Tranlate - remote virtual artifact(test dir)
An altered state of consciousness, definitely. Multidimensionality, mnogoplanovost and powerful apathy:) it's here now so
Константин.
- Been thanked: 2 times
Re: Tranlate - remote virtual artifact(test
Now can accurately compare conventional broadcast and stereo:
In comparison to the usual rough and tough. Bends the line not paying attention to anything.
Often there were small overloads and the associated status.
FOR "stereo" is instantly gone. Stereo mode is very soft and long-awaited!
it's easy to breathe and live. Either side of this mode is preferable for me.
About "Turbo" will write later...
It goes away after you turn personal reference.Константин. wrote:In comparison to the usual rough and tough.
- С. Альбатрос
- Been thanked: 1 time
From a personal bind all other sensations. It's like a suit made to order, where nothing is too tight, the pockets, where you want, when something is convenient, it does not notice. And the stereo is more powerful and detailed the feed. The power is felt, and no Overdrive. I think just from a personal reference stereo best work should be.
Reviews about turbo: more powerful
After connecting a strong flow of energy in the head, the crown and nose much vigarello, sneezed, there has been a light runny nose. Status ""I'm in the tank"
Yes, with personal reference are completely different things...
Do turbo mode "invent" to "charge" inanimate objects, there is lots and lots of small privaseek (like usual) in stereo mode. Ie the whole "turbo" is a 18 stereo broadcasts (i.e. 36 sataconnect, if stream 1 breaks) and it is one or two servers .... (depends on broadcast and modifiers).
For the "naturelink" missing days,and bright effect starts after 2-3 minutes.
many small stereo privaseek is not the same as personal too - ie is also different.
The point in such a thing - an unusual (and temporary) increase effects at the time of "turbo" and / or rapid development of some qualities, speed training yourself.
Here's the next fun mode is derived from the turbo and it we later....
Yes, the weakening effects of "turbo" - slow (slower than usual), so a couple-three days is enough for a sharp "splix" for a longer time.
Michael, I have a request, can I disable a gene?
after it began airing a lot different I understand outbursts of health,and not for the better
first time watched, week after connect, maybe sooner, started the spikes in temperature, I was ill more than the past five years, there is still neponyatki different, as if I decided to pass on all that once was, brrr...
and somehow started to "cancelled" some developments of the standard
if you can instead of the genome to connect PC, Panacea and FRM, if not then no, but gene please disconnect
Yes, and th is may be due, I've got guesses, but interesting all the same opinions are more mixed people
СтАвР wrote:, I was ill more than the past five years, there is still neponyatki different, as if I decided to pass on all that once was, brrr...
Most likely it's all inside you slowly smoldered,and gene took it out(andreyko described such moments were attended by his son, when AMB clothed) I would in your place did not turn off especially when so much positive change has already passed you
Eh.. Protryasli well - from panic to apathy. Today soft centering and alignment. Feeling very powerful support, you can rely on. Mental calmness and clarity, presence, and feeling in the here and now simultaneously with multiple plans. I feel completely different, can't describe it clearly, but I have a feeling I changed the form in which I dwelt before, it is new interesting and yet not very clear for me. Later I will write more
Personally, I would not have refused the connection genome + other stuff, it's to dopolneniy already connected to me broadcast.СтАвР wrote:can I disable a gene?
All you want, but time at us is not present.
here the time sometimes no....
Константин.
Today my summary for "Turbo"...
with each new day growing up the intensity! Beginning to heat up everything! just piss off!
Everything that does not begin to do glows and angry. Only if that does not do more or less calm
only today figured out why: it wants to accelerate! in all. and all around the bog is very slow.
The computers are slow! people think slowly, things like low gear happen.
The speed of this society and the world is just depressing
and infuriating that it is impossible to speed things along.
Consciousness requires a completely different speed of interaction throughout.
So.
So.
- С. Альбатрос
Yesterday and today for some reason and wanted to listen to charging track 3.0., what did. As Constantine, there are bursts of mood, too, hate the laziness of the computer and some of the members of the movement. Track 3.0. acts as a calming
Maybe just hard now three worked out or the standard? Even promerium a bit in the evening, especially the legs, has long been so, to keep warm. Hands hot and feet cold.
Константин.
After these experiments revealed severe exacerbation of intuition.
well, it (the turbo) while no one was disabled.... because the two experimental servers now outside my reach and I long to restore it
A lot of strength, confidence, clarity, peace, clear understanding of how and where to move. Intuition works amazing, much power, little food and sleep, and the sense of correctness. In the mood observed stability and peace.
Константин.
It is heard that it is not disconnected. Pisses all regularly
Константин.
I agree with the fact that it freezes constantly. And it does not matter down and the building has a gym still freezes.
Not when it is still so painful not respond to cold. Didn't like winter forever!
it is highly likely added sensitivity to the "human" part of this cold... .sympathy
I think last year was worried.
- С. Альбатрос
A state close to the top three, occurs more frequently, can cause at will, lasts longer than before, in these moments as very comfortable, calm, without any emotional waves. Reaction to improper food became more rigid (experiment with chocolate ended headache and signs of poisoning), nothing but fruit, vegetables and nuts for food is not perceived. It seems completely gone heaviness in the heart area, breathing was smooth and deep (it was superficial, slow, with long pauses in the lower phase, above the heart there was a constant heaviness and tightness, back projection like a hole), looks like something finally to clean up, although the process in this area was long with periodic exacerbations. Became much more mobile neck. Less tired, sleep less time, easier to Wake up in the morning: he opened his eyes - and has a vigorous condition, without waking. In the evenings, even promerium feet, apparently some sort of cleaning continues.
Interesting... But I, on the contrary warm and even hot. And surprisingly, since I'm usually the heater
it's the next step
The feeling that I'm moving into a new level of perception of life and people. Maximum focus has shifted to myself. I am the author of the events in his world and in the world around. Awesome, Misha!
Константин.
With the beginning of the turbo, my cell is discharged is twice faster!
turbo discharge
turbo discharge
