Know the secret? The more You try to disable, the more you will have to think "Hmm..I think right now...man,that's the idea (I think now)" and went running Under Explorer I almost always sleep,aims to turn off thoughts there. Travel too much didn't expect anything while listening, because I know that then the fun begins, I mean AFTER. Just noticed that the "mixer" turned off for some time after the Journey...And under it I also sleep and do not bother, as for myself, I decided that after any listening to me will happen the most for me in the best way
Disk A. Patrushev, "Journey to inner worlds"
Svetlana
Thank You Dimas.Dimas wrote:Svetlana
Exactly what I wanted to hear. Inner voyage itself gives the effect of disabling the flow of ideas regardless of personal experience ..
Throughout the spine. On the sensations (tingling, heat..).Йоссариан wrote:and why on the spine, and to what point?
But if the attention remains in the head, then turns on logical thinking (the type of this button I have pressed 3 times, click on another) And on the spine I remember - 6 times pressed the left button.
This program is better (objective) than the card, because the cards, as I wrote, soon begins to affect the effect of superseniority.Йоссариан wrote:awaken
a serious approach
I played around with this program, it turned out after 100 attempts, 42 Yes, 58 no, and in the beginning was generally a blockage, (no disk).
Question to all - is there such a random number generator, a replacement for the card?
Or coin throw - heads or tails?
It's unlikely it's a random number generator - they would be ruined for a long time (because it is our innate prepeared)...Dimas wrote:Andrei Patrushev
It is a pity that now it is impossible to experiment on money on the machines,I wonder rabota lo would?
Александр_61
Vremni good day
bought the CD "Journey through inner worlds" listened to and remain in disbelief: a feeling that the disc contains pink noise, while recording 1 track different from the record of the 2nd. Very similar to the first and last tracks from "Sesego wanderer", the truth in This.Wanderer has some sort of modulation, and everything is exactly the noise/
I something not so do?
Marriage?
Marriage?
Only mail cameАлександр_61 wrote:vremni Good day
Marriage?
Павлум
Yossarian, Александр_61
If you listen very closely, there is some modulation within the noise, which is audible (to me, at least) from the very beginning. Actually the disc contains multiple frequencies, so the brain is easier to stay on resonance for the frequency. I like "sticks" 2-3 times during the listening of this disc, with approximately always at the same time from the beginning.
The drive is much more effective with the machine.
Павлум
This means you can change to ISS, which is felt as a sense of weightlessness, movement, absence of thoughts and comfortable emotional background, also all this is happening with full awareness and "burning" of concentration.
In General it's useless to try to describe that condition.
But the WTO is the most valuable, is a condition can then be called in without the drive and cars. I heard about it, but now was able to put into practice.
Павлум
- Дмитрий В.
- Been thanked: 2 times
Павлум
Until I stopped listening (15 days passed).
1. Increased ability to enter into trance through meditation (12 minutes).
2. This never happened before - to sit in the Lotus 50 minutes, never stir.
3. Do not want to write on, because it's useless, but it has changed .
I recommend to just buy and listen. The effect is all the same You will have your...
Not very nice to listen to this noise that if you impose on him what may be nature sounds like "the healing), will not lose in effectiveness? And if you mix that is the idea of the added track trim EQ(low pass filter) high from 18000-19000гц that would not interfere and.the gate, and it is possible to do more and mono(or is it unnecessary)???
Also, it is good to do it with "massage brain".
Павлум
Musician
I can assume that the effect will be lost. Music will keep the mind in a certain state and will not allow him to move in changed.
If in the case of the alpha state of the brain synchronizes with the imposed (so I guess it's no harm to mix the alpha session with music) here - no.
By itself, the drive is already a crutch. Poprobui to keep the consciousness awake, listening to him. If you turn on the music - get a crutch on a crutch (the drive to enter the theta state, music that was not boring to listen to the disc).
In qigong there is a practice of a Large tree (or post). This is the Desk where you have to stand for long and beginning to be very uncomfortable. Beginners listen to music. At first, it's easier, but a deep state of meditation is impossible to achieve. It is for example.
