Bracelets Life
верунчик
Post by верунчик » Fri Jan 21, 2011 20:07
Маг.нет wrote:
верунчик wrote:big-eyed become
so like already "see the light", the visible results... with review not in a hurry, yet very much unknown to me observations, but significant changes are noticeable... just expressed a kind of...
Sincerely, MAG.no
Yes, probably, and no need to rush.
I think this is very personal. Well that's my opinion.
Good Luck To You!
Has thanked: 24 times
Been thanked: 142 times
Post by Маг.нет » Fri Jan 21, 2011 20:14
верунчик wrote:Samantaray
And what is it?
Sincerely, MAG.no
Post by Михаил_ » Fri Jan 21, 2011 20:19
1. view sujok therapy
2. the title of the book :)
3. the impact of seeds, energy of which is very different, as podobie on sujok areas of compliance.
4. a good addition to the more short-term acupuncture or self-treatment (very effective).
5. what you can't hurt
.... and further the choice.... ie, 1-5 overall.
in General this is something that everyone should know as a first-and second help themselves and others.
Post by Маг.нет » Fri Jan 21, 2011 20:26
As I understand it follow certain seeds in certain areas depending on the necessary assistance for these or other symptoms? Or more difficult?
Sincerely, MAG.no
Post by Михаил_ » Fri Jan 21, 2011 21:27
Yes, exactly, but if desired, and harder. Everything else can influence the direction of the seed (in addition to the type and zone).
Post by Маг.нет » Fri Jan 21, 2011 21:50
Michael_ and You would recommend to charge the "working seeds" well, for example, 1.0 L or SK? Or seeds, and so "all necessary" for therapy in prosperity?
Sincerely, MAG.no
верунчик
Post by верунчик » Fri Jan 21, 2011 23:40
Samantaray self-sufficient treatment.
About charging 1.0 L. for example very elderly people with heart failure. It is recommended to use seed of viburnum - form heart. How this seed of energy? And how quickly this energy people with the deficiency will absorb, and how much could she do? With the matrix will probably be more. You can just the matrix, but ( my opinion ) with the seed is suddenly softer.
Interesting treatment. For gluttons it is possible part of the stomach to fill with seeds on the line and will eat less :)
For men suffering from impotence to take a twig and stick in the right place for the growth of the branches.
Well, if "sex. maniac" on the contrary :)
Has thanked: 5 times
Been thanked: 8 times
Post by Воффка » Sat Jan 22, 2011 0:01
Маг.нет wrote: Like derbanit not necessarily possible to act otherwise, or 1.0 L (to apply the matrix), or 1.0 (charged tracks), , or 2.0 using the same bracelet 2.x laser engraved...
Sincerely, MAG.no
Hello, Roman!
I here a little do not understand. With the bracelet 2.x you can create a new 2.0?
Post by Маг.нет » Sat Jan 22, 2011 1:09
верунчик wrote:Can be just the matrix, but ( my opinion ) with the seed is suddenly softer.
But the matrix itself that will not allow the quality energy it needs seed... if not charging:)realized it could be done probably if you have experience and visible results of the efficiency of the method.
Sincerely, MAG.no
верунчик
Post by верунчик » Sat Jan 22, 2011 3:17
Sincerely, MAG.no
So after the BJ, ck, ........ Su Jok - the work of mental activities and intentions with the "tools"
Post by Маг.нет » Sat Jan 22, 2011 10:40
I agree. For best result it is necessary and sufficient to have "high-quality" mental organization intentions control, but in any case, you want "scheme interaction" and "results output", and here is the understanding of the principles and experience greatly enhance the efficiency (compared to the minimal presence of these factors). Sometimes it helps "guide to the experience" BJ, then even the understanding all principles may not be required. Triggered a simple algorithm - input/prilojenie experience/exit if to cling to someone effective experience, the output is the result of "same as usual" the media experience in similar situations. It doesn't work "as expert advice, but as a mentor-assistant-specialist".
"tools" can be varied...
Sincerely, MAG.no
Has thanked: 478 times
Been thanked: 264 times
Post by ЛИЛИЯ-Р » Wed Jan 26, 2011 14:03
Michael question about the bracelet at all. If a person not wearing a wristband (but to measure his for a few seconds - the trace of him remains?), happened disease ,but at this time he had no bracelet if he could send help all wear the bracelets ? Or for example just use some kind of bracelet with the aim to send it the energy to recover? In the UK have tried to nakalyakat goal more than heighten (Except Radionics of course)?
Post by Михаил_ » Wed Jan 26, 2011 14:27
1. there is no "send all" and never was. Is there a module that can only cause the man himself and he wasn't meant for such situations.
2. a few seconds - too little trail, it is easier to work on the man module "replicate".
3. for health you need to use modules related to algorithms of this type, i.e. what is conventionally called a first aid kit, pill, cleaning of blood, etc.
Post by Маг.нет » Wed Jan 26, 2011 15:23
So there is a simple and "specially designed" for such emergency events is 1.0 L. In the extreme case just to put a few matrices on a strip of paper and "wrap" it as a bracelet or offered another band-aid and stick on parts of the body, it is possible for "certain schemes" and models.
Sincerely, MAG.no
Post by Михаил_ » Wed Jan 26, 2011 15:28
it seemed to me that the question concerns when to send the bracelet is impossible, and people may not want to work with light at all... it is time to porosity and understand that all pull on the lasso cannot....
Post by Маг.нет » Wed Jan 26, 2011 15:36
Михаил_ wrote:when to pass the bracelet is impossible, and people may not want to work with the light...
Then BJ is better "not to go"... Some of the people are "gifted 2.0" was originally taken the position not that of unbelief, and even criticism, but... now DEEPLY GRATEFUL for the opportunity to influence for the better, for example in matters of health. Don't know a single User who receives BJ 1.0, 2.0 me, which eventually abandoned its use (observed the opposite, refusing - requested return...). Well, the experience I have. Offer choices not convincing... Everyone in the effectiveness of make sure yourself! On my personal experience.
Sincerely, MAG.no
Post by Маг.нет » Wed Jan 26, 2011 15:56
Struck mandala 1.0 L flower pot (+in the land of the onion root was placed a copper plate with the matrix, water poured 1.0 L). Previously (before charging 1.0) flower, among others such as "unwell", there is something to compare.
Michael_ expected any benefit to him from such an intervention in "his life and health"?
Sincerely, MAG.no
Post by ЛИЛИЯ-Р » Wed Jan 26, 2011 17:28
The point is that the person is not close and there is no way to convey the bracelet or whatever else.But there is a desire to help his quick recovery.T e with your bracelet to cause the module to recover to a specific person is impossible? And send him. Need only for yourself and from your bracelet?
Then only the SCM is probably suitable.
And yet-in any case, you can use this module when you invoke the emergency aid all wielders of the bracelet. Previously somewhere on the forum it was written.
Владмосква
Been thanked: 7 times
Post by Владмосква » Wed Jan 26, 2011 18:55
LILIYA-R,
"group shock", it will bring up a bunch of subconscious experience of those who wear the bracelets and create some kind of corrective wave.
After starting the module to try to sleep.
that Michael wrote is applicable to health. But the "group shock" and emergency of a different kind can be used as a last resort:
Shockproof-Group - force-majeure only for extremely critical situations. Activates a network of subconscious everyone who wears the bracelets and all relations and can be used for impact and to solve problems, rather it happens automatically. Activating this module You actually turn to the collective wisdom of the subconscious of several thousand people with your situation and it triggers some kind of response. It is clear that it should not be used unnecessarily. It is clear also that the subconscious can not lie and suffer human frailties. They will assist if this is an objective need and the situation is critical. For those who were helping and not geeky it's unlikely to be noticeable.
It should be understood that the "fake call" will not of course result in direct negative consequences, but it will not be exact. Can occur in some kind of trouble, or discontinuance of this module is for You personally in the future. Meaning deliberately false call, not a personal delusion.
The module group is entirely voluntary. Ie comes to a "call" which is perceived by the subconscious. If no resonance is ignored. The subconscious should be your personal desire to help and involvement in the case, usually a professional involvement. Energy to person when it comes to the activation of the subconscious, but those who are rarely in this state, the transition to strong activation of one of the personalities inside, can cause certain ISS. Further assistance can be energy intensive, and like any job it can cause some fatigue, regardless of any power-UPS. However, is this:
1. good Smile fatigue increases the resource person and his subconscious significant, i.e., after such work personal ability to grow.
2. this is a voluntary help - comparable with the fact that You called a friend and asked to come to help on saimnieciska case, if the subconscious mind responded, it was for a good reason.
3. helping you can count to help yourself, and the module aktiviziruyutsya sometimes myself, if You get in a really critical situation.
The fact that the appropriateness of participation in this module chooses our subconscious. There are people who notice it and can then say at least that "something was different" and often even "one". Many people simply do not notice and many have even their part is not actually seen, despite the sleep or wakefulness.
But theoretically there may be a situation fatigue.
Time shifting is also possible. Moreover, as I already wrote, the call module may not be aware.
Can be some strange distortions in this case. For example, if a person constantly uses this opportunity without real need, then the subconscious the most part bears BJ and can largely be ignored (according to the principle that it itself), and to respond will be those who otherwise are also aligned with this person. Then "call" will not be as massive and specific load of the participant more. Truth and training the effect stronger...
Post by Воффка » Wed Jan 26, 2011 20:40
I decided to write my regular review of the use of bracelets 2.5 and 2.6.
Included remember this one module to invoke a lucid dream. And slept not at home, and on the construction site (it happened :) ). I still there so it was scary to sleep in, a big building under construction on some floors there is no light at all and plates are deposited, the fact that somewhere some of you make a sound unexpected. The pipes from the temperature of the deform starts crackling and, in General, in short scary and I am the light in all the places included where they could. And tossing and turning tossing and turning I eventually fell asleep. Then began interesting. I don't understand the dream or what, but feel to sleep not like. I am in the same place where they sleep, i.e. on the construction site, but only dark and light is nowhere to be found. I'm so scared what happens when a child is afraid of the dark and scary thing, but scary strong. And I don't know right what to do to move on somewhere really scary, I want to Wake up soon. In the end, woke up, everything is fine, all the lights are on.
Then there was another time before that. I sleep so well on this same site (again, it happened :) ) and again, I'm so damn scary once one night. In the end, I fell asleep, but no modules did not cause. And then, whether in dreams, whether somewhere else, but the feeling that it wasn't like a dream. And in General, I'm on this site, only in another room and again there is no light!!!! And I realize that I am without a body. Ie we of eyes can see where a shape of the nose, the top is not see a lot of eyebrows, but then this was not all, it was just the field of view and clean all. Further, I understand that there's someone else, but it is not visible (it is as though as the clot of emptiness was) I was scared as God knows who, and for some reason want to start is that someone has to attack somehow (the habit of hands and feet without a body I'm not can). In the end, I begin to move very quickly in the direction of this bunch, and Wake up.
Then, too, a curious case was, but in the apartment where I live. Before bedtime include a module to call a Wasp. Going to bed and this same story to me, whether a dream it is that, but I'm in my apartment at the same place where you went to sleep all so well worth it, but the light never lit (and then I have deja vu :) ). Me again is scary, but somehow not to fight with anyone not already hochitsya, and in the end I try to stir myself something to Wake up and barely as some time later I Wake up.
Before this module I have this effect is not caused, and to purchase RF consoles it is not funcitonal at all. After RF bought it, he began to call the OS, but normal where I realized that I was in a dream, could do anything, and not like the last times.
Don't know what it all means?<
Post by Михаил_ » Wed Jan 26, 2011 22:10
MAG.no -the expected. The experiment was set with water 1.0 was a positive result compared to the control group.
Post by Маг.нет » Wed Jan 26, 2011 22:24
Going to watch...
Sincerely, MAG.no
Post by Михаил_ » Thu Jan 27, 2011 0:34
Voffka
well it may be - HF save up energy, it turns to WTO in the dream, someone pulls in "fresh" ones in the face of your not waste of unusual reaction to the situation (fear=release of energy including + fear itself can be stimulated by the extension of perception).
In General BJ active and when it exits from the body and gives good defense, so attack someone it usually makes no sense...
Fear (from the singularity) is simply a lead attracting lovers energy.
Post by Воффка » Thu Jan 27, 2011 9:22
Michael_
And that in the WTO you need to do and why is there a light is there? :)
Малика
Has thanked: 251 times
Been thanked: 110 times
Post by Малика » Thu Jan 27, 2011 11:41
A report on the work of the matrix:
I wrote that caused the mental matrix of the body, including the shoulder,which ached with the month of June, and I could not freely rotate the arm. The doctor who I was told is the beginning osteoporosis (and this despite the fact that I constantly care about your health..).
After the matrix arm was free to move on the third day, now, thank God and thanks to Michael, it was working. Draw a mental matrix of all the time, fix the result.
Even her husband drew, no longer resists..really I draw with pen..
Another interesting point with the matrix - when applied on the stomach I lost appetite. Weighed constantly, lost about two kilos! :D :D :D
