PSYLERON
Check the connection between human consciousness and physical world
Post by Михаил_ » Thu May 05, 2011 14:05
will not help
since these are different things that should not be there in the signal of the same frequency.
Well the CPU is running at some frequency and video card, too, and also have a scan of the monitor, we see the whole image on the screen, which is not linked directly with these frequencies.
Psyleron takes a picture of a single-pixel camera (primitive sensor), and in the brain - clock frequency. It's not the same thing.
Астранавт
Post by Астранавт » Thu May 05, 2011 14:32
I'm not talking about brainwave frequency. BrainBay not only for EEG brain, it is a universal app - analyzer low-frequency signals open source MSVisual C++. Just look at the very prog - there is a constructor of any low-frequency block diagrams.
Астранавт
Post by Астранавт » Tue May 31, 2011 20:34
http://www.global-mind.org/reg.html
The location of the cogs are the same...
At first I thought that's what it is, but there are RS-232, early model.
Has thanked: 125 times
Been thanked: 263 times
Re: PSYLERON
Post by Шалтай Балтай » Tue Nov 08, 2016 11:25
Espada,
che, I have a feeling that I'm in the wood for the trees lost. On pomoschi!
read here: http://www.mindmachine.ru/psyleron/psyleron.pdf and here: http://www.psyleron.com/reg1_overview.aspx
Says Shaw is a true random gene (RGN). I Mastiff. Now correct me. There are varieties of true Gnoff: https://en.wikipedia.org/wiki/Hardware_ ... properties
  • Psyleron on what principle? Who knows? (without the word quantum)
  • What is the power of extradition? In both? (without much/enough, etc)
  • Thread who measured the entropy? entom, for example?
  • Certificate to it is?
  • Why it is not in the list of Gnoff, https://en.wikipedia.org/wiki/Compariso ... generators
  • koganti have experience with alternative devices?
Thank you in advance
Humpty
Has thanked: 478 times
Been thanked: 264 times
Re: PSYLERON
Post by ЛИЛИЯ-Р » Wed Nov 09, 2016 14:15
1. ,2,3,4.5.6 viewtopic.php?f=26&t=2966&start=25
here all described.
Dmitry promised to answer today.
Re: PSYLERON
Post by Шалтай Балтай » Wed Nov 09, 2016 15:35
Good zdraveska, LILY-P
ЛИЛИЯ-Р wrote:1. ,2,3,4.5.6
what is it? :roll: Morse codes? :)
ЛИЛИЯ-Р wrote:everything is described.
loved this phrase,
and also:
it's all there,
and
we already talked about this
ЛИЛИЯ-Р wrote:Dmitry promised to answer today.
gut
and then this thing I have, I want to understand what is IO :oops:
in short, I need (only in numbers!) to evaluate the entropy density of this thing. ACC, I'll think about the hardware to fit your needs, modestly-world reproduction ratio :oops:
Re: PSYLERON
Post by ЛИЛИЯ-Р » Wed Nov 09, 2016 15:57
Шалтай Балтай wrote:ELIJAH-R wrote(a):everything is described.loved this phrase,and also: Quote:it's all there,
Said Noise )))) everything is written in the topics about Psyleron and measurements and stuff :?
мимоходом
Has thanked: 66 times
Been thanked: 312 times
Re: PSYLERON
Post by мимоходом » Wed Nov 09, 2016 16:41
... entropy Is a concept from information theory - you can read theory to deal with this term...
And calculated the entropy so http://planetcalc.ru/2476/ is the mathematical expectation of the distribution of the random variable. In the case of a true random variable in this formula, substitute p(i) = 1/n where n is the number of all possible values of size (the easiest way is determined by the resolution of the ADC).
Well, in any language to write a few lines for calculating the actual entropy of the captured signal, to compare with the ideal entropy.
but the density of entropy... it's not a very clear term
Re: PSYLERON
Post by Шалтай Балтай » Wed Nov 09, 2016 16:50
ЛИЛИЯ-Р wrote:said That Noise )))) everything is written in the topics about Psyleron and measurements and stuff
sorry, I do not know this :?
http://www.fourmilab.ch/random/
https://calomel.org/entropy_random_numb ... ators.html
I would have died, but it is good to know b moshu, in mega/kilo/bots, experimentally poking in the pool lazily 8)
мимоходом
Re: PSYLERON
Post by мимоходом » Wed Nov 09, 2016 16:52
would you once wrote for a magical DIY you consider the random number generator - so a professional would have you immediately on the shelves written, why this magic generator is not suitable )))) And all from afar...
Re: PSYLERON
Post by ЛИЛИЯ-Р » Wed Nov 09, 2016 16:56
Шалтай Балтай wrote:LILIYA-R wrote(a):That said, Noise )))) everything is written in the topics about Psyleron and measurements and stuff sorry, I do not know this
Dmitry__
Developer aka Dmitry Noises :? He's a "commentator" in this topic, as it initially used , studied Psyleron. And posted here the topic with explanations. And the device itself ,in fact.
Re: PSYLERON
Post by Шалтай Балтай » Wed Nov 09, 2016 17:05
мимоходом wrote:you'd write
if you can, leave me alone, pancreas-of lsta
ЛИЛИЯ-Р wrote:Dmitry__
OK
мимоходом
Re: PSYLERON
Post by мимоходом » Wed Nov 09, 2016 17:13
know the problems... Only the "strong entropy" is about as supercena or megawatch. She can't be powerful - it has no capacity, entropy as characteristics of redundancy... and a unit of information, not a bot, and the bit and transmission speed - baud... as for white noise as the carrier signal... I recommend to see what the radio is used the carrier frequency, what types of modulations of the signal are and why they are applicable only to the analog signal, and in the case of a digital signal is just a noise and all...
I'm just 11 years old after reading about ruby laser pumped it too tried to collect, so you very well understand )))) When it seems that will take a nail to it to join the line and get the laptop
Зозерхат
Has thanked: 49 times
Been thanked: 69 times
Re: PSYLERON
Post by Зозерхат » Wed Nov 09, 2016 17:30
мимоходом wrote:Only "strong entropy" is about as supercena or megawatch. She can't be powerful - it has no capacity, entropy as characteristics of redundancy of information...
There is such a parameter as the coefficient of entropy. It is used to describe determinirovannogo spectrum of radio frequency noise generators. In fact, from these spectra and get a random number in the random number generators. Initially, as noisy element can be used by noisy elements such as Zener diodes, special noise diodes, transistors crossings, bridges, resistors, etc. For the needs of cryptography, never used digital methods of generation of random numbers, but only analog, with subsequent digitization. Therefore, many modern processors and microcontrollers, having in its composition cryptomodule or cryptosecurity, typically have a so-called "generators of true random numbers", built on the already mentioned principles. They work pretty good. Checked it on STM32F415.
мимоходом
Re: PSYLERON
Post by мимоходом » Wed Nov 09, 2016 17:31
Yes, you have right )))) But when you read that sculpt people - will understand )))
Зозерхат
Re: PSYLERON
Post by Зозерхат » Wed Nov 09, 2016 18:24
мимоходом wrote:Yes, you have right )))) But when you read that sculpt people - will understand )))
Fill is this not the height of genius. This usage is fairly standard principles. I'm using TRNG on Board CPU in the device-"processor" to control your dreams. As an experiment, I laid the option of contactless diagnostics of human organs. Roughly speaking, the condition of the organs will be expressed in the ratio of entropy. A healthy body will have a lower coefficient of entropy, and the patient - more. It all happens completely hands-free, thanks to human sensing multi-band radar. Well, not even radar. I would not like to delve into the principle, because it would have to be very long to explain. Moreover, in serial devices this feature will be available only for very big money. Not soon. I'm not in much of a hurry to implement it, and more research is not applied to diagnostics, but absolutely for other purposes.
мимоходом
Re: PSYLERON
Post by мимоходом » Wed Nov 09, 2016 18:41
just like in Star trek where the doctor is a hologram scanned patients )))) And accuracy percentage which has already been tested or are in development?
Зозерхат
Re: PSYLERON
Post by Зозерхат » Wed Nov 09, 2016 19:22
The high accuracy is obtained, but there are "problems" some. For example, you can see the disease before it appeared. For some items we can predict their destruction or annihilation.
I'm more interested in the impact on the likely outcomes of any event, than the diagnosis of diseases. This "diagnosis" I see as just an indulgence. So... in development.
I'm more interested in ways of technical realization of the principle of "rabbits Maharishi" in relation to a person. This could be adapted to "Celeron", but I don't like to use the devices, which is unknown to mathematics. Even if I understand how the instrument is considered to be a correlation between the values TRNG and dynamic next get person parameters of a specific formula and what method, I still prefer to make the device. City "hodgepodge" of diverse devices connecting them with wires, cables, coordinate and relate to each other IN a thankless task. It's like in good spy movies show how the undercover placed batteries, microphones, wireless microphones. voice recorders and all of this is connected by wires, cables, etc. Really the situation is exactly the same. This is inconvenient from the point of view of practical use. Thank God, everything is possible to do without the use of computers are quite cheap and common microprocessors. The use of "big brother" is not always economically feasible and is not always justified.
Re: PSYLERON
Post by Шалтай Балтай » Tue Nov 15, 2016 10:19
Шалтай Балтай wrote:of Espada,
Humpty
Okay, he pierced.
Only one question:
Re: PSYLERON
Post by Шалтай Балтай » Tue Nov 22, 2016 16:15
who-thread put psyleron on Windows 7 ?
che that my headgear does not see the device. The driver I have set
Re: PSYLERON
Post by Шалтай Балтай » Fri Nov 25, 2016 21:47
Шалтай Балтай wrote:Okay, he pierced.
Only one question:
pierced. Refute. 260х8 Bot
NOT a kilo, not Mega/ Exactly 260 Bytes / sec!
I pereprava, although already checked, but it seems that this misery
I have a friend and b black out most of the entropy density provides :(
entom I will not watch this skin.... :cry:
Re: PSYLERON
Post by Шалтай Балтай » Sat Nov 26, 2016 2:58
Results:
Collect entropy for 10 seconds:
Code: Select all
$ ./psy-test.exe out-10Sec.dat
iNewSources: 1
There had been found 1 Psylerons connected
0) Name:"RGZD378" Type:"REG1"
Selecting Psyleron with #0 as a source
Writing to file: 'out-10Sec.dat'
Cnt: 205; k = 13.05%
where
Code: Select all
Cnt - the number of queries to the Psycho
K - the ratio given bytes to a common buffer
calling asynchronous
Code: Select all
 0 Sep 26 01:53 .
 0 Nov 21 14:10 ..
 46 Nov 21 14:10 Makefile
 2676 Nov 26 01:54 out-10Sec.dat
 2214 Sep 26 01:53 psy-test.c
 17763 Nov 26 01:53 psy-test.exe
 4081 Nov 26 01:53 psy-test.o
Well, it is clear that for 10 seconds crazy gave much 2676 bytes :roll: tried, probably
Re: PSYLERON
Post by Шалтай Балтай » Sat Nov 26, 2016 3:02
shot by 30 seconds
Code: Select all
$ ./psy-test.exe out-30Sec.dat
iNewSources: 1
Writing to file: 'out-30Sec.dat'
Cnt: 539; k = 14.75%
Code: Select all
 0 Nov 26 01:59 .
 0 Nov 21 14:10 ..
 7952 Nov 26 02:00 out-30Sec.dat
 2214 Sep 26 01:59 psy-test.c
 17763 Nov 26 01:59 psy-test.exe
 4081 Nov 26 01:59 psy-test.o
atstoy
Re: PSYLERON
Post by Шалтай Балтай » Sat Nov 26, 2016 3:06
the vinzip 30C is not compressed, though there is not cheated :)
in General, Cho stem device do not even know.... :?
Re: PSYLERON
Post by Шалтай Балтай » Sat Nov 26, 2016 16:37
no, entropy can be accumulated, do not argue
but on the real-tymovskoe options for psycho, you can forget, it's just sophomoric, 2Кбота :(
