Session for MM from A. Patrushev. About them!))
Installation and discussion
Никкей
Post by Никкей » Sat Jun 25, 2011 14:08
Hello.
The question in the first place Andrew and/or Dimas. At the session of the "alpha-meditation 1" at some point, stop working glasses (Kolor-track). And it is not started immediately, but after about 10 times. And, in all other sessions, including from Andrew, working without a glitch. I tried to change the color, session times - all too, or one diode dies, or both. Tried to reinstall the session - did not help. Breakage of glasses or cars (Innerpulse) not like, or would be failures in other sessions. What here can be the problem?
Никкей
Post by Никкей » Sat Jun 25, 2011 20:45
In the previous post.
I reread the thread and found this:
Андрей Патрушев wrote:
тишина wrote:I in the middle Petrushevsky sessions glasses are sometimes disabled(( hate it
This is done on purpose (certainly not to make You furious). :?
To be clear, this is not a short-term shutdown caused by the feature sessions, back they start. Before such was not, 10 days session yuzal, everything was fine.
Post by Андрей Патрушев » Sun Jun 26, 2011 14:01
the Nikkei
Hello.
That, with high probability, "Naropa" in some connection. When heat from working parts expand and the gap increases - all failing. Look for this defect is extremely difficult and it appears randomly...
Been thanked: 182 times
Post by Андрей Кабанков » Sun Jun 26, 2011 14:39
Check the position of the dimmer switch on the machine ,it needs to be high and the charge level of the batteries.
Никкей
Post by Никкей » Sun Jun 26, 2011 18:06
Thank you.
The regulator at the maximum, with new batteries. Strange that they disabled it on the same session. For a week the use of cars on any other session, there were no blackouts, and "alpha meditation 1" every time is like trying poyuzat in the hope that the glasses will not turn off. If it is really "Naropa", maybe it affects the fact that at this session the brightness slider on the glasses put on the maximum (as recommended in the description) and it is overheating. Experiment with other sessions at maximum brightness, to test this version.
Has thanked: 5 times
Been thanked: 8 times
Re: Session for MM from A. Patrushev. About them!))
Post by Воффка » Sun Jan 22, 2012 12:28
Andrei Patrushev
Andrew, the effect of Your sessions will not be reduced if they combine with the music?
Post by Андрей Патрушев » Sun Jan 22, 2012 15:55
Воффка wrote:Andrei Patrushev
In the General case decreases, because the music carries its informational and emotional load.
Борис М.
Post by Борис М. » Mon Mar 04, 2013 12:19
Andrei Patrushev please tell me, are there any session or program , as it is clearer to say that give the effect is akin to the technique of recapitulation ? Kind of likeness of turbosplit MM in the embodiment .
Has thanked: 31 times
Been thanked: 129 times
Post by к-13 » Mon Mar 04, 2013 13:00
The effect of the recapitulation is impossible without an awareness of the fact that the event that perepisyvatsya need to be reviewed. And to recapitulate the events can be in any alpha session (the alpha state by itself contributes to the surfacing of events that requires a recapitulation). Try "the conductor" - it is closest in fact.
Борис М.
Post by Борис М. » Mon Mar 04, 2013 13:39
K-13 thanks for the reply , I understand .
sem1001
Post by sem1001 » Thu Nov 17, 2016 13:55
Question Andrew
Sorry in advance if this question has already been asked or is somewhere described.
I recently, on occasion, acquired the InnerPulse mind machine.
And I took it with a specific purpose (to try to improve vision)
Turned out to need a period of adjustment...
Now the actual questions:
It is suitable for an adaptation period of Your session, morning and vecher?
(Still listen to them without glasses and put a very short time. From the evening, the effect is small morning and bracing)
And is it possible to listen to without glasses Zrenie?
Post by Андрей Патрушев » Thu Nov 17, 2016 16:05
sem1001
sem1001 wrote:it is Suitable for an adaptation period of Your session, morning and vecher?
For adaptation to what?
sem1001 wrote:And is it possible to listen to without glasses Zrenie?
You can, but for what?
sem1001
Post by sem1001 » Thu Nov 17, 2016 23:04
On this forum there is a branch a Period of adaptation.
As I understand it's the lead-in period is necessary for the effective use of the machine. The author argues that first, you need to get used to using a mind machine.
That's what I was interested in whether or not Your sessions morning and evening for use in water period (i.e. without glasses), although from the morning session and with glasses and without is about the same, and pretty strong effect.
And whether the effect of session vision when using it in water period, without glasses?Session a vision of what I wanted to listen instead of charging for gas. The last few years I have begun to experience problems with vision, by the end of the day my eyes start hard to focus (i.e. the image is not sharp blurred). The morning vision excellent doctors assert that over the past year the vision has improved.
Post by Андрей Патрушев » Fri Nov 18, 2016 0:47
sem1001
Some call it a period of adaptation, someone a threshold effect (when to some then it seems nothing happens - no effects from AVS). Session "Morning" and "Evening" - this is an alpha session which, I believe, need to start with ABC. However, You as well can use all session "r".
As for the session "Zrenie", this session has a corresponding effect solely from light (from points), and the sound only helps to create a calm serene state, in which the effect on vision manifested more fully.
As for eye fatigue, it is an excellent job with this session "r".
Юра88
Has thanked: 6 times
Post by Юра88 » Fri Jul 28, 2017 17:05
Hello. I'm listening session alpha trainer 2 and 3 on the new Navigator-2. Throughout the session, I periodically hear the audio. This is provided the session or something I don't have it on the GPS?
Post by Андрей Патрушев » Sat Jul 29, 2017 20:09
Юра88
Hello.
And for a long time disappear?
Юра88
Post by Юра88 » Mon Jul 31, 2017 11:59
Andrei Patrushev
at 22 seconds disappears
Post by Андрей Патрушев » Mon Jul 31, 2017 16:54
Юра88
No, it should not disappear - the volume and brightness everywhere constant.
Юра88
Post by Юра88 » Mon Jul 31, 2017 20:15
It's a shame, a new product ... and testing of performance of the underlying sessions are not normally done. Andrew, thank you for the reply.
Post by Андрей Патрушев » Mon Jul 31, 2017 21:53
Юра88 wrote:and the testing of basic sessions, normally not done
Here you again... :) With what You have? These sessions still on the Nova Pro 100 (Innerpulse) was tested.
Юра88
Post by Юра88 » Tue Aug 01, 2017 12:07
I've only tried the R session and the alpha trainer, the sessions section R there is no question), They seemed to me like something softer than Innerpulse). The device Navigator 2 is very cool and comfortable. everything is intuitive how to operate the device)After the inner Pulse immediately I was under the impression is just Wow!)) I'll try your alpha trainer pour on the SD card. I think to fix the situation with sound:) anyway thanks to the developers for the device and you Andrew for the session!:)
Post by Андрей Патрушев » Tue Aug 01, 2017 12:15
Юра88 wrote:I'll Try your alpha trainer pour on the SD card.
Hmm, but now that they have You where? :roll:
And another question - where did You get them? Something similar happened a few years ago (due to inconsistencies of iron with my ideas :)), but then I quickly corrected.
Юра88
Post by Юра88 » Tue Aug 01, 2017 12:46
Andrei Patrushev
Under Basic sessions VIII. Special
13. ATr2 alpha тренер2
14. ATr3 alpha тренер3
Post by Андрей Патрушев » Tue Aug 01, 2017 12:52
Юра88
So it's all on the flash drive and lies. :)
And you can email me to throw - I'll check. And then suddenly, indeed, the old was accidentally uploaded.
Юра88
Post by Юра88 » Tue Aug 01, 2017 13:05
Andrei Patrushev
write your mail please:)
In the evening as I come home from work I'll send them to you:)
