Re: Stream. The basic features and rates.
Post by Михаил_ » Mon Dec 15, 2014 7:53
Alfm,
Well, if you have tails from the past, accumulated to the autopilot and effective (the example of the runic tradition), in General, do not see why the case (well, maybe not regular, but it is for your situations) not to use them in social/oriented field (because it is in itself a tribute to the history and the past in its current form).
If it doesn't feel like his own, it is best to apply what feel.
In General Practitioner's rights / needs to appelrouth to the real law violated "under his nose", to his suppliers/carriers or conductors. The most pertinent question would be in themes "range"/"stabilizer" on it?
In the Stabilizer is anchored in the zones stop / law and maybe even chaos (if the law and stop will not give visible result or even simultaneously with them ).
The Spectrum is the mass from direct assistance and "I" prior to taxiing of their situation through the proper part of the system (through the egregors that the topic is woven directly). It is obvious that without real action by all stakeholders, the situation may not be resolved in spite of any actions (so actions on the instruments and products to be effective, they need to season the search for a solution through quite human/physical actions).
АлексейН
Has thanked: 20 times
Been thanked: 3 times
Post by АлексейН » Sat Dec 20, 2014 3:44
Sorry for many letters.
Michael, I had mentioned about the bounce when buying new products or broadcasts. But compared to the bounce that occurred when the old slots and broadcasting was transferred to the off - kindergarten, nursery group. All I will not enumerate, and everything can be blamed on coincidence, something on the trends in politics and Economics. Briefly:
On the day of the transfer slots and broadcast mode pending trip, we decided spekulnut on the course, which climbed into the red only made Rin.payments. One of the partners took (with the exchange rates not connected) themselves do not affiliate and not very adequately. But if earlier I'd be nervous and freaking out a much stronger and longer then the day I was in full confidence that everything will be OK and it was somehow even fun and there was the excitement of a sport - well, play your games. I had to run and maximally different methods as possible to reduce the negative effects of the incident. But everything planned that I did not had the opportunity. All "toppled".
The funny thing has already happened in the evening in the gym, in the pool. After all trivalley decided to practice, to relax. What actually did. After training found the absence of their slap. Well, first - what a douchebag their skomunizdili? Via one track to see exactly the same sneaker, but more size 2 and newer :). Well, as it is clear that most likely someone left in my. But well this is how the gaper need to be! Well, of course, I went to the "new" flip flops, not barefoot to walk.
Today I put a new slots and broadcasts the connection.. Well, with the course clear? :) I'm back in the black. "Inappropriate" partner fully adequate and did everything as agreed earlier and even more, as if nothing had happened. During the day, did a lot for work and decided scheduled cases, but not all. In addition to daughter very successfully developed my route, so I managed to get to school and even pick up that all was not in my plans and would not coincide in time. Looks like she's pushing :) And she very successfully defended two works. But then this morning I had to be a small part of modules, it does not know. And funny - come to the pool, meet the coach, which was the last time on the next lane, explain the situation with logical calculations. He looked at my Slippers - this guy just finished training. Slippers were exchanged :) In General, the day to cheer.
I.e. the shutdown had a strong negative chatter on the connection (not included) positive. Some sort of direct dependency. Or was it my hallucinations? Michael, can you explain? Thank you.<
Post by Михаил_ » Mon Dec 22, 2014 0:51
...sometimes I do not answer theme questions immediately because I want to wait - suddenly someone with their views to share...
Like everything here is quite obvious :
1) with the running stream of mental uses their full potential, but the quality has not yet caught on enough to disable did not give noticeable difference.
2) if you disable involved earlier potential apparently "rolled back" and the world generates some passive "rollback" to the old position, which results in sometimes fanciful phenomena (sneakers for example). As a shaped picture - predstavlyaem from the ball part of the air is lowered and its surrounding balls tight, squeezing what is left (reflex driven).
3) the renewal of the broadcast - the ball was blown in place....
Everything seems pretty obvious, but not all so bright. As the speed of imparting its own qualities different. Someone off is almost not noticeable either because of interaction with the world is softer and weaker, either because it is better quality self-developed (or a combination).
АлексейН
Post by АлексейН » Mon Dec 22, 2014 2:40
Michael, thank you...
For the year turns out quality or not caught, or the wall ball hard as the warmer :)
Кона
Been thanked: 8 times
Post by Кона » Wed Dec 24, 2014 11:25
Guys, tell me, the question of setting up the broadcast, something not catch, how to make...
Paid slots, and now you want to check the "Kids calm", but it is not.
Not found and when placing the order and after payment.
Where to press?
ПавелРозов
Post by ПавелРозов » Wed Dec 24, 2014 11:57
Most likely the IP when it was more connected and not currently active. We have to find him in the disabled items and click renew.
Кона
Post by Кона » Wed Dec 24, 2014 15:20
There under "Current broadcast" column "Items" in it, the link "View" and it only BJ 2.2.
All.
Never are being snapped.
Любоовь
Post by Любоовь » Wed Dec 24, 2014 16:27
About The Children's Calm :) Section Purchasing products. It lists all the IP, it is necessary to specify for which group of slots
Кона
Post by Кона » Wed Dec 24, 2014 16:56
Love, thanks, all found, great!
Just seems that when they just paid rent, without this show, the train has already left?
Любоовь
Post by Любоовь » Wed Dec 24, 2014 17:06
I was so. You can ask the office, they are in manual mode added. And so there emerges the requirement of min. at 400 rubles, I think :)
Любоовь
Post by Любоовь » Wed Dec 24, 2014 17:24
I want to share on the theme of reconnection. It turned out, for technical reasons, that I lost all of my club connections, and a few days, I went to machine 32 channel 2.4. This TURBO, as I understand it :) I genome and bracelet bought. During this time I have a start of horror as to hurt the body, laid with temperature, even at work went. Thought the flu. Today was released, and then the connect message came in. But gradually, when connected, seems to be not especially noticeable :)
Любоовь
Post by Любоовь » Wed Dec 24, 2014 17:52
It seems with the TURBO messed up. Channels broadcast the 2.4 was 40 pieces. But still a clear overweight :)
Андрей С.
Been thanked: 4 times
Post by Андрей С. » Wed Dec 24, 2014 19:44
No, it's not turbo :) Turbo is when 36 bindings, not just products 36... number of the same products at the same binding at all particularly no effect, that is, one and the same product in 40 slots is not the same, what to wear 40 bracelets.
Любоовь
Post by Любоовь » Wed Dec 24, 2014 19:56
Well..... call it a coincidence :aa
Been thanked: 182 times
Post by Андрей Кабанков » Thu Dec 25, 2014 21:55
Dear customers, from December 31 to January 11 inclusive the office is closed for the holidays.
Break in service there is no translation, you can place orders and make payment during this period without restriction. All will be promptly processed.
Герой
Post by Герой » Tue Dec 30, 2014 10:12
All welcome! Michael, tell me what is better to connect for a seven-month newborn girls
and to register a new profile without a photo, it is possible to make a connection?
Girl very young, was born on the 29th, now in intensive care, on ancillary equipment.
Thank you! Thank you!!!
Post by Михаил_ » Tue Dec 30, 2014 19:24
PC+ / 2.2 write /genome
What brought her to the intensive care unit ? early childbirth?
profile write something about it as the link (well, parents do enough or for example their name, uniquely identifies the child if the newborn even among possibly several children - one). and then throw me in a personal email to the profile. I turn it on...
if the finances are not really, you can not pay, I understand that at this time not to the broadcasts possible.
Герой
Post by Герой » Wed Dec 31, 2014 9:18
Understand
Yes, the early birth - mom is leaking amniotic fluid and gradually moved all the water
the doctors decided to remove the baby surgically...
In PM you do not get to go
Maria.Shalimova29.12.2014@yandex.ru - email newborn
Mom and dad connected on a broadcast their profiles, photos
For the understanding of the situation, from our family, me and three girls - huge human gratitude and kind words!
Happy new year!
Марат Г.
Post by Марат Г. » Thu Jan 01, 2015 0:13
Michael is generally the best representative of humanity!
Everyone should be so..
And life would be just great :wink:
I wish you health, happiness, prosperity, well-being, and indeed all the best to Him and His fellow men.
And also, I wish the same to all forum members!
Happy New Year, Friends!
Let come true all your dreams!
Best regards, Marat :o
Поминус
Post by Поминус » Thu Jan 01, 2015 20:19
On the forum many wrote about the bounce when you connect broadcasts. I somehow still passed it by. But here a connection 2.6. and literally the next day, new year's eve my house brazenly robbed, while the whole family slept peacefully at home, turn off the lights and forgot the house was well-lit. Insolent not hesitate fumbled around the house, but they only took money (a very tidy sum), taking with him several bottles of elite alcohol. At the same 2.6. the idea was to make me lucky. What are the chances I thought? Robbed twice in a month (first time too stole money and also the next day after another broadcast connection). Imagine how upset I was?
However, the investigators and operatives were told how lucky we were that none of the households did not Wake up to the time of the theft. Could all end very tragically, they assured me.
Here in this regard I have a question: can I use Michael, to see the situation resolved as best as possible for me?
And it's a shame, with the money stolen and cards Svetlitsa Blaga, and I'm only clues to her ordered, not even received yet. The first time was robbed I lost the modulator Amethyst together with your phone. But the next day was miraculously found.
ММ
Has thanked: 185 times
Been thanked: 40 times
Post by ММ » Thu Jan 01, 2015 23:17
Nightmare! :shock: Very sorry for.Pour thieves and criminals " in the funnel drain.amplifier" Is a module like this. Also let the module to quickly defused. For example "the matrix of the crystal key".
Post by bofara » Thu Jan 01, 2015 23:28
Stabilizer - You, at least in the law - remember Michael gave a similar example on Ω, in the theme of the Stabilizer.
Поминус
Post by Поминус » Fri Jan 02, 2015 0:42
Thank you that responded. But before the stabilizer I have not grown. I do not understand how it works and how it can be used. Michael advised not to be greedy and not to rush to buy everything. The line appeared keychain Stabilizer No. 1. Has anyone used this product? Will it help to stabilize the events around me without operator control?
Post by bofara » Fri Jan 02, 2015 2:25
OminusYou help. Yet.
Герой
Post by Герой » Wed Jan 07, 2015 21:13
Michael_ Michael, Hello, why can't you send a message to the PM to here is not oftopit, perhaps because of the small number of posts. Wanted to clarify regarding the broadcast on the new baby. I apologize for the deviation from the focus of this branch of the forum!
