killing 2 birds with one stone: 1)she puts the frequency from 0 to 99 without having to RUB the plate of the device; 2)contains a set of Trends. So even more tempting for the money is impossible, because more than half the trash outright, separately, would not buy
I would like to believe that the way it is.
Talking (or rather trying) with the support of Charles on this occasion
By the way, someone predictableit this Manifestacin work? She had on the output and how it turns out?
- Шалтай Балтай
- Has thanked: 1 time
- Been thanked: 182 times
- Шалтай Балтай
- Шалтай Балтай
- Шалтай Балтай
Andrew
If you can popinat them about the programs
The main problem here. Radionic - operate - no doubt. BUT here's the setup and tuning of the instrument is trouble.
If the program takes it over or at least partially bi facilitates the process is a big +.
1. How connects.
2. What does?
2.and does "primary" frequency of the device?
2.b Establishes whether the communication with the trend?
3. Does it require manual settings (on the device) or does everything itself?
4. Is there any API? Is it possible to write programs for yourself?
saved
1. How connects.
2. What does?
saved
Ванька-встанька
About tuning, I would poosteregsya: people from the pucks eyes burn (if you wear them for a long time), and we offer Potency Booster's pocket carry. It will completely ruin Vanke vstanku...Шалтай Балтай wrote:Main problem. Radionic - operate - no doubt. BUT here's the setup and tuning of the instrument is trouble
. So about every Manifesto it is written that protected the internal structural relationships - "do not get - kill" sort of. In this scenario, even about the copyright you can not writeШалтай Балтай wrote:is There any API? Can I write programs for myself
