I think enough to learn how to relax efficiently.Тимур И wrote:what do I need to do is make it work for me??
The Program Of Andrey Patrushev Raduga
Re: The Program Of Andrey Patrushev Raduga
Andrei Patrushev
I have been doing meditation for half a year, but I'm doing it correctly or not can't be sure. If You could please tell me where to start and how to do it correctly? I would be grateful
Timur And
Better to start, IMHO, with the classic auditory training.
Just the same them is what I do, the Experience I already have some, but whether I shift the TRANS in the right direction, sometimes I just fall asleep already after 15-20 minutes. Or it is itself come with time and practice?
Timur And
About the TRANS and the side of "we don't understand",
the criterion can serve as a clear sense that You inspire.
Some time working with the program rainbow using words for affirmations upside down: for example: "Healthy" - "Warez", etc. the Efficiency increased sensations.
Dear friends, can anyone knows, is there an analogue of the program "rainbow" in the Android OS?
LIVE+
What's the point?
What's the point?
Andrei Patrushev The meaning is quite technical. As win 8.1 on the PC and put the Rainbow on nine plants resources didn't grab, on XP everything was fine. There was a topic you want to study, now I think how to be.
LIVE+
All this should happen on a large enough monitor...
Andrei Patrushev
The monitor apparently has sufficient time on the PC set. There is such a thing that rainbow on win 8.1 (actually designed for tablets or touch monitor) does not work properly. And if there was a solution for the Android OS, it's likely that to win 8.1 it would fit.
LIVE+
Only thing is that for Android no solutions...
LIVE+
Andrei Patrushev
Andrew, Hello!
I have a problem like this. As often as possible to say "Yes" to various proposals
The film "Always say Yes" look? Here I need the same thing, but within reasonable standards
Prompt how better to make a affirmation, for assistance in mastering this skill? In other words, not to "prosecute" moments and automatically out of habit, not to say "no."
Probably need the topic of mindfulness as something to address?
Andrew, Hello!
AndrewThink a screen size of 9.7" in this case does not fit?
Voffkafor Android already there are quite a few solutions on the basis of 25 fps, but nine units of the "Rainbow" is not found.
LIVE+
No, for Rainbow screen needs to be at least wider than the muzzle face. And, in General, the wider the better (more convenient).
Hello all!
Prepared by Vladimir Nikonov affirmations for Quick Reading for Rainbow-Arc.
Simultaneously came the idea to do with them supraliminally* audio.
Did using the "talk". Had to try several, including paid... Of all liked koobaudio2.0.12.00_beta - your settings and quality.
Special recommendations and restrictions for listening no, but it is better to avoid listening to right before bedtime as supraliminal causes some anxiety. Is - the combination with a Rainbow-Arc: first listen(16 min), then see (10min). It is possible to save time and at the same time, only there is a request to close the eyes, therefore, the request you can close your eyes, and when the membership will end and begin the "silence" you can open and run a Rainbow.
*Supraliminal (supraliminal) - about threshold differs from subliminal (subliminal) - subliminal fact that the volume its same as normal audio, only due to the shift of the signal in the frequency region, his consciousness does not perceive, but the subconscious perceives very well. Abroad, this method is almost pushed out of the market subliminal, and we have only APK (SOMVI).<
Hi Andrew
I have the program says Invalid filename. I read your answer Natella (Message Thu Mar 21, 2013 12:27) the same problem:
Natella
It is not necessary Nitsche manually register. For each file open (if you click on the three dots) vindovsky standard window in which you select the file You want.
and did not understand from your answer, except it is Not necessary Nitsche manually register (although the user manual says: — Personalization. Before starting, You need to download (either manually or from a saved file) the different names and nicknames that You are called for life).
What about the 3 points you write? If Save Download Run the setup program window them 4 and not point this and button. There are no more points
What you need file is it?
Be kind, please answer in more detail to this question: why isn't prog, what am I doing wrong?
Natella
Eugene
The left three lines: "a file with the phrases", "File name", "text File". Remove the checkmark from the lines: "Sound" and "Background".
Your files should be in the program folder.
Everything went, thanks
Eugene
"To create and throw" - a little. And the way something prescribed?
Yes, prescribed and start
Hello!
1. I laid out the affirmation, "confident", on more than a hundred affirmations.
That's not even counting affirmati...
Plus still going to do the same with several similar affirmations.
Wakes more than five hundred in a single file.
Not too much is it??
I, Mr everyone knows that I believe in myself in any situation!
Is this normal?<
2, When using pronouns and names, the Phrase: everyone knows that I believe in myself in any situation, awakens to look like:let my insecurities
worthy to let go of insecurities
I see that I let my insecurities
I know that I let my insecurities
I hear that I let my insecurities
remember that I let my insecurities
sure that I let my insecurities
appreciate the fact that I let my insecurities
understand that I let my insecurities
happy that I let my insecurities
I feel that I let my insecurities
everyone knows that I let my insecurities
claim that I let my insecurities
I tell myself that I let my insecurities
can afford to let go of insecurities
thankful to let my insecurities
believe in yourself in any situation!
can afford to believe in yourself in any situation!
worthy to believe in yourself in any situation!
feel that I believe in myself in any situation!
I see that I believe in myself in any situation!
understand that I believe in myself in any situation!
know that I believe in myself in any situation!
sure I believe in myself in any situation!
saying that I believe in myself in any situation!
I tell myself that I believe in myself in any situation!
I really appreciate the fact that I believe in myself in any situation!
definitely believe in yourself!
can afford of course believe in yourself!
worthy of course believe in yourself!
all know I definitely believe in yourself!
I feel that I definitely believe in yourself!
see, I definitely believe in yourself!
understand I definitely believe in yourself!
I know that I certainly believe in yourself!
sure I definitely believe in yourself!
say that I of course believe in yourself!
I tell myself that I certainly believe in yourself!
I really appreciate the fact that I certainly believe in yourself!
confident HERE and NOW!
can afford to be confident HERE and NOW!
worthy to be confident HERE and NOW!
everyone knows that I'm very confident HERE and NOW!
I feel that I have confidence in myself HERE and NOW!
see I'm confident HERE and NOW!
understand that I'm very confident HERE and NOW!
I know that I'm very confident HERE and NOW!
I am sure that I have confidence in myself HERE and NOW!
saying that I am confident HERE and NOW!
I tell myself I am confident HERE and NOW!
really appreciate what I have confidence in myself HERE and NOW!
confident in every way!
can afford to be confident in every way!
deserve to be confident in every way!
everyone knows I'm confident in every way!
I feel that I have confidence in myself in every way!
see I'm confident in every way!
understand that I am confident in every way!
I know that I have confidence in myself in every way!
I am sure that I have confidence in myself in every way!
saying that I am confident in every way!
I tell myself I am confident in every way!
I really appreciate the fact that I am confident in every way!
radiate confidence!
can afford to exude confidence!
worthy to radiate confidence!
everyone knows that I exude confidence!
I feel that I exude confidence!
I see that I radiate confidence!
I understand that I exude confidence!
I know that I exude confidence!
I am sure that I exude confidence!
say that I exude confidence!
I tell myself that I exude confidence!
really appreciate that I radiate confidence!
confident in their capabilities!
can afford to be confident in their capabilities!
deserve to be confident in their capabilities!
everyone knows that I am confident in their capabilities!
I feel that I am confident in their capabilities!
I see that I am confident in their capabilities!
I understand that I am confident in their capabilities!
I know that I am confident in their capabilities!
I am sure that I am confident in their capabilities!
say that I am confident in their capabilities!
I tell myself that I am confident in their capabilities!
I really appreciate the fact that I am confident in their capabilities!
radiate confidence
can afford to exude confidence in yourself!
sure I ooze confidence!
I really appreciate the fact that I exude confidence!
with each passing day becoming more and more confident!
can afford every day to become more and more confident!
worthy every day to become more and more confident!
everyone knows that I am every day becoming more and more confident!
feel like I every day become more and more confident!
see I'm getting more and more confident!
understand that I am every day becoming more and more confident!
know what I every day become more and more confident!
sure I every day become more and more confident!
claim I every day become more and more confident!
I tell myself I am every day becoming more and more confident!
really appreciate what I have every day become more and more confident!
Is this normal?<
Barmaley
Hi.
1. No one purposes that's fine.
2. Completely.
Share with the people.
Hi.
2. Completely.
I have a request for help regarding the installation of the program, the rainbow arc on a computer interface Latin script - in Spanish. I have a program installed, but all the text it shows the encrypted - encoded words - icons, question marks... what to do on the computer that the program was highlighted with normal text? Thanks in advance.
Luke
The first
go to start - control panel - languages regional options - go through all the tabs and see that everywhere was Russian. And most importantly, in the last 4th "Advanced" tab, look at the Language programs do not support unicod: the following should stand Russian.
Also, if nothing helps, you can do the following: reset the field Format to English (United Sates) and back to Russian (Russia), or slightly poshamanit: Change all formats first in English, then restart and install all the formats in Russian and again to restart.
Advanced text services must be enabled.
The file encoding should be a standard Windows - Cyrillic, as all the texts coming along with the program. If the text appears correctly in Notepad, it should appear correctly in the Rainbow.
The system must be the MS Sans Serif font with support of Cyrillic, this is the standard font, you can simply put from another computer, but before that you need to remove the old necessarily through the management control panel fonts.
Only for those who knows and understandswhat he does:
Run REGEDIT and edit at:
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Nls\CodePage]
"1250"="c_1251.nls”
"1252"="c_1251.nls”
P. S. the Program is written in Дельфи7, so Unicode is not supported.
The first
"1250"="c_1251.nls”
"1252"="c_1251.nls”
Rita
Hello.
Please write in detail how You "tried".
In the file "read first" I we are all so much in detail that any longer.
Maybe You've downloaded? Download again this file has been updated several times.
Hello.
