Popular questions and answers (FAQ)
Вы нашли ответ на свой вопрос?
Да
13
43%
Частично
6
20%
Нет
11
37%
Total votes: 30
пyпo
Post by пyпo » Thu Mar 26, 2009 13:12
Once again thank you very much, good that there are people like you who give really helpful tips:)
Тимофей
Post by Тимофей » Mon Apr 06, 2009 22:11
Doing massage of the body,want to open a massage salty.How it will look using a mind machine?
Post by Dimas » Wed Apr 08, 2009 12:58
Timothy
Will look great :) Some of our customers have already taken the instrument for massage parlors.
Филипп
Post by Филипп » Tue Apr 21, 2009 10:48
You have certainly a lot of things are simplified, in contrast to real life... :)
Post by Dimas » Tue Apr 21, 2009 11:15
Philip
??? I mean :roll:
Юджин
Post by Юджин » Sat Apr 25, 2009 12:15
Стюра
Post by Стюра » Sat Apr 25, 2009 13:13
Explain to me please: I Want a job as MM to listen to the disc Patrushev. What is needed for this player (or any special)? And the players, basically, there is only the headphone Jack, I do not understand what the audio input Jack to connect the player? What MM socket I understand.
Post by Андрей Патрушев » Sat Apr 25, 2009 20:42
Стюра wrote:please Explain to me: I Want a job as MM to listen to the disc Patrushev. What is needed for this player (or any special)? And the players, basically, there is only the headphone Jack, I do not understand what the audio input Jack to connect the player? What MM socket I understand.
A normal player. Just to stick in the headphone Jack. :)
Александр Сах
Post by Александр Сах » Wed Apr 29, 2009 16:33
It's all nonsense, it is better to sleep with the TV on!
Тур
Post by Тур » Wed Apr 29, 2009 17:36
Issue to the sellers on the site have never found that MM passed at least some sort of certification, I'm talking about the neurophysiological institutes, but even a simple certificate of conformity no. What's the catch? I would like detailed comments, the device affects the organism (brain) and none of the articles from neuroscientists.
Been thanked: 182 times
Post by Андрей Кабанков » Wed Apr 29, 2009 17:54
Тур wrote:a question to the sellers on the website have never found that MM passed at least some sort of certification, I'm talking about the neurophysiological institutes, but even a simple certificate of conformity no. What's the catch? I would like detailed comments, the device affects the organism (brain) and none of the articles from neuroscientists.
The catch in your carelessness,on the website plenty of articles,there is even a book about MM.
Certificates uploaded.
Learn.
http://www.mindmachine.ru/articles/index.htm
Стюра
Post by Стюра » Sat May 02, 2009 14:11
Андрей Патрушев wrote:Regular player. Just to stick in the headphone Jack. Smile
Thanks for the response. :wink:
Post by Гость » Fri May 15, 2009 17:20
Can't choose between enerpulse and a new missile defense system, according to the table interpuls better (able to listen to the two of us I don't need, number of sessions does not matter because free download session which is on Nova and listen to the iner, cast voice I don't want it). It is not clear just what "the Number of segments loaded sessions" but I think it is not very important. In the description of the new item is "Nine choices of the kind of signal" and then a listing, and in inertia, how many variants and what? Tell me all the differences listed or not? If all then I probably will choose a iner. Just with one hand like enough to Nova, and another in the money all of the drives Patrushev to buy..
Post by Андрей Патрушев » Fri May 15, 2009 21:16
Гость wrote:can't choose between enerpulse and a new missile defense system, according to the table interpuls better (able to listen to the two of us I don't need, number of sessions does not matter because free download session which is on Nova and listen to the iner, cast voice I don't want it). It is not clear just what "the Number of segments loaded sessions" but I think it is not very important. In the description of the new item is "Nine choices of the kind of signal" and then a listing, and in inertia, how many variants and what? Tell me all the differences listed or not? If all then I probably will choose a iner. Just with one hand like enough to Nova, and another in the money all of the drives Patrushev to buy..
Innerpulse also still light and compact... :)
Павел Ф.
Consider the option of a Nova Pro 100 Inner Pulse occurred 3??
Post by Павел Ф. » Sat May 16, 2009 0:06
Consider the option of a Nova Pro 100 Inner Pulse occurred 3 questions at once.
1) both cars have modes with the same designation and the description. Why do they have different frequencies (for example, Calm down! 2,5-18, and 7-18; Day dream), what is the explanation?
2) Where you can view a list of additional programs for Nova Pro 100 Inner Pulse and there for the Inner Pulse program "language Training"?
3) In what cases to use glasses with clear lenses and whether there is the possibility of using these glasses to perceive text information, for example, when using the program "language Training"?
Сергей1752
Post by Сергей1752 » Sun May 17, 2009 13:16
for some reason, the package 100 njvapro no light &sound Designer100??? cable with com port and program, no. please lay. and how to listen with MM discs Patrushev... and what better sequence. As they are combined with built-in programs, and which combinations studied and proven...Please complete a detailed answer.Thanks in advance
Post by Dimas » Sun May 17, 2009 13:52
Сергей1752
The program can be downloaded in the section "Articles".
Full and detailed answers You will receive by reading the "FAQ" on disks of A. Patrushev.
Re: Consider the option of a Nova Pro 100 Inner Pulse occurred
Post by Guest » Sun May 17, 2009 14:48
Павел Ф. wrote:Consider the option of a Nova Pro 100 Inner Pulse occurred 3 questions at once.
This question can someone answer?
Post by Dimas » Sun May 17, 2009 15:06
here you can see descriptions of the sessions.
http://www.mindmachine.ru/sessions.htm
On different models one name can have different program as an area of relaxation and sleep involves a wide range of frequencies.
Language learning is a process of learning.The question of HOW You learn a language.
Glasses with clear glass for use by people of creative professions, mainly for drawing and the activation of creative thinking when writing poems, etc.
Лицвин
Post by Лицвин » Sun May 17, 2009 17:43
and wma format preserves different frequency in the dash and the left earpiece?
Павел Ф.
Post by Павел Ф. » Sun May 17, 2009 23:28
Dimas wrote:here you can see descriptions of the sessions.
Description of the sessions have already seen. Additional question.
How to get a detailed description of the session Zrenie (session to improve vision. Session times cannot be changed)? A few years ago in a similar way to improve vision (if required, can describe in detail the letter). I would like to know more, because at that time, required a long course, but the possibilities go through his fiction.
Now, the description of sessions with the same name and exactly the same description have different frequencies. The crux of the matter in difference between the impact of the sessions.
The question found no answer. The question for the study of language was discussed on the session (Nova Pro 100) in conjunction with which, at the same time, listen to the recording of the language course. And can such download to InnerPulse? the same? Please answer in detail. For the link with the list of sessions, about which little can be said.
Post by Андрей Патрушев » Mon May 18, 2009 12:29
Павел Ф. wrote: Description of the sessions have already seen. Additional question.
What exactly are You interested in? A description of all the sessions is inside the sessions and can be read either from the editor sessions, either from the library sessions.
All the difference in the fit the claimed effect... :)
For vocabulary this session L03.
Павел Ф.
Post by Павел Ф. » Mon May 18, 2009 19:08
How to get a detailed description of the session Zrenie (session to improve vision. Session times cannot be changed)? ...
Interest indications and contraindications the use of this session. Namely (in descending order of importance):
1) retinal degeneration (after laser surgery 1,5 years) or there are no contraindications;
2) what is the impact on myopic astigmatism;
3) if myopia affects what changes can be expected;
4) use this session to relax the eyes after working on the computer.
Post by Андрей Патрушев » Mon May 18, 2009 19:38
This topic was discussed here:
http://www.mindmachine.ru/viewtopic.php?t=1079&start=0
http://www.mindmachine.ru/viewtopic.php?t=1699&start=0
http://www.mindmachine.ru/viewtopic.php?p=15901#15901
Has thanked: 2 times
Been thanked: 21 times
Post by Логик » Mon May 18, 2009 21:55
Павел Ф wrote:4) use this session to relax the eyes after working on the computer.
If while working on the computer eye strain, then you need to change the monitor. Eyes more.
