Room, Mirror
The card to the mirror attached to the white side without inscriptions.Владиаааа wrote:ASD
Tell me where the card "Mirror of ISIS" side and which side should be glued to the reverse side of the mirror. If you look at the light, then from the side where no pictures are seen two dark structures, it is the front side?
I repeat the question again:
Sincerely, MAG.no
Маг.нет wrote:posted: Fri Jan 28, 2011 4:37 pm
The mirror of ISIS (the previous sample - 2 disk), is it possible to apply the disks so that between them is a metal plate bearing? if the distance in this case between the rims (edges) of at least 10 cm?
Sticker on mirror large size (full length) at eye level, running the entire mirror surface or only a limited region?
Sincerely, MAG.no
Sincerely, MAG.no
Sorry, I missed Your question...Маг.нет wrote:I Repeat the question again:Маг.нет wrote:posted: Fri Jan 28, 2011 4:37 pm
Sincerely, MAG.no
Sincerely, MAG.no
Works, of course, the entire surface of the mirror. However, at the location of the card effect of interaction with light eyes are more pronounced. Therefore, we recommend to stick the card at eye level. It is clear that a large mirror can see people of different growth. Therefore the zone "at eye level" choose averaged for basic users.
For example, in the children's Fund of Krasnodar, we glued the cards on two large mirrors hanging on the wall. Placed approximately in the middle of the mirror, as the children engaged in a wide range of ages. It turned out that the effect of the mirrors is shown in all space of the hall. People, even sitting on the opposite end of the hall, you start to feel better after a while. Cm. Latest user reviews of the "Valentina".
Mirror in a frame with already inserted in the card.Тяфа wrote:does anyone know what is different about the Mirror in the frame. It looks like? The picture is not very clear. The last time I was in the office, then sold the card and you could buy a mirror for her. What is this?????
Looks like a mirror in the frame
Good idea - the finished mirror is glued to the card.Андрей Кабанков wrote:Mirror in a frame with already inserted in the card.Тяфа wrote:does anyone know what is different about the Mirror in the frame. It looks like? The picture is not very clear. The last time I was in the office, then sold the card and you could buy a mirror for her. What is this?????
I liked it. And there is a choice and time does not need to spend. In my very comfortable.
м-р Фримэн
Re: Drawing Rooms, Mirror
Please tell me how should be placed the card on the mirror, the wide side vertically or horizontally?
And whether that card from time to time to move from one mirror to another (in my case with small to large and back)?
Location does not matter, you can move from mirror to mirror.
dear forum, dear ASD and author of the website, good day!
card zi to mount vertically with the white side to the mirror on the back side of the mirror( summary of recommendations), at eye level.
now, two questions if I may:
1. can I mount the card using double-sided tape( how to fasten the Chamber-Window)?
or more rigid fixation should be( glue, epoxy.) will not corrode if corrosive medium glue amalgam?
2. the minimum ( optimal and ideal) of the thickness of the mirror used( bought specially for Z. I.) in millimeters?
as I understand it from the description - principle of operation, the thicker the mirror, the result( more powerful) effect, right?
thank you.
PS sory if the answer is already listed on the forum. I have reviewed, read before writing... maybe.
thank you.
1. Scotch and all things
2. At least 4-5 mm
2. At least 4-5 mm
Can be fastened and regular Scotch tape. You can leave the plastic gripper. You can not glue, and pressed the cap frame.
Amazing device Z, the seminar convinced what opportunities does this thing. And as the space is included in the projection geometricheskih shapes created with the help of mirrors, in particular 5 and 6 pointed stars wow mirrors will work.
Akelahave you Svetlichnaya parts, combined with BRM-products..?
PS the fact that I want to move forward on both paths and want to combine these products.. I Hope you understand me.. Thanks..
I like Bruski, even in the "adapter" i.e. when the modulator operates in broadcast mode service program and qualities of the crystals themselves already good and even better intentions.
But I will say that it is not a magic wand and gin everything srivatsa will not have to work on myself...
About the mirror, the seminar worked well, there were not many people because of this complex figure did not make, but simply impressed me.
So everyone was a mirror with a card, sat down in a circle with the beginning of a five mirror at the breast but is aimed at the man who is slightly to the left and he look in the mirror at that one a bit to the right, so that each participant, if you look from the top and mentally to draw straight lines from each participant, you get a five-pointed star.
What energy went, uh, and when another member came then "painted" the final six i.e. the triangle in the triangle and then another thread went, if I was not "hardened Sunnyvale" would be to torture yourself with thoughts about mysticism and devilry.
And if the participants used more than these "whirlwinds" around, uh...
I mean how amazing is manifested in the space of a new quality when drawn shapes "light flows".
