СК1М
Евгений-М
Re: СК1М
Post by Евгений-М » Sat Dec 20, 2014 2:35
АндрейКо wrote:Whole life my wife grew orchids but not in bloom..
By the way is not only the UK and the rest of you. People change, but it is not weaker than SK does. :)
Re: СК1М
Post by Михаил_ » Sat Dec 20, 2014 6:40
yeah, still kicking, but SK really very very upset with life energy due to method of manufacture and due TO he also has a tendency this background of widely spread around...
Бисо
Has thanked: 49 times
Been thanked: 38 times
Re: СК1М
Post by Бисо » Tue Dec 23, 2014 16:58
Hello,
I have a question in connection with the manufacture of improvised W1 and can't decide what to do.
In the manual for the manufacturer said that "clay can take up to one-third of the volume of the composition". The druid used "the proportion 1:1".
I did an experiment with my epoxy and clay and the resulting mixture was sufficiently thin at a ratio of 1:2.
But it's a very big difference in comparison with 1:1/3 or 1:1.
How critical is the ratio of epoxy resin and clay for power work, homemade W1?
And if I use a ratio of 1:2 whether it's correct or not?
Thank you in advance.
Re: СК1М
Post by Михаил_ » Tue Dec 23, 2014 19:59
do on your own - all options will work... you can increase the percentage of clay from layer to layer from the bottom up
АлексейН
Has thanked: 20 times
Been thanked: 3 times
Re: СК1М
Post by АлексейН » Tue Dec 30, 2014 20:22
New СК1М don't already have an audio connector?
Re: СК1М
Post by Михаил_ » Tue Dec 30, 2014 21:32
Why ? have the SK3 does not have.
АлексейН
Re: СК1М
Post by АлексейН » Tue Dec 30, 2014 21:38
I don't know what you've gotten. Ordered a 7 continent СК1М for 30200. Today the courier brought the box externally on СК1М. But the audio input on it. In the end I got?
АлексейН
Re: СК1М
Post by АлексейН » Tue Dec 30, 2014 21:47
Excuse me!!!! The device was packaged in a film that's through two layers have not transparent. Behind it was hidden by the connector.
Бисо
Re: СК1М
Post by Бисо » Fri Jan 30, 2015 23:45
Hello,
I just discovered that the audio file is from 3.0 to damage W1.
I tried to feel if it affected my improvised W1, but not sure that correctly assessed my feelings.
All the same, I am inclined to believe on the basis of my sensations that the device is working fine but wanted to be 100% sure of that.
I have a big request, if possible someone to check on the photo, not whether I damaged the device?
And if damaged the device must be disposed of as a Stabilizer?
Re: СК1М
Post by Михаил_ » Mon Feb 02, 2015 20:53
well, you can damage the... to be disposed of is not necessary ... well ... I think you can use but it can work somewhat ... weaker, because the functionality 3. 0 to it is conceptually not very active and the operator is not there.
Бисо
Re: СК1М
Post by Бисо » Sat Feb 14, 2015 3:49
Michael, thank you for your answer.
I already made a second W1. For me it is very important to have a fully functional and powerful device.
Etalon felt very clearly when run through W1.
I was also able to foresee problems with a mini Jack and used two pairs for each W1. In my case it was very helpful. On the first device, a mini-Jack, which is used in the manufacturing process, missed epoxy and the cable is stuck. On the second device, mini-Jack, which is used in the manufacturing process, despite the measures taken, too, missed epoxy. But I managed to pull the cable and I was able to clean it and now everything works great.
Thank you again.
Гарет
Re: СК1М
Post by Гарет » Fri Mar 13, 2015 21:12
Hi all.
Fly from Thailand to Belarus via Moscow, if you carry the SC in the Luggage, the border guards can get they say, what it is etc?
Thank you.
Been thanked: 182 times
Re: СК1М
Post by Андрей Кабанков » Fri Mar 13, 2015 22:22
Yes, most likely questions will arise on the aviation security control, but obstacles to baggage there. If you didn't have to take in your hand Luggage, there is no question.
Гарет
Re: СК1М
Post by Гарет » Sat Mar 14, 2015 19:57
Andrew, thank you.
Those who have experienced issues, it is better to answer?
Re: СК1М
Post by Михаил_ » Sat Mar 14, 2015 20:10
I did not experience - what did not taken. Box and carton. Answer that for example special column :) you can check poke audiojack at high volume - it there himself quietly on the high notes sing. Just hand Luggage do not need. I took the instrument/tool/Tesla coil/coil wire/strange tool, and much more. Sometimes asked "what have you"
To open the bag asked 1 time, and the question was, will not believe - to the battery from the drill :) because it's battery is assembled in such a unit of little round :) and it looks about as Packed Assembly of trotyl blocks with the round ends up :) hihihi
Here is prossy times carried a didgeridoo, this is a very specific musical instrument :) in the case wrapped on the outside and 2 meter almost. The lady at the scanner asked, "have You got a musical instrument? which termites eat?" :) :) :) :) there they have all seen that is no surprise :) So just go safely - nothing is legitimate're not taking, what questions?
I also smuggled in hand Luggage many different strange spec devices (I1/ GDV, etc.) and also everything was OK.
In the UK in the lumen of the coil will see it with an asterisk. The audio Jack is. Everything is logical and legal.
Has thanked: 112 times
Been thanked: 71 times
Re: СК1М
Post by АндрейКо » Wed Apr 15, 2015 22:21
Михаил_ wrote:yeah, still kicking, but SK really very very upset with life energy due to method of manufacture and due TO he also has a tendency this background of widely spread around...
I advise you to make little homemade SK (0.6-1 litre) and the mode of harmonization of premises {sk1room.mp3} to put the thing in a bedroom, kitchen, and other rooms (including the workplace) where you are a long time. it turns out cheap and cheerful :D bi
Thank You, Michael_! Very cool gift!
Re: СК1М
Post by Михаил_ » Thu Apr 16, 2015 3:26
Yeah and they so few people use ... sorry... but so simple.
Андрей Ермаков
Has thanked: 3 times
Been thanked: 15 times
Re: СК1М
Post by Андрей Ермаков » Thu Apr 16, 2015 19:56
Not very... just In town this clay and of humus, and should not be done IMHO.
Re: СК1М
Post by АндрейКо » Thu Apr 16, 2015 20:05
Андрей Ермаков wrote:is Not very simple. In this clay and of humus, and should not be done IMHO.
Even if there were one or two 5 litre plastic cans in a backpack than to dig - on the bus - 40 minutes drive for 70 rubles + walk 10 minutes and there :)
+ back.
A total of 3 hours + 140 roubles = one or two five-liter jars with clay :)
Been thanked: 10 times
Re: СК1М
Post by Мастер 108 » Thu Apr 16, 2015 20:53
АндрейКо wrote:a total of 3 hours + 140 roubles = one or two five-liter jars with clay :)
So it is necessary to know the place 8)
Андрей Ермаков
Re: СК1М
Post by Андрей Ермаков » Thu Apr 16, 2015 21:05
Yes, I'm talking about the other, if a strong desire, everything is possible :). I'm currently 6 small stabilizers made, and in the UK have a different amount of work and what you do not want to mess this brew for five days plus 3 hours on the bus with the banks :). Not just :).
Иван Евгеньевич
Re: СК1М
Post by Иван Евгеньевич » Sun Aug 02, 2015 14:40
Hi all!
СКМ1 baggage from Yakutia to Moscow, and in Samara (received by mail). In Yakutia, long explained that the device for treatment, and there's nothing forbidden. The policeman came looked. In short, the eyes round them was. In Moscow, everything just happened, even the baggage was not unpacked and no problems there. If the airport is big, they know what a bomb is, but in the province there is a little more complicated.
Re: СК1М
Post by Михаил_ » Sun Aug 02, 2015 17:28
Hmm... this is the first such a joke :) I recommend just to take the Luggage (not in hand Luggage).
Иван Евгеньевич
Re: СК1М
Post by Иван Евгеньевич » Sun Aug 02, 2015 21:29
he transported in Luggage, hand Luggage - laptop
Re: СК1М
Post by Михаил_ » Mon Aug 03, 2015 14:09
Well I remember in the old old days, I ran Gruemire older versions (in case it was done as an integral part of it - open and everything is on al-panels), so it had a piece of paper what is this device and what to call a person from the interior Ministry, the Central Board, responsible for the project in the Ministry of interior :) because the x-raying there was veeeery funny - the unit of the multiplier looked exactly like a bunch of TNT blocks :) and next to something round - like the old Soviet alarm clock :) :) :) ) -once the paper is useful, but to call on the phone night no one of course did not...
Otherwise I then drove it in through the border without incidents and problems.
With the UK in General have not yet been plugging never, although personally I rarely drive here and there.
