Bioresonance modulators
Your own guide in the energy-space
Ира
Has thanked: 7 times
Been thanked: 7 times
Re: Bioresonance modulators.
Post by Ира » Wed Mar 18, 2015 1:44
Something quiet))) I want to revive a little interest in the topic. Let them help in choosing a beginner.
Yes, I have a 2 BRM: one quartz, the other tourmaline code. The difference between them is enormous and if the first tune for longer to the operator and leads to a more stable target, tourmaline BRM is configured to quickly and dramatically gives all "that we should not have" within the desired. This work had not yet learned too many responses and options when working with tourmaline BRM, you must be able to reflect on and Refine their desires in the direction you want.
Who remembers my past record, can be part about the "blockade" - I don't know what it was in January, but now it's all gone again and everything works. Just was kind of "dead area", that ended.
Bio-resonance modulators.
Post by bofara » Wed Mar 18, 2015 14:16
Yeah, really quiet, but this does not prevent to use successfully BRM-Ki..
By the way, essence is really more powerful..
I personally have not yet mastered etu thing:
other people notice the “presence effect” at a distance
but working on that..
владимыричь
Been thanked: 3 times
Post by владимыричь » Sun Mar 22, 2015 14:21
bofara wrote:by the Way, essence is really more powerful..
For me and the essence of BRM is the product of different actions and goals. Essences mainly use when you need their state/attitude set up, and BRM more of a global thing...I get to build the right connections with the outside world.
bofara wrote:Yeah, really quiet, but this does not prevent to use successfully BRM-Ki..
I now also quiet, so it was sometime in the summer, but then it turned out that this is the calm before the storm :) Let's see how this time works BRM :) Even noticed that schorl and dravite tourmalines though both have a very different feel and work.
Андерссон
Post by Андерссон » Sat Mar 28, 2015 2:11
All good day, I'm new here and just think to buy BRM. I want to ask is it possible to glue it for example on a laptop connected to the Internet, or only on smartphone, is there a difference or is it just due to the fact that the phone is constantly with you?
Has thanked: 478 times
Been thanked: 264 times
Post by ЛИЛИЯ-Р » Sat Mar 28, 2015 14:43
Andersson Can . About where to glue and how to work there in the beginning of this topic,there are other topics for BRM, read these topics again, and again realize what works along with what BRM is right for you.
Post by bofara » Sat Mar 28, 2015 15:38
AnderssonI would recommend You to practice exercises with psychic workshop.. good Luck!
Андерссон
Post by Андерссон » Sun Mar 29, 2015 21:22
LILY-P And can be bonded if I have a phone with a metal lid, it does not affect?
Post by ЛИЛИЯ-Р » Mon Mar 30, 2015 1:34
Can. The case is just not worth it,it makes no sense .
Андерссон
Post by Андерссон » Mon Mar 30, 2015 3:08
LILY-P Thank you for your answer, at the expense of the cases I have read, I understand it is necessary to have tactile contact. I was just wondering on the account because the phone is metal body.
нева
Has thanked: 21 times
Been thanked: 90 times
Post by нева » Mon Mar 30, 2015 11:09
Андерссон wrote:I was just wondering on the account because the phone is metal body.
If the metal casing of the phone something screened at such high frequencies, respectively, and the signal is not emitted to the phone. Since the metal casing of the phone is not grounded then it is assumed that the interference from the phone antenna to the metal elements of the phone case do these elements, something like an additional passive antenna. I once long ago was a Nokia with a metal lid, as this lid came from inside contacts that suggests that there is this metal cover was used as an antenna. Also in the fourth iPhone is the antenna issue is solved by the metal elements of the case. So it turns out that pasting Pmcu for the metal in the phone which means to paste it directly into the antenna.
Ира
Post by Ира » Mon Mar 30, 2015 22:49
You know, something I'm impressed..... Today saw the manifestation of the properties of "boomerang" in BRM Verdilite (able to create a powerful protective field around the operator. Protection created by BRM Verdelite, operates on the boomerang principle: reflects the negative impact and returns them to the source on the energy-informational channel).
Me unfairly at work, hurt on Friday.... And today they showed me how my abuser takes away from work soon. (It "showed", I did not need is in this time in this place).
Well, all sorts of feedback on the little things today filled the air. Directly into all of the thoughts and intents for the last time.
Андерссон
Post by Андерссон » Wed Apr 01, 2015 1:03
bofara Thank read, but why focus on 12 nodes? I mean what is that BRM?
Post by bofara » Wed Apr 01, 2015 11:21
If easier - so Your operatorsthe in GEIP will be more easy and effective..
Андерссон
Post by Андерссон » Sat Apr 04, 2015 0:37
bofara That is, I understand operatortoken depends on the concentration, that is, from his natrenirovannosti? :ap
Акела
Has thanked: 28 times
Been thanked: 64 times
Post by Акела » Sat Apr 04, 2015 1:35
operatortoken I mean a confident user of "your consciousness", well, as confident PC user with the option of programming in any language, and concentration is just one of the many qualities necessary for effective typically mental activities. But be careful when apart walls of consciousness and falling to the roof...
Post by bofara » Sat Apr 04, 2015 2:34
Андерссон wrote:bofara so I understand operatortoken depends on the concentration, that is, from his natrenirovannosti? :ap
I think You have heard somewhere-I read the phrase: "Where attention - there is energy". Sings and started to think this way. In addition to concentration for operatorsthe there are other things, of course. See, for example, a workshop practices there is much wider than just one concentration..
p.s.
Андерссон wrote:to concentrate on 12 nodes
That, from my point of view, can be called a partial "de-concentration", although the name does not matter, it is important to work.. Here what I wrote Aura:
Аура wrote:Volume attention is able to perceive every event immediately with a variety of parties and to move the focus of consciousness in the best at the moment, the situation in which the problem does not exist at all or the way to solve the problem already
laid. Through the work of the attention in the volume formed by the volume of consciousness. The volume of the consciousness in the psychic-energy practice is the base.
нева
Post by нева » Sat Apr 04, 2015 12:04
Sometimes my concentration can interfere with the natural course of events for achieving the result, because usually we want that interim events were not applicable to our plan or the way we would like to, and setting on the end result strays. So I think that concentration is better to consider in a pair of relaxation. Usually people want to control the course of events, and in this, they spend their strength, focusing for example on the fact that suddenly the taxi driver took an unfamiliar route. We just don't know how to trust the World, so the world exploit the human ability to concentrate for pumping energy, concentrating its(human) on anything. Therefore, the ability to keep the "relaxed" attention is equally important. We can say that the credibility of the environment is another level of personal relationships with the outside World, where the focus seems to have a very different quality.
Aura
Has thanked: 22 times
Been thanked: 1124 times
Post by Aura » Sun Apr 05, 2015 1:03
Андерссон wrote:so I understand operatortoken depends on the concentration, that is, from his natrenirovannosti?
From concentration, it all depends, even a jar of ogurcami open. In BRM, of crucial importance is the question of encoding and decoding or connection OS-BRM. Further elements of the chain have a similar crystalline structure. This is the connection, the alignment of the operator with the crystal BRM. And for this there is like a lot of psycho and our workshop. There are several options: You can so powerfully on the intention to focus, but then it will have to do constantly when BRM is the field operator. Quickly get tired, concentration is still a lot of is spent. And it is possible to concentrate a couple of times, but at the time of kontakata crystal, described in the instructions as "Activation", but then do not have BRM to hold between your hands, it is enough to understand once it's done. The instructions described the second varinat. In BRM-2 this issue was solved in the presence of audio input.
Жако
Has thanked: 15 times
Post by Жако » Mon Apr 06, 2015 21:04
Hi guys, this is my first post :) .
I'm italian and I'm sorry I write you in english ... and my english is not too good :oops: .
I have a question about BRM, I read all these pages (translated by google :D ) but I didn't find an answer to my question.
I would like to paste the BRM directly on the back of the phone and insert the phone into a case.
I want to cut out a small window on the rear side of the case, so that the crystal remains exposed and the circuit remains covered by the case.
Can I do it in this way or is it better that the circuit must be exposed, too?
Thank you very much
Post by bofara » Mon Apr 06, 2015 21:25
You don't need to cut a window-hole. The BRM will also work through the case. I use my BRMs the same way-they are covered-protected with silicone case. Luck.
You should have in mind that at first you have to activate your BRM. BTW-what is the type of your BRM?
Жако
Post by Жако » Mon Apr 06, 2015 22:24
Thanks for the answer and advices, Bofara :).
I'm waiting for Smoky Quartz for start :).
Post by bofara » Tue Apr 07, 2015 1:39
:ay Smoky Quartz, in my opinion, is an excellent starting BRM..
p.s. if you, anyway, find difficulties in expressing your thoughts in english - you may write me in personal message /in russian here at the forum: "BOS"/ in italian /I understand italian, but many years passed, when I spoke this language/..
Post by bofara » Tue Apr 07, 2015 1:44
Andrew Kabankov, Aura - my opinion is that Jacko is simply unaware of the opportunity to fill in the questionnaire and to test the pendant.. And I think it would be good.. :o
Aura
Post by Aura » Fri Apr 10, 2015 16:15
Good article on the subject in English though
http://www.ursi.org/Proceedings/ProcGA0 ... /p2236.pdf
Post by bofara » Sun Apr 12, 2015 15:27
By the way, I'm trying to understand how GAIP and ectoplasma
All positively related to the existence of ectoplasm, the researchers agree that ecto — plastic material substance
interact.. the Article opens the curtain a little bit. Thank you.
