Thank youАура wrote:a Good article on the subject in English though
http://www.ursi.org/Proceedings/ProcGA0 ... /p2236.pdf
Bioresonance modulators
Re: Bioresonance modulators.
bofara One more question. And when one workshop have to do with BRM or without?
Possible without..Андерссон wrote:And when one workshop have to do with BRM or without?
bofara Well, I understand, as it to improve the interface and use BRM. Thank you)
Aura
- Has thanked: 22 times
- Been thanked: 1124 times
The workshop include a free product
Hi all, just ordered BRM Amethyst, help to formulate the intention - I want to get rid of debt and loan obligations, to get the job you want to have a family and your house
Aura
AnnaYou all at one intention want to wrap? The result is something like "give to drink, and then so hungry, nowhere to sleep already".
Others ready-made formulations if they are not General and for a specific task of getting rid of debts, find work for the soul etc. is not recommended. BRM reads not wording, and Your both conscious and subconscious desire. That is why the desire must be real, not superficial. For example, the person sets the intention of obtaining money, and the money may be needed for gaining power, or for the purchase of the machine. Real intent in this case is to machine or power. And that puts one person in a specific language, often does not coincide with what puts in the same words the other person is.
Another example with a real psychotherapeutic technique. It would seem a very positive setting to "harmonization" and "mobilization" (resources, I think) the subconscious mind of the patient was interpreted as soldiers (i.e., mobilized in the army) with the accordion.
Therefore, it is recommended to read the rules and guidelines for the correct formulation of the intentions in this thread, and there are other good threads on this topic, for example viewtopic.php?f=8&t=577
on this basis, to formulate intentions, and if there is doubt, it is possible to name here, if necessary will correct.
Thanks a lot for the answer, of course not all of it immediately, turns out it is necessary to unwind the chain you want
how to define, write
By the way I use together as a BRM-s and-hypnosis - works well in the direction of assuring.. Much..Аура wrote:Therefore, it is recommended to read the rules and guidelines for the correct formulation of the intentions in this thread, and there are other good threads on this topic, for example viewtopic.php?f=8&t=577
If BRM works best with verbal information as BRM-Amethyst
And a question: won't affect BRM, intentions surrounding a number of people, his wife for example) she's always there
I sometimes give my wife to talk on my smartphone /my rate is flexible/ not see any effect.. well, It is not activated BRM-s on a smartphone.. Even she /my wife/ a very positive person, so if it affects - only positive..
Hello, question to the Aura
it is unclear how there was a large crack on Smokey quartz - did not drop, did not beat, where the corruption I'll never know.
He is not working? or with a crack will work?
Aura
the Pianistthe quartz , unlike kt, non-friable minerals. Crystal BRM, especially if used for some time, so in sync with the operator that it is possible for a colour change, cracking and other manifestations to read that You have to HEIP happens. If the Topaz cracked and it was not mechanical damage, then the crystal "take" on the situation, perhaps the influence. Swipe the surface with your finger: if the crack is internal, it is still possible that Brom to use, if the crack goes through and is felt by the finger, tell that BRM thank you very much.
The crack is large, not one - as if it crashed, went cracks in the fall, but just didn't fall. Well, thank you, my dear Smokey quartz, maybe this was his destiny - different result I felt.Аура wrote:Pianistthe quartz , unlike kt, non-friable minerals. Crystal BRM, especially if used for some time, so in sync with the operator that it is possible for a colour change, cracking and other manifestations to read that You have to HEIP happens. If the Topaz cracked and it was not mechanical damage, then the crystal "take" on the situation, perhaps the influence. Swipe the surface with your finger: if the crack is internal, it is still possible that Brom to use, if the crack goes through and is felt by the finger, tell that BRM thank you very much.
Aura
the Pianist, BRM is not a product where you have to "result to feel." The result of BRM is Your interaction with GAIP. If you expect the manifestation of some properties, it is best to use essential oils. In BRM the most can manifest the so-called "side" (in this case) effects of being active polarized crystal field operator as beverage energy or protective properties (which apparently in this case happened). All the other "results" is a result of operator interaction with the crystal and channel direct-feedback from the GIEP. It's like to stand next to the machine and say no drive speed is not felt.
Got my amethyst - a handsome, all very quickly, spent activated created intention, now listen to yourself
daughter is stuck on the phone way 210
"Anna"]So it is recommended to read the rules and guidelines for the correct formulation of the intentions in this thread, and there are other good threads on this topic, for example viewtopic.php?f=8&t=577
my intention turned out like this: I mentally, physically and financially free from obligations to creditors.My material wealth is stable and exceeds all my needs to four times. This contributes to my new interesting high-paying job.
please correct, but loans hurting me mentally, I need money to buy food, now I week already unemployed. amethyst chose right, no matter how much reading other options, so based on this...
- Иван Славов
- Has thanked: 650 times
- Been thanked: 150 times
Annaabout the sustainability of Your wording You can have spraviti Andrei V. Patrushev, in the related topic.. He gives good recommendations on the forum Mindmachine..
Me personally, Your wording not like it, but why and what would change I'm not going to write..
Good luck!
Good luck!
Thank You, Bopara! still asking for your advice...
- Иван Славов
From my point of view so you can die..АнНна wrote: ..physically..I'm free from obligations to creditors..
I put a different meaning - that physically I'm not in prison, for example
АнНна wrote: physically and financially free from obligations to creditors.
..Apparently freedom "from" obligations..this is similar to "not" wanting (something) and the installation should be positive. So it's best just. "financially and physically free"
Thank you, Neva, d to think. the next day after activation, there was a feeling of tightness of the head at one point either the nose or the forehead, and then very strongly hit this place, cut off two inches of the head, at the edge of hair growth right in the middle of the forehead, nothing noticed in terms of response
